path: root/drivers/net/e1000
2007-02-07Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: (41 commits) Revert "PCI: remove duplicate device id from ata_piix" msi: Make MSI useable more architectures msi: Kill the msi_desc array. msi: Remove attach_msi_entry. msi: Fix msi_remove_pci_irq_vectors. msi: Remove msi_lock. msi: Kill msi_lookup_irq MSI: Combine pci_(save|restore)_msi/msix_state MSI: Remove pci_scan_msi_device() MSI: Replace pci_msi_quirk with calls to pci_no_msi() PCI: remove duplicate device id from ipr PCI: remove duplicate device id from ata_piix PCI: power management: remove noise on non-manageable hw PCI: cleanup MSI code PCI: make isa_bridge Alpha-only PCI: remove quirk_sis_96x_compatible() PCI: Speed up the Intel SMBus unhiding quirk PCI Quirk: 1k I/O space IOBL_ADR fix on P64H2 shpchp: delete trailing whitespace shpchp: remove DBG_XXX_ROUTINE ...
2007-02-07PCI: Use newly defined PCI channel offline routineLinas Vepstas
Use newly minted routine to access the PCI channel state. Signed-off-by: Linas Vepstas <linas@linas.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-05remove NETIF_F_TSO ifdeferyArjan van de Ven
Remove the NETIF_F_TSO #ifdef-ery in drivers/net; this was for old-old-2.4 compat (even current 2.4 has NETIF_F_TSO) but it's time to get rid of it by now. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-05e1000: update version to 7.3.20-k2Auke Kok
Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
2007-02-05e1000: tune our dynamic itr transmit packet accountingJesse Brandeburg
The driver was still mis-calculating the number of bytes sent during transmit, now the driver computes what appears to be exactly 100% correct byte counts (not including CRC) when figuring out how many bytes and frames were sent during the current transmit packet.
2007-02-05e1000: clear ip csum info from context descriptorBruce Allan
Since the driver sets the IP checksum insertion bit (IXSM in Status field) in transmit context descriptors, it should clear the IP checksum bits of any garbage so as not to confuse the hardware. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
2007-02-05e1000: display flow control of link status at link upAuke Kok
Print RX/TX flow control setting at link up time to display the actual link FC properties instead of the advertised values. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
2007-02-05e1000: fix NAPI performance on 4-port adaptersJesse Brandeburg
This fix attempts to solve a customer (IBM) reported issue with NAPI enabled e1000 having bad performance when transmitting simultaneously on four ports. The issue comes down to an interaction between NAPI, hardware interrupt balancing, and the driver rescheduling poll on the same processor. Try to fix by allowing the driver to re-enable interrupts sooner instead of polling one more time, when there was recently all the work completed in cleanup. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
2007-02-05e1000: Fix MSI only interrupt handler routineJesse Brandeburg
Unfortunately the read-free MSI interrupt handler needs to flush write the icr register and thus we can't be read-free. Our MSI irq routine thus becomes a lot more simpler since we don't need to track link state anymore. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
2007-02-05e1000: clean up debug output definesAuke Kok
Remove unused MSGOUT macro and add "\n" to function debug output. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
2007-02-05e1000: simplify case handling gigabit at half duplexJesse Brandeburg
Remvoe duplicate code handling erraneous user supplied wrong case of gigabit speed with half duplex. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
2007-01-07Revert "[PATCH] e1000: disable TSO on the 82544 with slab debugging"Jeff Garzik
This reverts commit 72f3ab7462f4e153d1e8ac78e379716ad71d6923, which was superceded by commit 683a2aa339f607c8a422835161ceab68b2a5a18a ("e1000: Do not truncate TSO TCP header with 82544 workaround"), which fixed the real problem. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-26e1000: Do not truncate TSO TCP header with 82544 workaroundHerbert Xu
The e1000 driver has a workaround for 82544 on PCI-X where if the terminating byte of a buffer is at addresses 0-3 mod 8, then 4 bytes are shaved off it and defered to a new segment. This is due to an erratum that could otherwise cause TX hangs. Unfortunately this breaks TSO because it may cause the TCP header to be split over two segments which itself causes TX hangs. The solution is to pull 4 bytes of data up from the next segment rather than pushing 4 bytes off. This ensures the TCP header remains in one piece and works around the PCI-X hang. This patch is based on one from Jesse Brandeburg. This bug has been trigered by both CONFIG_DEBUG_SLAB as well as Xen. Note that the only reason we don't see this normally is because the TCP stack starts writing from the end, i.e., it writes the TCP header first then slaps on the IP header, etc. So the end of the TCP header (skb->tail - 1 here) is always aligned correctly. Had we made the start of the IP header (e.g., IPv6) 8-byte aligned instead, this would happen for normal TCP traffic as well. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Jesse Brandeburg <jesse.brandeburg@intel.com> -- Visit Openswan at http://www.openswan.org/ Email: Herbert Xu ~{PmV>HI~} <herbert@gondor.apana.org.au> Home Page: http://gondor.apana.org.au/~herbert/ PGP Key: http://gondor.apana.org.au/~herbert/pubkey.txt -- Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-26[PATCH] e1000: No-delay link detection at interface upJesse Brandeburg
