path: root/drivers/net/ethernet/i825xx
2011-11-08sweep the floors and convert some .get_drvinfo routines to strlcpyRick Jones
Per the mention made by Ben Hutchings that strlcpy is now the preferred string copy routine for a .get_drvinfo routine, do a bit of floor sweeping and convert some of the as-yet unconverted ethernet drivers to it. Signed-off-by: Rick Jones <rick.jones2@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-01drivers/net/ethernet/i825xx/3c505.c: fix build with dynamic debugAndrew Morton
The `#define filename' screws up the expansion of DEFINE_DYNAMIC_DEBUG_METADATA: drivers/net/ethernet/i825xx/3c505.c: In function 'send_pcb': drivers/net/ethernet/i825xx/3c505.c:390: error: expected identifier before string constant drivers/net/ethernet/i825xx/3c505.c:390: error: expected '}' before '.' token drivers/net/ethernet/i825xx/3c505.c:436: error: expected identifier before string constant drivers/net/ethernet/i825xx/3c505.c:435: error: expected '}' before '.' token drivers/net/ethernet/i825xx/3c505.c: In function 'start_receive': drivers/net/ethernet/i825xx/3c505.c:557: error: expected identifier before string constant drivers/net/ethernet/i825xx/3c505.c:557: error: expected '}' before '.' token drivers/net/ethernet/i825xx/3c505.c: In function 'receive_packet': drivers/net/ethernet/i825xx/3c505.c:629: error: expected identifier before string constant etc So remove that #define and "open-code" it. Cc: Philip Blundell <philb@gnu.org> Cc: David Miller <davem@davemloft.net> Cc: Jason Baron <jbaron@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-28i825xx: Fix incorrect dependency for BVME6000_NETGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-27drivers/net/ethernet/*: Enabled vendor Kconfig optionsJeff Kirsher
Based on finds for Stephen Rothwell, where current defconfig's enable a ethernet driver and it is not compiled due to the newly added NET_VENDOR_* component of Kconfig. This patch enables all the "new" Kconfig options so that current defconfig's will continue to compile the expected drivers. In addition, by enabling all the new Kconfig options does not add any un-expected options. CC: Stephen Rothwll <sfc@canb.auug.org.au> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-17net: remove use of ndo_set_multicast_list in driversJiri Pirko
replace it by ndo_set_rx_mode Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-10i825xx: Move the Intel 82586/82593/82596 based driversJeff Kirsher
Move the drivers that use the i82586/i82593/i82596 chipsets into drivers/net/ethernet/i825xx/ and make the necessary Kconfig and Makefile changes. There were 4 3Com drivers which were initially moved into 3com/, which now reside in i825xx since they all used the i82586 chip. CC: Philip Blundell <philb@gnu.org> CC: Russell King <linux@arm.linux.org.uk> CC: <aris@cathedrallabs.org> CC: Donald Becker <becker@scyld.com> CC: Chris Beauregard <cpbeaure@undergrad.math.uwaterloo.ca> CC: Richard Procter <rnp@paradise.net.nz> CC: Andries Brouwer <aeb@cwi.nl> CC: "M.Hipp" <hippm@informatik.uni-tuebingen.de> CC: Richard Hirst <richard@sleepie.demon.co.uk> CC: Sam Creasey <sammy@oh.verio.com> CC: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
