path: root/drivers/mtd/mtd_blkdevs.c
2006-03-31[PATCH] sem2mutex: drivers/mtd/Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26BUG_ON() Conversion in drivers/mtd/Eric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-08[PATCH] Add block_device_operations.getgeo block device methodChristoph Hellwig
HDIO_GETGEO is implemented in most block drivers, and all of them have to duplicate the code to copy the structure to userspace, as well as getting the start sector. This patch moves that to common code [1] and adds a ->getgeo method to fill out the raw kernel hd_geometry structure. For many drivers this means ->ioctl can go away now. [1] the s390 block drivers are odd in this respect. xpram sets ->start to 4 always which seems more than odd, and the dasd driver shifts the start offset around, probably because of it's non-standard sector size. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Jens Axboe <axboe@suse.de> Cc: <mike.miller@hp.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo Giarrusso <blaisorblade@yahoo.it> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[MTD] core: Clean up trailing white spacesThomas Gleixner
2005-08-04[MTD] mtd_blkdevs.c: Fix names when many devices/partitions are createdTodd Poynor
mtdblock (and other mtd modules that use the mtd_blkdevs interface between the mtd translation layers and the linux block layer) handles incorrectly more than 10 devices or 26 partitions in the names passed to the generic disk layer. This causes the device file names and other info kept by the generic disk/block layers to have names such as "mtdblock<". Use integer formatting for device numbers; use "aa-az" for partitions 27-52, "ba-bz" for 53-78... Signed-off-by: Todd Poynor <tpoynor@mvista.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-08-04[MTD] mtd_blkdevs.c: Remove DEVFS leftoversTodd Poynor
Remove mtd_blkdevs refs to the no longer functional DEVFS filesystem. Verified mtdblock continues to work fine via udev with these calls removed. Signed-off-by: Todd Poynor <tpoynor@mvista.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
