path: root/drivers/net/cpmac.c
2008-08-14[netdrvr] remove unnecessary #includeHuang Weiyi
The drivers below do not use LINUX_VERSION_CODE nor KERNEL_VERSION. drivers/net/acenic.c drivers/net/bnx2x_link.c drivers/net/bnx2x_main.c drivers/net/cpmac.c drivers/net/gianfar_sysfs.c drivers/net/ipg.h drivers/net/ppp_mppe.c drivers/net/pppol2tp.c drivers/net/r6040.c drivers/net/sh_eth.c drivers/net/sky2.c drivers/net/tehuti.h drivers/net/typhoon.c This patch removes the said #include <linux/version.h>. Signed-off-by: Huang Weiyi <hwy@cn.fujitsu.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-22netdev: bunch of drivers: avoid WARN at net/core/dev.c:1328Anton Vorontsov
The drivers were touching net queue before it has been started, so without this patch, the drivers will potentially WARN at net/core/dev.c:1328. I don't have the hardware for the drivers below, so this patch is untested, and thus should be carefully peer reviewed. tc35815.c au1000_eth.c bfin_mac.c macb.c ^ The four drivers are using phylib, they're calling netif_start_queue() in open() callback. So trivially remove netif_tx_schedule_all(). Phylib will handle netif_carrier_*(). cpmac.c fec_mpc52xx.c fs_enet/fs_enet-main.c sh_eth.c ^ The same as above, but these were also needlessly calling netif_carrier_*() functions. So removed queue calls and also remove carrier calls, since phylib will handle it. fs_enet-main.c also didn't call netif_start_queue() at open(), this is fixed now. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17net: Use queue aware tests throughout.David S. Miller
This effectively "flips the switch" by making the core networking and multiqueue-aware drivers use the new TX multiqueue structures. Non-multiqueue drivers need no changes. The interfaces they use such as netif_stop_queue() degenerate into an operation on TX queue zero. So everything "just works" for them. Code that really wants to do "X" to all TX queues now invokes a routine that does so, such as netif_tx_wake_all_queues(), netif_tx_stop_all_queues(), etc. pktgen and netpoll required a little bit more surgery than the others. In particular the pktgen changes, whilst functional, could be largely improved. The initial check in pktgen_xmit() will sometimes check the wrong queue, which is mostly harmless. The thing to do is probably to invoke fill_packet() earlier. The bulk of the netpoll changes is to make the code operate solely on the TX queue indicated by by the SKB queue mapping. Setting of the SKB queue mapping is entirely confined inside of net/core/dev.c:dev_pick_tx(). If we end up needing any kind of special semantics (drops, for example) it will be implemented here. Finally, we now have a "real_num_tx_queues" which is where the driver indicates how many TX queues are actually active. With IGB changes from Jeff Kirsher. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17netdev: Kill NETIF_F_MULTI_QUEUE.David S. Miller
There is no need for a feature bit for something that can be tested by simply checking the TX queue count. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08net: Delete NETDEVICES_MULTIQUEUE kconfig option.David S. Miller
Multiple TX queue support is a core networking feature. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-22cpmac bugfixes and enhancementsMatteo Croce
* Resolve some locking issues using atomic_inc/atomic_dec * move status code in cpmac_check_status * unmark the BROKEN flag in Kconfig * move code which should have been in platform code in arch/mips/ar7/platform.c * fixed an IRQ storm which lets the kernel hang * fixed a double call to netif_start_queue which causes a kernel panic * don't fail to register the PHY, works on many devices now Signed-off-by: Matteo Croce <matteo@openwrt.org> Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25net drivers: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable network platform drivers, to re-enable auto loading. NOTE: didn't change drivers/net/fs_enet/fs_enet-main.c "old binding" support. That looks problematic in the first place (it even uses the ancient "struct device_driver" binding scheme for platform_bus!) and I suspect it will vanish soonish when arch/powerpc rules the world. Also, drivers/net/ne.c would have needed more thought to sort out. [akpm@linux-foundation.org: fix sgiseeq.c] [dbrownell@users.sourceforge.net: more drivers, registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Scott Wood <scottwood@freescale.com> Cc: Vitaly Bordug <vitb@kernel.crashing.org> Cc: Dale Farnsworth <dale@farnsworth.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Andrew Victor <andrew@sanpeople.com> Cc: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-16phy: Change mii_bus id field to a stringAndy Fleming
