This patch is an alternative to similar patch provided by Joe Perches.
Substitute DPRINTK macro for e_<level> that uses netdev_<level> and dev_<level>
similar to e1000e.
- Convert printk to pr_<level> where applicable.
- Use common #define pr_fmt for the driver.
- Use dev_<level> for displaying text in parts of the driver where the interface
name is not assigned (like e1000_param.c).
- Better align test with the new macros.
CC: Joe Perches <joe@perches.com>
Signed-off-by: Emil Tantilov <emil.s.tantilov@intel.com>
Previously the driver tweaked txqueuelen to avoid false Tx hang reports
seen at half duplex. This had the effect of overriding user set values
on link change/reset. Testing shows that adjusting only the timeout
factor is sufficient to prevent Tx hang reports at half duplex.
This patch removes all instances of tx_queue_len in the driver.
Based on e1000e patch by Franco Fichtner <franco@lastsummer.de>
CC: Franco Fichtner <franco@lastsummer.de>
Acked-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
With this change ethtool will correctly report link status when
the interface is down. Currently ethtool reports the link as not
detected when the interface is down.
Signed-off-by: Nicholas Nunley <nicholasx.d.nunley@intel.com>
Originally From: Neil Horman <nhorman@tuxdriver.com>
Modified by: Jesse Brandeburg <jesse.brandeburg@intel.com>
Hey all-
A security discussion was recently given:
http://events.ccc.de/congress/2009/Fahrplan//events/3596.en.html
And a patch that I submitted awhile back was brought up. Apparently some of
their testing revealed that they were able to force a buffer fragment in e1000
in which the trailing fragment was greater than 4 bytes. As a result the
fragment check I introduced failed to detect the fragement and a partial
invalid frame was passed up into the network stack. I've written this patch
to correct it. I'm in the process of testing it now, but it makes good
logical sense to me. Effectively it maintains a per-adapter state variable
which detects a non-EOP frame, and discards it and subsequent non-EOP frames
leading up to _and_ _including_ the next positive-EOP frame (as it is by
definition the last fragment). This should prevent any and all partial frames
from entering the network stack from e1000.
Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
Remove the use of skb_dma_map from the e1000 driver in order to avoid
issues when HW iommu are in use.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
Since net_device has an instance of net_device_stats,
we can remove the instance of this from the adapter structure.
Signed-off-by: Ajit Khaparde <ajitk@serverengines.com>
this patch is the first in a series of clean up patches for e1000 to drop
unused code, and update the driver to kernel spec, and then, to update the
driver to have all available bug fixes.
Call it the e1000 weight loss plan.
Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com>
This is code extremely similar to what is committed in e1000e
already.
e1000 will no longer request 32kB slab buffers to support jumbo
frames on PCI/PCI-X adapters. This will significantly reduce the
likelyhood of order:3 allocation failures.
This new code adds support for using pages as receive buffers,
and the driver will chain multiple pages together to build a
jumbo frame for OS consumption.
The hardware takes a power of two buffer size and will
dump as much data as it can receive into 1 or more buffers.
The benefits of applying this are
1) stop akpm's dissing :-) of this lame e1000 behavior [1]
2) more efficient memory allocation (half) when using jumbo
frames, which will also allow for much better socket utilization
with jumbos since the socket is charged for the full allocation
of each receive buffer, regardless of how much is used.
3) this was a feature request by a customer
4) copybreak for small packets < 256 bytes still applies
[1] http://lkml.org/lkml/2008/7/10/68
http://article.gmane.org/gmane.linux.network/130986
CC: Andrew Morton <akpm@linux-foundation.org>
This patch allows on-the-fly adjustment of the interrupts per second generated
by e1000 devices 82545/82546 (hardware support of ITR register is a
requirement)
adjust using this command:
ethtool -C eth0 rx-usecs 10
where 10 is 10 microseconds per interrupt interval, so 10 = 100,000 interrupts
per second, and 125 = 8000 interrupts per second.
changes should be immediate.
1,3 are special values and indicate the automatic tuning mode to the driver,
where 1 is 4000-90000 interrupts per second and 3 is 4000-20000 interrupts
per second and is the driver default.
LLTX is deprecated, don't use it. This completes the removal of LLTX from
the Intel Network drivers.
Commit bea3348eef27e6044b6161fd04c3152215f96411
"[NET]: Make NAPI polling independent of struct net_device objects."
made NAPI polling to be independent of net_device.
So e1000_adapter->polling_netdev is no longer used.
Kill it.
Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com>
Since the e1000/e1000e split, no hardware supported by e1000
supports packet split, just remove the Kconfig option and associated
code from the driver.
This patch makes e1000 driver ioport-free.
