path: root/drivers/net/Makefile
2006-03-22[PATCH] fix spidernet build issueJens Osterkamp
<unchangelogged> Signed-off-by: Jens Osterkamp <Jens.Osterkamp@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-01-09[NET]: Add IFB (Intermediate Functional Block) network device.Jamal Hadi Salim
A new device to do intermidiate functional block in a system shared manner. To use the new functionality, you need to turn on qos/classifier actions. The new functionality can be grouped as: 1) qdiscs/policies that are per device as opposed to system wide. ifb allows for a device which can be redirected to thus providing an impression of sharing. 2) Allows for queueing incoming traffic for shaping instead of dropping. Packets are redirected to this device using tc/action mirred redirect construct. If they are sent to it by plain routing instead then they will merely be dropped and the stats would indicate that. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-18[PATCH] intel ixp2000 network driverLennert Buytenhek
The way the hardware and firmware work is that there is one shared RX queue and IRQ for a number of different network interfaces. Due to this, we would like to process received packets for every interface in the same NAPI poll handler, so we need a pseudo-device to schedule polling on. What the driver currently does is that it always schedules polling for the first network interface in the list, and processes packets for every interface in the poll handler for that first interface -- however, this scheme breaks down if the first network interface happens to not be up, since netif_rx_schedule_prep() checks netif_running(). sky2 apparently has the same issue, and Stephen Hemminger suggested a way to work around this: create a variant of netif_rx_schedule_prep() that does not check netif_running(). I implemented this locally and called it netif_rx_schedule_prep_notup(), and it seems to work well, but it's something that probably not everyone would be happy with. The ixp2000 is an ARM CPU with a high-speed network interface in the CPU itself (full duplex 4Gb/s or 10Gb/s depending on the IXP model.) The CPU package also contains 8 or 16 (again depending on the IXP model) 'microengines', which are somewhat primitive but very fast and efficient processor cores which can be used to offload various things from the main CPU. This driver makes the high-speed network interface in the CPU visible and usable as a regular linux network device. Currently, it only supports the Radisys ENP2611 IXP board, but adding support for other board types should be fairly easy. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-18[PATCH] Gianfar update and sysfs supportAndy Fleming
This seems to have gotten lost, so I'll resend. Signed-off-by: Andy Fleming <afleming@freescale.com> * Added sysfs support to gianfar for modifying FIFO and stashing parameters * Updated driver to support 10 Mbit, full duplex operation * Improved comments throughout * Cleaned up and optimized offloading code * Fixed a bug where rx buffers were being improperly mapped and unmapped * (only manifested if cache-coherency was off) * Added support for using the eTSEC exact-match MAC registers * Bumped the version to 1.3 * Added support for distinguishing between reduced 100 and 10 Mbit modes * Modified default coalescing values to lower latency * Added documentation Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-11Merge branch 'master'Jeff Garzik
2005-11-08[PPP]: add PPP MPPE encryption moduleMatt Domsch
From: Matt Domsch <Matt_Domsch@dell.com> The patch below implements the Microsoft Point-to-Point Encryption method as a PPP compressor/decompressor. This is necessary for Linux clients and servers to interoperate with Microsoft Point-to-Point Tunneling Protocol (PPTP) servers (either Microsoft PPTP servers or the poptop project) which use MPPE to encrypt data when creating a VPN. This patch differs from the kernel_ppp_mppe DKMS pacakge at pptpclient.sourceforge.net by utilizing the kernel crypto routines rather than providing its own SHA1 and arcfour implementations. Minor changes to ppp_generic.c try to prevent a link from disabling compression (in our case, the encryption) after it has started using compression (encryption). Feedback to <pptpclient-devel@lists.sourceforge.net> please. Signed-off-by: Matt Domsch <Matt_Domsch@dell.com> Cc: James Cameron <james.cameron@hp.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Brice Goglin <Brice.Goglin@ens-lyon.org> Acked-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-05Merge branch 'master'Jeff Garzik
