path: root/drivers/net/bonding/bonding.h
2013-09-11bonding: fix bond_arp_rcv setting and arp validate desync statenikolay@redhat.com
We make bond_arp_rcv global so it can be used in bond_sysfs if the bond interface is up and arp_interval is being changed to a positive value and cleared otherwise as per Jay's suggestion. This also fixes a problem where bond_arp_rcv was set even though arp_validate was disabled while the bond was up by unsetting recv_probe in bond_store_arp_validate and respectively setting it if enabled. Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com> Signed-off-by: Marcelo Ricardo Leitner <mleitner@redhat.com> Acked-by: Veaceslav Falico <vfalico@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-03bonding: remove bond_vlan_used()Veaceslav Falico
We're using it currently to verify if we have vlans before getting the tag from the skb we're about to send. It's useless because the vlan_get_tag() verifies if the skb has the tag (and returns an error if not), and we can receive tagged skbs only if we *already* have vlans. Plus, the current RCUed implementation is kind of useless anyway - the we can remove the last vlan in the moment we return from the function. So remove the only usage of it and the whole function. CC: Jay Vosburgh <fubar@us.ibm.com> CC: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: Veaceslav Falico <vfalico@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-29bonding: remove vlan_list/current_alb_vlanVeaceslav Falico
Currently there are no real users of vlan_list/current_alb_vlan, only the helpers which maintain them, so remove them. CC: Jay Vosburgh <fubar@us.ibm.com> CC: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: Veaceslav Falico <vfalico@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-29bonding: use netdev_upper list in bond_vlan_usedVeaceslav Falico
Convert bond_vlan_used() to traverse the upper device list to see if we have any vlans above us. It's protected by rcu, and in case we are holding rtnl_lock we should call vlan_uses_dev() instead - it's faster. CC: Jay Vosburgh <fubar@us.ibm.com> CC: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: Veaceslav Falico <vfalico@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-01bonding: initial RCU conversionnikolay@redhat.com
This patch does the initial bonding conversion to RCU. After it the following modes are protected by RCU alone: roundrobin, active-backup, broadcast and xor. Modes ALB/TLB and 3ad still acquire bond->lock for reading, and will be dealt with later. curr_active_slave needs to be dereferenced via rcu in the converted modes because the only thing protecting the slave after this patch is rcu_read_lock, so we need the proper barrier for weakly ordered archs and to make sure we don't have stale pointer. It's not tagged with __rcu yet because there's still work to be done to remove the curr_slave_lock, so sparse will complain when rcu_assign_pointer and rcu_dereference are used, but the alternative to use rcu_dereference_protected would've created much bigger code churn which is more difficult to test and review. That will be converted in time. 1. Active-backup mode 1.1 Perf recording while doing iperf -P 4 - old bonding: iperf spent 0.55% in bonding, system spent 0.29% CPU in bonding - new bonding: iperf spent 0.29% in bonding, system spent 0.15% CPU in bonding 1.2. Bandwidth measurements - old bonding: 16.1 gbps consistently - new bonding: 17.5 gbps consistently 2. Round-robin mode 2.1 Perf recording while doing iperf -P 4 - old bonding: iperf spent 0.51% in bonding, system spent 0.24% CPU in bonding - new bonding: iperf spent 0.16% in bonding, system spent 0.11% CPU in bonding 2.2 Bandwidth measurements - old bonding: 8 gbps (variable due to packet reorderings) - new bonding: 10 gbps (variable due to packet reorderings) Of course the latency has improved in all converted modes, and moreover while doing enslave/release (since it doesn't affect tx anymore). Also I've stress tested all modes doing enslave/release in a loop while transmitting traffic. Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-01bonding: factor out slave id tx code and simplify xmit pathsNikolay Aleksandrov
I factored out the tx xmit code which relies on slave id in bond_xmit_slave_id. It is global because later it can be used also in 3ad mode xmit. Unnecessary obvious comments are removed. Active-backup mode is simplified because bond_dev_queue_xmit always consumes the skb. bond_xmit_xor becomes one line because of bond_xmit_slave_id. bond_for_each_slave_from is not used in bond_xmit_slave_id because later when RCU is used we can avoid important race condition by using standard rculist routines. Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-01bonding: convert to list API and replace bond's custom listnikolay@redhat.com
This patch aims to remove struct bonding's first_slave and struct slave's next and prev pointers, and replace them with the standard Linux list API. The old macros are converted to list API as well and some new primitives are available now. The checks if there're slaves that used slave_cnt have been replaced by the list_empty macro. Also a few small style fixes, changing longest -> shortest line in local variable declarations, leaving an empty line before return and removing unnecessary brackets. This is the first step to gradual RCU conversion. Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-27bonding: remove unnecessary dev_addr_from_first membernikolay@redhat.com
