git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux into mips-for-linux-next
include/linux/ssb/ssb_driver_gige.h
Also resolves a logical merge conflict in drivers/net/ethernet/broadcom/-
bgmac.c due to change of an API.
Without this patch b44 always allocates the 2 bytes needed for aligned
access on every platform, now it uses netdev_alloc_skb_ip_align().
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
The nvram functions are exported and used by some normal drivers. To
prevent name clashes with ofter parts of the kernel code add a bcm47xx_
prefix in front of the function names and the header file name.
Patchwork: http://patchwork.linux-mips.org/patch/4744/
Signed-off-by: John Crispin <blogic@openwrt.org>
alloc failures already get standardized OOM
messages and a dump_stack.
Convert kzalloc's with multiplies to kcalloc.
Convert kmalloc's with multiplies to kmalloc_array.
Fix a few whitespace defects.
Convert a constant 6 to ETH_ALEN.
Use parentheses around sizeof.
Convert vmalloc/memset to vzalloc.
Remove now unused size variables.
perm_addr is initialized correctly in register_netdevice() so to init it in
drivers is no longer needed.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
The __dev* removal patches for the network drivers ended up messing up
the function prototypes for a bunch of drivers. This patch fixes all of
them back up to be properly aligned.
Bonus is that this almost removes 100 lines of code, always a nice
surprise.
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Gary Zambrano <zambrano@broadcom.com>
Add support for 64 bit stats to Broadcom b44 ethernet driver.
Signed-off-by: Kevin Groeneveld <kgroeneveld@gmail.com>
commit a1c7fff7e1 (net: netdev_alloc_skb() use build_skb()) broke b44 on
some 64bit machines.
It appears b44 and b43 use __netdev_alloc_skb() instead of alloc_skb()
for their bounce buffers.
There is no need to add an extra NET_SKB_PAD reservation for bounce
buffers :
- In TX path, NET_SKB_PAD is useless
- In RX path in b44, we force a copy of incoming frames if
GFP_DMA allocations were needed.
Reported-and-bisected-by: Stefan Bader <stefan.bader@canonical.com>
drivers/net/ethernet/sfc/rx.c
Overlapping changes in drivers/net/ethernet/sfc/rx.c, one to change
the rx_buf->is_page boolean into a set of u16 flags, and another to
adjust how ->ip_summed is initialized.
WARNING: drivers/net/ethernet/broadcom/built-in.o(.init.text+0x5d): Section mismatch in reference from the function b44_init() to the function .exit.text:b44_pci_exit()
module exits with b44_cleanup()
Signed-off-by: Nikola Pajkovsky <n.pajkovsky@gmail.com>
alloc_etherdev has a generic OOM/unable to alloc message.
Remove the duplicative messages after alloc_etherdev calls.
Reported issues when using dev_kfree_skb() on UP systems and
systems with low numbers of cores. dev_kfree_skb_irq() will
properly save IRQ state before freeing the skb.
Tested on 3.1.1 and 3.2_rc2
Example of reproducible trace of kernel 3.1.1
WARNING: at kernel/softirq.c:159 local_bh_enable+0x32/0x79()
Pid: 0, comm: swapper Not tainted 3.1.1-gentoo #1
Call Trace:
[<c1022970>] warn_slowpath_common+0x65/0x7a
[<c102699e>] ? local_bh_enable+0x32/0x79
[<c1022994>] warn_slowpath_null+0xf/0x13
[<c102699e>] local_bh_enable+0x32/0x79
[<c134bfd8>] destroy_conntrack+0x7c/0x9b
[<c134890b>] nf_conntrack_destroy+0x1f/0x26
[<c132e3a6>] skb_release_head_state+0x74/0x83
[<c132e286>] __kfree_skb+0xb/0x6b
[<c132e30a>] consume_skb+0x24/0x26
[<c127c925>] b44_poll+0xaa/0x449
[<c1333ca1>] net_rx_action+0x3f/0xea
[<c1026a44>] __do_softirq+0x5f/0xd5
[<c10269e5>] ? local_bh_enable+0x79/0x79
<IRQ> [<c1026c32>] ? irq_exit+0x34/0x8d
[<c1003628>] ? do_IRQ+0x74/0x87
[<c13f5329>] ? common_interrupt+0x29/0x30
[<c1006e18>] ? default_idle+0x29/0x3e
[<c10015a7>] ? cpu_idle+0x2f/0x5d
[<c13e91c5>] ? rest_init+0x79/0x7b
[<c15c66a9>] ? start_kernel+0x297/0x29c
[<c15c60b0>] ? i386_start_kernel+0xb0/0xb7
---[ end trace 583f33bb1aa207a9 ]---
Signed-off-by: Xander Hover <LKML@hover.be>
replace it by ndo_set_rx_mode
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Moves the drivers for Broadcom devices into
drivers/net/ethernet/broadcom/ and the necessary Kconfig and Makefile
changes.
CC: Eilon Greenstein <eilong@broadcom.com>
CC: Michael Chan <mchan@broadcom.com>
CC: Matt Carlson <mcarlson@broadcom.com>
CC: Gary Zambrano <zambrano@broadcom.com>
CC: "Maciej W. Rozycki" <macro@linux-mips.org>
