This converts pretty much everything to print_mac. There were
a few things that had conflicts which I have just dropped for
now, no harm done.
I've built an allyesconfig with this and looked at the files
that weren't built very carefully, but it's a huge patch.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
This is nicer than the MAC_FMT stuff.
We now have struct net_device_stats embedded in struct net_device,
and the default ->get_stats() hook does the obvious thing for us.
Run through drivers/net/* and remove the driver-local storage of
statistics, and driver-local ->get_stats() hook where applicable.
This was just the low-hanging fruit in drivers/net; plenty more drivers
remain to be updated.
[ Resolved conflicts with napi_struct changes and fix sunqe build
regression... -DaveM ]
Signed-off-by: Jeff Garzik <jeff@garzik.org>
One less thing for drivers writers to worry about.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
The following patch fixes a kernel bug in depca_platform_probe().
We don't use a dynamic pointer for pldev->dev.platform_data, so it seems
that the correct way to proceed if platform_device_add(pldev) fails is
to explicitly set the pldev->dev.platform_data pointer to NULL, before
calling the platform_device_put(pldev), or it will be kfree'ed by
platform_device_release().
This was spotted by coverity (cid #793). All callers dereference dev
before calling this functions, and we dereference it earlier in the
function, when initializing lp.
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
Cc: Jeff Garzik <jeff@garzik.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
First of all it is unnecessary to allocate a new skb in skb_pad since
the existing one is not shared. More importantly, our hard_start_xmit
interface does not allow a new skb to be allocated since that breaks
requeueing.
This patch uses pskb_expand_head to expand the existing skb and linearize
it if needed. Actually, someone should sift through every instance of
skb_pad on a non-linear skb as they do not fit the reasons why this was
originally created.
Incidentally, this fixes a minor bug when the skb is cloned (tcpdump,
TCP, etc.). As it is skb_pad will simply write over a cloned skb. Because
of the position of the write it is unlikely to cause problems but still
it's best if we don't do it.
hi,
this fixes coverity bug #888, where the variable
dev is used uninitialized. I assume the programmer
meant to use mdev, which is initialized.
Compile tested only.
This allows us to eliminate the casts in the drivers, and eventually
remove the use of the device_driver function pointer methods for
platform device drivers.
Release code in driver modules is a potential cause of oopsen.
The device may be in use by a userspace process, which will keep
a reference to the device. If the module is unloaded, the module
text will be freed. Subsequently, when the last reference is
dropped, the release code will be called, which no longer exists.
Use generic platform device allocation/release code in modules.
Convert everyone who uses platform_bus_type to include
linux/platform_device.h.
infrastructure for it.
Let it rip!
