path: root/drivers/net/benet/be_cmds.h
2011-05-16be2net: FW download for LancerShripad Nunjundarao
Added implementation of FW download feature for Lancer. Signed-off-by: Shripad Nunjundarao <shripad.nunjundarao@emulex.com> Signed-off-by: Sevin Xavier <selvin.xavier@emulex.com> Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16be2net: Stats for LancerSelvin Xavier
Added Lancer stats implementation. Signed-off-by: Selvin Xavier <selvin.xavier@emulex.com> Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16be2net: Support for version 1 of stats for BE3Ajit Khaparde
Added support to get version 1 of the stats for BE3. Use old stats command for BE2. Signed-off-by: Ajit Khaparde <ajit.khaparde@emulex.com> Signed-off-by: Selvin Xavier <selvin.xavier@emulex.com> Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-11be2net: Use NTWK_RX_FILTER command for promiscous modePadmanabh Ratnakar
Use OPCODE_COMMON_NTWK_RX_FILTER command for promiscous mode as OPCODE_ETH_PROMISCUOUS command is getting deprecated. Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-19be2net: pass domain id to be_cmd_link_status_queryAjit Khaparde
Signed-off-by: Ajit Khaparde <ajit.khaparde@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-30be2net: Support for FAT dump retrieval using ethtool --register-dump optionSomnath Kotur
Signed-off-by: Somnath Kotur <somnath.kotur@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-16be2net: Copyright notice change. Update to Emulex instead of ServerEnginesAjit Khaparde
2011-03-14be2net: changes for BE3 native mode supportSathya Perla
So far be2net has been using BE3 in legacy mode. It now checks for native mode capability and if available it sets it. In native mode, the RX_COMPL structure is different from that in legacy mode. Signed-off-by: Sathya Perla <sathya.perla@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-07be2net: Add multicast filter capability for LancerPadmanabh Ratnakar
Lancer requires multicast capability flag set during IFACE_CREATE for adding multicast filters. Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: Sathya Perla <sathya.perla@emulex.com> Signed-off-by: Subramanian Seetharaman <subbu.seetharaman@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-07be2net: Change f/w command versions for LancerPadmanabh Ratnakar
Change f/w command versions for Lancer Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: Sathya Perla <sathya.perla@emulex.com> Signed-off-by: Subramanian Seetharaman <subbu.seetharaman@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-22be2net: use hba_port_num instead of port_numAjit Khaparde
Use hba_port_num for phy loopback and ethtool phy identification. From: Suresh R <suresh.reddy@emulex.com> Signed-off-by: Ajit Khaparde <ajit.khaparde@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-22be2net: add code to display temperature of ASICAjit Khaparde
Add support to display temperature of ASIC via ethtool -S From: Somnath K <somnath.kotur@emulex.com> Signed-off-by: Ajit Khaparde <ajit.khaparde@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-22be2net: fix to ignore transparent vlan ids wrongly indicated by NICAjit Khaparde
With transparent VLAN tagging, the ASIC wrongly indicates packets with VLAN ID. Strip them off in the driver. The VLAN Tag to be stripped will be given to the host as an async message. Signed-off-by: Ajit Khaparde <ajit.khaparde@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-22be2net: add new counters to display via ethtool statsAjit Khaparde
New counters: > jabber frame stats > red drop stats Signed-off-by: Ajit Khaparde <ajit.khaparde@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-11be2net: pass domain numbers for pmac_add/del functionsAjit Khaparde
be_cmd_pmac_add/del functions need to pass domain number to the firmware. Signed-off-by: Ajit Khaparde <ajit.khaparde@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-11be2net: Use domain id when be_cmd_if_destroy is called.Ajit Khaparde
2010-11-27be2net: adding support for Lancer family of CNAsSathya Perla
Key changes are: - EQ ids are not assigned consecutively in Lancer. So, fix mapping of MSIx vector to EQ-id. - BAR mapping and some req locations different for Lancer. - TCP,UDP,IP checksum fields must be compulsorily set in TX wrb for TSO in Lancer. - CEV_IST reg not present in Lancer; so, peek into event queue to check for new entries - cq_create and mcc_create cmd interface is different for Lancer; handle accordingly Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: Sathya Perla <sathya.perla@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-24benet: remove dead codestephen hemminger
The following code and data are defined but never used in current driver. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21be2net: Changes to use only priority codes allowed by f/wSomnath Kotur
Changes to use one of the priority codes allowed by CNA f/w for NIC traffic from host. The driver gets the bit map of the priority codes allowed for host traffic through a asynchronous message from the f/w that the driver subscribes to. Signed-off-by: Somnath Kotur <somnath.kotur@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-03be2net: add multiple RX queue supportSathya Perla
This patch adds multiple RX queue support to be2net. There are upto 4 extra rx-queues per port into which TCP/UDP traffic can be hashed into. Some of the ethtool stats are now displayed on a per queue basis. Signed-off-by: Sathya Perla <sathya.perla@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-03be2net: fix a bug in UE detection logicAjit Khaparde
