There are two spellings in use for 'freeze' + 'able' - 'freezable' and
'freezeable'. The former is the more prominent one. The latter is
mostly used by workqueue and in a few other odd places. Unify the
spelling to 'freezable'.
Reported-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
Cc: Alex Dubov <oakad@yahoo.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
It turns out that pci core now handles these, so this code is redundant
and can even cause bugs
Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com>
Remove unnesessary casts from void*.
Signed-off-by: Kulikov Vasiliy <segooon@gmail.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
This turns out to be the reason for DMA timeouts on resume,
if card was inserted while system was suspended
* Don't call complete on dma completion
* do a INIT_COMPLETE before using it each time
* Report DMA read error via ecc 'correct'
I finally managed to make my system do suspend to ram propertly, and I see that
if card was inserted during suspend (while system was off), I get dma timeouts
on resume. Simple card reinsert solves the issue.
This patch solves a crash that would happen otherwise
Otherwise, if it fires right away, it might access
uninitialized spinlock
Implicit slab.h inclusion via percpu.h is about to go away. Make sure
gfp.h or slab.h is included as necessary.
2GB xD card, and 4MB SmartMedia ROM card share same ID, so to make both work
split xD and smartmedia ID tables.
Hardware driver must be able to know which type it handles (and probably just one).
... instead of comparing with DMA_ERROR_CODE, which will only work on
powerpc/sparc/x86.
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
r852 fails to build when CONFIG_PCI is not enabled since it uses
pci_*() calls and is a PCI driver, so it should depend on PCI
to prevent build errors.
It should also #include <linux/pci.h>.
drivers/mtd/nand/r852.c:1053: error: implicit declaration of function 'pci_prepare_to_sleep'
drivers/mtd/nand/r852.c:1062: error: implicit declaration of function 'pci_back_from_sleep'
Cc: Maxim Levitsky <maximlevitsky@gmail.com>
and include delay.h for msleep().
Fix r852 build for the case of CONFIG_PM=n.
drivers/mtd/nand/r852.c:1039: error: implicit declaration of function 'pci_prepare_to_sleep'
drivers/mtd/nand/r852.c:1048: error: implicit declaration of function 'pci_back_from_sleep'
This patch leaves r852_pm_ops untouched.
Acked-by: Maxim Levitsky <maximlevitsky@gmail.com>
inserted/removed.
First don't enable card detection logic to early. Second be very careful with
DMA engine, to be sure it doesn't write to kernel memory driver doesn't own.
The PCI_DEVICE_ID_RICOH_R5C852 was missed in the edited commit, and on
second thought I just open code it.
This fixes compile error.
* Test results of few functions that were declared with __must_check
* Fix bogus gcc warning about uinitialized variable 'ret'
* Remove unused variable from mtdblock_remove_dev
* Don't use deprecated DMA_32BIT_MASK
This adds a driver for Ricoh R5C852 xD card reader.
This reader is a part of larger mulifunction chip
and found at least in R5C832
Driver is complete, but bewere of the fact that some
(probably only type M) xD cards are 'fake' which means that
they have an on board CPU and expose emulated nand command set
These cards don't even store the oob area on the flash,
but generate it on the fly from something else.
Thus they demand to have proper values written in the oob area,
and therefore only useful with SmartMedia FTL.