Currently after an interface up, the link state is detected 2 seconds later when the first watchdog timer runs. This patch changes that by triggering the hardware to generate a link-change interrupt from the up() function instead. This has the result that the link state gets detected immediately and without races. This has the potential to speed up booting since a normal distribution boot process waits for a link before DHCP is attempted. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-26e1000: 3 new driver stats for managability testingJeff Garzik
Add 3 extra packet redirect counters for tracking purposes to make sure we can test that all packets arrive properly. Originally from Jesse Brandeburg <jesse.brandeburg@intel.com>, rewritten to use feature flags by me. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-26[PATCH] e1000: Make the copybreak value a module parameterJesse Brandeburg
Allow the user to vary the size that copybreak works. Currently cb is enabled for packets < 256 bytes, but various tests indicate that this should be configurable for specific use cases. In addition, this parameter allows us to force never/always during testing to get full and predictable coverage of both code paths. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-26[PATCH] e1000: Fix PBA allocation calculationsBruce Allan
Assign the PBA to be large enough to contain at least 2 jumbo frames on all adapters. This dramatically increases performance on several adapters and fixes TX performance degradation issues where the PBA was misallocated in the old algorithm. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-26[PATCH] e1000: narrow down the scope of the tipg timer tweakJesse Brandeburg
the driver has (ancient) code for messing with TIPG from the 82542 days. Unfortunately this code was running on our current adapters and setting TIPG for fiber to be +1 over the copper value. This caused 1.45Mpps to be sent instead of 1.487Mpps. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-26[PATCH] e1000: fix ethtool reported bus type for older adaptersJeff Kirsher
For older adapters we know that they are of the PCI bus type, so we can just set this. Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-26[PATCH] e1000: fix to set the new max frame size before resetting the adapterBruce Allan
This bugfix makes sure that the driver data reflects the full new situation before the adapter is reinitialized. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-26e1000: workaround for the ESB2 NIC RX unit issueJeff Garzik
In rare occasions, ESB2 systems would end up started without the RX unit being turned on. Add a check that runs post-init to work around this issue. Originally from Jesse Brandeburg <jesse.brandeburg@intel.com>, rewritten to use feature flags by me. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-26[PATCH] e1000: disable TSO on the 82544 with slab debuggingJesse Brandeburg
CONFIG_DEBUG_SLAB changes alignments of the data structures the slab allocators return. These break certain workarounds for TSO on the 82544. Since DEBUG_SLAB is relatively rare and not used for performance sensitive cases, the simplest fix is to disable TSO in this special situation. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-26[PATCH] e1000: Fix Wake-on-Lan with forced gigabit speedJesse Brandeburg
If the user has forced gigabit speed, phy power management must be disabled; otherwise the NIC would try to negotiate to a linkspeed of 10/100 mbit on shutdown, which would lead to a total loss of link. This loss of link breaks Wake-on-Lan and IPMI. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-26e1000: consolidate managability enabling/disablingJeff Garzik
Several bugs existed in how we handle manageability issues all over the driver. This patch consolidates all the managability release and init code in two single functions and call them from appropriate locations. This fixes several BMC packet redirect issues and powerup/down hiccups. Originally from Jesse Brandeburg <jesse.brandeburg@intel.com>, rewritten to use feature flags by me. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-26e1000: omit stats for broken counter in 82543Jeff Garzik