In struct bonding there's a member called dev_addr_from_first which is used to denote when the bond dev should clone the first slave's MAC address but since we have netdev's addr_assign_type variable that is not necessary. We clone the first slave's MAC each time we have a random MAC set to the bond device. This has the nice side-effect of also fixing an inconsistency - when the MAC address of the bond dev is set after its creation, but prior to having slaves, it's not kept and the first slave's MAC is cloned. The only way to keep the MAC was to create the bond device with the MAC address set (e.g. through ip link). In all cases if the bond device is left without any slaves - its MAC gets reset to a random one as before. Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-27bonding: remove unnecessary setup_by_slave membernikolay@redhat.com
We have a member called setup_by_slave in struct bonding to denote if the bond dev has different type than ARPHRD_ETHER, but that is already denoted in bond's netdev type variable if it was setup by the slave, so use that instead of the member. Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-25bonding: add an option to fail when any of arp_ip_target is inaccessibleVeaceslav Falico
Currently, we fail only when all of the ips in arp_ip_target are gone. However, in some situations we might need to fail if even one host from arp_ip_target becomes unavailable. All situations, obviously, rely on the idea that we need *completely* functional network, with all interfaces/addresses working correctly. One real world example might be: vlans on top on bond (hybrid port). If bond and vlans have ips assigned and we have their peers monitored via arp_ip_target - in case of switch misconfiguration (trunk/access port), slave driver malfunction or tagged/untagged traffic dropped on the way - we will be able to switch to another slave. Though any other configuration needs that if we need to have access to all arp_ip_targets. This patch adds this possibility by adding a new parameter - arp_all_targets (both as a module parameter and as a sysfs knob). It can be set to: 0 or any (the default) - which works exactly as it's working now - the slave is up if any of the arp_ip_targets are up. 1 or all - the slave is up if all of the arp_ip_targets are up. This parameter can be changed on the fly (via sysfs), and requires the mode to be active-backup and arp_validate to be enabled (it obeys the arp_validate config on which slaves to validate). Internally it's done through: 1) Add target_last_arp_rx[BOND_MAX_ARP_TARGETS] array to slave struct. It's an array of jiffies, meaning that slave->target_last_arp_rx[i] is the last time we've received arp from bond->params.arp_targets[i] on this slave. 2) If we successfully validate an arp from bond->params.arp_targets[i] in bond_validate_arp() - update the slave->target_last_arp_rx[i] with the current jiffies value. 3) When getting slave's last_rx via slave_last_rx(), we return the oldest time when we've received an arp from any address in bond->params.arp_targets[]. If the value of arp_all_targets == 0 - we still work the same way as before. Also, update the documentation to reflect the new parameter. v3->v4: Kill the forgotten rtnl_unlock(), rephrase the documentation part to be more clear, don't fail setting arp_all_targets if arp_validate is not set - it has no effect anyway but can be easier to set up. Also, print a warning if the last arp_ip_target is removed while the arp_interval is on, but not the arp_validate. v2->v3: Use _bh spinlock, remove useless rtnl_lock() and use jiffies for new arp_ip_target last arp, instead of slave_last_rx(). On bond_enslave(), use the same initialization value for target_last_arp_rx[] as is used for the default last_arp_rx, to avoid useless interface flaps. Also, instead of failing to remove the last arp_ip_target just print a warning - otherwise it might break existing scripts. v1->v2: Correctly handle adding/removing hosts in arp_ip_target - we need to shift/initialize all slave's target_last_arp_rx. Also, don't fail module loading on arp_all_targets misconfiguration, just disable it, and some minor style fixes. Signed-off-by: Veaceslav Falico <vfalico@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-25bonding: add helper function bond_get_targets_ip(targets, ip)Veaceslav Falico
Add function bond_get_targets_ip(targets, ip) which searches through targets array of ips (arp_targets) and returns the position of first match. If ip == 0, returns the first free slot. On failure to find the ip or free slot, return -1. Use it to verify if the arp we've received is valid and in sysfs. v1->v2: Fix "[2/6] bonding: add helper function bond_get_targets_ip(targets, ip)", per Nikolay's advice, to verify if source ip != 0.0.0.0, otherwise we might update 'null' arp_ip_targets' last_rx. Also, address style. Signed-off-by: Veaceslav Falico <vfalico@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/wireless/ath/ath9k/Kconfig drivers/net/xen-netback/netback.c net/batman-adv/bat_iv_ogm.c net/wireless/nl80211.c The ath9k Kconfig conflict was a change of a Kconfig option name right next to the deletion of another option. The xen-netback conflict was overlapping changes involving