path: root/drivers/mtd/mtdpart.c
2009-04-06[MTD] mtdpart: Make ecc_stats more realistic.Yauhen Kharuzhy
In the existing implementation, ecc_stats fields are incremented only by one, regardless of master mtd errors number. For example, if there are N errors were corrected by ECC, partition ecc_stats.corrected will be incremented by one. This commit changes simple increment to sum of old value and parent mtd error count. Signed-off-by: Yauhen Kharuzhy <jekhor@gmail.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-04-04[MTD] driver model updatesDavid Brownell
Update driver model support in the MTD framework, so it fits better into the current udev-based hotplug framework: - Each mtd_info now has a device node. MTD drivers should set the dev.parent field to point to the physical device, before setting up partitions or otherwise declaring MTDs. - Those device nodes always map to /sys/class/mtdX device nodes, which no longer depend on MTD_CHARDEV. - Those mtdX sysfs nodes have a "starter set" of attributes; it's not yet sufficient to replace /proc/mtd. - Enabling MTD_CHARDEV provides /sys/class/mtdXro/ nodes and the /sys/class/mtd*/dev attributes (for udev, mdev, etc). - Include a MODULE_ALIAS_CHARDEV_MAJOR macro. It'll work with udev creating the /dev/mtd* nodes, not just a static rootfs. So the sysfs structure is pretty much what you'd expect, except that readonly chardev nodes are a bit quirky. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-03-24NOMMU: Present backing device capabilities for MTD chardevsDavid Howells
Present backing device capabilities for MTD character device files to allow NOMMU mmap to do direct mapping where possible. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Bernd Schmidt <bernd.schmidt@analog.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-12-10[MTD] update internal API to support 64-bit device sizeAdrian Hunter
MTD internal API presently uses 32-bit values to represent device size. This patch updates them to 64-bits but leaves the external API unchanged. Extending the external API is a separate issue for several reasons. First, no one needs it at the moment. Secondly, whether the implementation is done with IOCTLs, sysfs or both is still debated. Thirdly external API changes require the internal API to be accepted first. Note that although the MTD API will be able to support 64-bit device sizes, existing drivers do not and are not required to do so, although NAND base has been updated. In general, changing from 32-bit to 64-bit values cause little or no changes to the majority of the code with the following exceptions: - printk message formats - division and modulus of 64-bit values - NAND base support - 32-bit local variables used by mtdpart and mtdconcat - naughtily assuming one structure maps to another in MEMERASE ioctl Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-10-20Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (69 commits) Revert "[MTD] m25p80.c code cleanup" [MTD] [NAND] GPIO driver depends on ARM... for now. [MTD] [NAND] sh_flctl: fix compile error [MTD] [NOR] AT49BV6416 has swapped erase regions [MTD] [NAND] GPIO NAND flash driver [MTD] cmdlineparts documentation change - explain where mtd-id comes from [MTD] cfi_cmdset_0002.c: Add Macronix CFI V1.0 TopBottom detection [MTD] [NAND] Fix compilation warnings in drivers/mtd/nand/cs553x_nand.c [JFFS2] Write buffer offset adjustment for NOR-ECC (Sibley) flash [MTD] mtdoops: Fix a bug where block may not be erased [MTD] mtdoops: Add a magic number to logged kernel oops [MTD] mtdoops: Fix an off by one error [JFFS2] Correct parameter names of jffs2_compress() in comments [MTD] [NAND] sh_flctl: add support for Renesas SuperH FLCTL [MTD] [NAND] Bug on atmel_nand HW ECC : OOB info not correctly written [MTD] [MAPS] Remove unused variable after ROM API cleanup. [MTD] m25p80.c extended jedec support (v2) [MTD] remove unused mtd parameter in of_mtd_parse_partitions() [MTD] [NAND] remove dead Kconfig associated with !CONFIG_PPC_MERGE [MTD] [NAND] driver extension to support NAND on TQM85xx modules ...