The 82543 chip does not count tx_carrier_errors properly in FD mode; report zeros instead of garbage. Originally from Jesse Brandeburg <jesse.brandeburg@intel.com>, rewritten to use feature flags by me. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-26e1000: For sanity, reformat e1000_set_mac_type(), struct e1000_hw[_stats]Jeff Garzik
Makes future changes a bit more readable. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-26[PATCH] e1000: dynamic itr: take TSO and jumbo into accountJesse Brandeburg
The dynamic interrupt rate control patches omitted proper counting for jumbo's and TSO resulting in suboptimal interrupt mitigation strategies. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-26[PATCH] e1000: The user-supplied itr setting needs the lower 2 bits masked offJesse Brandeburg
The lower 2 bits of a user-supplied itr setting (via ethtool) need to be masked off: These lower two bits are used as control bits. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-05Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/infiniband/core/iwcm.c drivers/net/chelsio/cxgb2.c drivers/net/wireless/bcm43xx/bcm43xx_main.c drivers/net/wireless/prism54/islpci_eth.c drivers/usb/core/hub.h drivers/usb/input/hid-core.c net/core/netpoll.c Fix up merge failures with Linus's head and fix new compilation failures. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-12-02[NET]: Split skb->csumAl Viro
... into anonymous union of __wsum and __u32 (csum and csum_offset resp.) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02e1000 linkage fixAndrew Morton
ia64: drivers/built-in.o(.text+0xd9a72): In function `e1000_xmit_frame': : undefined reference to `csum_ipv6_magic' Cc: Auke Kok <auke-jan.h.kok@intel.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-02e1000: increment version to 7.3.15-k2Auke Kok
2006-12-02e1000: add dynamic itr modesJesse Brandeburg
Add a new dynamic itr algorithm, with 2 modes, and make it the default operation mode. This greatly reduces latency and increases small packet performance, at the "cost" of some CPU utilization. Bulk traffic throughput is unaffected. The driver can limit the amount of interrupts per second that the adapter will generate for incoming packets. It does this by writing a value to the adapter that is based on the maximum amount of interrupts that the adapter will generate per second. Setting InterruptThrottleRate to a value greater or equal to 100 will program the adapter to send out a maximum of that many interrupts per second, even if more packets have come in. This reduces interrupt load on the system and can lower CPU utilization under heavy load, but will increase latency as packets are not processed as quickly. The default behaviour of the driver previously assumed a static InterruptThrottleRate value of 8000, providing a good fallback value for all traffic types,but lacking in small packet performance and latency. The hardware can handle many more small packets per second however, and for this reason an adaptive interrupt moderation algorithm was implemented. Since 7.3.x, the driver has two adaptive modes (setting 1 or 3) in which it dynamically adjusts the InterruptThrottleRate value based on the traffic that it receives. After determining the type of incoming traffic in the last timeframe, it will adjust the InterruptThrottleRate to an appropriate value for that traffic. The algorithm classifies the incoming traffic every interval into classes. Once the class is determined, the InterruptThrottleRate value is adjusted to suit that traffic type the best. There are three classes defined: "Bulk traffic", for large amounts of packets of normal size; "Low latency", for small amounts of traffic and/or a significant percentage of small packets; and "Lowest latency", for almost completely small packets or minimal traffic. In dynamic conservative mode, the InterruptThrottleRate value is set to 4000 for traffic that falls in class "Bulk traffic". If traffic falls in the "Low latency" or "Lowest latency" class, the InterruptThrottleRate is increased stepwise to 20000. This default mode is suitable for most applications. For situations where low latency is vital such as cluster or grid computing, the algorithm can reduce latency even more when InterruptThrottleRate is set to mode 1. In this mode, which operates the same as mode 3, the InterruptThrottleRate will be increased stepwise to 70000 for traffic in class "Lowest latency". Setting InterruptThrottleRate to 0 turns off any interrupt moderation and may improve small packet latency, but is generally not suitable for bulk throughput traffic. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Cc: Rick Jones <rick.jones2@hp.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
2006-12-02e1000: add dynamic generic MSI interrupt routineJesse Brandeburg
Add a generic MSI interrupt routine that is IO read-free, speeding up MSI interrupt handling. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
2006-12-02e1000: reorder e1000_param.cAuke Kok
