path: root/drivers/net/atlx/atl2.c
2008-11-25atlx: fix warning in drivers/net/atlx/atl2.cIngo Molnar
fix this warning: drivers/net/atlx/atl2.c: In function ‘atl2_request_irq’: drivers/net/atlx/atl2.c:644: warning: unused variable ‘err’ 'err' is unused in the !CONFIG_PCI_MSI case. Instead of further increasing the #ifdeffery in this function, restructure the code a bit and get rid of the #ifdef. This relies on the fact that pci_enable_msi() will always fail in the !CONFIG_PCI_MSI case. There should be no change in driver behavior. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20netdev: add more functions to netdevice opsStephen Hemminger
This patch moves neigh_setup and hard_start_xmit into the network device ops structure. For bisection, fix all the previously converted drivers as well. Bonding driver took the biggest hit on this. Added a prefetch of the hard_start_xmit in the fast path to try and reduce any impact this would have. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ixgbe/ixgbe_main.c include/net/mac80211.h net/phonet/af_phonet.c
2008-11-20atl2: don't request irq on resume if netif runningAlan Jenkins
If the device is suspended with the cable disconnected, then resumed with the cable connected, dev->open is called before resume. During resume, we request an IRQ, but the IRQ was already assigned during dev->open, resulting in the warning shown below. Don't request an IRQ if the device is running. Call Trace: [<c011b89a>] warn_on_slowpath+0x40/0x59 [<c023df15>] raw_pci_read+0x4d/0x55 [<c023dff3>] pci_read+0x1c/0x21 [<c01bcd81>] __pci_find_next_cap_ttl+0x44/0x70 [<c01bce86>] __pci_find_next_cap+0x1a/0x1f [<c01bcef9>] pci_find_capability+0x28/0x2c [<c01c4144>] pci_msi_check_device+0x53/0x62 [<c01c49c2>] pci_enable_msi+0x3a/0x1cd [<e019f17b>] atl2_write_phy_reg+0x40/0x5f [atl2] [<c01061b1>] dma_generic_alloc_coherent+0x0/0xd7 [<e019f107>] atl2_request_irq+0x15/0x49 [atl2] [<e01a1481>] atl2_open+0x20b/0x297 [atl2] [<c024a35c>] dev_open+0x62/0x91 [<c0248b9a>] dev_change_flags+0x93/0x141 [<c024f308>] do_setlink+0x238/0x2d5 [<c02501b2>] rtnl_setlink+0xa9/0xbf [<c0297f0c>] mutex_lock+0xb/0x19 [<c024ffa7>] rtnl_dump_ifinfo+0x0/0x69 [<c0250109>] rtnl_setlink+0x0/0xbf [<c024fe42>] rtnetlink_rcv_msg+0x185/0x19f [<c0240fd1>] sock_rmalloc+0x23/0x57 [<c024fcbd>] rtnetlink_rcv_msg+0x0/0x19f [<c0259457>] netlink_rcv_skb+0x2d/0x71 [<c024fcb7>] rtnetlink_rcv+0x14/0x1a [<c025929e>] netlink_unicast+0x184/0x1e4 [<c025992a>] netlink_sendmsg+0x233/0x240 [<c023f405>] sock_sendmsg+0xb7/0xd0 [<c0129131>] autoremove_wake_function+0x0/0x2b [<c0129131>] autoremove_wake_function+0x0/0x2b [<c0147796>] mempool_alloc+0x2d/0x9e [<c020c923>] scsi_pool_alloc_command+0x35/0x4f [<c0297f0c>] mutex_lock+0xb/0x19 [<c028e867>] unix_stream_recvmsg+0x357/0x3e2 [<c01b81c9>] copy_from_user+0x23/0x4f [<c02452ea>] verify_iovec+0x3e/0x6c [<c023f5ab>] sys_sendmsg+0x18d/0x1f0 [<c023ffa8>] sys_recvmsg+0x146/0x1c8 [<c0240016>] sys_recvmsg+0x1b4/0x1c8 [<c0118f48>] __wake_up+0xf/0x15 [<c02586cd>] netlink_table_ungrab+0x17/0x19 [<c01b83ba>] copy_to_user+0x25/0x3b [<c023fe4a>] move_addr_to_user+0x50/0x68 [<c0240266>] sys_getsockname+0x6f/0x9a [<c0240280>] sys_getsockname+0x89/0x9a [<c015046a>] do_wp_page+0x3ae/0x41a [<c0151525>] handle_mm_fault+0x4c5/0x540 [<c02405d0>] sys_socketcall+0x176/0x1b0 [<c010376d>] sysenter_do_call+0x12/0x21 Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Signed-off-by: Jay Cliburn <jcliburn@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-19atlx: convert to net_device_opsStephen Hemminger
Convert this driver to network device ops. Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-02atlx: timer cleanupStephen Hemminger
Do some cleanup on timer usage in this driver: * Use round_jiffies to align wakeups and reduce power. * Remove atl1_watchdog which does nothing but rearm itself * Use setup_timer() function Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-11-02atlx: use embedded net_device_statsStephen Hemminger
There is now a net_device_stats structure inside net_device that should be used if possible by devices. Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-08net: remove LLTX in atl2 driverKevin Hao
When NETIF_F_LLTX is set, the atlx driver will use a private lock. But in recent kernels this implementation seems redundant and can cause problems where AF_PACKET sees things twice. Since NETIF_F_LLTX is marked as deprecated and shouldn't be used in new driver, this patch removes NETIF_F_LLTX and adds a mmiowb before sending packet. I have tested this driver on a Eee PC. It works well. Signed-off-by: Kevin Hao <kexin.hao@windriver.com> Acked-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08net: add net poll support for atl2 driverKevin Hao
Add netconsole support for Atheros L2 10/100 network device. Signed-off-by: Kevin Hao <kexin.hao@windriver.com> Acked-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-24atl2: add tx bytes statisticJay Cliburn
Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-18atl2: add atl2 driverChris Snook
Driver for Atheros L2 10/100 network device. Includes necessary changes for Kconfig, Makefile, and pci_ids.h. Signed-off-by: Chris Snook <csnook@redhat.com> Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