the handling of the notify list in xen_netbk_rx_action(). Batman conflict resolution provided by Antonio Quartulli, basically keep everything in both conflict hunks. The nl80211 conflict is a little more involved. In 'net' we added a dynamic memory allocation to nl80211_dump_wiphy() to fix a race that Linus reported. Meanwhile in 'net-next' the handlers were converted to use pre and post doit handlers which use a flag to determine whether to hold the RTNL mutex around the operation. However, the dump handlers to not use this logic. Instead they have to explicitly do the locking. There were apparent bugs in the conversion of nl80211_dump_wiphy() in that we were not dropping the RTNL mutex in all the return paths, and it seems we very much should be doing so. So I fixed that whilst handling the overlapping changes. To simplify the initial returns, I take the RTNL mutex after we try to allocate 'tb'. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-13bonding: fix igmp_retrans type and two related racesNikolay Aleksandrov
First the type of igmp_retrans (which is the actual counter of igmp_resend parameter) is changed to u8 to be able to store values up to 255 (as per documentation). There are two races that were hidden there and which are easy to trigger after the previous fix, the first is between bond_resend_igmp_join_requests and bond_change_active_slave where igmp_retrans is set and can be altered by the periodic. The second race condition is between multiple running instances of the periodic (upon execution it can be scheduled again for immediate execution which can cause the counter to go < 0 which in the unsigned case leads to unnecessary igmp retransmissions). Since in bond_change_active_slave bond->lock is held for reading and curr_slave_lock for writing, we use curr_slave_lock for mutual exclusion. We can't drop them as there're cases where RTNL is not held when bond_change_active_slave is called. RCU is unlocked in bond_resend_igmp_join_requests before getting curr_slave_lock since we don't need it there and it's pointless to delay. The decrement is moved inside the "if" block because if we decrement unconditionally there's still a possibility for a race condition although it is much more difficult to hit (many changes have to happen in a very short period in order to trigger) which in the case of 3 parallel running instances of this function and igmp_retrans == 1 (with check bond->igmp_retrans-- > 1) is: f1 passes, doesn't re-schedule, but decrements - igmp_retrans = 0 f2 then passes, doesn't re-schedule, but decrements - igmp_retrans = 255 f3 does the unnecessary retransmissions. Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-07bonding: Convert hw addr handling to sync/unsync, support ucast addressesJay Vosburgh
This patch converts bonding to use the dev_uc/mc_sync and dev_uc/mc_sync_multiple functions for updating the hardware addresses of bonding slaves. The existing functions to add or remove addresses are removed, and their functionality is replaced with calls to dev_mc_sync or dev_mc_sync_multiple, depending upon the bonding mode. Calls to dev_uc_sync and dev_uc_sync_multiple are also added, so that unicast addresses added to a bond will be properly synced with its slaves. Various functions are renamed to better reflect the new situation, and relevant comments are updated. Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Cc: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-30bond: have random dev address by default instead of zeroesJiri Pirko
Makes more sense to have randomly generated address by default than to have all zeroes. It also allows user to for example put the bond into bridge without need to have any slaves in it. Also note that this changes only behaviour of bonds with no slaves. Once the first slave device is enslaved, its address will be used (no change here). Also, fix dev_assign_type values on the way. Reported-by: Pavel Šimerda <psimerda@redhat.com> Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-04bonding: remove usage of dev->masterJiri Pirko
Benefit from new upper dev list and free bonding from dev->master usage. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial branch from Jiri Kosina: "Usual stuff -- comment/printk typo fixes, documentation updates, dead code elimination." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) HOWTO: fix double words typo x86 mtrr: fix comment typo in mtrr_bp_init propagate name change to comments in kernel source doc: Update the name of profiling based on sysfs treewide: Fix typos in various drivers treewide: Fix typos in various Kconfig wireless: mwifiex: Fix typo in wireless/mwifiex driver messages: i2o: Fix typo in messages/i2o scripts/kernel-doc: check that non-void fcts describe their return value Kernel-doc: Convention: Use a "Return" section to describe return values radeon: Fix typo and copy/paste error in comments doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c various: Fix spelling of "asynchronous" in comments. Fix misspellings of "whether" in comments. eisa: Fix spelling of "asynchronous". various: Fix spelling of "registered" in comments. doc: fix quite a few typos within Documentation target: iscsi: fix comment typos in target/iscsi drivers treewide: fix typo of "suport" in various comments and Kconfig treewide: fix typo of "suppport" in various comments ...
