path: root/drivers/net/ethernet/i825xx/lib82596.c
2011-08-17net: remove use of ndo_set_multicast_list in driversJiri Pirko
replace it by ndo_set_rx_mode Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-10i825xx: Move the Intel 82586/82593/82596 based driversJeff Kirsher
Move the drivers that use the i82586/i82593/i82596 chipsets into drivers/net/ethernet/i825xx/ and make the necessary Kconfig and Makefile changes. There were 4 3Com drivers which were initially moved into 3com/, which now reside in i825xx since they all used the i82586 chip. CC: Philip Blundell <philb@gnu.org> CC: Russell King <linux@arm.linux.org.uk> CC: <aris@cathedrallabs.org> CC: Donald Becker <becker@scyld.com> CC: Chris Beauregard <cpbeaure@undergrad.math.uwaterloo.ca> CC: Richard Procter <rnp@paradise.net.nz> CC: Andries Brouwer <aeb@cwi.nl> CC: "M.Hipp" <hippm@informatik.uni-tuebingen.de> CC: Richard Hirst <richard@sleepie.demon.co.uk> CC: Sam Creasey <sammy@oh.verio.com> CC: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
