path: root/drivers/net/b44.c
2006-09-13drivers/net: const-ify ethtool_ops declarationsJeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-19drivers/net: Remove deprecated use of pci_module_init()Jeff Garzik
From: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-05[netdrvr] use dev_xxx() printk helpers, rather than dev_printk(KERN_xxx, ...Jeff Garzik
Suggested by Jiri Slaby. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-05[netdrvr] Use dev_printk() when ethernet interface isn't availableJeff Garzik
For messages prior to register_netdev(), prefer dev_printk() because that prints out both our driver name and our [PCI | whatever] bus id. Updates: 8139{cp,too}, b44, bnx2, cassini, {eepro,epic}100, fealnx, hamachi, ne2k-pci, ns83820, pci-skeleton, r8169. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-02[PATCH] irq-flags: drivers/net: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-22[PATCH] b44: update version to 1.01Gary Zambrano
Update the driver version to 1.01 Signed-off-by: Gary Zambrano <zambrano@broadcom.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-06-22[PATCH] b44: add wol for old nicGary Zambrano
This patch adds wol support for the older 440x nics that use pattern matching. This patch is a redo thanks to feedback from Michael Chan and Francois Romieu. Signed-off-by: Gary Zambrano <zambrano@broadcom.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-06-22[PATCH] b44: add parameterGary Zambrano
This patch adds a parameter to init_hw() to not completely initialize the nic for wol. Signed-off-by: Gary Zambrano <zambrano@broadcom.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-06-22[PATCH] b44: add wolGary Zambrano
Adds wol to the driver. This is a redo of a previous patch thanks to feedback from Francois Romieu. Signed-off-by Gary Zambrano <zambrano@broadcom.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-06-22[PATCH] b44: fix manual speed/duplex/autoneg settingsGary Zambrano
Fixes for speed/duplex/autoneg settings and driver settings info. This is a redo of a previous patch thanks to feedback from Jeff Garzik. Signed-off-by: Gary Zambrano <zambrano@broadcom.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-05-16[PATCH] x86_64: Check for bad dma address in b44 1GB DMA workaroundAndi Kleen
Needed for interaction with the nommu code in x86-64 which will return bad_dma_address if the address exceeds dma_mask. Cc: netdev@vger.kernel.org Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-12[netdrvr b44] trim trailing whitespaceJeff Garzik
2006-04-12[PATCH] b44: increase version to 1.00Gary Zambrano
2006-04-12[PATCH] b44: disable default tx pauseGary Zambrano
Disable default tx pause frame support. The b44 controller has a bug that generates excessive tx pause frames. Signed-off-by: Gary Zambrano <zambrano@broadcom.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-04-02BUG_ON() Conversion in drivers/net/Eric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-29[PATCH] b44: ensure valid mac addrGary Zambrano
Added code to check for invalid MAC address from eeprom or user input. Signed-off-by: Gary Zambrano <zambrano@broadcom.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-29b44: fix force mac address before ifconfig upGary Zambrano
Initializing the b44 MAC & PCI functional blocks in the controller must occur inside init_one(). This will allow access to the MAC registers. The controller was being powered up in b44_open() which would not allow access to the registers before ifconfig was up. Philip Kohlbecher found this bug. Signed-off-by: Gary Zambrano <zambrano@broadcom.com>
2006-01-26[PATCH] b44: fix laptop carrier detectStephen Hemminger
On my laptop, the b44 device is created and the carrier state defaults to ON when created by alloc_etherdev. This means tools like NetworkManager see the carrier as On and try and bring the device up. The correct thing to do is mark the carrier as Off when device is created. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2006-01-17[PATCH] Fix warning with b44.c on 64bit boxesAlan Cox
sizeof() return is not an int, so use max_t to get the types right. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-30b44: increase version numberFrancois Romieu
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2005-11-30b44: early return in dev->do_ioctl when the device is not upFrancois Romieu
