path: root/drivers/net/can/usb/ems_usb.c
2013-02-08drivers: net: Remove remaining alloc/OOM messagesJoe Perches
alloc failures already get standardized OOM messages and a dump_stack. For the affected mallocs around these OOM messages: Converted kmallocs with multiplies to kmalloc_array. Converted a kmalloc/memcpy to kmemdup. Removed now unused stack variables. Removed unnecessary parentheses. Neatened alignment. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Arend van Spriel <arend@broadcom.com> Acked-by: Marc Kleine-Budde <mkl@pengutronix.de> Acked-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-04can: Remove unnecessary alloc/OOM messagesJoe Perches
alloc failures already get standardized OOM messages and a dump_stack. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-29can: ems_usb: remove obsolete variable open_timeMarc Kleine-Budde
The variable open_time in the struct ems_usb was used to protect ems_usb_set_mode() only to be called, if the interface is up. Now the CAN device infrastructure takes care of this. Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2012-07-20can: mark bittiming_const pointer in struct can_priv as constMarc Kleine-Budde
This patch marks the bittiming_const pointer as in the struct can_pric as "const". This allows us to mark the struct can_bittiming_const in the CAN drivers as "const", too. Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2012-02-03can: replace the dev_dbg/info/err/... with the new netdev_xxx macrosWolfgang Grandegger
Cc: uclinux-dist-devel@blackfin.uclinux.org Cc: Anant Gole <anantgole@ti.com> Cc: Chris Elston <celston@katalix.com> Cc: Sebastian Haas <haas@ems-wuensche.com> Cc: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Acked-by: Sebastian Haas <dev@sebastianhaas.info> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2012-02-03can: ems_usb: Improved memory handling on ems_usb_startSebastian Haas
Do not return from ems_usb_start if allocation fails. If not all URBs could be allocated use the one already submitted. Signed-off-by: Sebastian Haas <dev@sebastianhaas.info> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2012-02-03can: ems_usb: Removed double netif_device_detachSebastian Haas
netif_device_attched is called twice when ems_usb_start fails with -ENODEV Signed-off-by: Sebastian Haas <dev@sebastianhaas.info> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2011-11-18USB: convert drivers/net/* to use module_usb_driver()Greg Kroah-Hartman
This converts the drivers in drivers/net/* to use the module_usb_driver() macro which makes the code smaller and a bit simpler. Added bonus is that it removes some unneeded kernel log messages about drivers loading and/or unloading. Cc: Wolfgang Grandegger <wg@grandegger.com> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: Oliver Neukum <oliver@neukum.name> Cc: Peter Korsgaard <jacmet@sunsite.dk> Cc: Petko Manolov <petkan@users.sourceforge.net> Cc: Steve Glendinning <steve.glendinning@smsc.com> Cc: Christian Lamparter <chunkeey@googlemail.com> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: Dan Williams <dcbw@redhat.com> Cc: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Cc: Ivo van Doorn <IvDoorn@gmail.com> Cc: Gertjan van Wingerde <gwingerde@gmail.com> Cc: Helmut Schaa <helmut.schaa@googlemail.com> Cc: Herton Ronaldo Krzesinski <herton@canonical.com> Cc: Hin-Tak Leung <htl10@users.sourceforge.net> Cc: Larry Finger <Larry.Finger@lwfinger.net> Cc: Chaoming Li <chaoming_li@realsil.com.cn> Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi> Cc: "David S. Miller" <davem@davemloft.net> Cc: Roel Kluin <roel.kluin@gmail.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Jiri Pirko <jpirko@redhat.com> Cc: Pavel Roskin <proski@gnu.org> Cc: Yoann DI-RUZZA <y.diruzza@lim.eu> Cc: George <george0505@realtek.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-06-03drivers/net: use __packed annotationEric Dumazet
cleanup patch. Use new __packed annotation in drivers/net/ Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (229 commits) USB: remove unused usb_buffer_alloc and usb_buffer_free macros usb: musb: update gfp/slab.h includes USB: ftdi_sio: fix legacy SIO-device header USB: kl5usb105: reimplement using generic framework USB: kl5usb105: minor clean ups USB: kl5usb105: fix memory leak USB: io_ti: use kfifo to implement write buffering USB: io_ti: remove unsused private counter USB: ti_usb: use kfifo to implement write buffering USB: ir-usb: fix incorrect write-buffer length USB: aircable: fix incorrect write-buffer length USB: safe_serial: straighten out read processing USB: safe_serial: reimplement read using generic framework USB: safe_serial: reimplement write using generic framework usb-storage: always print quirks USB: usb-storage: trivial debug improvements USB: oti6858: use port write fifo USB: oti6858: use kfifo to implement write buffering USB: cypress_m8: use kfifo to implement write buffering USB: cypress_m8: remove unused drain define ... Fix up conflicts (due to usb_buffer_alloc/free renaming) in drivers/input/tablet/acecad.c drivers/input/tablet/kbtab.c drivers/input/tablet/wacom_sys.c drivers/media/video/gspca/gspca.c sound/usb/usbaudio.c
2010-05-20USB: rename usb_buffer_alloc() and usb_buffer_free() usersDaniel Mack
