path: root/drivers/mtd/mtdconcat.c
2006-03-26BUG_ON() Conversion in drivers/mtd/Eric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-11-07[MTD] core: Clean up trailing white spacesThomas Gleixner
2005-11-07[MTD] Tidy up Tims include cleanupThomas Gleixner
While we are at it, reorder the includes and remove the silly /* TASK */ comment Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
