path: root/drivers/net/cs89x0.c
2009-11-18drivers/net: request_irq - Remove unnecessary leading & from second argJoe Perches
Not as fancy as coccinelle. Checkpatch errors ignored. Compile tested allyesconfig x86, not all files compiled. grep -rPl --include=*.[ch] "\brequest_irq\s*\([^,\)]+,\s*\&" drivers/net | while read file ; do \ perl -i -e 'local $/; while (<>) { s@(\brequest_irq\s*\([^,\)]+,\s*)\&@\1@g ; print ; }' $file ;\ done Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01netdev: convert bulk of drivers to netdev_tx_tStephen Hemminger
In a couple of cases collapse some extra code like: int retval = NETDEV_TX_OK; ... return retval; into return NETDEV_TX_OK; Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-12net: cs89x0: includecheck fix for cs89x0.cJaswinder Singh Rajput
fix the following 'make includecheck' warning: drivers/net/cs89x0.c: asm/irq.h is included more than once. Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-16Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/orinoco/main.c
2009-07-14drivers/net: using spin_lock_irqsave() in net_send_packet()Dongdong Deng
spin_unlock_irq() will enable interrupt in net_send_packet(), this patch changes it to spin_lock_irqsave/spin_lock_irqrestore, so that it doesn't enable interrupts when already disabled, and netconsole would work properly over cs89x0/isa-skeleton. Call trace: netconsole write_msg() { ... -> spin_lock_irqsave(); -> netpoll_send_udp() -> netpoll_send_skb() -> net_send_packet() ->... -> spin_unlock_irqrestore(); ... } Signed-off-by: Dongdong Deng <dongdong.deng@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-06drivers/net/cs89x0.c: Avoid using magic number in set_dma_modeJulia Lawall
The constant DMA_RX_MODE is defined to be 0x14 in the local include file cs89x0.h. Since a constant with the same name is used elsewhere with set_dma_mode, it seems likely that this constant could be used here. The semantic match that finds this problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ expression E1; identifier I; constant int C; @@ ( set_dma_mode(E1,I,...) | *set_dma_mode(E1,C,...) ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-13net: use symbolic values for ndo_start_xmit() return codesPatrick McHardy
Convert magic values 1 and -1 to NETDEV_TX_BUSY and NETDEV_TX_LOCKED respectively. 0 (NETDEV_TX_OK) is not changed to keep the noise down, except in very few cases where its in direct proximity to one of the other values. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-27netdev: convert cs89x0 to net_device_opsStephen Hemminger
2008-12-30Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (407 commits) [ARM] pxafb: add support for overlay1 and overlay2 as framebuffer devices [ARM] pxafb: cleanup of the timing checking code [ARM] pxafb: cleanup of the color format manipulation code [ARM] pxafb: add palette format support for LCCR4_PAL_FOR_3 [ARM] pxafb: add support for FBIOPAN_DISPLAY by dma braching [ARM] pxafb: allow pxafb_set_par() to start from arbitrary yoffset [ARM] pxafb: allow video memory size to be configurable [ARM] pxa: add document on the MFP design and how to use it [ARM] sa1100_wdt: don't assume CLOCK_TICK_RATE to be a constant [ARM] rtc-sa1100: don't assume CLOCK_TICK_RATE to be a constant [ARM] pxa/tavorevb: update board support (smartpanel LCD + keypad) [ARM] pxa: Update eseries defconfig [ARM] 5352/1: add w90p910-plat config file [ARM] s3c: S3C options should depend on PLAT_S3C [ARM] mv78xx0: implement GPIO and GPIO interrupt support [ARM] Kirkwood: implement GPIO and GPIO interrupt support [ARM] Orion: share GPIO IRQ handling code [ARM] Orion: share GPIO handling code [ARM] s3c: define __io using the typesafe version [ARM] S3C64XX: Ensure CPU_V6 is selected ...