2012-11-30bonding: rlb mode of bond should not alter ARP originating via bridgezheng.li
Do not modify or load balance ARP packets passing through balance-alb mode (wherein the ARP did not originate locally, and arrived via a bridge). Modifying pass-through ARP replies causes an incorrect MAC address to be placed into the ARP packet, rendering peers unable to communicate with the actual destination from which the ARP reply originated. Load balancing pass-through ARP requests causes an entry to be created for the peer in the rlb table, and bond_alb_monitor will occasionally issue ARP updates to all peers in the table instrucing them as to which MAC address they should communicate with; this occurs when some event sets rx_ntt. In the bridged case, however, the MAC address used for the update would be the MAC of the slave, not the actual source MAC of the originating destination. This would render peers unable to communicate with the destinations beyond the bridge. Signed-off-by: Zheng Li <zheng.x.li@oracle.com> Cc: Jay Vosburgh <fubar@us.ibm.com> Cc: Andy Gospodarek <andy@greyhouse.net> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-19treewide: fix typo of "suport" in various comments and KconfigMasanari Iida
Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-06-12bonding: remove packet cloning in recv_probe()Eric Dumazet
Cloning all packets in input path have a significant cost. Use skb_header_pointer()/skb_copy_bits() instead of pskb_may_pull() so that recv_probe handlers (bond_3ad_lacpdu_recv / bond_arp_rcv / rlb_arp_recv ) dont touch input skb. bond_handle_frame() can avoid the skb_clone()/dev_kfree_skb() Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Jay Vosburgh <fubar@us.ibm.com> Cc: Andy Gospodarek <andy@greyhouse.net> Cc: Jiri Bohac <jbohac@suse.cz> Cc: Nicolas de Pesloüan <nicolas.2p.debian@free.fr> Cc: Maciej Żenczykowski <maze@google.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-13bonding: Fix LACPDU rx_dropped commit.David S. Miller
I applied the wrong version of Jiri's bonding fix in commit 13a8e0c8cdb43982372bd6c65fb26839c8fd8ce9 ("bonding: don't increase rx_dropped after processing LACPDUs") I applied v3, which introduces warnings I asked him to fix, instead of v4 which properly takes care of those issues. This inter-diffs such that the warnings are now gone. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-22bonding: remove entries for master_ip and vlan_ip and query devices insteadAndy Gospodarek
The following patch aimed to resolve an issue where secondary, tertiary, etc. addresses added to bond interfaces could overwrite the bond->master_ip and vlan_ip values. commit 917fbdb32f37e9a93b00bb12ee83532982982df3 Author: Henrik Saavedra Persson <henrik.e.persson@ericsson.com> Date: Wed Nov 23 23:37:15 2011 +0000 bonding: only use primary address for ARP That patch was good because it prevented bonds using ARP monitoring from sending frames with an invalid source IP address. Unfortunately, it didn't always work as expected. When using an ioctl (like ifconfig does) to set the IP address and netmask, 2 separate ioctls are actually called to set the IP and netmask if the mask chosen doesn't match the standard mask for that class of address. The first ioctl did not have a mask that matched the one in the primary address and would still cause the device address to be overwritten. The second ioctl that was called to set the mask would then detect as secondary and ignored, but the damage was already done. This was not an issue when using an application that used netlink sockets as the setting of IP and netmask came down at once. The inconsistent behavior between those two interfaces was something that needed to be resolved. While I was thinking about how I wanted to resolve this, Ralf Zeidler came with a patch that resolved this on a RHEL kernel by keeping a full shadow of the entries in dev->ifa_list for the bonding device and vlan devices in the bonding driver. I didn't like the duplication of the list as I want to see the 'bonding' struct and code shrink rather than grow, but liked the general idea. As the Subject indicates this patch drops the master_ip and vlan_ip elements from the 'bonding' and 'vlan_entry' structs, respectively. This can be done because a device's address-list is now traversed to determine the optimal source IP address for ARP requests and for checks to see if the bonding device has a particular IP address. This code could have all be contained inside the bonding driver, but it made more sense to me to EXPORT and call inet_confirm_addr since it did exactly what was needed. I tested this and a backported patch and everything works as expected. Ralf also helped with verification of the backported patch. Thanks to Ralf for all his help on this. v2: Whitespace and organizational changes based on suggestions from Jay Vosburgh and Dave Miller. v3: Fixup incorrect usage of rcu_read_unlock based on Dave Miller's suggestion. Signed-off-by: Andy Gospodarek <andy@greyhouse.net> CC: Ralf Zeidler <ralf.zeidler@nsn.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-30bonding: eliminate bond_close race conditionsJay Vosburgh