2005-10-28Add fs_enet ethernet network driver, for several embedded platforms.Pantelis Antoniou
2005-10-28Merge branch 'master'Jeff Garzik
2005-10-18[PATCH] mipsnet: Virtual ethernet driver for MIPSsim.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> drivers/net/Kconfig | 8 + drivers/net/Makefile | 1 drivers/net/mipsnet.c | 371 ++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/net/mipsnet.h | 127 +++++++++++++++++ 4 files changed, 507 insertions(+) Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-03Merge branch 'upstream-fixes'Jeff Garzik
2005-09-27[NET]: Add Sun Cassini driver.David S. Miller
Written by Adrian Sun (asun@darksunrising.com). Ported to 2.6.x by Tom 'spot' Callaway <tcallawa@redhat.com>. Further cleaned up and integrated by David S. Miller Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-23[netdrvr gianfar] use new phy layerAndy Fleming
Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-14[PATCH] Add rapidio net driverMatt Porter
Adds an "Ethernet" driver which sends Ethernet packets over the standard RapidIO messaging. This depends on the core RIO patch for mailbox/doorbell access. Signed-off-by: Matt Porter <mporter@kernel.crashing.org> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-14Merge /spare/repo/linux-2.6/ Jeff Garzik
2005-09-06[PATCH] net: add driver for the NIC on Cell BladesJens Osterkamp
This patch adds a driver for a new 1000 Mbit ethernet NIC. It is integrated on the south bridge that is used for our Cell Blades. The code gets the MAC address from the Open Firmware device tree, so it won't compile on platforms other than ppc64. This is the first public release, so I don't expect the first version to get merged, but I'd aim for integration within the 2.6.13 time frame. Cc: Utz Bacher <utz.bacher@de.ibm.com> Signed-off-by: Arnd Bergmann <arndb@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-29/spare/repo/netdev-2.6 branch 'chelsio'Jeff Garzik
2005-08-29Merge /spare/repo/linux-2.6/Jeff Garzik
2005-08-29/spare/repo/netdev-2.6 branch 'sis190'Jeff Garzik
2005-08-17[PATCH] sky2: new experimental Marvell Yukon2 driverStephen Hemminger
New driver for the Marvell Yukon2 Gigabit Ethernet chipset. This driver is based on the skge driver, but using the logic from the SysKonnect version of the sk98lin driver. It should support all the Yukon2 chipsets that are available in many current Intel and AMD motherboards. The driver does support ethtool, tx and rx checksum, and tcp segmentation offload. But it has only been tested for a short while and is known to stop receiving under heavy load. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-07-30This patch adds a PHY Abstraction Layer to the Linux Kernel, enablingAndy Fleming
ethernet drivers to remain as ignorant as is reasonable of the connected PHY's design and operation details. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-07-30[PATCH] sis190: resurrectionFrancois Romieu
Raise the sis190 driver from the dead The driver handles the integrated network device found on SiS 965L chipset. It follows the classical (non-napi) interrupt-driven model and provides minimal ethtool support. The code comes from a heavy cleanup/rewrite of the original code which was removed from the kernel on 14/04/2004. Since the r8169 driver does not work too bad and there will probably be (at least) a few months of improvements/testing/fixing, I made the code as close as possible to the r8169 one. Pascal Chapperon <pascal.chapperon@wanadoo.fr> deserves some special credit for testing and bug-catching. Many thanks to Lars Vahlenberg as well. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-06-22Merge /spare/repo/linux-2.6/Jeff Garzik
2005-06-04Automatic merge of /spare/repo/netdev-2.6 branch skge
2005-06-04Automatic merge of /spare/repo/netdev-2.6 branch remove-drivers
2005-06-04Automatic merge of /spare/repo/netdev-2.6 branch dm9000
