path: root/drivers/net/amd8111e.c
2007-10-10amd8111e big-endian fixAl Viro
amd8111e_calc_coalesce() ends up with insane values of tx_data_rate since ->tx_bytes increments missing conversion from little- to host-endian Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10amd8111e: trivial endianness annotations, NULL noise removalAl Viro
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make NAPI polling independent of struct net_device objects.Stephen Hemminger
Several devices have multiple independant RX queues per net device, and some have a single interrupt doorbell for several queues. In either case, it's easier to support layouts like that if the structure representing the poll is independant from the net device itself. The signature of the ->poll() call back goes from: int foo_poll(struct net_device *dev, int *budget) to int foo_poll(struct napi_struct *napi, int budget) The caller is returned the number of RX packets processed (or the number of "NAPI credits" consumed if you want to get abstract). The callee no longer messes around bumping dev->quota, *budget, etc. because that is all handled in the caller upon return. The napi_struct is to be embedded in the device driver private data structures. Furthermore, it is the driver's responsibility to disable all NAPI instances in it's ->stop() device close handler. Since the napi_struct is privatized into the driver's private data structures, only the driver knows how to get at all of the napi_struct instances it may have per-device. With lots of help and suggestions from Rusty Russell, Roland Dreier, Michael Chan, Jeff Garzik, and Jamal Hadi Salim. Bug fixes from Thomas Graf, Roland Dreier, Peter Zijlstra, Joseph Fannin, Scott Wood, Hans J. Koch, and Michael Chan. [ Ported to current tree and all drivers converted. Integrated Stephen's follow-on kerneldoc additions, and restored poll_list handling to the old style to fix mutual exclusion issues. -DaveM ] Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-03network drivers: eliminate unneeded kill_vid codeStephen Hemminger
Many drivers had code that did kill_vid, but they weren't doing vlan filtering. With new API the stub is unneeded unless device sets NETIF_F_HW_VLAN_FILTER. Bad habit: I couldn't resist fixing a couple of nearby style things in acenic, and forcedeth. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-06-01potential parse error in ifdefYoann Padioleau
I have made a tool to parse the kernel that does not pre-process the source. That means that my parser tries to parse all the code, including code in the #else branch or code that is not often compiled because the driver is not very used (or not used at all). So, my parser sometimes reports parse error not originally detected by gcc. Here is my (first) patch. [akpm@linux-foundation.org: fix amd8111e.c] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Acked-by: Matthew Wilcox <matthew@wil.cx> Acked-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: David Woodhouse <dwmw2@infradead.org> Acked-by: Jeff Garzik <jeff@garzik.org> Acked-by: James Bottomley <James.Bottomley@steeleye.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-02[VLAN]: Avoid a 4-order allocation.Dan Aloni
This patch splits the vlan_group struct into a multi-allocated struct. On x86_64, the size of the original struct is a little more than 32KB, causing a 4-order allocation, which is prune to problems caused by buddy-system external fragmentation conditions. I couldn't just use vmalloc() because vfree() cannot be called in the softirq context of the RCU callback. Signed-off-by: Dan Aloni <da-x@monatomic.org> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-06NET: turn local_save_flags() + local_irq_disable() into local_irq_save()Jiri Kosina
drivers/net/amd8111e.c::amd8111e_poll() contains local_irq_disable() after local_save_flags(). Turn it into local_irq_save(). Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-02[PATCH] amd8111e use standard CRC libStephen Hemminger
I noticed this driver (and several others) reinvent their own copy of the existing CRC library. Don't have the hardware, but tested by extracting code and comparing result. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-13drivers/net: const-ify ethtool_ops declarationsJeff Garzik
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-09-12Merge branch 'tmp' into upstreamJeff Garzik
2006-09-12[PATCH] Remove more unnecessary driver printk'sAndy Gospodarek
As I promised last week, here is the first pass at removing all unnecessary printk's that exist in network device drivers currently in promiscuous mode. The duplicate messages are not needed so they have been removed. Some of these drivers are quite old and might not need an update, but I did them all anyway. I am currently auditing the remaining conditional printk's and will send out a patch for those soon. Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-19drivers/net: Remove deprecated use of pci_module_init()Jeff Garzik
From: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-02[PATCH] irq-flags: drivers/net: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[git] change permissions on drivers/net/amd8111e.[ch] to 0644,Jeff Garzik
removing executable bits.
2005-07-27[PATCH] turn many #if $undefined_string into #ifdef $undefined_stringOlaf Hering
turn many #if $undefined_string into #ifdef $undefined_string to fix some warnings after -Wno-def was added to global CFLAGS Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27[PATCH] Use pci_set_dma_mask() instead of direct assignment of DMA maskTobias Klauser
The amd8111e driver directly assigns the DMA mask to the dma_mask member of the struct pci_dev instead of using pci_set_dma_mask(). This makes the call to pci_dma_supported() redundant as pci_set_dma_mask() does this check. I do not own this device so I only compile-tested this patch. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch>
2005-05-12 [PATCH] drivers/net/amd8111e.c: fix NAPI interrupt in pollLiu Tao
This patch makes the netif_rx_complete() and rx_interrupt_enable atomic when exiting the poll() method, so to avoid interrupt in poll. It also fixes the rx interrupt check logic in interrupt handler. Signed-off-by: Liu Tao <liutao1980@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
