path: root/drivers/mtd/nand/autcpu12.c
2011-09-11mtd: nand: rename NAND_USE_FLASH_BBTBrian Norris
Recall the recently added prefix requirements: * "NAND_" for flags in nand.h, used in nand_chip.options * "NAND_BBT_" for flags in bbm.h, used in nand_chip.bbt_options or in nand_bbt_descr.options Thus, I am changing NAND_USE_FLASH_BBT to NAND_BBT_USE_FLASH. Again, this flag is found in bbm.h and so should NOT be used in the "nand_chip.options" field. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-09-11mtd: nand: consolidate redundant flash-based BBT flagsBrian Norris
This patch works with the following three flags from two headers (nand.h and bbm.h): (1) NAND_USE_FLASH_BBT (nand.h) (2) NAND_USE_FLASH_BBT_NO_OOB (nand.h) (3) NAND_BBT_NO_OOB (bbm.h) These flags are all related and interdependent, yet they were in different headers. Flag (2) is simply the combination of (1) and (3) and can be eliminated. This patch accomplishes the following: * eliminate NAND_USE_FLASH_BBT_NO_OOB (i.e., flag (2)) * move NAND_USE_FLASH_BBT (i.e., flag (1)) to bbm.h It's important to note that because (1) and (3) are now both found in bbm.h, they should NOT be used in the "nand_chip.options" field. I removed a small section from the mtdnand DocBook because it referes to NAND_USE_FLASH_BBT in nand.h, which has been moved to bbm.h. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-05-25mtd: convert remaining users to mtd_device_register()Jamie Iles
The older add_mtd_device()/add_mtd_partitions() and their removal counterparts will soon be gone. Replace uses with mtd_device_register() and mtd_device_unregister(). Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-04MTD/JFFS2: remove CVS keywordsAdrian Bunk
Once upon a time, the MTD repository was using CVS. This patch therefore removes all usages of the no longer updated CVS keywords from the MTD code. This also includes code that printed them to the user. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-02-03drivers/mtd/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-06-01potential parse error in ifdefYoann Padioleau
I have made a tool to parse the kernel that does not pre-process the source. That means that my parser tries to parse all the code, including code in the #else branch or code that is not often compiled because the driver is not very used (or not used at all). So, my parser sometimes reports parse error not originally detected by gcc. Here is my (first) patch. [akpm@linux-foundation.org: fix amd8111e.c] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Acked-by: Matthew Wilcox <matthew@wil.cx> Acked-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: David Woodhouse <dwmw2@infradead.org> Acked-by: Jeff Garzik <jeff@garzik.org> Acked-by: James Bottomley <James.Bottomley@steeleye.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-05-23[MTD] Refactor NAND hwcontrol to cmd_ctrlThomas Gleixner
The hwcontrol function enforced a step by step state machine for any kind of hardware chip access. Let the hardware driver know which control bits are set and inform it about a change of the control lines. Let the hardware driver write out the command and address bytes directly. This gives a peformance advantage for address bus controlled chips and simplifies the quirks in the hardware drivers. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-23[MTD] NAND modularize ECCThomas Gleixner
First step of modularizing ECC support. - Move ECC related functionality into a seperate embedded data structure - Get rid of the hardware dependend constants to simplify new ECC models Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-16[MTD NAND] Make various initfuncs static, remove #ifdef MODULE from exitfuncsDavid Woodhouse
We all inherited the same error from the original NAND board driver which got copied and changed. Fix them all at once... Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-14[MTD] Fix module refcounting in NAND board drivers.David Woodhouse
The _board_ driver needs to be mtd->owner, and it in turn pins the nand.ko module. Fix them all to actually do that, and fix nand.ko not to overwrite it -- and also to check that the caller sets it, if the caller is a module. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-13[MTD NAND] Indent all of drivers/mtd/nand/*.c.David Woodhouse
It was just too painful to deal with. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[MTD] NAND: Clean up trailing white spacesThomas Gleixner
