path: root/drivers/net/benet/be.h
2011-05-18be2net: Enable SR-IOV for LancerMammatha Edhala
Enable SR-IOV for Lancer Signed-off-by: Mammatha Edhala <mammatha.edhala@emulex.com> Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16be2net: Stats for LancerSelvin Xavier
Added Lancer stats implementation. Signed-off-by: Selvin Xavier <selvin.xavier@emulex.com> Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16be2net: Support for version 1 of stats for BE3Ajit Khaparde
Added support to get version 1 of the stats for BE3. Use old stats command for BE2. Signed-off-by: Ajit Khaparde <ajit.khaparde@emulex.com> Signed-off-by: Selvin Xavier <selvin.xavier@emulex.com> Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-3.6 Conflicts: drivers/net/benet/be_main.c
2011-05-09be2net: Fixed bugs related to PVID.Somnath Kotur
Fixed bug to make sure 'pvid' retrieval will work on big endian hosts. Fixed incorrect comparison between the Rx Completion's 16-bit VLAN TCI and the PVID. Now comparing only the relevant 12 bits corresponding to the VID. Renamed 'vid' field under Rx Completion to 'vlan_tag' to reflect accurate description. Signed-off-by: Somnath Kotur <somnath.kotur@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-07net: benet: convert to hw_featuresMichał Mirosław
Simple conversion. This also fixes a bug in TX checksum toggling --- driver was changing NETIF_F_HW_CSUM instead of NETIF_F_IP_CSUM+NETIF_F_IPV6_CSUM. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-07be2net: dynamically allocate adapter->vf_cfgAjit Khaparde
Instead of a fixed sized array for vf_cfg, allocate the size dynamically depending on number of VFs the device supports. Signed-off-by: Ajit Khaparde <ajit.khaparde@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-07be2net: use common method to check for sriov function typeAjit Khaparde
Lancer and BE can both use SLI_INTF_REG to check a VF or a PF. Signed-off-by: Ajit Khaparde <ajit.khaparde@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-07be2net: add rxhash supportAjit Khaparde
Add rxhash support, Based on initial work by Eric Dumazet. Cc: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Ajit Khaparde <ajit.khaparde@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-07Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/benet/be_main.c
2011-04-06be2net: Rename some struct members for clarityPadmanabh Ratnakar
Renamed msix_vec_idx to eq_idx in be_eq_obj struct. Renamed msix_vec_next_idx to eq_next_idx in be_adapter structure. These members are used in INTX mode also. Signed-off-by: Sarveswara Rao Mygapula <sarveswararao.mygapula@emulex.com> Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-06benet: convert to set_phys_idstephen hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-30be2net: refactor code that decides adapter->num_rx_queuesSathya Perla
The code has been refactored to not set num_rx_qs inside be_enable_msix(). num_rx_qs is now set at the time of queue creation based on the number of available msix vectors. Signed-off-by: Sathya Perla <sathya.perla@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-16be2net: Bump up the version numberAjit Khaparde
2011-03-16be2net: Copyright notice change. Update to Emulex instead of ServerEnginesAjit Khaparde
2011-03-14be2net: changes for BE3 native mode supportSathya Perla
So far be2net has been using BE3 in legacy mode. It now checks for native mode capability and if available it sets it. In native mode, the RX_COMPL structure is different from that in legacy mode. Signed-off-by: Sathya Perla <sathya.perla@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-07be2net: Remove ERR compl workaround for LancerPadmanabh Ratnakar
Workaround added for Lancer in handling RX ERR completion received when no RX buffers are posted is not needed. Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: Sathya Perla <sathya.perla@emulex.com> Signed-off-by: Subramanian Seetharaman <subbu.seetharaman@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-22be2net: use hba_port_num instead of port_numAjit Khaparde
Use hba_port_num for phy loopback and ethtool phy identification. From: Suresh R <suresh.reddy@emulex.com> Signed-off-by: Ajit Khaparde <ajit.khaparde@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-22be2net: add code to display temperature of ASICAjit Khaparde
Add support to display temperature of ASIC via ethtool -S From: Somnath K <somnath.kotur@emulex.com> Signed-off-by: Ajit Khaparde <ajit.khaparde@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-22be2net: fix to ignore transparent vlan ids wrongly indicated by NICAjit Khaparde
With transparent VLAN tagging, the ASIC wrongly indicates packets with VLAN ID. Strip them off in the driver. The VLAN Tag to be stripped will be given to the host as an async message. Signed-off-by: Ajit Khaparde <ajit.khaparde@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-22be2net: variable name changeAjit Khaparde
change occurances of stats_ioctl_sent to stats_cmd_sent Signed-off-by: Ajit Khaparde <ajit.khaparde@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-11be2net: For the VF MAC, use the OUI from current MAC addressAjit Khaparde
Currently we are always using the Emulex OUI for a VF MAC address while generating MAC for a VF. Use OUI from current MAC instead. Signed-off-by: Ajit Khaparde <ajit.khaparde@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bnx2x/bnx2x.h drivers/net/wireless/iwlwifi/iwl-1000.c drivers/net/wireless/iwlwifi/iwl-6000.c drivers/net/wireless/iwlwifi/iwl-core.h drivers/vhost/vhost.c
2010-12-16be2net: use mutex instead of spin lock for mbox_lockIvan Vecera
Since the mbox polling uses the schedule_timeout, the mbox_lock should be a mutex and not a spin lock. The commit f25b03a replaced udelay() with schedule_timeout() but didn't change mbox_lock to semaphore or mutex. Signed-off-by: Ivan Vecera <ivecera@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-06be2net: Handle out of buffer completions for lancerSathya Perla
If Lancer chip does not have posted RX buffers, it posts an RX completion entry with the same frag_index as the last valid completion. The Error bit is also set. In BE, a flush completion is indicated with a zero value for num_rcvd in the completion. Such completions don't carry any data and are not processed. This patch refactors code to handle both cases with the same code. Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: Sathya Perla <sathya.perla@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-27be2net: adding support for Lancer family of CNAsSathya Perla