2008-10-17remove CONFIG_KMOD from driversJohannes Berg
Straight forward conversions to CONFIG_MODULE; many drivers include <linux/kmod.h> conditionally and then don't have any other conditional code so remove it from those. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: video4linux-list@redhat.com Cc: David Woodhouse <dwmw2@infradead.org> Cc: linux-ppp@vger.kernel.org Cc: dm-devel@redhat.com Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-08-12[MTD] Define and use MTD_FAIL_ADDR_UNKNOWN instead of 0xffffffffAdrian Hunter
Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-25[MTD][MTDPART] Fix a division by zero bugAtsushi Nemoto
When detecting a partition beyond the end of the device, skip most of the initialisation, in particular those bits causing a division by zero. Signed-off-by: Jörn Engel <joern@logfs.org> Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-25[MTD][MTDPART] Cleanup and document the erase region handlingAtsushi Nemoto
Mostly simplifying the loops. Now everything fits into 80 columns, is easier to read and the finer details have extra comments. Signed-off-by: Jörn Engel <joern@logfs.org> Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-25[MTD][MTDPART] Handle most checkpatch findingsAtsushi Nemoto
Remaining are 12 warnings about long lines and 1 about braces that could be argued about. Signed-off-by: Jörn Engel <joern@logfs.org> Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-25[MTD][MTDPART] Seperate main loop from per-partition code in add_mtd_partitionAtsushi Nemoto
add_mtd_partition was a 150+ line monster consisting mostly of a single loop. Seperate the loop from most of the body. Now it should be obvious which variables are carried around from iteration to iteration. Signed-off-by: Jörn Engel <joern@logfs.org> Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-06-04[MTD] Use list_for_each_entry[_safe] where appropriate.Chris Malley
Janitorial work to remove temporary pointers and make some functions a bit more readable. Signed-off-by: Chris Malley <mail@chrismalley.co.uk> Reviewed-By: Jörn Engel <joern@logfs.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-06-04MTD/JFFS2: remove CVS keywordsAdrian Bunk
Once upon a time, the MTD repository was using CVS. This patch therefore removes all usages of the no longer updated CVS keywords from the MTD code. This also includes code that printed them to the user. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-05-01[MTD][NOR] Add physical address to point() methodJared Hulbert
Adding the ability to get a physical address from point() in addition to virtual address. This physical address is required for XIP of userspace code from flash. Signed-off-by: Jared Hulbert <jaredeh@gmail.com> Reviewed-by: Jörn Engel <joern@logfs.org> Acked-by: Nicolas Pitre <nico@cam.org> Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-02-07[MTD] Add mtd panic_write function pointerRichard Purdie
MTDs are well suited for logging critical data and the mtdoops driver allows kernel panics/oops to be written to flash in a blackbox flight recorder fashion allowing better debugging and analysis of crashes. Any kernel oops in user context can be easily handled since the kernel continues as normal and any queued mtd writes are scheduled. Any kernel oops in interrupt context results in a panic and the delayed writes will not be scheduled however. The existing mtd->write function cannot be called in interrupt context so these messages can never be written to flash. This patch adds a panic_write function pointer that drivers can optionally implement which can be called in interrupt context. It is only intended to be called when its known the kernel is about to panic and we need to write to succeed. Since the kernel is not going to be running for much longer, this function can break locks and delay to ensure the write succeeds (but not sleep). Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-08-03[MTD] Makefile fix for mtdsuperSatyam Sharma
We want drivers/mtd/{mtdcore, mtdsuper, mtdpart}.c to be built and linked into the same mtd.ko module. Fix the Makefile to ensure this, and remove duplicate MODULE_ declarations in mtdpart.c, as mtdcore.c already has them. Signed-off-by: Satyam Sharma <satyam@infradead.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-05-09[MTD] Delete allegedly obsolete "bank_size" field of mtd_info.Robert P. J. Day
Delete the allegedly obsolete "bank_size" member of struct mtd_info. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-03-08[MTD] Correct partition failed erase addressAdrian Hunter
If an erase operation fails, the address at which the failure occurred is returned by the driver. The MTD partition must adjust this address (by subtracting the partition offset) before returning to the caller. This was not happening, which caused JFFS2 to mark the wrong block bad! Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-03-08[MTD] [NAND] make oobavail publicVitaly Wool
During the MTD rework the oobavail parameter of mtd_info structure has become private. This is not quite correct in terms of integrity and logic. If we have means to write to OOB area, then we'd like to know upfront how many bytes out of OOB are spare per page to be able to adapt to specific cases. The patch inlined adds the public oobavail parameter. Signed-off-by: Vitaly Wool <vwool@ru.mvista.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-02-09[MTD] remove unused ecctype,eccsize fields from struct mtd_infoArtem Bityutskiy
Remove unused and broken mtd->ecctype and mtd->eccsize fields from struct mtd_info. Do not remove them from userspace API data structures (don't want to breake userspace) but mark them as obsolete by a comment. Any userspace program which uses them should be half-broken anyway, so this is more about saving data structure size. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-11-29[MTD] NAND: add subpage write supportThomas Gleixner
Many SLC NANDs support up to 4 writes at one NAND page. Add support of this feature. Signed-off-by: Artem Bityutskiy <dedekind@infradead.org>
2006-11-28[MTD] replace kmalloc+memset with kzallocBurman Yan
Signed-off-by: Yan Burman <yan_952@hotmail.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-11-28[MTD] [NAND] remove len/ooblen confusion.Vitaly Wool
