path: root/drivers/net/ethernet/neterion/s2io.c
2018-09-21net: neterion: remove redundant continuezhong jiang
The continue will not truely skip any code. hence it is safe to remove it. Signed-off-by: zhong jiang <zhongjiang@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2018-09-18net: neterion: s2io: Use linux/io-64-nonatomic-lo-hi.hCorentin Labbe
This patch replace the custom definition of writeq/read and use ones defined in linux/io-64-nonatomic-lo-hi.h. Signed-off-by: Corentin Labbe <clabbe@baylibre.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2018-09-12net: ethernet: Use DIV_ROUND_UP instead of reimplementing its functionzhong jiang
DIV_ROUND_UP has implemented the code-opened function. Therefore, just replace the implementation with DIV_ROUND_UP. Signed-off-by: zhong jiang <zhongjiang@huawei.com> Acked-by: Tariq Toukan <tariqt@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-10-18net: neterion: Convert timers to use timer_setup()Kees Cook
In preparation for unconditionally passing the struct timer_list pointer to all timer callbacks, switch to using the new timer_setup() and from_timer() to pass the timer pointer explicitly. Cc: Jon Mason <jdmason@kudzu.us> Cc: netdev@vger.kernel.org Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-07-17s2io: Remove UFO support.David S. Miller
2017-06-15net: s2io: remove useless variable in fill_rx_buffersGustavo A. R. Silva
Remove useless variable rxd_index and code related. Addresses-Coverity-ID: 1397691 Signed-off-by: Gustavo A. R. Silva <garsilva@embeddedor.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-02-26net: s2io: fix typo argumnet argumentLABBE Corentin
This commit fix the typo argumnet/argument Signed-off-by: Corentin Labbe <clabbe.montjoie@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-02-12net: neterion: s2io: use new api ethtool_{get|set}_link_ksettingsPhilippe Reynes
The ethtool api {get|set}_settings is deprecated. We move this driver to new api {get|set}_link_ksettings. As I don't have the hardware, I'd be very pleased if someone may test this patch. Signed-off-by: Philippe Reynes <tremyfr@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-01-30drivers: net: generalize napi_complete_done()Eric Dumazet
napi_complete_done() allows to opt-in for gro_flush_timeout, added back in linux-3.19, commit 3b47d30396ba ("net: gro: add a per device gro flush timer") This allows for more efficient GRO aggregation without sacrifying latencies. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-10-18ethernet/neterion: use core min/max MTU checkingJarod Wilson
s2io: min_mtu 46, max_mtu 9600 vxge: min_mtu 68, max_mtu 9600 CC: netdev@vger.kernel.org CC: Jon Mason <jdmason@kudzu.us> Signed-off-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-08-01net: s2io: simplify logical constraintxypron.glpk@gmx.de
(!A || (A && B)) is equivalent to (!A || B) Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-04-26drivers: net: remove NETDEV_TX_LOCKEDFlorian Westphal
replace the trylock by a full spin_lock and remove TX_LOCKED return value. Followup patch will remove TX_LOCKED from the kernel. Cc: Jon Mason <jdmason@kudzu.us> Cc: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-10-16drivers/net: get rid of unnecessary initializations in .get_drvinfo()Ivan Vecera
Many drivers initialize uselessly n_priv_flags, n_stats, testinfo_len, eedump_len & regdump_len fields in their .get_drvinfo() ethtool op. It's not necessary as these fields is filled in ethtool_get_drvinfo(). v2: removed unused variable v3: removed another unused variable Signed-off-by: Ivan Vecera <ivecera@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-09neterion: s2io: Use module_pci_driverVaishali Thakkar
Use module_pci_driver for drivers whose init and exit functions only register and unregister, respectively. A simplified version of the Coccinelle semantic patch that performs this transformation is as follows: @a@ identifier f, x; @@ -static f(...) { return pci_register_driver(&x); } @b depends on a@ identifier e, a.x; statement S; @@ -static e(...) { -pci_unregister_driver(&x); -DBG_PRINT(INIT_DBG,"S"); - } @c depends on a && b@ identifier a.f; declarer name module_init; @@ -module_init(f); @d depends on a && b && c@ identifier b.e, a.x; declarer name module_exit; declarer name module_pci_driver; @@ -module_exit(e); +module_pci_driver(x); Signed-off-by: Vaishali Thakkar <vthakkar1994@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-25neterion: s2io: Fix kernel doc formattingJoe Perches
These two uses seem to have had carriage returns removed. Make these entries like all the others in this file. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-08s2io: Update driver to use dma_wmbAlexander Duyck