For more clearance what the functions actually do, usb_buffer_alloc() is renamed to usb_alloc_coherent() usb_buffer_free() is renamed to usb_free_coherent() They should only be used in code which really needs DMA coherency. All call sites have been changed accordingly, except for staging drivers. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Pedro Ribeiro <pedrib@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-14drivers/net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from drivers/net/ all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. It also does not remove null void functions with return. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' with some cleanups by hand. Compile tested x86 allmodconfig only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-21can: Fix possible NULL pointer dereference in ems_usb.cHans J. Koch
In ems_usb_probe(), a pointer is dereferenced after making sure it is NULL... This patch replaces netdev->dev.parent with &intf->dev in dev_err() calls to avoid this. Signed-off-by: "Hans J. Koch" <hjk@linutronix.de> Acked-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-07ems_usb: cleanup: remove uneeded checkDan Carpenter
"skb" is alway non-null here, but even if it were null the check isn't needed because dev_kfree_skb() can handle it. This eliminates a smatch warning about dereferencing a variable before checking that it is non-null. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-04can: ems_usb: removed duplicated code setting local echo supportThadeu Lima de Souza Cascardo
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-15can: Proper ctrlmode handling for CAN devicesChristian Pellegrin
This patch adds error checking of ctrlmode values for CAN devices. As an example all availabe bits are implemented in the mcp251x driver. Signed-off-by: Christian Pellegrin <chripell@fsfe.org> Acked-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-12can: Unify droping of invalid tx skbs and netdev statsOliver Hartkopp
To prevent the CAN drivers to operate on invalid socketbuffers the skbs are now checked and silently dropped at the xmit-function consistently. Also the netdev stats are consistently using the CAN data length code (dlc) for [rx|tx]_bytes now. Signed-off-by: Oliver Hartkopp <oliver@hartkopp.net> Acked-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-13can: Fix data length code handling in rx pathOliver Hartkopp
A valid CAN dataframe can have a data length code (DLC) of 0 .. 8 data bytes. When reading the CAN controllers register the 4-bit value may contain values from 0 .. 15 which may exceed the reserved space in the socket buffer! The ISO 11898-1 Chapter 8.4.2.3 (DLC field) says that register values > 8 should be reduced to 8 without any error reporting or frame drop. This patch introduces a new helper macro to cast a given 4-bit data length code (dlc) to __u8 and ensure the DLC value to be max. 8 bytes. The different handlings in the rx path of the CAN netdevice drivers are fixed. Signed-off-by: Oliver Hartkopp <oliver@hartkopp.net> Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03drivers/net: Move && and || to end of previous lineJoe Perches
Only files where David Miller is the primary git-signer. wireless, wimax, ixgbe, etc are not modified. Compile tested x86 allyesconfig only Not all files compiled (not x86 compatible) Added a few > 80 column lines, which I ignored. Existing checkpatch complaints ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-08Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/can/usb/ems_usb.c
2009-11-06ems_usb: Fix byte order issues on big endian machinesSebastian Haas
CPC-USB is using a ARM7 core with little endian byte order. The "id" field in can_msg needs byte order conversion from/to CPU byte order. Signed-off-by: Sebastian Haas <haas@ems-wuensche.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-20can: provide library functions for skb allocationWolfgang Grandegger
This patch makes the private functions alloc_can_skb() and alloc_can_err_skb() of the at91_can driver public and adapts all drivers to use these. While making the patch I realized, that the skb's are *not* setup consistently. It's now done as shown below: skb->protocol = htons(ETH_P_CAN); skb->pkt_type = PACKET_BROADCAST; skb->ip_summed = CHECKSUM_UNNECESSARY; *cf = (struct can_frame *)skb_put(skb, sizeof(struct can_frame)); memset(*cf, 0, sizeof(struct can_frame)); The frame is zeroed out to avoid uninitialized data to be passed to user space. Some drivers or library code did not set "pkt_type" or "ip_summed". Also, "__constant_htons()" should not be used for runtime invocations, as pointed out by David Miller. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13can: make the number of echo skb's configurableWolfgang Grandegger
This patch allows the CAN controller driver to define the number of echo skb's used for the local loopback (echo), as suggested by Kurt Van Dijck, with the function: struct net_device *alloc_candev(int sizeof_priv, unsigned int echo_skb_max); The CAN drivers have been adapted accordingly. For the ems_usb driver, as suggested by Sebastian Haas, the number of echo skb's has been increased to 10, which improves the transmission performance a lot. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Kurt Van Dijck <kurt.van.dijck@eia.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-21ems_usb: Added support for EMS CPC-USB/ARM7 CAN/USB interfaceSebastian Haas
This patch adds support for one channel CAN/USB interace CPC-USB/ARM7 from EMS Dr. Thomas Wuensche (http://www.ems-wuensche.com). Signed-off-by: Sebastian Haas <haas@ems-wuensche.com> Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David S. Miller <davem@davemloft.net>