This patch resolves two sets of race conditions. Mitsuo Hayasaka <mitsuo.hayasaka.hu@hitachi.com> reported the first, as follows: The bond_close() calls cancel_delayed_work() to cancel delayed works. It, however, cannot cancel works that were already queued in workqueue. The bond_open() initializes work->data, and proccess_one_work() refers get_work_cwq(work)->wq->flags. The get_work_cwq() returns NULL when work->data has been initialized. Thus, a panic occurs. He included a patch that converted the cancel_delayed_work calls in bond_close to flush_delayed_work_sync, which eliminated the above problem. His patch is incorporated, at least in principle, into this patch. In this patch, we use cancel_delayed_work_sync in place of flush_delayed_work_sync, and also convert bond_uninit in addition to bond_close. This conversion to _sync, however, opens new races between bond_close and three periodically executing workqueue functions: bond_mii_monitor, bond_alb_monitor and bond_activebackup_arp_mon. The race occurs because bond_close and bond_uninit are always called with RTNL held, and these workqueue functions may acquire RTNL to perform failover-related activities. If bond_close or bond_uninit is waiting in cancel_delayed_work_sync, deadlock occurs. These deadlocks are resolved by having the workqueue functions acquire RTNL conditionally. If the rtnl_trylock() fails, the functions reschedule and return immediately. For the cases that are attempting to perform link failover, a delay of 1 is used; for the other cases, the normal interval is used (as those activities are not as time critical). Additionally, the bond_mii_monitor function now stores the delay in a variable (mimicing the structure of activebackup_arp_mon). Lastly, all of the above renders the kill_timers sentinel moot, and therefore it has been removed. Tested-by: Mitsuo Hayasaka <mitsuo.hayasaka.hu@hitachi.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-19bonding: Use a per netns implementation of /sys/class/net/bonding_masters.Eric W. Biederman
This fixes a network namespace misfeature that bonding_masters looked at current instead of the remembering the context where in which /sys/class/net/bonding_masters was opened in to see which network namespace to act upon. This removes the need for sysfs to handle tagged directories with untagged members allowing for a conceptually simpler sysfs implementation. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-17bonding: use ndo_change_rx_flags callbackJiri Pirko
Benefit from use of ndo_change_rx_flags in handling change of promisc and allmulti. No need to store previous state locally. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-21bonding: do vlan cleanupJiri Pirko
Now when all devices are cleaned up, bond can be cleaned up as well - remove bond->vlgrp - remove bond_vlan_rx_register - substitute necessary occurences of vlan_group_get_device Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-23bonding: add min links parameter to 802.3adstephen hemminger
This adds support for a configuring the minimum number of links that must be active before asserting carrier. It is similar to the Cisco EtherChannel min-links feature. This allows setting the minimum number of member ports that must be up (link-up state) before marking the bond device as up (carrier on). This is useful for situations where higher level services such as clustering want to ensure a minimum number of low bandwidth links are active before switchover. See: http://bugzilla.vyatta.com/show_bug.cgi?id=7196 Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Flavio Leitner <fbl@redhat.com> Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-09bonding: delete unused arp_mon_ptPeter Pan(潘卫平)
Now all received packets are handled by bond_handle_frame, and arp_mon_pt isn't used any more. Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Weiping Pan <panweiping3@gmail.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-15net: drivers: kill two unused macro definitionsShan Wei
Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Reviewed-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-29ipv4, ipv6, bonding: Restore control over number of peer notificationsBen Hutchings
For backward compatibility, we should retain the module parameters and sysfs attributes to control the number of peer notifications (gratuitous ARPs and unsolicited NAs) sent after bonding failover. Also, it is possible for failover to take place even though the new active slave does not have link up, and in that case the peer notification should be deferred until it does. Change ipv4 and ipv6 so they do not automatically send peer notifications on bonding failover. Change the bonding driver to send separate NETDEV_NOTIFY_PEERS notifications when the link is up, as many times as requested. Since it does not directly control which protocols send notifications, make num_grat_arp and num_unsol_na aliases for a single parameter. Bump the bonding version number and update its documentation. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Acked-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-25bonding: move processing of recv handlers into handle_frame()Jiri Pirko
Since now when bonding uses rx_handler, all traffic going into bond device goes thru bond_handle_frame. So there's no need to go back into bonding code later via ptype handlers. This patch converts original ptype handlers into "bonding receive probes". These functions are called from bond_handle_frame and they are registered per-mode. Note that vlan packets are also handled because they are always untagged thanks to vlan_untag() Note that this also allows arpmon for eth-bond-bridge-vlan topology. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17bonding, ipv4, ipv6, vlan: Handle NETDEV_BONDING_FAILOVER like ↵Ben Hutchings
NETDEV_NOTIFY_PEERS It is undesirable for the bonding driver to be poking into higher level protocols, and notifiers provide a way to avoid that. This does mean removing the ability to configure reptitition of gratuitous ARPs and unsolicited NAs. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-14net-bonding: Adding support for throughputs larger than 65536 MbpsDavid Decotigny
This updates the bonding driver to support v2.6.27-rc3 enhancements (b11f8d8c aka. "ethtool: Expand ethtool_cmd.speed to 32 bits") which allow to encode the Mbps link speed on 32-bits (Max 4 Pbps) instead of 16 (Max 65536 Mbps). This patch also attempts to compact struct slave by reordering its fields. Signed-off-by: David Decotigny <decot@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-14net-bonding: Fix minor sparse complaintsDavid Decotigny
This gets rid of minor sparse complaints: drivers/net/bonding/bond_main.c:4361:4: warning: do-while statement is not a compound statement drivers/net/bonding/bond_main.c:243:12: warning: symbol 'bond_mode_name' was not declared. Should it be static? Signed-off-by: David Decotigny <decot@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-23bonding: fix rx_handler lockingJiri Pirko
This prevents possible race between bond_enslave and bond_handle_frame as reported by Nicolas by moving rx_handler register/unregister. slave->bond is added to hold pointer to master bonding sructure. That way dev->master is no longer used in bond_handler_frame. Also, this removes "BUG: scheduling while atomic" message Reported-by: Nicolas de Pesloüan <nicolas.2p.debian@gmail.com> Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Tested-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-16bonding: get rid of IFF_SLAVE_INACTIVE netdev->priv_flagJiri Pirko
Since bond-related code was moved from net/core/dev.c into bonding, IFF_SLAVE_INACTIVE is no longer needed. Replace is with flag "inactive" stored in slave structure Signed-off-by: Jiri Pirko <jpirko@redhat.com> Reviewed-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-16bonding: wrap slave state workJiri Pirko
transfers slave->state into slave->backup (that it's going to transfer into bitfield. Introduce wrapper inlines to do the work with it. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Reviewed-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-16net: get rid of multiple bond-related netdevice->priv_flagsJiri Pirko
Now when bond-related code is moved from net/core/dev.c into bonding code, multiple priv_flags are not needed anymore. So let them rot. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Reviewed-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-16bonding: register slave pointer for rx_handlerJiri Pirko
