path: root/drivers/net/8139cp.c
2006-09-24Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (217 commits) net/ieee80211: fix more crypto-related build breakage [PATCH] Spidernet: add ethtool -S (show statistics) [NET] GT96100: Delete bitrotting ethernet driver [PATCH] mv643xx_eth: restrict to 32-bit PPC_MULTIPLATFORM [PATCH] Cirrus Logic ep93xx ethernet driver r8169: the MMIO region of the 8167 stands behin BAR#1 e1000, ixgb: Remove pointless wrappers [PATCH] Remove powerpc specific parts of 3c509 driver [PATCH] s2io: Switch to pci_get_device [PATCH] gt96100: move to pci_get_device API [PATCH] ehea: bugfix for register access functions [PATCH] e1000 disable device on PCI error drivers/net/phy/fixed: #if 0 some incomplete code drivers/net: const-ify ethtool_ops declarations [PATCH] ethtool: allow const ethtool_ops [PATCH] sky2: big endian [PATCH] sky2: fiber support [PATCH] sky2: tx pause bug fix drivers/net: Trim trailing whitespace [PATCH] ehea: IBM eHEA Ethernet Device Driver ... Manually resolved conflicts in drivers/net/ixgb/ixgb_main.c and drivers/net/sky2.c related to CHECKSUM_HW/CHECKSUM_PARTIAL changes by commit 84fa7933a33f806bbbaae6775e87459b1ec584c0 that just happened to be next to unrelated changes in this update.
2006-09-22[NET]: Replace CHECKSUM_HW by CHECKSUM_PARTIAL/CHECKSUM_COMPLETEPatrick McHardy
Replace CHECKSUM_HW by CHECKSUM_PARTIAL (for outgoing packets, whose checksum still needs to be completed) and CHECKSUM_COMPLETE (for incoming packets, device supplied full checksum). Patch originally from Herbert Xu, updated by myself for 2.6.18-rc3. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-13drivers/net: const-ify ethtool_ops declarationsJeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-12Merge tag '8139cp-20060912-00' of ↵Jeff Garzik
git://electric-eye.fr.zoreil.com/home/romieu/linux-2.6 into tmp
2006-09-128139cp: ring_info removal for the transmit pathFrancois Romieu
As long as the descriptor fits on a single cacheline, the change should be almost free. Now ring_info is not used at all. Remove it. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2006-09-12Merge branch 'tmp' into upstreamJeff Garzik
2006-09-12[PATCH] Remove more unnecessary driver printk'sAndy Gospodarek
As I promised last week, here is the first pass at removing all unnecessary printk's that exist in network device drivers currently in promiscuous mode. The duplicate messages are not needed so they have been removed. Some of these drivers are quite old and might not need an update, but I did them all anyway. I am currently auditing the remaining conditional printk's and will send out a patch for those soon. Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-318139cp: use PCI_DEVICE() to shorten the PCI device tableFrancois Romieu
2006-08-318139cp: pci_get_drvdata(pdev) can not be NULL in suspend handlerFrançois Romieu
1) pci_set_drvdata() is used in cp_{init/remove}_one to initialize/reset driver_data to the relevant value (resp. net_device * and NULL). 2) each of the 3 relevant functions is issued under (device *)->sem: 2.1) pci_unregister_driver -> driver_unregister -> bus_remove_driver -> driver_detach (takes (device *)->sem) -> __device_release_driver(dev) -> dev->bus-remove(dev) (== pci_device_remove) -> drv->remove(pdev) (== cp_remove_one) [...] pci_dev->driver = NULL; 2.2) pci_register_driver -> __pci_register_driver -> driver_register -> bus_add_driver -> driver_attach -> __driver_attach (takes (device *)->sem) -> driver_probe_device(drv, dev) -> dev->bus->probe(dev) (== pci_device_probe) -> _pci_device_probe(drv, pci_dev) -> pci_call_probe(drv, pci_dev, id) -> drv->probe(dev, id) (== cp_init_one) [...] pci_dev->driver = drv; 2.3) suspend_device (takes (device *)->sem) -> dev->bus->suspend(dev) (== pci_device_suspend) checking for drv = pci_dev->driver != NULL [...] -> drv->suspend(pci_dev, state) (== cp_suspend) dev->sem and the state of pci_dev->driver provide the expected result. St Mary's day was a bit rainy here. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2006-08-318139cp: removal of useless BUG_ON() checkFrancois Romieu
netdev_priv() will provide a nice oops a few lines before the BUG_ON() check. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2006-08-318139cp: sync the device private data with its r8169 counterpartFrancois Romieu