As was discussed between Ricard Wanderlöf, David Woodhouse, Artem Bityutskiy and me, the current API for reading/writing OOB is confusing. The thing that introduces confusion is the need to specify ops.len together with ops.ooblen for reads/writes that concern only OOB not data area. So, ops.len is overloaded: when ops.datbuf != NULL it serves to specify the length of the data read, and when ops.datbuf == NULL, it serves to specify the full OOB read length. The patch inlined below is the slightly updated version of the previous patch serving the same purpose, but with the new Artem's comments taken into account. Artem, BTW, thanks a lot for your valuable input! Signed-off-by: Vitaly Wool <vwool@ru.mvista.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-30[MTD] NAND Expose the new raw mode function and status info to userspaceThomas Gleixner
The raw read/write access to NAND (without ECC) has been changed in the NAND rework. Expose the new way - setting the file mode via ioctl - to userspace. Also allow to read out the ecc statistics information so userspace tools can see that bitflips happened and whether errors where correctable or not. Also expose the number of bad blocks for the partition, so nandwrite can check if the data fits into the parition before writing to it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-29[MTD] Rework the out of band handling completelyThomas Gleixner
Hopefully the last iteration on this! The handling of out of band data on NAND was accompanied by tons of fruitless discussions and halfarsed patches to make it work for a particular problem. Sufficiently annoyed by I all those "I know it better" mails and the resonable amount of discarded "it solves my problem" patches, I finally decided to go for the big rework. After removing the _ecc variants of mtd read/write functions the solution to satisfy the various requirements was to refactor the read/write _oob functions in mtd. The major change is that read/write_oob now takes a pointer to an operation descriptor structure "struct mtd_oob_ops".instead of having a function with at least seven arguments. read/write_oob which should probably renamed to a more descriptive name, can do the following tasks: - read/write out of band data - read/write data content and out of band data - read/write raw data content and out of band data (ecc disabled) struct mtd_oob_ops has a mode field, which determines the oob handling mode. Aside of the MTD_OOB_RAW mode, which is intended to be especially for diagnostic purposes and some internal functions e.g. bad block table creation, the other two modes are for mtd clients: MTD_OOB_PLACE puts/gets the given oob data exactly to/from the place which is described by the ooboffs and ooblen fields of the mtd_oob_ops strcuture. It's up to the caller to make sure that the byte positions are not used by the ECC placement algorithms. MTD_OOB_AUTO puts/gets the given oob data automaticaly to/from the places in the out of band area which are described by the oobfree tuples in the ecclayout data structre which is associated to the devicee. The decision whether data plus oob or oob only handling is done depends on the setting of the datbuf member of the data structure. When datbuf == NULL then the internal read/write_oob functions are selected, otherwise the read/write data routines are invoked. Tested on a few platforms with all variants. Please be aware of possible regressions for your particular device / application scenario Disclaimer: Any whining will be ignored from those who just contributed "hot air blurb" and never sat down to tackle the underlying problem of the mess in the NAND driver grown over time and the big chunk of work to fix up the existing users. The problem was not the holiness of the existing MTD interfaces. The problems was the lack of time to go for the big overhaul. It's easy to add more mess to the existing one, but it takes alot of effort to go for a real solution. Improvements and bugfixes are welcome! Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-29[MTD] NAND Replace oobinfo by ecclayoutThomas Gleixner
The nand_oobinfo structure is not fitting the newer error correction demands anymore. Replace it by struct nand_ecclayout and fixup the users all over the place. Keep the nand_oobinfo based ioctl for user space compability reasons. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-29[MTD] NAND Consolidate oobinfo handlingThomas Gleixner
The info structure for out of band data was copied into the mtd structure. Make it a pointer and remove the ability to set it from userspace. The position of ecc bytes is defined by the hardware and should not be changed by software. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-23[MTD] Remove read/write _ecc variantsThomas Gleixner
MTD clients are agnostic of FLASH which needs ECC suppport. Remove the functions and fixup the callers. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-23[MTD] Remove readv/readv_eccThomas Gleixner
These functions were never implemented and added only bloat to partition and concat code. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-23[MTD] Remove nand writev supportThomas Gleixner
NAND writev(_ecc) support is not longer necessary. Remove it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-22[MTD] Introduce writesizeJoern Engel
At least two flashes exists that have the concept of a minimum write unit, similar to NAND pages, but no other NAND characteristics. Therefore, rename the minimum write unit to "writesize" for all flashes, including NAND. Signed-off-by: Joern Engel <joern@wh.fh-wedel.de>
2006-05-17[MTD] generic: propagate oobavail to MTD partitionsVitaly Wool
'oobavail' parameter of mtd_info structure is now propagated to the MTD partitions Signed-off-by: Vitaly Wool <vwool@ru.mvista.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-11-07[MTD] core: Clean up trailing white spacesThomas Gleixner
2005-11-06[MTD] mtdpart.c: Allow eraseblock size != power of 2Artem B. Bityutskiy
Don't assume eraseblock size is power of 2. Dataflash can have aligned eraseblock size. From: Peter Menzebach <pm-mtd@mw-itcon.de> Acked-by: Artem B. Bityutskiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[MTD] Support for protection register support on Intel FLASH chipsNicolas Pitre
This enables support for reading, writing and locking so called "Protection Registers" present on some flash chips. A subset of them are pre-programmed at the factory with a unique set of values. The rest is user-programmable. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
