path: root/drivers/net/arcnet
2006-02-17[PATCH] trivial: fix spelling errors in KconfigsJon Mason
This patch corrects a few spelling and grammar errors found in drivers/net Signed-off-by: Jon Mason <jdmason@us.ibm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-02-09Merge branch 'viro'Jeff Garzik
2006-01-28[PATCH] arcnet probing cleanups and fixesAl Viro
make arcnet probing do request_mem_region() for all iomem it's going to access, clean the code up. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-01-17[PATCH] drivers/net/arcnet/: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make needlessly global code static - arcnet.c: remove the unneeded EXPORT_SYMBOL(arc_proto_null) - arcnet.c: remove the unneeded EXPORT_SYMBOL(arcnet_dump_packet) To make Jeff happy, arcnet.c still prints arcnet: v3.93 BETA 2000/04/29 - by Avery Pennarun et al. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2006-01-17[PATCH] drivers/net/*: use time_after() and friendsMarcelo Feitoza Parisi
They deal with wrapping correctly and are nicer to read. Also make jiffies-holding variables unsigned long. Signed-off-by: Marcelo Feitoza Parisi <marcelo@feitoza.com.br> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-13[PATCH] Remove unnecessary check_region references in commentsPeter Osterlund
Remove check_region references from comments and printk statements so that searching for real users of this deprecated function gets easier. Signed-off-by: Peter Osterlund <petero2@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-06[ARCNET]: Fix return value from arcnet_send_packet().Pieter Dejaeghere
From: Pieter Dejaeghere <pieter@dejaeghere.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-05[PATCH] make some things staticAdrian Bunk
This patch makes some needlessly global identifiers static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Arjan van de Ven <arjanv@infradead.org> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
