path: root/drivers/net/bnx2.c
2008-12-23Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ppp_generic.c
2008-12-22net: Remove unused netdev arg from some NAPI interfaces.Neil Horman
When the napi api was changed to separate its 1:1 binding to the net_device struct, the netif_rx_[prep|schedule|complete] api failed to remove the now vestigual net_device structure parameter. This patch cleans up that api by properly removing it.. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-17bnx2: Fix bug in bnx2_free_rx_mem().Michael Chan
DMA memory for the jumbo rx page rings was freed incorrectly using the wrong local variable as the array index. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-16bnx2: Update version to 1.9.0.Michael Chan
And fix the 5716S pci_device_id entry to point to the proper string. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-16bnx2: Rename MSI-X vectors.Michael Chan
Change MSI-X vector names to "ethx-%d". Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-05Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-core.c drivers/net/wireless/iwlwifi/iwl-sta.c
2008-12-03bnx2: Add workaround to handle missed MSI.Michael Chan
The bnx2 chips do not support per MSI vector masking. On 5706/5708, new MSI address/data are stored only when the MSI enable bit is toggled. As a result, SMP affinity no longer works in the latest kernel. A more serious problem is that the driver will no longer receive interrupts when the MSI receiving CPU goes offline. The workaround in this patch only addresses the problem of CPU going offline. When that happens, the driver's timer function will detect that it is making no forward progress on pending interrupt events and will recover from it. Eric Dumazet reported the problem. We also found that if an interrupt is internally asserted while MSI and INTA are disabled, the chip will end up in the same state after MSI is re-enabled. The same workaround is needed for this problem. Signed-off-by: Michael Chan <mchan@broadcom.com> Tested-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-28bnx2: use net_device_stats nowadays available in net_deviceIlpo Järvinen
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-21bnx2: convert to net_device_opsStephen Hemminger
Convert driver to new net_device_ops. Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/isdn/i4l/isdn_net.c fs/cifs/connect.c
2008-11-12bnx2: fix poll_controller to pass proper structures and check all rx queuesNeil Horman
Fix bnx2 so that netpoll works properly. Specifically: 1) Fix parameters to bnx2_interrupt to be a struct bnx2_napi rather than a struct net_device 2) Fix poll_controller method to check every queue in the rx case so frames aren't missed Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-12bnx2: Update version to 1.8.2.Michael Chan
Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-12bnx2: Reorganize timeout constants.Michael Chan
Move all related timeout constants to the same location. BNX2 prefix is also added to make them more consistent. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-12bnx2: Set rx buffer water marks based on MTU.Michael Chan
The default rx buffer water marks for XOFF/XON are for 1500 MTU. At larger MTUs, these water marks need to be adjusted for effective flow control. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-12bnx2: Restrict WoL support.Michael Chan
On some quad-port cards that cannot support WoL on all ports due to excessive power consumption, the driver needs to restrict WoL on some ports by checking VAUX_PRESET bit. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-12bnx2: Add PCI ID for 5716S.Michael Chan
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-09bnx2: Update version to 1.8.1.Michael Chan
2008-10-09bnx2: Handle DMA mapping errors.Benjamin Li
Before, the driver would not care about the return codes from pci_map_* functions. This could be potentially dangerous if a mapping failed. Now, we will check all pci_map_* calls. On the transmit side, we switch to use the new function skb_dma_map(). On the receive side, we add pci_dma_mapping_error(). Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-09bnx2: Eliminate TSO header modifications.Michael Chan
This is now possible with updated firmware. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-09bnx2: Check netif_running() in all ethtool operations.Michael Chan
We need to check netif_running() state in most ethtool operations and properly handle the !netif_running() state where the chip is in an uninitailzed state or low power state that may not accept any MMIO. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-09bnx2: Add bnx2_shutdown_chip().Michael Chan
This logic is used in bnx2_close() and bnx2_suspend() and so should be separated out into a separate function. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-18bnx2: Remove timer_interval field from the bnx2 structureBenjamin Li
The timer_interval field is only assigned once, and never reassigned. We can safely replace all instances of the timer_interval with a constant value. Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-18bnx2: Remove name field from bnx2 structureBenjamin Li
The name of the board is only used during the initialization of the adapter. We can save the space of a pointer by not storing this information. Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-18bnx2: Update MODULE_DESCRIPTION to include the 5716Benjamin Li
2008-09-18bnx2: In bnx2_set_mac_link() return void rather then intBenjamin Li
bnx2_set_mac_link() doesn't need to return any error codes. And all the callers don't check the return code. It is safe to change the return type to a void. Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-15bnx2: Fix build with VLAN_8021Q disabled.David S. Miller
Reported by Randy Dunlap. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-14bnx2: Update version to 1.8.0.Michael Chan
2008-08-14bnx2: Reinsert VLAN tag when necessary.Michael Chan