struct cp_private is reorganized to be more easily compared between the r8169 and the 8139cp drivers. The alignment should not be impacted. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2006-08-318139cp: ring_info removal for the receive pathFrancois Romieu
The ring_info.len field is not used at all. cp_private.rx_skb is turned into an array of sk_buff *. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2006-08-318139cp: remove gratuitous indirectionFrancois Romieu
dev is an argument of the current function. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2006-08-318139cp: trim ring_infoFrancois Romieu
Fat removal: the mapping address is available from the Rx/Tx descriptors. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2006-08-19drivers/net: Remove deprecated use of pci_module_init()Jeff Garzik
From: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-12[PATCH] 8139cp.c printk fixAndrew Morton
drivers/net/8139cp.c: In function 'cp_init_one': drivers/net/8139cp.c:1919: warning: format '%lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t' drivers/net/8139cp.c:1919: warning: format '%lx' expects type 'long unsigned int', but argument 5 has type 'resource_size_t' Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-05[netdrvr] use dev_xxx() printk helpers, rather than dev_printk(KERN_xxx, ...Jeff Garzik
Suggested by Jiri Slaby. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-05[netdrvr] Use dev_printk() when ethernet interface isn't availableJeff Garzik
For messages prior to register_netdev(), prefer dev_printk() because that prints out both our driver name and our [PCI | whatever] bus id. Updates: 8139{cp,too}, b44, bnx2, cassini, {eepro,epic}100, fealnx, hamachi, ne2k-pci, ns83820, pci-skeleton, r8169. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-02[PATCH] irq-flags: drivers/net: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] 64bit Resource: convert a few remaining drivers to use ↵Greg Kroah-Hartman
resource_size_t where needed Based on a patch series originally from Vivek Goyal <vgoyal@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-27[PATCH] 64bit resource: fix up printks for resources in networks driversGreg Kroah-Hartman
This is needed if we wish to change the size of the resource structures. Based on an original patch from Vivek Goyal <vgoyal@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-23[NET]: Merge TSO/UFO fields in sk_buffHerbert Xu
Having separate fields in sk_buff for TSO/UFO (tso_size/ufo_size) is not going to scale if we add any more segmentation methods (e.g., DCCP). So let's merge them. They were used to tell the protocol of a packet. This function has been subsumed by the new gso_type field. This is essentially a set of netdev feature bits (shifted by 16 bits) that are required to process a specific skb. As such it's easy to tell whether a given device can process a GSO skb: you just have to and the gso_type field and the netdev's features field. I've made gso_type a conjunction. The idea is that you have a base type (e.g., SKB_GSO_TCPV4) that can be modified further to support new features. For example, if we add a hardware TSO type that supports ECN, they would declare NETIF_F_TSO | NETIF_F_TSO_ECN. All TSO packets with CWR set would have a gso_type of SKB_GSO_TCPV4 | SKB_GSO_TCPV4_ECN while all other TSO packets would be SKB_GSO_TCPV4. This means that only the CWR packets need to be emulated in software. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-22[PATCH] 8139cp: add ethtool eeprom supportPhilip Craig
Implement the ethtool eeprom operations for the 8139cp driver. Tested on x86 and big-endian ARM. Signed-off-by: Philip Craig <philipc@snapgear.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-06-22[PATCH] 8139cp: fix eeprom read command lengthPhilip Craig
The read command for the 93C46/93C56 EEPROMS should be 3 bits plus the address. This doesn't appear to affect the operation of the read command, but similar errors for write commands do cause failures. Signed-off-by: Philip Craig <philipc@snapgear.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-05-26[netdrvr] trim trailing whitespace: 8139*.c, epic100, forcedeth, tulip/*Jeff Garzik
