This patch removes direct reference of gpmc address from generic nand platform code.
Nand platform code now uses wrapper functions which are implemented in gpmc module.
Signed-off-by: Sukumar Ghorai <s-ghorai@ti.com>
few functions added in gpmc module and to be used by other drivers like NAND.
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
drivers/mtd/mtdcore.c
Pull in the bdi fixes and ARM platform changes that other outstanding
patches depend on.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
drivers/mtd/nand/sh_flctl.c
Maxim's patch to initialise sysfs attributes depends on the patch which
actually adds sysfs_attr_init().
There is a bug in nand prefetch read routine, which comes into effect
only if nand device is a 16-bit device (as we have in zoom boards).
This bug is effective only with below combination of conditions:
1. nand deivce, in use, is a 16 bit device
2. nand driver supports 'subpage' read
3. SW ECC is in use
This was not seen old kernel (ex: .23), because when, in early days,
we tested this (nand prefetch read in LDP boards) there was no
'subpage read' support.
Later when we had subpage read in (.27) kernel, we had hw ecc enabled
always in our internal tree. So, we missed this bug.
This patch fixes the issue.
Signed-off-by: Vimal Singh <vimalsingh@ti.com>
Removing OMAP NAND driver, when loaded as a module, gives error and
does not get success. This fixes this and makes driver loadable and
removable run time.
Fixing below warning in compilation:
drivers/mtd/nand/omap2.c: In function 'omap_write_buf_dma_pref':
drivers/mtd/nand/omap2.c:508: warning: passing argument 2 of
'omap_nand_dma_transfer' discards qualifiers from pointer target type
Introducing 'gpmc-nand.c' for GPMC specific NAND init.
For example: GPMC timing parameters and all.
This patch also migrates gpmc related calls from 'nand/omap2.c'
to 'gpmc-nand.c'.
Move the remaining headers under plat-omap/include/mach
to plat-omap/include/plat. Also search and replace the
files using these headers to include using the right path.
This was done with:
#!/bin/bash
mach_dir_old="arch/arm/plat-omap/include/mach"
plat_dir_new="arch/arm/plat-omap/include/plat"
headers=$(cd $mach_dir_old && ls *.h)
omap_dirs="arch/arm/*omap*/ \
drivers/video/omap \
sound/soc/omap"
other_files="drivers/leds/leds-ams-delta.c \
drivers/mfd/menelaus.c \
drivers/mfd/twl4030-core.c \
drivers/mtd/nand/ams-delta.c"
for header in $headers; do
old="#include <mach\/$header"
new="#include <plat\/$header"
for dir in $omap_dirs; do
find $dir -type f -name \*.[chS] | \
xargs sed -i "s/$old/$new/"
done
find drivers/ -type f -name \*omap*.[chS] | \
for file in $other_files; do
sed -i "s/$old/$new/" $file
done
done
for header in $(ls $mach_dir_old/*.h); do
git mv $header $plat_dir_new/
done
This patch adds DMA mode support for nand prefetch/post-write engine.
This patch adds prefetch support to access nand flash in mpu mode.
This patch also adds 8-bit nand support (omap_read/write_buf8).
Prefetch can be used for both 8- and 16-bit devices.
We need to include jiffies.h manually in some cases, and the status
returned from omap_wait() was broken in two separate ways.
Also add cond_resched() to the loop.
This driver is present in the OMAP tree, now pushing it to MTD.
Original author(s):
Jian Zhang <jzhang@ti.com>
Cc: Jian Zhang <jzhang@ti.com>
Cc: Artem Bityutskiy <dedekind@infradead.org>