Register slave pointer as rx_handler data. That would eventually prevent need to loop over slave devices to find the right slave. Use synchronize_net to ensure that bond_handle_frame does not get slave structure freed when working with that. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Reviewed-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-09bonding: move procfs code into bond_procfs.cAmerigo Wang
V2: Move #ifdef CONFIG_PROC_FS into bonding.h, as suggested by David. bond_main.c is bloating, separate the procfs code out, move them to bond_procfs.c Signed-off-by: WANG Cong <amwang@redhat.com> Reviewed-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-28bonding: fix sparse warningstephen hemminger
Fix use of zero where NULL expected. And wrap long line. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-27netpoll: remove IFF_IN_NETPOLL flagAmerigo Wang
V4: rebase to net-next-2.6 This patch removes the flag IFF_IN_NETPOLL, we don't need it any more since we have netpoll_tx_running() now. Signed-off-by: WANG Cong <amwang@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-27bonding: sync netpoll code with bridgeAmerigo Wang
V4: rebase to net-next-2.6 V3: remove an useless #ifdef. This patch unifies the netpoll code in bonding with netpoll code in bridge, thanks to Herbert that code is much cleaner now. Signed-off-by: WANG Cong <amwang@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-10headers: kobject.h reduxAlexey Dobriyan
Remove kobject.h from files which don't need it, notably, sched.h and fs.h. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bnx2x/bnx2x.h drivers/net/wireless/iwlwifi/iwl-1000.c drivers/net/wireless/iwlwifi/iwl-6000.c drivers/net/wireless/iwlwifi/iwl-core.h drivers/vhost/vhost.c
2010-12-16bonding: Fix slave selection bug.Hillf Danton
The returned slave is incorrect, if the net device under check is not charged yet by the master. Signed-off-by: Hillf Danton <dhillf@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-10bonding: add the debugfs facility to the bonding driverTaku Izumi
This patch provides the debugfs facility to the bonding driver. The "bonding" directory is created in the debugfs root and directories of each bonding interface (like bond0, bond1...) are created in that. # mount -t debugfs none /sys/kernel/debug # ls /sys/kernel/debug/bonding bond0 bond1 Signed-off-by: Taku Izumi <izumi.taku@jp.fujitsu.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-09net: Convert netpoll blocking api in bonding driver to be a counterNeil Horman
A while back I made some changes to enable netpoll in the bonding driver. Among them was a per-cpu flag that indicated we were in a path that held locks which could cause the netpoll path to block in during tx, and as such the tx path should queue the frame for later use. This appears to have given rise to a regression. If one of those paths on which we hold the per-cpu flag yields the cpu, its possible for us to come back on a different cpu, leading to us clearing a different flag than we set. This results in odd netpoll drops, and BUG backtraces appearing in the log, as we check to make sure that we only clear set bits, and only set clear bits. I had though briefly about changing the offending paths so that they wouldn't sleep, but looking at my origional work more closely, it doesn't appear that a per-cpu flag is warranted. We alrady gate the checking of this flag on IFF_IN_NETPOLL, so we don't hit this in the normal tx case anyway. And practically speaking, the normal use case for netpoll is to only have one client anyway, so we're not going to erroneously queue netpoll frames when its actually safe to do so. As such, lets just convert that per-cpu flag to an atomic counter. It fixes the rescheduling bugs, is equivalent from a performance perspective and actually eliminates some code in the process. Tested by the reporter and myself, successfully Reported-by: Liang Zheng <lzheng@redhat.com> CC: Jay Vosburgh <fubar@us.ibm.com> CC: Andy Gospodarek <andy@greyhouse.net> CC: David S. Miller <davem@davemloft.net> Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-17drivers/net/bonding: Remove unnecessary casts of netdev_privJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21bonding: make release_and_destroy staticstephen hemminger
Only used in main file. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