In certain cases when ASF or other management firmware is running, the chip may be configured to always strip out the VLAN tag even when VLAN acceleration is not enabled. This causes some VLAN tagged packets to be received by the host stack without any knowledge that the original packet was VLAN tagged. We fix this by re-inserting the VLAN tag into the packet when necessary. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-14bnx2: Use proper CONFIG_VLAN_8021Q to compile the VLAN code.Michael Chan
2008-08-14bnx2: Fix logic to setup VLAN rx tagging.Michael Chan
We should now be checking BNX2_FLAG_CAN_KEEP_VLAN to determine how to set the VLAN rx tagging in the RX_MODE register. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18bnx2: Update version to 1.7.9.Benjamin Li
2008-07-18bnx2: Fix Sparse warningsBenjamin Li
This patch will fix the following sparse warnings: /home/benli/sparse/bnx2.c:297:8: warning: symbol 'val' shadows an earlier one /home/benli/sparse/bnx2.c:286:60: originally declared here /home/benli/sparse/bnx2.c:7461:7: warning: symbol 'i' shadows an earlier one /home/benli/sparse/bnx2.c:7265:10: originally declared here Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18bnx2: Add TX multiqueue support.Benjamin Li
2008-07-14bnx2: Update version to 1.7.8.Michael Chan
Signed-off-by: Michael Chan <mchan@braodcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-14bnx2: Support secondary MAC addresses.Benjamin Li
Add support for configuring secondary unicast addresses. There are 4 additional perfect match filters which can be used for secondary unicast address support. * Modified bnx2_set_mac_addr() to be more generic in handling the setting of the perfect match filters * Changed bnx2_set_rx_mode() to handle the unicast dev_addr_list Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-14bnx2: Allow flexible VLAN tag settings.Michael Chan
Negotiate with boot code and ASF firmware to see if it can support keeping VLAN tags in the RX packets. If supported by firmware, the VLAN tag will be kept in the RX packet unless VLAN acceleration is registered. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-14bnx2: Add ack parameter to bnx2_fw_sync().Michael Chan
ack=1 means wait for firmware acknowledgement, and ack=0 means don't wait. All current callers will set it to 1. In the next patch, new calls will set ack=0. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-14bnx2: Add PCI ID for 5716.Michael Chan
Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Benjamin Li <Benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-14bnx2: Prevent ethtool -s from crashing when device is down.Michael Chan
The device may be in D3-hot state and may crash if we try to configure the speed settings by accessing the registers. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-19bnx2: Update driver version to 1.7.7.Michael Chan
And update module description. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-19bnx2: Cleanup error handling in bnx2_open().Michael Chan
All error handling in bnx2_open() can be consolidated. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-19bnx2: Turn on multi rx rings.Michael Chan
Enable multiple rx rings if MSI-X vectors are available. We enable up to 7 rx rings. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-19bnx2: Use one handler for all MSI-X vectors.Michael Chan
Use the same MSI-X handler to schedule NAPI. Change the dev_instance void pointer to the bnx2_napi struct instead so we can have the proper context for each MSI-X vector. Add a new bnx2_poll_msix() that is optimized for handling MSI-X NAPI polling of rx/tx work only. Remove the old bnx2_tx_poll() that is no longer needed. Each MSI-X vector handles 1 tx and 1 rx ring. The first vector handles link events as well. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-19bnx2: Optimize fast-path tx and rx work.Michael Chan
Add hw_tx_cons_ptr and hw_rx_cons_ptr to speed up the retreival of the tx and rx consumer index, since the MSI-X and default status blocks have different structures. Combine status_blk and status_blk_msix into a union. We'll only use one type of status block for each vector. Separate the code to detect more rx and tx work from the code to detect link related work. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-19bnx2: Put rx ring variables in a separate struct.Michael Chan
In preparation for multi-ring support, rx ring variables are now put in a separate bnx2_rx_ring_info struct. With MSI-X, we can support multiple rx rings. The functions to allocate/free rx memory and to initialize rx rings are now modified to handle multiple rings. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-19bnx2: Put tx ring variables in a separate struct.Michael Chan
In preparation for multi-ring support, tx ring variables are now put in a separate bnx2_tx_ring_info struct. Multi tx ring will not be enabled until it is fully supported by the stack. Only 1 tx ring will be used at the moment. The functions to allocate/free tx memory and to initialize tx rings are now modified to handle multiple rings. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-13Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/smc911x.c
2008-06-12net: Eliminate flush_scheduled_work() calls while RTNL is held.David S. Miller
If the RTNL is held when we invoke flush_scheduled_work() we could deadlock. One such case is linkwatch, it is a work struct which tries to grab the RTNL semaphore. The most common case are net driver ->stop() methods. The simplest conversion is to instead use cancel_{delayed_}work_sync() explicitly on the various work struct the driver uses. This is an OK transformation because these work structs are doing things like resetting the chip, restarting link negotiation, and so forth. And if we're bringing down the device, we're about to turn the chip off and reset it anways. So if we cancel a pending work event, that's fine here. Some drivers were working around this deadlock by using a msleep() polling loop of some sort, and those cases are converted to instead use cancel_{delayed_}work_sync() as well. Signed-off-by: David S. Miller <davem@davemloft.net>