2005-05-26[BNX2]: New Broadcom gigabit network driver.Michael Chan
A new driver bnx2 for Broadcom bcm5706 is available. The patch also includes new 1000BASE-X advertisement bit definitions in mii.h Thanks to David Miller and Jeff Garzik for reviewing and their valuable feedback. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-15[PATCH] drivers/net/wireless enabled by wrong optionAl Viro
NET_WIRELESS is only a subset of the stuff in drivers/net/wireless; NET_RADIO is what covers all of them. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk>
2005-05-15[PATCH] A new 10GB Ethernet Driver by Chelsio CommunicationsChristoph Lameter
A Linux driver for the Chelsio 10Gb Ethernet Network Controller by Chelsio (http://www.chelsio.com). This driver supports the Chelsio N210 NIC and is backward compatible with the Chelsio N110 model 10Gb NICs. It supports AMD64, EM64T and x86 systems. Signed-off-by: Tina Yang <tinay@chelsio.com> Signed-off-by: Scott Bardone <sbardone@chelsio.com> Signed-off-by: Christoph Lameter <christoph@lameter.com> Adrian said: - my3126.c is unused (because t1_my3126_ops isn't used anywhere) - what are the EXTRA_CFLAGS in drivers/net/chelsio/Makefile for? - $(cxgb-y) in drivers/net/chelsio/Makefile seems to be unneeded - completely unused global functions: - espi.c: t1_espi_get_intr_counts - sge.c: t1_sge_get_intr_counts - the following functions can be made static: - sge.c: t1_espi_workaround - sge.c: t1_sge_tx - subr.c: __t1_tpi_read - subr.c: __t1_tpi_write - subr.c: t1_wait_op_done shemminger said: The performance recommendations in cxgb.txt are common to all fast devices, and should be in one file rather than just for this device. I would rather see ip-sysctl.txt updated or a new file on tuning recommendations started. Some of them have consequences that aren't documented well. For example, turning off TCP timestamps risks data corruption from sequence wrap. A new driver shouldn't need so may #ifdef's unless you want to putit on older vendor versions of 2.4 Some accessor and wrapper functions like: t1_pci_read_config_4 adapter_name t1_malloc are just annoying noise. Why have useless dead code like: /* Interrupt handler */ +static int pm3393_interrupt_handler(struct cmac *cmac) +{ + u32 master_intr_status; +/* + 1. Read master interrupt register. + 2. Read BLOCK's interrupt status registers. + 3. Handle BLOCK interrupts. +*/ Jeff said: step 1: kill all the OS wrappers. And do you really need hooks for multiple MACs, when only one MAC is really supported? Typically these hooks are at a higher level anyway -- struct net_device. From: Christoph Lameter <christoph@lameter Driver modified as suggested by Pekka Enberg, Stephen Hemminger and Andrian Bunk. Reduces the size of the driver to ~260k. - clean up tabs - removed my3126.c - removed 85% of suni1x10gexp_regs.h - removed 80% of regs.h - removed various calls, renamed variables/functions. - removed system specific and other wrappers (usleep, msleep) - removed dead code - dropped redundant casts in osdep.h - dropped redundant check of kfree - dropped weird code (MODVERSIONS stuff) - reduced number of #ifdefs - use kcalloc now instead of kmalloc - Add information about known issues with the driver - Add information about authors Signed-off-by: Scott Bardone <sbardone@chelsio.com> Signed-off-by: Christoph Lameter <christoph@lameter.com> Signed-off-by: Andrew Morton <akpm@osdl.org> diff -puN /dev/null Documentation/networking/cxgb.txt
2005-05-15[PATCH] DM9000 network driverSascha Hauer
This patch adds support for the davicom dm9000 network driver. The dm9000 is found on some embedded arm boards such as the pimx1 or the scb9328. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@osdl.org> diff -puN /dev/null drivers/net/dm9000.c
2005-05-12 [PATCH] remove two obsolete net driversAdrian Bunk
The options FMV18X and SK_G16 do depend on the non-available CONFIG_OBSOLETE even in kernel 2.4 - IOW, the last time it was able to select them was in kernel 2.2 (or even before). Since it seems noone misses these drivers, this patch removes them. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-05-12[netdrvr] new driver skge, for SysKonnect cardsStephen Hemminger