2008-12-25drivers/net: fix sparse warnings: make symbols staticHannes Eder
Fix this sparse warnings: drivers/net/3c523.c:350:6: warning: symbol 'alloc586' was not declared. Should it be static? drivers/net/cs89x0.c:1029:14: warning: symbol 'reset_chip' was not declared. Should it be static? drivers/net/eepro.c:1399:1: warning: symbol 'read_eeprom' was not declared. Should it be static? drivers/net/plip.c:1020:5: warning: symbol 'plip_hard_header_cache' was not declared. Should it be static? drivers/net/s2io.c:5116:6: warning: symbol 'do_s2io_store_unicast_mc' was not declared. Should it be static? drivers/net/smc9194.c:767:12: warning: symbol 'smc_findirq' was not declared. Should it be static? Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-27[ARM] clps7500: remove supportRussell King
The CLPS7500 platform has not built since 2.6.22-git7 and there seems to be no interest in fixing it. So, remove the platform support. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-16Remove Andrew Morton's old email accountsFrancois Cami
People can use the real name an an index into MAINTAINERS to find the current email address. Signed-off-by: Francois Cami <francois.cami@free.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-11Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (236 commits) [ARM] 5300/1: fixup spitz reset during boot [ARM] 5295/1: make ZONE_DMA optional [ARM] 5239/1: Palm Zire 72 power management support [ARM] 5298/1: Drop desc_handle_irq() [ARM] 5297/1: [KS8695] Fix two compile-time warnings [ARM] 5296/1: [KS8695] Replace macro's with trailing underscores. [ARM] pxa: allow multi-machine PCMCIA builds [ARM] pxa: add preliminary CPUFREQ support for PXA3xx [ARM] pxa: add missing ACCR bit definitions to pxa3xx-regs.h [ARM] pxa: rename cpu-pxa.c to cpufreq-pxa2xx.c [ARM] pxa/zylonite: add support for USB OHCI [ARM] ohci-pxa27x: use ioremap() and offset for register access [ARM] ohci-pxa27x: introduce pxa27x_clear_otgph() [ARM] ohci-pxa27x: use platform_get_{irq,resource} for the resource [ARM] ohci-pxa27x: move OHCI controller specific registers into the driver [ARM] ohci-pxa27x: introduce flags to avoid direct access to OHCI registers [ARM] pxa: move I2S register and bit definitions into pxa2xx-i2s.c [ARM] pxa: simplify DMA register definitions [ARM] pxa: make additional DCSR bits valid for PXA3xx [ARM] pxa: move i2c register and bit definitions into i2c-pxa.c ... Fixed up conflicts in arch/arm/mach-versatile/core.c sound/soc/pxa/pxa2xx-ac97.c sound/soc/pxa/pxa2xx-i2s.c manually.
2008-10-01[NET] 5268/1: cs89x0: add support for i.MX31ADS ARM board.Gilles Chanteperdrix
Add support for i.MX31ADS board to the cs89x0 ethernet driver. Rework Kconfig options for the cs89x0 driver to reduce the #ifdef clutter. Signed-off-by: Gilles Chanteperdrix <gilles.chanteperdrix@xenomai.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-24cs89x0: fix warning release_irq labelYoichi Yuasa
release_irq label is only used when ALLOW_DMA is defined. drivers/net/cs89x0.c: In function 'net_open': drivers/net/cs89x0.c:1401: warning: label 'release_irq' defined but not used Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-30[netdrvr] CS89X0: Add cleanup for dma after failWang Chen
After request_dma() succeeding, any error path should do free_dma(). Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-02-23drivers/net/cs89x0.c: compilation warning fixLeonardo Potenza
Suppress the warning message about the 'netcard_portlist' defined but not used. Signed-off-by: Leonardo Potenza <lpotenza@inwind.it> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10drivers/net/: all drivers/net/ cleanup with ARRAY_SIZEDenis Cheng
Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-04[PATCH] trivial missing __init in drivers/net/*Al Viro
2006-11-30[PATCH] Fix an offset error when reading the CS89x0 ADD_PORT registerGeorge G. Davis
Fix an offset error when reading the CS89x0 ADD_PORT register. Signed-off-by: George G. Davis Signed-off-by: Jeff Garzik <jeff@garzik.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-08-19[PATCH] cs89x0 section fixAndrew Morton
WARNING: drivers/net/cs89x0.o - Section mismatch: reference to .init.data:version from .text between 'init_module' (at offset 0x13d8) and 'net_get_stats' WARNING: drivers/net/cs89x0.o - Section mismatch: reference to .init.text: from .text between 'init_module' (at offset 0x1634) and 'net_get_stats' WARNING: drivers/net/cs89x0.o - Section mismatch: reference to .init.text: from .text between 'init_module' (at offset 0x1a1f) and 'net_get_stats' Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-01-16[PATCH] cs89x0: credit Dmitry PervushinLennert Buytenhek
