path: root/drivers/net/ethernet/dlink/dl2k.c
2016-05-04treewide: replace dev->trans_start update with helperFlorian Westphal
Replace all trans_start updates with netif_trans_update helper. change was done via spatch: struct net_device *d; @@ - d->trans_start = jiffies + netif_trans_update(d) Compile tested only. Cc: user-mode-linux-devel@lists.sourceforge.net Cc: linux-xtensa@linux-xtensa.org Cc: linux1394-devel@lists.sourceforge.net Cc: linux-rdma@vger.kernel.org Cc: netdev@vger.kernel.org Cc: MPT-FusionLinux.pdl@broadcom.com Cc: linux-scsi@vger.kernel.org Cc: linux-can@vger.kernel.org Cc: linux-parisc@vger.kernel.org Cc: linux-omap@vger.kernel.org Cc: linux-hams@vger.kernel.org Cc: linux-usb@vger.kernel.org Cc: linux-wireless@vger.kernel.org Cc: linux-s390@vger.kernel.org Cc: devel@driverdev.osuosl.org Cc: b.a.t.m.a.n@lists.open-mesh.org Cc: linux-bluetooth@vger.kernel.org Signed-off-by: Florian Westphal <fw@strlen.de> Acked-by: Felipe Balbi <felipe.balbi@linux.intel.com> Acked-by: Mugunthan V N <mugunthanvnm@ti.com> Acked-by: Antonio Quartulli <a@unstable.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-20dl2k: Implement suspendOndrej Zary
Add suspend/resume support to dl2k driver. This requires RX/TX rings to be reset so split out the required functionality from alloc_list() into new rio_reset_ring(). Tested on Asus NX1101 (IP1000A) and D-Link DGE-550T (DL-2000). Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-20dl2k: Reorder and cleanup initializationOndrej Zary
Move HW init and stop into separate functions. Request IRQ only after the HW has been reset (so interrupts are disabled and no stale interrupts are pending). Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-20dl2k: Handle memory allocation errors in alloc_listOndrej Zary
If memory allocation fails in alloc_list(), free the already allocated memory and return -ENOMEM. In rio_open(), call alloc_list() first and abort if it fails. Move HW access (set RFDListPtr) out ot alloc_list(). Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-16dl2k: Add support for IP1000A-based cardsOndrej Zary
Add support for IP1000A chips to dl2k driver. IP1000A chip looks like a TC9020 with integrated PHY. This allows IP1000A chips to work reliably because the ipg driver is buggy - it loses packets under load and then completely stops transmitting data. Tested with Asus NX1101 v2.0 at 10, 100 and 1000Mbps: vendor=0x13f0 device=0x1023 (rev 0x41) subsystem vendor=0x1043 device=0x8180 MAC address registers access needed to be changed from 8-bit to 16-bit because 8-bit does not work on IP1000A. 8-bit access is not even allowed in the TC9020 datasheet (although it worked). 16-bit access works on both. Tested that it does not break D-Link DGE-550T (DL-2000 chip, probably a rebranded TC9020): vendor=0x1186 device=0x4000 (rev 0x0c) subsystem vendor=0x1186 device=0x4000 Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-31net: dl2k: Use setup_timerVaishali Thakkar
Use the timer API function setup_timer instead of structure field assignments to initialize a timer. A simplified version of the Coccinelle semantic patch that performs this transformation is as follows: @change@ expression e1, e2, e3, e4, a, b; @@ -init_timer(&e1); +setup_timer(&e1, a, b); ... when != a = e2 when != b = e3 -e1.data = b; ... when != a = e4 -e1.function = a; Signed-off-by: Vaishali Thakkar <vthakkar1994@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-06net: use SPEED_UNKNOWN and DUPLEX_UNKNOWN when appropriateJiri Pirko
Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-13net: get rid of SET_ETHTOOL_OPSWilfried Klaebe
