path: root/drivers/net/ethernet/rdc
2012-01-04r6040: place comments before codeFlorian Fainelli
checkpatch.pl complained about the line exceding 80 columns, and the comment was actually on the same line as the code, fix that. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-04r6040: use __aligned(size)Florian Fainelli
instead of __attribute__((__aligned(size)__)) Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-04r6040: use definitions for MAC_SM register read/writesFlorian Fainelli
Bit 1 is the reset bit of the MAC status machine register, define and use it. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-04r6040: use MAC_RST bit definition with MCR1 read/writesFlorian Fainelli
MAC_RST bit is already defined, use it instead of 0x1 where applicable. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-04r6040: define more MCR0 register bitsFlorian Fainelli
Define more MCR0-register bits and use them in place of the bits values. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-04r6040: remove unused variables and definitionsFlorian Fainelli
Since the conversion to phylib (3831861b: r6040: implement phylib) some PHY-related variables and definitions are now useless, remove them. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-04r6040: use an unique MDIO bus nameFlorian Fainelli
We should use an unique MDIO bus name which does not clash with anything else in the system like the Fixed MDIO bus. The bus is now named: r6040-<card number> which is unique in the system. Reported-by: Vladimir Kolpakov <vova.kolpakov@gmail.com> Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-16r6040: fix check against MCRO_HASHEN bit in r6040_multicast_listFlorian Fainelli
We are checking whether the MCR0_HASHEN bit is set using a logical and instead of bitwise and, fix that. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-09r6040: bump version to 0.28 and date to 07Oct2011.Florian Fainelli
2011-10-09r6040: invoke phy_{start,stop} when appropriateFlorian Fainelli
Joe reported to me that right after a bring up of a r6040 interface the ethtool output had no consistent output with respect to link duplex and speed. Fix this by adding a missing phy_start call in r6040_up and conversely a phy_stop call in r6040_down to properly initialize phy states. Reported-by: Joe Chou <Joe.Chou@rdc.com.tw> Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-15MII: fix Kconfig dependencies for MIIJeff Kirsher
MII Kconfig option is apart of the core networking drivers and by default NET_CORE is enabled so drivers selecting MII will have MII enabled as well. It was found using the randconfig option during testing, MII would be selected but NET_CORE could be disabled. This caused a dependency error. Resolved the dependency by selecting NET_CORE when MII is selected. Reported-by: Emil Tantilov <emil.s.tantilov@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-27drivers/net/ethernet/*: Enabled vendor Kconfig optionsJeff Kirsher
Based on finds for Stephen Rothwell, where current defconfig's enable a ethernet driver and it is not compiled due to the newly added NET_VENDOR_* component of Kconfig. This patch enables all the "new" Kconfig options so that current defconfig's will continue to compile the expected drivers. In addition, by enabling all the new Kconfig options does not add any un-expected options. CC: Stephen Rothwll <sfc@canb.auug.org.au> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-17net: remove use of ndo_set_multicast_list in driversJiri Pirko
replace it by ndo_set_rx_mode Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-12r6040: Move the RDC driverJeff Kirsher
Move the RDC driver into drivers/net/ethernet/rdc/ and make the necessary Kconfig and Makefile changes. CC: Florian Fainelli <florian@openwrt.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