This corrects behavior in probe function so as not to request ioport
resources as long as they are not really needed. This is based on the
ioport-free patch of e1000 driver from Auke Kok and Tomohiro Kusumi.
Signed-off-by: Tomohiro Kusumi <kusumi.tomohiro@jp.fujitsu.com>
Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
Signed-off-by: Taku Izumi <izumi.taku@jp.fujitsu.com>
Signed-off-by: Jeff Kirsher<jeffrey.t.kirsher@intel.com>
Compile-tested only.
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
Redefine DPRINTK macro using do while(0)
__FUNCTION__ to __func__
structs {} on separate lines
Surround negative constants with ()
Conglomerate from 4 separate patches from Joe.
irq_sem was just a hack to prevent interrupts from being enabled
unexpectedly in deep call paths. Simply finding those call paths and
fixing them by hand results in a driver that behaves as we expect and
doesn't need the atomic at all.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
On Thu, 2008-03-06 at 10:07 -0800, Kok, Auke wrote:
> send me a patch for e1000 and for ixgb and I'll happily apply those :)
boolean_t to bool
TRUE to true
FALSE to false
comment typo ahread to ahead
Fix sparse warnings and problems from e1000 driver.
Added a sparse fix for the module param array index
-- Auke
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
Several devices have multiple independant RX queues per net
device, and some have a single interrupt doorbell for several
queues.
In either case, it's easier to support layouts like that if the
structure representing the poll is independant from the net
device itself.
The signature of the ->poll() call back goes from:
int foo_poll(struct net_device *dev, int *budget)
to
int foo_poll(struct napi_struct *napi, int budget)
The caller is returned the number of RX packets processed (or
the number of "NAPI credits" consumed if you want to get
abstract). The callee no longer messes around bumping
dev->quota, *budget, etc. because that is all handled in the
caller upon return.
The napi_struct is to be embedded in the device driver private data
structures.
Furthermore, it is the driver's responsibility to disable all NAPI
instances in it's ->stop() device close handler. Since the
napi_struct is privatized into the driver's private data structures,
only the driver knows how to get at all of the napi_struct instances
it may have per-device.
With lots of help and suggestions from Rusty Russell, Roland Dreier,
Michael Chan, Jeff Garzik, and Jamal Hadi Salim.
Bug fixes from Thomas Graf, Roland Dreier, Peter Zijlstra,
Joseph Fannin, Scott Wood, Hans J. Koch, and Michael Chan.
[ Ported to current tree and all drivers converted. Integrated
Stephen's follow-on kerneldoc additions, and restored poll_list
handling to the old style to fix mutual exclusion issues. -DaveM ]
pci_enable_msi failure is a normal event so we should not print any error.
Going over the code I spotted a missing pci_disable_msi() leak when irq
allocation fails. The whole code also needed a cleanup, so I combined the
two different calls to pci_request_irq into a single call making this
look a lot better. All #ifdef CONFIG_PCI_MSI's have been removed.
Compile tested with both CONFIG_PCI_MSI enabled and disabled.
E1000_ROUNDUP macro cleanup, use ALIGN
Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com>
Now that 2.6.19 provides a proper implementation that saves MSI, PCI-E
config space, we can have the e1000 driver use those instead of it's
custom implementation.
Remove the NETIF_F_TSO #ifdef-ery in drivers/net; this was
for old-old-2.4 compat (even current 2.4 has NETIF_F_TSO)
but it's time to get rid of it by now.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Unfortunately the read-free MSI interrupt handler needs to flush write
the icr register and thus we can't be read-free. Our MSI irq routine
thus becomes a lot more simpler since we don't need to track link state
anymore.
Add a new dynamic itr algorithm, with 2 modes, and make it the default
operation mode. This greatly reduces latency and increases small packet
performance, at the "cost" of some CPU utilization. Bulk traffic
throughput is unaffected.
The driver can limit the amount of interrupts per second that the
adapter will generate for incoming packets. It does this by writing a
value to the adapter that is based on the maximum amount of interrupts
that the adapter will generate per second.
Setting InterruptThrottleRate to a value greater or equal to 100 will
program the adapter to send out a maximum of that many interrupts per
second, even if more packets have come in. This reduces interrupt
load on the system and can lower CPU utilization under heavy load,
but will increase latency as packets are not processed as quickly.
The default behaviour of the driver previously assumed a static
InterruptThrottleRate value of 8000, providing a good fallback value
for all traffic types,but lacking in small packet performance and
latency. The hardware can handle many more small packets per second
however, and for this reason an adaptive interrupt moderation algorithm
was implemented.
Since 7.3.x, the driver has two adaptive modes (setting 1 or 3) in
which it dynamically adjusts the InterruptThrottleRate value based on
the traffic that it receives. After determining the type of incoming
traffic in the last timeframe, it will adjust the InterruptThrottleRate
to an appropriate value for that traffic.
