path: root/drivers/net/atarilance.c
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-11make drivers/net/atarilance.c:lance_addr_list[] staticAdrian Bunk
This patch makes the needlessly global lance_addr_list[] static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-03-17/drivers/net/atarilance.c replaced init_module&cleanup_module with ↵Jon Schindler
module_init&module_exit Replaced init_module and cleanup_module with static functions and module_init/module_exit. Signed-off-by: Jon Schindler <jkschind@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-05fix drivers/net/atarilance.c compilationAdrian Bunk
This patch fixes the following build error: <-- snip --> ... CC [M] drivers/net/atarilance.o {standard input}: Assembler messages: {standard input}:406: Error: symbol `Lberr' is already defined {standard input}:460: Error: symbol `Lberr' is already defined make[3]: *** [drivers/net/atarilance.o] Error 1 <-- snip --> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-13fallout from DECLARE_MAC_BUF patchesAl Viro
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET] drivers/net: statistics cleanup #1 -- save memory and shrink codeJeff Garzik
We now have struct net_device_stats embedded in struct net_device, and the default ->get_stats() hook does the obvious thing for us. Run through drivers/net/* and remove the driver-local storage of statistics, and driver-local ->get_stats() hook where applicable. This was just the low-hanging fruit in drivers/net; plenty more drivers remain to be updated. [ Resolved conflicts with napi_struct changes and fix sunqe build regression... -DaveM ] Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10drivers/net/: all drivers/net/ cleanup with ARRAY_SIZEDenis Cheng
Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-04[PATCH] trivial missing __init in drivers/net/*Al Viro
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-09-12[PATCH] Remove more unnecessary driver printk'sAndy Gospodarek
As I promised last week, here is the first pass at removing all unnecessary printk's that exist in network device drivers currently in promiscuous mode. The duplicate messages are not needed so they have been removed. Some of these drivers are quite old and might not need an update, but I did them all anyway. I am currently auditing the remaining conditional printk's and will send out a patch for those soon. Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-06-23[NET]: Avoid allocating skb in skb_padHerbert Xu
First of all it is unnecessary to allocate a new skb in skb_pad since the existing one is not shared. More importantly, our hard_start_xmit interface does not allow a new skb to be allocated since that breaks requeueing. This patch uses pskb_expand_head to expand the existing skb and linearize it if needed. Actually, someone should sift through every instance of skb_pad on a non-linear skb as they do not fit the reasons why this was originally created. Incidentally, this fixes a minor bug when the skb is cloned (tcpdump, TCP, etc.). As it is skb_pad will simply write over a cloned skb. Because of the position of the write it is unlikely to cause problems but still it's best if we don't do it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-25[PATCH] Remove MODULE_PARMRusty Russell
MODULE_PARM was actually breaking: recent gcc version optimize them out as unused. It's time to replace the last users, which are generally in the most unloved drivers anyway. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-06[PATCH] lvalues abuse in lanceAl Viro
result of comma operator is not an lvalue Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