The ONLINE registers can return 0xFFFFFFFF on more than one occassion. On systems that care, reading these registers could lead to problems. So the new code decides that the ASIC has encountered and error by reading the UE_STATUS_LOW/HIGH registers. AND them with the mask values and a non-zero result indicates an error. Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-30be2net: add code to dump registers for debugAjit Khaparde
when the BE device becomes unresponsive, dump the registers to help debugging Signed-off-by: Somnath K <somnathk@serverengines.com> Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-23be2net: variable name changesAjit Khaparde
This patch changes names of some variables. Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-23be2net: code to support tx rate configuration on virtual functionsAjit Khaparde
2010-07-01be2net: changes to properly provide phy detailsAjit Khaparde
be2net driver is currently not showing correct phy details in certain cases. This patch fixes it. Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-01be2net: Adding PCI SRIOV supportSarveshwar Bandi
- Patch adds support to enable PCI SRIOV in the driver and changes to handle initialization of PCI virtual functions. - Function handler to change mac addresses for VF from its corresponding PF. Signed-off-by: Sarveshwar Bandi <sarveshwarb@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-02be2net: fix tx completion pollingSathya Perla
In tx/mcc polling, napi_complete() is being incorrectly called before reaping tx completions. This can cause tx compl processing to be scheduled on another cpu concurrently which can result in a panic. This if fixed by calling napi complete() after tx/mcc compl processing but before re-enabling interrupts (via a cq notify). Signed-off-by: Sathya Perla <sathyap@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-22net: convert multiple drivers to use netdev_for_each_mc_addr, part3Jiri Pirko
Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-19be2net: update copyright datesAjit Khaparde
2010-02-17be2net: don't rearm mcc cq when device is not openSathya Perla
When an MCC cmd is issued (via a netdev/ethtool op) while the device is not open, the MCC CQ gets processed but the EQ is not processed (as isr is not registered.) This can cause the EQ to become full. So, while the device is not open, CQ must not be re-armed to prevent EQ entries. Signed-off-by: Sathya Perla <sathyap@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-12be2net: bug fix for flashing the BladeEngine3 ASICAjit Khaparde
Now flashing both BE2 and BE3 devices is supported. From: Naresh G <nareshg@serverengines.com> Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-28Merge branch 'master' of ↵David S. Miller
2010-01-28be2net: Bug fix to support newer generation of BE ASICAjit Khaparde
Bug fix in be2net for newer generation of BladeEngine ASIC. Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-10Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/benet/be_cmds.h include/linux/sysctl.h
2010-01-08be2net: implements ethtool function to read eeprom data.Sarveshwar Bandi
The patch implements a firmware command to fetch the eeprom data. Signed-off-by: Sarveshwar Bandi <sarveshwarb@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-23be2net: Bug fix to config NIC appropriately before loopback testSarveshwar Bandi
NIC controller has to be set to an appropriate mode before doing a loopback test. Test will fail otherwise. Signed-off-by: Sarveshwar Bandi <sarveshwarb@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-07Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: kernel/irq/chip.c
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-03be2net: Add support for ethtool self testSuresh R
This patch adds support for ethtool selftest. From: Suresh R <sureshr@serverengines.com> Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03be2net: Support for WoL using magic packet after suspend.Ajit Khaparde
Add support for WOL using Magic Packet after suspend is done. Signed-off-by: Sarveshwar Bandi <sarveshwarb@serverengines.com> Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-23be2net: Issue fw_init/clean cmds to fwSathya Perla
These cmds are issued to the fw in probe/resume and remove/suspend paths to help fw execute some initialization and cleanup code. This change needed the be_hw_up() code to be refactored as be_get_config(). Signed-off-by: Sathya Perla <sathyap@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-23be2net: support configuration of 64 multicast addresses instead of 32Sathya Perla
To send upto 64 addresses in the multicast-set cmd, the non-embeeded cmd format that provides for a bigger buffer is used instead of an embedded format. Signed-off-by: Sathya Perla <sathyap@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-20be2net: Patch to flash redboot section while firmware update.Sarveshwar Bandi
Please apply patch to update redboot section while firmware update. Code checks if section needs to be updated before actually doing it. Signed-off-by: Sarveshwar Bandi <sarveshwarb@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/usb/cdc_ether.c All CDC ethernet devices of type USB_CLASS_COMM need to use '&mbm_info'. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-06be2net: Fix CQE_STATUS_EXTD_SHIFT defineSathya Perla
2009-10-28be2net: Changes to update ethtool get_settings function to return ↵Sarveshwar Bandi
appropriate values. Update ethtool get_settings function to: - get current link speed settings from controller - get port transceiver type from controller - fill appropriate values for supported, phy_address Signed-off-by: Sarveshwar Bandi <sarveshwarb@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-27Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/sh_eth.c
2009-10-14be2net: fix promiscuous and multicast promiscuous modes being enabled alwaysSathya Perla
2009-10-12be2net: Implement ethtool get_phys_id function.Sarveshwar Bandi