This file needs some cleanups and reordering - logically order it so that relevant defines and code are together with properly quoted defaults. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
2006-12-02e1000: Only set IDE for tx when we are using TIDV/TADVJesse Brandeburg
Spec fix: don't set IDE unless we are actually setting the tx int delay time. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
2006-12-02e1000: rename ICH8 flash macrosJeff Kirsher
ICH8 will soon be followed by newer chipsets bearing the same acronym, thus we remove the '8' and make it independent of the version number in the platform name. Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
2006-12-02e1000: add queue restart counterJesse Brandeburg
Add a netif_wake/start_queue counter to the ethtool statistics to indicated to the user that their transmit ring could be too small for their workload. Signed-off-by: Jesse brandeburg <jesse.brandeburg@intel.com> Cc: Jamal Hadi <hadi@cyberus.ca> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
2006-12-02e1000: New hardware supportAuke Kok
Add support for a Low Profile quad-port PCI-E adapter and 2 variants of the ICH8 systems' onboard NIC's. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
2006-12-02e1000: Remove unneeded and unwanted memsetsJesse Brandeburg
This memsetting was added in a paranoid rage debugging TX hangs, but are no longer of importance. We can beef up the performance quite a bit removing them. Make sure to fill in next_to_watch to allow this. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
2006-12-02e1000: simplify skb_put call.Auke Kok
Simplify two calls to skb_put by removing one call to it. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
2006-12-02e1000: reorder pci-e infor structJeff Kirsher
Order pci-e capability struct according to bus/pci bus width ordering preserving the hard pci spec numbers. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2006-12-02e1000: fix VR powerdown codeJeff Kirsher
On ich systems during PHY power down to D3, the voltage regulators were left on. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2006-12-02e1000: add mmiowb() for IA64 to sync tail writesJesse Brandeburg
IA64 SMP systems were seeing TX issues with multiple cpu's attempting to write tail registers unordered. This mmiowb() fixes the issue. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
2006-12-02e1000: Enble early receive (ERT) on 82573Auke Kok
Enable early receives on 82573 for jumbo frame performance. Jumbo's are only supported on 82573L with ASPM disabled. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
2006-12-02e1000: FIX: enable hw TSO for IPV6Auke Kok
Enable TSO for IPV6. All e1000 hardware supports it. This reduces CPU utilizations by 50% when transmitting IPv6 frames. Fix symbol naming enabling ipv6 TSO. Turn off TSO6 for 10/100. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
2006-12-02e1000: Remove DISABLE_MULR debug codeAuke Kok
Remove debugging code disabling MULR (multiple reads). It's not usable for a wide audience and there are no known problems with MULR right now. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
2006-12-02e1000: whitespace changes, comments, typosAuke Kok
Small whitespace changes, comment changes, typo fixes. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
2006-11-30Fix misc .c/.h comment typosMatt LaPlante
Fix various .c/.h typos in comments (no code changes). Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-22WorkStruct: Pass the work_struct pointer instead of context dataDavid Howells
Pass the work_struct pointer to the work function rather than context data. The work function can use container_of() to work out the data. For the cases where the container of the work_struct may go away the moment the pending bit is cleared, it is made possible to defer the release of the structure by deferring the clearing of the pending bit. To make this work, an extra flag is introduced into the management side of the work_struct. This governs auto-release of the structure upon execution. Ordinarily, the work queue executor would release the work_struct for further scheduling or deallocation by clearing the pending bit prior to jumping to the work function. This means that, unless the driver makes some guarantee itself that the work_struct won't go away, the work function may not access anything else in the work_struct or its container lest they be deallocated.. This is a problem if the auxiliary data is taken away (as done by the last patch). However, if the pending bit is *not* cleared before jumping to the work function, then the work function *may* access the work_struct and its container with no problems. But then the work function must itself release the work_struct by calling work_release(). In most cases, automatic release is fine, so this is the default. Special initiators exist for the non-auto-release case (ending in _NAR). Signed-Off-By: David Howells <dhowells@redhat.com>
