path: root/drivers/net/ethernet/sfc/mcdi_mon.c
2013-12-12sfc: Add new sensor namesBen Hutchings
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2013-12-12sfc: Revise sensor names to be more understandable and consistentEdward Cree
2013-12-12sfc: Report units in sensor warningsEdward Cree
Add units to the "Sensor reports condition X for raw value Y" messages. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2013-11-29sfc: Convert to use hwmon_device_register_with_groupsGuenter Roeck
Simplify the code. Avoid race conditions caused by attributes being created after hwmon device registration. Implicitly (through hwmon API) add mandatory 'name' sysfs attribute. Reviewed-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-29sfc: Update copyright bannersBen Hutchings
Update the dates for files that have been added to in 2012-2013. Drop the 'Solarstorm' brand name that's still lingering here. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2013-08-29sfc: Add support for new board sensorsBen Hutchings
Add support for power and current sensors, which need to be named differently in sysfs. Power sensors also require values to be scaled between MCDI and sysfs, and have no minimum value. Add definitions of the power, current, fan, and additional temperature and voltage sensors found on SFA6902F, SFN7022F and SFN7122F. (Includes a bug fix from Andrew Jackson.) Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2013-08-27sfc: Use extended MC_CMD_SENSOR_INFO and MC_CMD_READ_SENSORSBen Hutchings
We need to use extended requests to read and get metadata for sensors numbered > 31. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2013-08-27sfc: Return an error code when a sensor is busy.Alexandre Rames
[bwh: Also name this new state, though we don't expect to see it in an event] Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2013-08-21sfc: Add GFP flags to efx_nic_alloc_buffer() and make most callers allow ↵Ben Hutchings
blocking Most call sites for efx_nic_alloc_buffer() are part of the probe or reconfiguration paths and can allocate with GFP_KERNEL. A few others should use GFP_NOIO (I think). Only one is in atomic context and must use the current GFP_ATOMIC. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2013-08-21sfc: Add and use MCDI_SET_QWORD() and MCDI_SET_ARRAY_QWORD()Ben Hutchings
No need to keep open-coding the assignment of high and low dwords. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2013-08-21sfc: Introduce and use MCDI_DECLARE_BUF macroBen Hutchings
MCDI_DECLARE_BUF declares a variable as an MCDI buffer of the requested length, adding any necessary padding. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2013-08-21sfc: Use efx_mcdi_mon() to find efx_mcdi_mon structure from efx_nicBen Hutchings
This needs to be done before we separate MCDI from siena_nic_data. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2012-07-19sfc: initialize dynamic sysfs attributes for lockdepMichal Schmidt
Dynamically allocated sysfs attributes must be initialized using sysfs_attr_init(), otherwise lockdep complains: BUG: key <address> not in .data! Signed-off-by: Michal Schmidt <mschmidt@redhat.com> Acked-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-22sfc: Minor formatting cleanupBen Hutchings
Fix some indentation and line continuations. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2012-01-27sfc: Add hwmon driver for boards using SFC9000-family controllersBen Hutchings
The SFC9000-family controllers have firmware to manage all board peripherals including temperature, heat sink continuity and voltage sensors. The firmware reports sensor alarms, which we log, and will shut down the board if necessary. Some users may want to monitor their boards more closely, so add an hwmon driver that exposes all sensors reported by the firmware. Move efx_mcdi_sensor_event() into the new file so it can share the array of sensor labels with the hwmon driver. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