Key changes are: - EQ ids are not assigned consecutively in Lancer. So, fix mapping of MSIx vector to EQ-id. - BAR mapping and some req locations different for Lancer. - TCP,UDP,IP checksum fields must be compulsorily set in TX wrb for TSO in Lancer. - CEV_IST reg not present in Lancer; so, peek into event queue to check for new entries - cq_create and mcc_create cmd interface is different for Lancer; handle accordingly Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: Sathya Perla <sathya.perla@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21be2net: Changes to use only priority codes allowed by f/wSomnath Kotur
Changes to use one of the priority codes allowed by CNA f/w for NIC traffic from host. The driver gets the bit map of the priority codes allowed for host traffic through a asynchronous message from the f/w that the driver subscribes to. Signed-off-by: Somnath Kotur <somnath.kotur@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21vlan: Rename VLAN_GROUP_ARRAY_LEN to VLAN_N_VID.Jesse Gross
VLAN_GROUP_ARRAY_LEN is simply the number of possible vlan VIDs. Since vlan groups will soon be more of an implementation detail for vlan devices, rename the constant to be descriptive of its actual purpose. Signed-off-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-03be2net: add multiple RX queue supportSathya Perla
This patch adds multiple RX queue support to be2net. There are upto 4 extra rx-queues per port into which TCP/UDP traffic can be hashed into. Some of the ethtool stats are now displayed on a per queue basis. Signed-off-by: Sathya Perla <sathya.perla@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-09Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/mac80211/main.c
2010-09-03be2net: fix net-snmp error because of wrong packet statsAjit Khaparde
Wrong packet statistics for multicast Rx was causing net-snmp error messages every 15 seconds. Instead of picking the multicast stats from hardware, now maintain it in the driver itself. Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-25be2net: fix to dynamically generate MAC Address for VFsAjit Khaparde
The BE ASIC/firmware doesnot reserve and assign MAC address for VFs. This results in the VF interfaces being created with MAC Address 0. The code change proposed takes the MAC address of PF to generate a seed. MAC Address for VFs are assigned incrementally starting from the seed. These addresses are programmed in the ASIC by the PF and the VF driver queries for the MAC address during its probe. Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-30be2net: fix to avoid sending get_stats request if one is already being ↵Ajit Khaparde
processed. GET_STATS request uses the same memory region as the response. If a new request for get stats is fired before the response for the previous get_stats request is received, the response will corrupt the new request, causing the f/w to misbehave. Signed-off-by: Somnath K <somnathk@serverengines.com> Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-30be2net: add code to dump registers for debugAjit Khaparde
when the BE device becomes unresponsive, dump the registers to help debugging Signed-off-by: Somnath K <somnathk@serverengines.com> Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-23be2net: bump the driver version numberAjit Khaparde
2010-07-23be2net: variable name changesAjit Khaparde
This patch changes names of some variables. Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-23be2net: code to support tx rate configuration on virtual functionsAjit Khaparde
2010-07-23be2net: add vlan support for sriov virtual functionsAjit Khaparde
2010-07-23be2net: add support to get vf configAjit Khaparde
2010-07-23be2net: change to call pmac_del only if necessaryAjit Khaparde
If a mac address has not been configured for a VF, there is no need to call be_cmd_pmac_del. Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-10be2net: Patch to determine if function is VF while running in guest OS.Sarveshwar Bandi
When driver is loaded in guest OS, the pci variables is_virtfn and is_physfn are both set to 0. This change uses registers in controller to determine the same. Signed-off-by: Sarveshwar Bandi <sarveshwarb@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-01be2net: changes to properly provide phy detailsAjit Khaparde
be2net driver is currently not showing correct phy details in certain cases. This patch fixes it. Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-25be2net: Bug fix to avoid disabling bottom half during firmware upgrade.Sarveshwar Bandi
Certain firmware commands/operations to upgrade firmware could take several seconds to complete. The code presently disables bottom half during these operations which could lead to unpredictable behaviour in certain cases. This patch now does all firmware upgrade operations asynchronously using a completion variable. Signed-off-by: Sarveshwar Bandi <sarveshwarb@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-07benet: use the dma state API instead of the pci equivalentsFUJITA Tomonori
The DMA API is preferred. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Sathya Perla <sathyap@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-01be2net: Adding PCI SRIOV supportSarveshwar Bandi
- Patch adds support to enable PCI SRIOV in the driver and changes to handle initialization of PCI virtual functions. - Function handler to change mac addresses for VF from its corresponding PF. Signed-off-by: Sarveshwar Bandi <sarveshwarb@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-08be2net: remove usage of be_pci_funcAjit Khaparde
When PCI functions are virtuialized in applications by assigning PCI functions to VM (PCI passthrough), the be2net driver in the VM sees a different function number. So, use of PCI function number in any calculation will break existing code. This patch takes care of it. Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-19be2net: Bump the driver version numberAjit Khaparde
2010-02-19be2net: Maintain tx and rx counters in driverAjit Khaparde
For certain skews of the BE adapter, H/W Tx and Rx counters could be common for more than one interface. Add Tx and Rx counters in the adapter structure (to maintain stats on a per interfae basis). Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