This change updates several spots where a wmb was being used to instead use a dma_wmb to flush out writes before updating the control portion of the descriptor. Signed-off-by: Alexander Duyck <alexander.h.duyck@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-08ethernet: codespell comment spelling fixesJoe Perches
To test a checkpatch spelling patch, I ran codespell against drivers/net/ethernet/. $ git ls-files drivers/net/ethernet/ | \ while read file ; do \ codespell -w $file; \ done I removed a false positive in e1000_hw.h Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: arch/arm/boot/dts/imx6sx-sdb.dts net/sched/cls_bpf.c Two simple sets of overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-19s2io: use snprintf() as a safety featureDan Carpenter
"sp->desc[i]" has 25 characters. "dev->name" has 15 characters. If we used all 15 characters then the sprintf() would overflow. I changed the "sprintf(sp->name, "%s Neterion %s"" to snprintf(), as well, even though it can't overflow just to be consistent. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-13net: rename vlan_tx_* helpers since "tx" is misleading thereJiri Pirko
The same macros are used for rx as well. So rename it. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-12PCI: Remove DEFINE_PCI_DEVICE_TABLE macro useBenoit Taine
We should prefer `struct pci_device_id` over `DEFINE_PCI_DEVICE_TABLE` to meet kernel coding style guidelines. This issue was reported by checkpatch. A simplified version of the semantic patch that makes this change is as follows (http://coccinelle.lip6.fr/): // <smpl> @@ identifier i; declarer name DEFINE_PCI_DEVICE_TABLE; initializer z; @@ - DEFINE_PCI_DEVICE_TABLE(i) + const struct pci_device_id i[] = z; // </smpl> [bhelgaas: add semantic patch] Signed-off-by: Benoit Taine <benoit.taine@lip6.fr> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-06-06net: use SPEED_UNKNOWN and DUPLEX_UNKNOWN when appropriateJiri Pirko
2014-05-13net: get rid of SET_ETHTOOL_OPSWilfried Klaebe
net: get rid of SET_ETHTOOL_OPS Dave Miller mentioned he'd like to see SET_ETHTOOL_OPS gone. This does that. Mostly done via coccinelle script: @@ struct ethtool_ops *ops; struct net_device *dev; @@ - SET_ETHTOOL_OPS(dev, ops); + dev->ethtool_ops = ops; Compile tested only, but I'd seriously wonder if this broke anything. Suggested-by: Dave Miller <davem@davemloft.net> Signed-off-by: Wilfried Klaebe <w-lkml@lebenslange-mailadresse.de> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-22neterion/s2io: remove unused s2io_start_tx_queue routineYing Xue
Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-24s2io: Call dev_kfree_skb_any instead of dev_kfree_skb.Eric W. Biederman
Replace dev_kfree_skb with dev_kfree_skb_any in s2io_xmit that can be called in hard irq and other contexts. All instances that are changed are packet drops. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2014-03-14s2io: Don't receive packets when the napi budget == 0Eric W. Biederman
Processing any incoming packets with a with a napi budget of 0 is incorrect driver behavior. This matters as netpoll will shortly call drivers with a budget of 0 to avoid receive packet processing happening in hard irq context. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-18s2io: Use pci_enable_msix_range() instead of pci_enable_msix()Alexander Gordeev
As result of deprecation of MSI-X/MSI enablement functions pci_enable_msix() and pci_enable_msi_block() all drivers using these two interfaces need to be updated to use the new pci_enable_msi_range() and pci_enable_msix_range() interfaces. Signed-off-by: Alexander Gordeev <agordeev@redhat.com> Cc: Jon Mason <jdmason@kudzu.us> Cc: netdev@vger.kernel.org Cc: linux-pci@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-21net: neterion: remove unnecessary pci_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure. Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Jon Mason <jdmason@kudzu.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-19net: vlan: add protocol argument to packet tagging functionsPatrick McHardy
Add a protocol argument to the VLAN packet tagging functions. In case of HW tagging, we need that protocol available in the ndo_start_xmit functions, so it is stored in a new field in the skb. The new field fits into a hole (on 64 bit) and doesn't increase the sks's size. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-19net: vlan: rename NETIF_F_HW_VLAN_* feature flags to NETIF_F_HW_VLAN_CTAG_*Patrick McHardy
Rename the hardware VLAN acceleration features to include "CTAG" to indicate that they only support CTAGs. Follow up patches will introduce 802.1ad server provider tagging (STAGs) and require the distinction for hardware not supporting acclerating both. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-18net: neterion: replace ip_fast_csum with csum_replace2Li RongQing
