after review of all intel drivers, found several instances where
drivers had the incorrect pattern of:
memory mapped write();
delay();
which should always be:
write flush(); /* aka memory mapped read */
delay();
explanation:
The reason for including the flush is that writes can be held
(posted) in PCI/PCIe bridges, but the read always has to complete
synchronously and therefore has to flush all pending writes to a
device. If a write is held and followed by a delay, the delay
means nothing because the write may not have reached hardware
(maybe even not until the next read)
Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
Tested-by: Aaron Brown <aaron.f.brown@intel.com>
Private rx_csum flags are now duplicate of netdev->features & NETIF_F_RXCSUM.
Removing this needs deeper surgery.
Things noticed:
- RX csum disabled by default
- HW VLAN acceleration probably can be toggled, but it's left as is
- the resets on RX csum offload change can probably be avoided
- there is A LOT of copy-and-pasted code here
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
Based on the original patch from Stephen Hemminger.
Convert to new LED control infrastucture and remove no longer
necessary bits.
CC: Stephen Hemminger <shemminger@vyatta.com>
Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com>
This makes sure that one cannot request a 99Mbps full-duplex and get a
100Mbps half-duplex configuration in return due to the way the
speed/duplex parameters are handled internally.
Tested: e1000 works
Signed-off-by: David Decotigny <decot@google.com>
This updates the network drivers so that they don't access the
ethtool_cmd::speed field directly, but use ethtool_cmd_speed()
instead.
For most of the drivers, these changes are purely cosmetic and don't
fix any problem, such as for those 1GbE/10GbE drivers that indirectly
call their own ethtool get_settings()/mii_ethtool_gset(). The changes
are meant to enforce code consistency and provide robustness with
future larger throughputs, at the expense of a few CPU cycles for each
ethtool operation.
All drivers compiled with make allyesconfig ion x86_64 have been
updated.
Tested: make allyesconfig on x86_64 + e1000e/bnx2x work
This makes sure the ethtool's set_settings() callback of network
drivers don't ignore the 16 most significant bits when ethtool calls
their set_settings().
All drivers compiled with make allyesconfig on x86_64 have been
updated.
This patch restores the ability to set msglvl through ethtool.
The issue was introduced by:
commit 675ad47375c76a7c3be4ace9554d92cd55518ced
Reported-by: Joe Perches <joe@perches.com>
Signed-off-by: Emil Tantilov <emil.s.tantilov@intel.com>
This patch removes from drivers/net/ all the unnecessary
return; statements that precede the last closing brace of
void functions.
It does not remove the returns that are immediately
preceded by a label as gcc doesn't like that.
It also does not remove null void functions with return.
Done via:
$ grep -rP --include=*.[ch] -l "return;\n}" net/ | \
xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }'
with some cleanups by hand.
Compile tested x86 allmodconfig only.
Back before e1000-7.3.20, the e1000 driver had a simple algorithm that
managed interrupt moderation. The driver was updated in 7.3.20 to
have the new "adaptive" interrupt moderation but we have customer
requests to redeploy the old way as an option. This patch adds the
old functionality back. The new functionality can be enabled via
module parameter or at runtime via ethtool.
Module parameter: (InterruptThrottleRate=4) to use this new
moderation method.
Ethtool method: ethtool -C ethX rx-usecs 4
This patch is an alternative to similar patch provided by Joe Perches.
Substitute DPRINTK macro for e_<level> that uses netdev_<level> and dev_<level>
similar to e1000e.
- Convert printk to pr_<level> where applicable.
- Use common #define pr_fmt for the driver.
- Use dev_<level> for displaying text in parts of the driver where the interface
name is not assigned (like e1000_param.c).
- Better align test with the new macros.
CC: Joe Perches <joe@perches.com>
Signed-off-by: Nicholas Nunley <nicholasx.d.nunley@intel.com>
With this change ethtool will correctly report link status when
the interface is down. Currently ethtool reports the link as not
detected when the interface is down.
Not as fancy as coccinelle. Checkpatch errors ignored.
Compile tested allyesconfig x86, not all files compiled.
grep -rPl --include=*.[ch] "\brequest_irq\s*\([^,\)]+,\s*\&" drivers/net | while read file ; do \
perl -i -e 'local $/; while (<>) { s@(\brequest_irq\s*\([^,\)]+,\s*)\&@\1@g ; print ; }' $file ;\
done
Commit 23d26497 overlooked the way offsets for netdev stats were considered.
Because of this some of the stats shown by ethtool -S were wrong.
This patch fixes it.
Signed-off-by: Ajit Khaparde <ajitk@serverengines.com>
Since net_device has an instance of net_device_stats,
we can remove the instance of this from the adapter structure.
e1000 was using one particular way to detect link, but with the advent
of some of the newer hardware designs using SERDES connections, tests
for link must completely cover all cases.
Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com>
this patch is the first in a series of clean up patches for e1000 to drop
unused code, and update the driver to kernel spec, and then, to update the
driver to have all available bug fixes.
Call it the e1000 weight loss plan.
This patch allows on-the-fly adjustment of the interrupts per second generated
by e1000 devices 82545/82546 (hardware support of ITR register is a
requirement)
adjust using this command:
ethtool -C eth0 rx-usecs 10
where 10 is 10 microseconds per interrupt interval, so 10 = 100,000 interrupts
per second, and 125 = 8000 interrupts per second.
changes should be immediate.