2006-04-02BUG_ON() Conversion in drivers/net/Eric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-03Massive net driver const-ification.Arjan van de Ven
2006-02-278139cp: fix broken suspend/resumeFrancois Romieu
- check that the device is up before it is enabled again; - the descriptor ring indexes must be set to zero before cp_init_hw() is issued. Add a nice comment to remember that skb allocation failure is still not handled. Fixes http://bugzilla.kernel.org/show_bug.cgi?id=5681 Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2005-09-21Merge /spare/repo/linux-2.6/Jeff Garzik
2005-09-16[PATCH] 8139cp: allocate statistics space only when neededStephen Hemminger
Don't crash if ethtool statistics are requested and device is down. Fix is to allocate pci space for statistics only when needed. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-14[PATCH] drivers/net: fix-up schedule_timeout() usageNishanth Aravamudan
Use schedule_timeout_interruptible() instead of set_current_state()/schedule_timeout() to reduce kernel size. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-14[PATCH] 8139cp: support ETHTOOL_GPERMADDRJohn W. Linville
Add support for ETHTOOL_GPERMADDR to 8139cp. Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-18[PATCH] 8139cp - redetect link after suspendPierre Ossman
After suspend the driver needs to retest link status in case the cable has been inserted or removed during the suspend. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-06-28[NET]: Remove gratuitous use of skb->tail in network drivers.David S. Miller
Many drivers use skb->tail unnecessarily. In these situations, the code roughly looks like: dev = dev_alloc_skb(...); [optional] skb_reserve(skb, ...); ... skb->tail ... But even if the skb_reserve() happens, skb->data equals skb->tail. So it doesn't make any sense to use anything other than skb->data in these cases. Another case was the s2io.c driver directly mucking with the skb->data and skb->tail pointers. It really just wanted to do an skb_reserve(), so that's what the code was changed to do instead. Another reason I'm making this change as it allows some SKB cleanups I have planned simpler to merge. In those cleanups, skb->head, skb->tail, and skb->end pointers are removed, and replaced with skb->head_room and skb->tail_room integers. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Jeff Garzik <jgarzik@pobox.com>
2005-06-268139cp: safer spin loop for get_statisticsStephen Hemminger
The spin loop in 8139cp is limited to 100 iterations when pulling hardware stats. There is no allowance for processor speed so on a fast machine, the stats may not be available that fast. Also, if the board doesn't return soon enough make sure turn the address back off to prevent later updates when memory has gone away.
2005-06-26Merge upstream (approx. 2.6.12-git8) into 'janitor' branch of netdev-2.6.Jeff Garzik
2005-05-12 [PATCH] drivers/net/8139cp: Use the DMA_{64, 32}BIT_MASK constantsTobias Klauser
The previous patch did not compile cleanly on all architectures so here's a fixed one. Use the DMA_{64,32}BIT_MASK constants from dma-mapping.h when calling pci_set_dma_mask() or pci_set_consistent_dma_mask() Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-05-12[PATCH] 8139cp net driver: add MODULE_VERSION
2005-05-12 [PATCH] 8139cp - add netpoll supportSteffen Klassert
Patch adds netpoll support to the 8139cp driver. The patch needs some tests because I have no NIC of this type for testing. Applies against linux-2.6.9-rc2-mm3 Signed-off-by: Steffen Klassert <klassert@mathematik.tu-chemnitz.de>
2005-05-12 [PATCH] 8139cp - module_paramStephen Hemminger
Not sure if I sent this already... Convert 8139cp to use new module_param() not old MODULE_PARM Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
2005-05-12 [PATCH] 8139cp: SG support fixesFrancois Romieu
- suspicious length in pci_unmap_single; - wait for the last frag before freeing the relevant skb; - no need to crash when facing some unexpected csum combination.
2005-05-12[netdrvr 8139cp] TSO supportJeff Garzik
2005-04-16[PATCH] u32 vs. pm_message_t fixes for drivers/netPavel Machek
This fixes remaining u32s in drivers/ net. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