net: get rid of SET_ETHTOOL_OPS Dave Miller mentioned he'd like to see SET_ETHTOOL_OPS gone. This does that. Mostly done via coccinelle script: @@ struct ethtool_ops *ops; struct net_device *dev; @@ - SET_ETHTOOL_OPS(dev, ops); + dev->ethtool_ops = ops; Compile tested only, but I'd seriously wonder if this broke anything. Suggested-by: Dave Miller <davem@davemloft.net> Signed-off-by: Wilfried Klaebe <w-lkml@lebenslange-mailadresse.de> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-21net: dl2k: remove unnecessary pci_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure. Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-09drivers:net: Remove unnecessary OOM messages after netdev_alloc_skbJoe Perches
Emitting netdev_alloc_skb and netdev_alloc_skb_ip_align OOM messages is unnecessary as there is already a dump_stack after allocation failures. Other trivial changes around these removals: Convert a few comparisons of pointer to 0 to !pointer. Change flow to remove unnecessary label. Remove now unused variable. Hoist assignment from if. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-06ethtool: fix drvinfo strings set in driversJiri Pirko
Use strlcpy where possible to ensure the string is \0 terminated. Use always sizeof(string) instead of 32, ETHTOOL_BUSINFO_LEN and custom defines. Use snprintf instead of sprint. Remove unnecessary inits of ->fw_version Remove unnecessary inits of drvinfo struct. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-03dlink: remove __dev* attributesBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-31dlink: dl2k: use the module_pci_driver macroDevendra Naga
use the module_pci_driver macro to make the code simpler by eliminating module_init and module_exit calls. Signed-off-by: Devendra Naga <devendra.aaru@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/intel/e1000e/param.c drivers/net/wireless/iwlwifi/iwl-agn-rx.c drivers/net/wireless/iwlwifi/iwl-trans-pcie-rx.c drivers/net/wireless/iwlwifi/iwl-trans.h Resolved the iwlwifi conflict with mainline using 3-way diff posted by John Linville and Stephen Rothwell. In 'net' we added a bug fix to make iwlwifi report a more accurate skb->truesize but this conflicted with RX path changes that happened meanwhile in net-next. In e1000e a conflict arose in the validation code for settings of adapter->itr. 'net-next' had more sophisticated logic so that logic was used. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-26dl2k: Clean up rio_ioctlJeff Mahoney
The dl2k driver's rio_ioctl call has a few issues: - No permissions checking - Implements SIOCGMIIREG and SIOCGMIIREG using the SIOCDEVPRIVATE numbers - Has a few ioctls that may have been used for debugging at one point but have no place in the kernel proper. This patch removes all but the MII ioctls, renumbers them to use the standard ones, and adds the proper permission check for SIOCSMIIREG. We can also get rid of the dl2k-specific struct mii_data in favor of the generic struct mii_ioctl_data. Since we have the phyid on hand, we can add the SIOCGMIIPHY ioctl too. Most of the MII code for the driver could probably be converted to use the generic MII library but I don't have a device to test the results. Reported-by: Stephan Mueller <stephan.mueller@atsec.com> Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-07dl2k: stop using net_device.{base_addr, irq} and convert to __iomem.Francois Romieu
The eeprom registers always use the same PCI bar whereas the general registers may either use the same mapping as the eeprom registers or a different one. It is thus possible to simplify parse_eeprom(). Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2011-08-25dl2k: use standard #defines from mii.h.Francois Romieu
2011-08-17net: remove use of ndo_set_multicast_list in driversJiri Pirko
replace it by ndo_set_rx_mode Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-11de6*/dl2k/sundance: Move the D-Link driversJeff Kirsher
Move the D-Link drivers into drivers/net/ethernet/dlink/ and make the necessary Kconfig and Makefile changes. CC: Bjorn Ekwall <bj0rn@blox.se> CC: Donald Becker <becker@scyld.com> CC: Edward Peng <edward_peng@dlink.com.tw> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
