path: root/drivers/net/dgrs.c
2006-03-25[PATCH] EISA: tidy-up driver_register() return valueBjorn Helgaas
Remove the assumption that driver_register() returns the number of devices bound to the driver. In fact, it returns zero for success or a negative error value. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-by: Jeff Garzik <jgarzik@pobox.com> Acked-by: Marc Zyngier <maz@misterjones.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-03Massive net driver const-ification.Arjan van de Ven
2005-11-22[PATCH] net: Fix compiler-error on dgrs.c when !CONFIG_PCIRichard Knutsson
drivers/net/dgrs.c: In function `dgrs_init_module': drivers/net/dgrs.c:1598: `dgrs_pci_driver' undeclared (first use in this function) Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] dgrs: fix warnings when CONFIG_ISA and CONFIG_PCI are not enabledAshutosh Naik
This patch fixes compiler warnings when CONFIG_ISA and CONFIG_PCI are not enabled in the dgrc network driver. Signed-off-by: Ashutosh Naik <ashutosh.naik@gmail.com> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