replace ip_fast_csum with csum_replace2 to save cpu cycles Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-08remove init of dev->perm_addr in driversJiri Pirko
perm_addr is initialized correctly in register_netdevice() so to init it in drivers is no longer needed. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-04net: neterion: use for_each_pci_dev to simplify the codeWei Yongjun
Use for_each_pci_dev to simplify the code. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-03vxge/s2io: remove __dev* attributesBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Jon Mason <jdmason@kudzu.us> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-03net: neterion: Do not break word unregister.YOSHIFUJI Hideaki / 吉藤英明
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-07netdev: make pci_error_handlers constStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-07-10drivers/net/ethernet: Fix (nearly-)kernel-doc comments for various functionsBen Hutchings
Fix incorrect start markers, wrapped summary lines, missing section breaks, incorrect separators, and some name mismatches. Delete a few that are content-free. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-06ethernet: Remove casts to same typeJoe Perches
Adding casts of objects to the same type is unnecessary and confusing for a human reader. For example, this cast: int y; int *p = (int *)&y; I used the coccinelle script below to find and remove these unnecessary casts. I manually removed the conversions this script produces of casts with __force, __iomem and __user. @@ type T; T *p; @@ - (T *)p + p A function in atl1e_main.c was passed a const pointer when it actually modified elements of the structure. Change the argument to a non-const pointer. A function in stmmac needed a __force to avoid a sparse warning. Added it. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2012-04-07s2io: stop using net_device.{base_addr, irq}.Francois Romieu
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Cc: Jon Mason <jdmason@kudzu.us>
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-02-23ethernet: unify return value of .ndo_set_mac_address if address is invalidDanny Kukawka
Unify return value of .ndo_set_mac_address if the given address isn't valid. Return -EADDRNOTAVAIL as eth_mac_addr() already does if is_valid_ether_addr() fails. Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-06netdev: ethernet dev_alloc_skb to netdev_alloc_skbPradeep A Dalvi
Replaced deprecating dev_alloc_skb with netdev_alloc_skb in drivers/net/ethernet - Removed extra skb->dev = dev after netdev_alloc_skb Signed-off-by: Pradeep A Dalvi <netdev@pradeepdalvi.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-31drivers/net: Remove alloc_etherdev error messagesJoe Perches
alloc_etherdev has a generic OOM/unable to alloc message. Remove the duplicative messages after alloc_etherdev calls. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-29corral some wayward N/A fw_version dust bunniesRick Jones
Round-up some wayward "N/A" fw_version dust bunnies as part of that clean-up. Signed-off-by: Rick Jones <rick.jones2@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-16net: introduce and use netdev_features_t for device features setsMichał Mirosław
v2: add couple missing conversions in drivers split unexporting netdev_fix_features() implemented %pNF convert sock::sk_route_(no?)caps Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-08sweep the floors and convert some .get_drvinfo routines to strlcpyRick Jones
Per the mention made by Ben Hutchings that strlcpy is now the preferred string copy routine for a .get_drvinfo routine, do a bit of floor sweeping and convert some of the as-yet unconverted ethernet drivers to it. Signed-off-by: Rick Jones <rick.jones2@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-19net: add skb frag size accessorsEric Dumazet
To ease skb->truesize sanitization, its better to be able to localize all references to skb frags size. Define accessors : skb_frag_size() to fetch frag size, and skb_frag_size_{set|add|sub}() to manipulate it. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-07net: Remove unnecessary driver assignments of ethtool_ringparam fields to zeroRick Jones
Per comments from Ben Hutchings on a previous patch, sweep the floors a little removing unnecessary assignments of zero to fields of struct ethtool_ringparam in driver code supporting ethtool -g. Signed-off-by: Rick Jones <rick.jones2@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-06net: use DMA_x_DEVICE and dma_mapping_error with skb_frag_dma_mapIan Campbell
When I converted some drivers from pci_map_page to skb_frag_dma_map I neglected to convert PCI_DMA_xDEVICE into DMA_x_DEVICE and pci_dma_mapping_error into dma_mapping_error. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