The algorithm classifies the incoming traffic every interval into
classes. Once the class is determined, the InterruptThrottleRate
value is adjusted to suit that traffic type the best. There are
three classes defined: "Bulk traffic", for large amounts of packets
of normal size; "Low latency", for small amounts of traffic and/or
a significant percentage of small packets; and "Lowest latency",
for almost completely small packets or minimal traffic.
In dynamic conservative mode, the InterruptThrottleRate value is
set to 4000 for traffic that falls in class "Bulk traffic". If
traffic falls in the "Low latency" or "Lowest latency" class, the
InterruptThrottleRate is increased stepwise to 20000. This default
mode is suitable for most applications.
For situations where low latency is vital such as cluster or
grid computing, the algorithm can reduce latency even more when
InterruptThrottleRate is set to mode 1. In this mode, which operates
the same as mode 3, the InterruptThrottleRate will be increased
stepwise to 70000 for traffic in class "Lowest latency".
Setting InterruptThrottleRate to 0 turns off any interrupt moderation
and may improve small packet latency, but is generally not suitable
for bulk throughput traffic.
Cc: Rick Jones <rick.jones2@hp.com>
Add a netif_wake/start_queue counter to the ethtool statistics to indicated
to the user that their transmit ring could be too small for their workload.
Signed-off-by: Jesse brandeburg <jesse.brandeburg@intel.com>
Cc: Jamal Hadi <hadi@cyberus.ca>
Enable TSO for IPV6. All e1000 hardware supports it. This reduces CPU
utilizations by 50% when transmitting IPv6 frames.
Fix symbol naming enabling ipv6 TSO. Turn off TSO6 for 10/100.
We were plagued by our interrupt handler posting a watchdog event which
could occur when our adapter was going down in case a late packet arrived
just before e1000_down() finished. This caused the watchdog timer to start
after the NIC was down and keep rescheduling it every N seconds. Once
the driver unloaded it would panic.
Signed-off-by: Nicholas Nunley <nicholas.d.nunley@intel.com>
This update to the copyright header adds the mailinglist, and aligns it
with the kernel licensing as well as remove the offending 'all rights
reserved'.
WoL is constantly giving problems and needed a rewrite. Consolidates
all WoL capabilities into a single function, and disables WoL for all
other ports on the device except for port A.
Remove the code that reads part_num from the EEPROM. This part number
is never displayed or queryable by the user.
A panic was reported when receiving 1522 size packets if using
the default MTU. we should set the initial rx buffer length to the
value that e1000changemtu sets so that we can receive any packet
that would not be dropped by LPE=0.
Signed-off-by: Auke Kok <auke.jan.h.kok@intel.com>
into upstream
drivers/net/e1000/e1000_main.c
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
This hooks up the ich8 structure into the driver itself.
Smart Power Down is a power saving feature in newer e1000 hardware. We
disable it because it causes time to link to be long, but make it a
user choice.
After studying the driver mac reset code it was found that there
were multiple race conditions possible to reset the unit twice or
bring it e1000_up() double. This fixes all occurences where the
driver needs to reset the mac.
We also remove irq requesting/releasing into _open and _close so
that while the device is _up we will never touch the irq's. This fixes
the double free irq bug that people saw.
To make sure that the watchdog task doesn't cause another race we let
it run as a non-scheduled task.
Add the sourceforge project mailinglist to the contact information.
Bump version to 7.0.38-k2
Update copyright string with the new year.
Signed-off-by: John Ronciak <john.ronciak@intel.com>
Remove multi-descriptor support from legacy recieve path
Add memory usage efficiency by using more correct size descriptors for
small MTU sizes and optimize using LPE for <= 1522 byte frame sizes
An extra performance fix that effected our TCP window size growth
as a receiver. Set our initial buffer to be 128 bytes instead of 256
to prevent over-socket charge when truesize is computed in the stack.
old way: truesize = 256 + l1 = 256 + 1460 = 1716
new way: truesize = 128 + l1 = 128 + 1460 = 1588
The magic value that we can't cross is 1648.
Made an adapter struct variable into a local (txb2b)
This patch moves prototypes of global variables and functions to a header
file.
Acked-by: John Ronciak <john.ronciak@gmail.com>
code to ensure they would not wrap beyond 80 characters.
- Add restriction for ESB2 to MTU size <=9216
- Removed FIFO errors which were not being used
- Fixed issues with loopback
- Power management change for saving state and config space
- WA to disable recieves and reset device on link loss. Reset needed to be done outside the interrupt context - modified existing tx_timeout_task
forced at 100Mb/s