1,3 are special values and indicate the automatic tuning mode to the driver,
where 1 is 4000-90000 interrupts per second and 3 is 4000-20000 interrupts
per second and is the driver default.
Since dev->power.should_wakeup bit is used by the PCI core to
decide whether the device should wake up the system from sleep
states, set/unset this bit whenever WOL is enabled/disabled using
e1000_set_wol(). Accordingly, use device_can_wakeup() for checking
if wake-up is supported by the device.
Signed-off-by: "Rafael J. Wysocki" <rjw@sisk.pl>
Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
Use struct e1000_hw *hw = adapter->hw; where necessary
Change macros E1000_READ_REG and E1000_WRITE_REG to er32 and ew32
When enabling TSO via ethool on e1000, it is possible to set
NETIF_F_TSO6 on hardware that does not support it. Setting TSO via
ethtool now matches the settings used when the hardware is probed.
Signed-off-by: Andy Gospodarek <andy@greyhouse.net>
Conglomerate from 4 separate patches from Joe.
On Thu, 2008-03-06 at 10:07 -0800, Kok, Auke wrote:
> send me a patch for e1000 and for ixgb and I'll happily apply those :)
boolean_t to bool
TRUE to true
FALSE to false
comment typo ahread to ahead
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Minimal macro to function conversion in e1000_ethtool.c
Adds functions reg_pattern_test and reg_set_and_check
Changes REG_PATTERN_TEST and REG_SET_AND_CHECK macros
to call these functions.
Saves ~2.5KB
Compiled x86, untested (no hardware)
old:
$ size drivers/net/e1000/e1000_ethtool.o
16778 0 0 16778 418a drivers/net/e1000/e1000_ethtool.o
new:
14128 0 0 14128 3730 drivers/net/e1000/e1000_ethtool.o
Using ARRAY_SIZE() on arrays of the form array[][K] makes it unnecessary
to know the value of K when checking its size.
Signed-off-by: Alejandro Martinez Ruiz <alex@flawedcode.org>
drivers/net/e1000/e1000_ethtool.c:113:
#define E1000_TEST_LEN sizeof(e1000_gstrings_test) / ETH_GSTRING_LEN
drivers/net/e1000e/ethtool.c:106:
E1000_TEST_LEN*ETH_GSTRING_LEN will expand to
sizeof(e1000_gstrings_test) / (ETH_GSTRING_LEN * ETH_GSTRING_LEN)
A lack of parentheses around defines causes unexpected results due to
operator precedences.
Signed-off-by: Roel Kluin <12o3l@tiscali.nl>
Fix sparse warnings and problems from e1000 driver.
Added a sparse fix for the module param array index
-- Auke
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
These have been superceded by the new ->get_sset_count() hook.
For the operations
get-tx-csum
get-sg
get-tso
get-ufo
the default ethtool_op_xxx behavior is fine for all drivers, so we
permit op==NULL to imply the default behavior.
This provides a more uniform behavior across all drivers, eliminating
ethtool(8) "ioctl not supported" errors on older drivers that had
not been updated for the latest sub-ioctls.
The ethtool_op_xxx() functions are left exported, in case anyone
wishes to call them directly from a driver-private implementation --
a not-uncommon case. Should an ethtool_op_xxx() helper remain unused
for a while, except by net/core/ethtool.c, we can un-export it at a
later date.
[ Resolved conflicts with set/get value ethtool patch... -DaveM ]
Signed-off-by: Denis Cheng <crquan@gmail.com>
This blade-specific board form factor is identical to the 82571EB
board.
This patch adds support for 2 new board variants:
- A Quad port fiber 82571 board
- A blade version of the 82571 quad copper board
All drivers implement ethtool get_perm_addr the same way -- by calling
the generic function. So we can inline the generic function into the
caller and avoid going through the drivers.
Signed-off-by: Matthew Wilcox <matthew@wil.cx>
E1000_ROUNDUP macro cleanup, use ALIGN
Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com>
Replace kmalloc+memsetout the driver. Slightly modified by Auke Kok.
Signed-off-by: Yan Burman <burman.yan@gmail.com>
A patch to use ARRAY_SIZE macro already defined in kernel.h.
Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com>
By reading the MAC status register we can detect whether the MAC has
seen the PHY see link. This allows us to show the link properties before
the device is up in ethtool.
Remove the NETIF_F_TSO #ifdef-ery in drivers/net; this was
for old-old-2.4 compat (even current 2.4 has NETIF_F_TSO)
but it's time to get rid of it by now.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Add 3 extra packet redirect counters for tracking purposes to make sure
we can test that all packets arrive properly.
Originally from Jesse Brandeburg <jesse.brandeburg@intel.com>,
rewritten to use feature flags by me.
Add a netif_wake/start_queue counter to the ethtool statistics to indicated
to the user that their transmit ring could be too small for their workload.
Signed-off-by: Jesse brandeburg <jesse.brandeburg@intel.com>
Cc: Jamal Hadi <hadi@cyberus.ca>
Add support for a Low Profile quad-port PCI-E adapter and 2 variants
of the ICH8 systems' onboard NIC's.
Enable TSO for IPV6. All e1000 hardware supports it. This reduces CPU
utilizations by 50% when transmitting IPv6 frames.
Fix symbol naming enabling ipv6 TSO. Turn off TSO6 for 10/100.
Small whitespace changes, comment changes, typo fixes.
