path: root/drivers/net/atl1/atl1_main.c
2008-03-17atl1: relocate atl1 driver to /drivers/net/atlxJay Cliburn
In preparation for a future Atheros L2 NIC driver (called atl2), relocate the atl1 driver into a new /drivers/net/atlx directory that will ultimately be shared with the future atl2 driver. Signed-off-by: Chris Snook <csnook@redhat.com> Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-18atl1: fix frame length bugJay Cliburn
The driver sets up the hardware to accept a frame with max length equal to MTU + Ethernet header + FCS + VLAN tag, but we neglect to add the VLAN tag size to the ingress buffer. When a VLAN-tagged frame arrives, the hardware passes it, but bad things happen because the buffer is too small. This patch fixes that. Thanks to David Harris for reporting the bug and testing the fix. Tested-by: David Harris <david.harris@cpni-inc.com> Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10network drivers: sparse warning fixesStephen Hemminger
Fix some of the easy warnings in network device drivers. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10atl1: explain 32-bit DMA restrictionChris Snook
Document the fact that atl1 uses a single shared register for the high 32 bits of 64-bit DMA addresses, making 64-bit DMA more trouble than it's worth. Signed-off-by: Chris Snook <csnook@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10Clean up duplicate includes in drivers/net/Jesper Juhl
This patch cleans up duplicate includes in drivers/net/ Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: "John W. Linville" <linville@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-09-12atl1: disable broken 64-bit DMALuca Tettamanti
64-bit DMA causes data corruption with atl1. We don't know why, and Atheros is working on it. For now, just use 32-bit DMA. This is a big hack that is probably wrong, but it stops the bleeding. Signed-off-by: Luca Tettamanti <kronos.it@gmail.com> Acked-by: Chris Snook <csnook@redhat.com> Acked-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-08-07atl1: use spin_trylock_irqsave()Ingo Molnar
use the simpler spin_trylock_irqsave() API to get the adapter lock. [ this is also a fix for -rt where adapter->lock is a sleeping lock. ] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-24atl1: make atl1_init_ring_ptrs staticChris Snook
Sparse (correctly) thinks this function should be static. Make it so. Signed-off-by: Chris Snook <csnook@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-24atl1: use kernel provided ethernet length constantsJay Cliburn
Use constants already provided by the kernel for ethernet related lengths. Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-24atl1: change cmb write thresholdJay Cliburn
Change the threshold number of descriptors used to trigger CMB writes. The vendor reports that under certain conditions this will reduce the number of unnecessary tx interrupts and improve rx performance. This change is lifted directly from vendor version 1.2.40.2 of the L1 driver. Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-24atl1: fix typo in DMA engine setupJay Cliburn
The DMA engine setup contains a typo that can result in an incorrect dmaw_block setting. Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-24atl1: change tpd_avail function nameJay Cliburn
Change tpd_avail() to atl1_tpd_avail(). Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-17atl1: missing includeAl Viro
2007-07-16Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (37 commits) forcedeth bug fix: realtek phy forcedeth bug fix: vitesse phy forcedeth bug fix: cicada phy atl1: reorder atl1_main functions atl1: fix excessively indented code atl1: cleanup atl1_main atl1: header file cleanup atl1: remove irq_sem cdc-subset to support new vendor/product ID 8139cp: implement the missing dev->tx_timeout myri10ge: Remove nonsensical limit in the tx done routine gianfar: kill unused header EP93XX_ETH must select MII macb: Add multicast capability macb: Use generic PHY layer s390: add barriers to qeth driver s390: scatter-gather for inbound traffic in qeth driver eHEA: Introducing support vor DLPAR memory add Fix a potential NULL pointer dereference in free_shared_mem() in drivers/net/s2io.c [PATCH] softmac: Fix ESSID problem ...