Having the id field be an int was making more complex bus topologies excessively difficult. For now, just convert it to a string, and change all instances of "bus->id = val" to snprintf(id, MII_BUS_ID_LEN, "%x", val). Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-02-05cpmac: convert to new Fixed PHY infrastructureAnton Vorontsov
This patch converts cpmac to the new Fixed PHY infrastructure, though it doesn't fix all the problems with that driver. I didn't even bother to test this patch to compile, because cpmac driver is broken in several ways: 1. This driver won't compile by itself because lack of its header describing platform data; 2. It assumes that fixed PHYs should be created by the ethernet driver. It is wrong assumption: fixed PHYs creation is platform code authority, driver must blindly accept bus_id and phy_id platform data variables instead. Also, it seem that that driver doesn't have actual in-tree users, so nothing to fix further. The main purpose of that patch is to get rid of the following Kconfig warning: scripts/kconfig/conf -s arch/powerpc/Kconfig drivers/net/Kconfig:1713:warning: 'select' used by config symbol 'CPMAC' refers to undefined symbol 'FIXED_MII_100_FDX' Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-28[netdrvr] irq handler minor cleanups in several driversJeff Garzik
* use irq_handler_t where appropriate * no need to use 'irq' function arg, its already stored in a data struct * rename irq handler 'irq' argument to 'dummy', where the function has been analyzed and proven not to use its first argument. * remove always-false "dev_id == NULL" test from irq handlers * remove pointless casts from void* * declance: irq argument is not const * add KERN_xxx printk prefix * fix minor whitespace weirdness Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-01-18Replace cpmac fixMatteo Croce
Please apply this patch since i reverted by mistake the commit 4e3ab47a547616e583c7a5458beced6aa34c8ef3 in 6cd043d99dcf5d252fcc682958541f449113f7b3 Signed-off-by: Matteo Croce <technoboy85@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-25cpmac: update to new fixed phy driver interfaceEugene Konev
Use fixed_mdio_get_phydev for obtaining fixed phy instances and adopt to changed fixed phy device naming. Signed-off-by: Eugene Konev <ejka@imfi.kspu.ru> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-25cpmac: convert to napi_struct interfaceEugene Konev
Convert cpmac to new napi_struct API introduced by bea3348eef27e6044b6161fd04c3152215f96411 [NET]: Make NAPI polling independent of struct net_device objects. Only disable rx interrupts if napi actually has been scheduled. Signed-off-by: Eugene Konev <ejka@imfi.kspu.ru> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-25cpmac: use print_mac() instead of MAC_FMTEugene Konev
Switch to using DECLARE_MAC_BUF/print_mac() added by commit 0795af5729b18218767fab27c44b1384f72dc9ad [NET]: Introduce and use print_mac() and DECLARE_MAC_BUF(). Signed-off-by: Eugene Konev <ejka@imfi.kspu.ru> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-23AR7 ethernet: small post-merge cleanups and fixesMatteo Croce
Signed-off-by: Matteo Croce <technoboy85@gmail.com> Signed-off-by: Eugene Konev <ejka@imfi.kspu.ru> Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-22[NET]: Make and use skb_get_queue_mappingPavel Emelyanov
Make the helper for getting the field, symmetrical to the "set" one. Return 0 if CONFIG_NETDEVICES_MULTIQUEUE=n Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15AR7 ethernetMatteo Croce
New version which uses less locking and drops old API Signed-off-by: Matteo Croce <technoboy85@gmail.com> Signed-off-by: Eugene Konev <ejka@imfi.kspu.ru> Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