The device has not gone through a whole reset/init sequence until the device is up. Accessing the mii interface before this point is not safe. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2005-11-30b44: missing netif_wake_queue() in b44_open()Mark Lord
This patch fixes a problem plaguing Dell notebooks with built-in b44 ethernet: The driver refuses to transmit packets of any kind until after the first 5-second tx_timeout occurs. This bug causes DHCP negotiation to fail (timeout) during installation of Ubuntu Linux. Signed-off-by: Mark Lord <lkml@rtr.ca> Signed-off-by: Andrew Morton <akpm@osdl.org>
2005-11-09Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] b44: increase version numberFrancois Romieu
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-09[PATCH] b44: race on device closingFrancois Romieu
Usual fix: - b44_interrupt() does not schedule NAPI polling when the device is going down; - b44_close() waits for any scheduled NAPI polling before it starts to release the private structures of the device. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-09[PATCH] b44: replace B44_FLAG_INIT_COMPLETE with netif_running()Francois Romieu
2005-11-07[PATCH] b44: late request_irq in b44_openFrancois Romieu
Don't request_irq before the registers are reset/init. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-07[PATCH] b44: s/spin_lock_irqsave/spin_lock/ in b44_interruptFrancois Romieu
There is no need to save/restore the irq state as the irq are always locally disabled when b44_interrupt is issued. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-07[PATCH] b44: expose counters through ethtoolFrancois Romieu
2005-11-07[PATCH] b44: miscellaneous cleanupFrancois Romieu
- remove unneeded forward declarations - s/kmalloc + memset/kzalloc/ - whitespace readjustement can't hurt - wrong comment: b44_init_rings _is_ called with a spinlock held in b44_{open/set_ringparam/set_pauseparam/etc}. Actually, it does not need to be able to sleep - b44_remove_one() can not be issued with a NULL device in its private member: remove the test. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-07[PATCH] b44: b44_start_xmit returns with a lock held when it fails allocatingFrancois Romieu
The patch simply factors out the release of the lock. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28[PATCH] b44: fix suspend/resumePavel Machek
Fix suspend/resume on b44 by freeing/reacquiring irq. Otherwise it hangs on resume. Signed-off-by: Pavel Machek <pavel@suse.cz> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28drivers/net: Remove pointless checks for NULL prior to calling kfree()Jesper Juhl
2005-10-28[netdrvr b44] include linux/dma-mapping.h to eliminate warningAndrew Morton
2005-10-28[PATCH] b44 reports wrong advertised flagsMatthew Wilcox
Looks like someone used the MII constants instead of the ethtool constants. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-18[PATCH] b44: alternate allocation option for DMA descriptorsJohn W. Linville
This is a (final?) hack to support the odd DMA allocation requirements of the b44 hardware. The b44 hardware has a 30-bit DMA mask. On x86, anything less than a 32-bit DMA mask forces allocations into the 16MB GFP_DMA range. The memory there is somewhat limited, often resulting in an inability to initialize the b44 driver. This hack uses streaming DMA allocation APIs in order to provide an alternative in case the GFP_DMA allocation fails. It is somewhat ugly, but not much worse than the similar existing hacks to support SKB allocations in the same driver. FWIW, I have received positive feedback on this from several Fedora users. Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-14[PATCH] b44: support ETHTOOL_GPERMADDRJohn W. Linville
Add support for ETHTOOL_GPERMADDR to b44. Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-07-12[ACPI] merge acpi-2.6.12 branch into latest Linux 2.6.13-rc...Len Brown
Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-11[ACPI] S3 Suspend to RAM: fix driver suspend/resume methodsDavid Shaohua Li
Drivers should do this: .suspend() pci_disable_device() .resume() pci_enable_device() http://bugzilla.kernel.org/show_bug.cgi?id=3469 Signed-off-by: David Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-06-27[PATCH] b44: check link state during openJohn W. Linville
Check the link state during b44_open. This closes a 1 HZ window that existed after b44_open ran but before the b44_timer handler ran, during which ethtool would report "Link detected: yes" no matter what the link state actually was. Signed-off-by: John W. Linville <linville@tuxdriver.com>