Credit Dmitry Pervushin for the PNX010X platform support. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] cs89x0: add ixdp2351 supportDeepak Saxena
This patch adds support for the Intel IXDP2351 to the CS89x0 driver. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] cs89x0: use u16 for device register dataLennert Buytenhek
cs89x0 inconsistently used 'int' and 'u32' for device register data. As the cs89x0 is a 16-bit chip, change the I/O accessors over to 'u16'. (Spotted by Deepak Saxena.) Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] cs89x0: use #elif instead of #else/#if/#endifLennert Buytenhek
2006-01-14[PATCH] cs89x0: credit Dmitry PervushinLennert Buytenhek
2006-01-11[PATCH] cs89x0: fix setting of ALLOW_DMALennert Buytenhek
There's an ifdef in cs89x0.c that seems to have been the wrong way round since it was merged (and noone seems to have noticed) -- the IXDP2x01 doesn't support ISA-style DMA, but when building for IXDP2x01, cs89x0's ALLOW_DMA is set to 1, and when building for another platform, ALLOW_DMA is set to 0. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] cs89x0: fix up after pnx0105 Kconfig symbol renamingLennert Buytenhek
The Kconfig symbol for pnx0105 was recently renamed to ARCH_PNX010X. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Cc: dmitry pervushin <dpervushin@ru.mvista.com> Cc: <dsaxena@plexity.net> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] cs89x0: switch {in,out}sw to {read,write}wordsLennert Buytenhek
Implement readwords/writewords that use readword/writeword, and switch the rest of the driver over to use these. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Cc: dmitry pervushin <dpervushin@ru.mvista.com> Cc: <dsaxena@plexity.net> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] cs89x0: cleanly implement ixdp2x01 and pnx0501 supportLennert Buytenhek
Implement suitable versions of the readword/writeword macros for ixdp2x01 and pnx0501. Handle the 32-bit spacing of the registers in these functions instead of in the header file. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Cc: dmitry pervushin <dpervushin@ru.mvista.com> Cc: <dsaxena@plexity.net> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] cs89x0: make {read,write}reg use {read,write}wordLennert Buytenhek
Make readreg/writereg use readword/writeword. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Cc: dmitry pervushin <dpervushin@ru.mvista.com> Cc: <dsaxena@plexity.net> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] cs89x0: swap {read,write}reg and {read,write}wordLennert Buytenhek
Reverse the order of readreg/writereg and readword/writeword in the file, so that we can make readreg/writereg use readword/writeword. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Cc: dmitry pervushin <dpervushin@ru.mvista.com> Cc: <dsaxena@plexity.net> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] cs89x0: convert {inw,outw} calls to {read,write}wordLennert Buytenhek
Switch all occurences of inw/outw in the driver over to readword/writeword. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Cc: dmitry pervushin <dpervushin@ru.mvista.com> Cc: <dsaxena@plexity.net> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] cs89x0: make {read,write}word take base_addrLennert Buytenhek
readword() and writeword() take a 'struct net_device *' and deref its ->base_addr member. Make them take the base_addr directly instead, so that we can switch the other occurences of inw/outw in the file over to readword/writeword as well. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Cc: dmitry pervushin <dpervushin@ru.mvista.com> Cc: <dsaxena@plexity.net> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-04[PATCH] ARM: Reverted 2919/1: CS8900A ethernet driver modifications for the ↵Russell King
Comdial MP1000 No longer maintained
2005-10-28[ARM] 2919/1: CS8900A ethernet driver modifications for the Comdial MP1000Jon Ringle
Patch from Jon Ringle This patch gives support for the CS8900A ethernet chip on the Comdial MP1000 Signed-off-by: Jon Ringle Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-26[PATCH] missing asm/irq.h (cs89x0)Al Viro
2005-09-09[PATCH] cs89x0: add netpoll supportDeepak Saxena
Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Cc: Matt Mackall <mpm@selenic.com> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-01[PATCH] silence cs89x0Denis Vlasenko
cs89x0 talks a lot at boot. Seems like debug leftover. This patch downgrades printks to KERN_DEBUG. While we're at it, make these messages a bit less obscure. Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-28[PATCH] cs89x0: collect tx_bytes statisticsIan Campbell
Signed-off-by: Ian Campbell <icampbell@arcom.com> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