2007-07-16atl1: reorder atl1_main functionsJay Cliburn
Reorder functions in atl1_main into more logical groupings to make the code easier to follow. This patch is large, but it's harmless; it neither adds nor removes any functionality whatsoever. Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-16atl1: fix excessively indented codeJay Cliburn
Move excessively indented code to separate functions. Also move ring pointer initialization to its own function. Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-16atl1: cleanup atl1_mainJay Cliburn
Fix indentation, remove dead code, improve some comments, change dev_dbg to dev_printk. Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-16atl1: header file cleanupJay Cliburn
Remove unused structure members, improve comments, break long comment lines, rename a constant to be consistent with others in the file. Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-16atl1: remove irq_semJay Cliburn
Remove unnecessary irq_sem code. Signed-off-by: Chris Snook <csnook@redhat.com> Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-11PCI: Change all drivers to use pci_device->revisionAuke Kok
Instead of all drivers reading pci config space to get the revision ID, they can now use the pci_device->revision member. This exposes some issues where drivers where reading a word or a dword for the revision number, and adding useless error-handling around the read. Some drivers even just read it for no purpose of all. In devices where the revision ID is being copied over and used in what appears to be the equivalent of hotpath, I have left the copy code and the cached copy as not to influence the driver's performance. Compile tested with make all{yes,mod}config on x86_64 and i386. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-10atl1: remove write-only var in tx handlerAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-06-03atl1: eliminate unneeded kill_vid codeStephen Hemminger
This driver has unneeded stubs for VLAN filtering. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-09atl1: add netconsole supportAlexey Dobriyan
Copied from b44 driver, but it works: netconsole: device eth0 not up yet, forcing it atl1: eth0 link is up 100 Mbps full duplex netconsole: network logging started Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-08atl1: use dev_printk macrosJay Cliburn
Use dev_printk macros for PCI related errors, warnings, debug and info console messages. Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-25[NETDRV]: Perform missing csum_offset conversionsHerbert Xu
When csum_offset was introduced we did a conversion from csum to csum_offset where applicable. A couple of drivers were missed in this process. It was harmless to begin with since the two fields coincided. Now that we've made them different with the addition of csum_start, the missed drivers must be converted or they can't send packets out at all that require checksum offload. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce tcp_hdr(), remove skb->h.thArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[TCP]: Introduce tcp_hdrlen() and tcp_optlen()Arnaldo Carvalho de Melo
The ip_hdrlen() buddy, created to reduce the number of skb->h.th-> uses and to avoid the longer, open coded equivalent. Ditched a no-op in bnx2 in the process. I wonder if we should have a BUG_ON(skb->h.th->doff < 5) in tcp_optlen()... Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_transport_offset()Arnaldo Carvalho de Melo
For the quite common 'skb->h.raw - skb->data' sequence. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ip_hdr(), remove skb->nh.iphArnaldo Carvalho de Melo
2007-04-25[SK_BUFF]: Introduce skb_network_offset()Arnaldo Carvalho de Melo
For the quite common 'skb->nh.raw - skb->data' sequence. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-29atl1: save mac address on removeChris Snook
Some atl1 boards get their MAC address written directly to the register by the BIOS during POST, rather than storing it in EEPROM that's accessible to the driver. If the MAC register on one of these boards is changed and then the module is unloaded, the permanent MAC address will be forgotten until the box is rebooted. We should save the permanent address during removal if we've been messing with it. Signed-off-by: Chris Snook <csnook@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-03-14[PATCH] atl1 trivial endianness misannotationsAl Viro
NB: driver is choke-full of code that will break on big-endian; as long as the hardware is onboard-only we can live with that, but sooner or later that'll need fixing. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-02[VLAN]: Avoid a 4-order allocation.Dan Aloni
This patch splits the vlan_group struct into a multi-allocated struct. On x86_64, the size of the original struct is a little more than 32KB, causing a 4-order allocation, which is prune to problems caused by buddy-system external fragmentation conditions. I couldn't just use vmalloc() because vfree() cannot be called in the softirq context of the RCU callback. Signed-off-by: Dan Aloni <da-x@monatomic.org> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-17atl1: bump version numberJay Cliburn
Bump the version number. Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-17atl1: add L1 device id to pci_ids, then use itChris Snook
Add device id for the Attansic L1 chip to pci_ids.h, then use it. Signed-off-by: Chris Snook <csnook@redhat.com> Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-17atl1: remove unused defineChris Snook
Remove unused define from atl1_main.c. Signed-off-by: Chris Snook <csnook@redhat.com> Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-08Add Attansic L1 ethernet driver.Jay Cliburn
This driver is a modified version of the Attansic reference driver for the L1 ethernet adapter. Attansic has granted permission for its inclusion in the mainline kernel. Signed-off-by: Jeff Garzik <jeff@garzik.org>
