path: root/drivers/mtd/maps
2010-02-27MIPS: Alchemy: physmap-flash for all devboardsManuel Lauss
Replace the devboard NOR MTD mapping driver with physmap-flash support. Also honor the "swapboot" switch settings wrt. to the layout of the NOR partitions. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Cc: Linux-MIPS <linux-mips@linux-mips.org> Acked-By: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-01-24Merge git://git.infradead.org/~dwmw2/mtd-2.6.33Linus Torvalds
* git://git.infradead.org/~dwmw2/mtd-2.6.33: mtd: tests: fix read, speed and stress tests on NOR flash mtd: Really add ARM pismo support kmsg_dump: Dump on crash_kexec as well
2010-01-13mtd: Really add ARM pismo supportRussell King - ARM Linux
(Commit 7cb777a3d71f9d1f7eb149c7a504d21f24219ae8 (mtd: add ARM pismo support) intended to add this, but seems only to have patched the Makefile without touching Kconfig or providing any code...) The following patch adds support for PISMO modules found on ARM Ltd development platforms. These are MTD modules, and can have a selection of SRAM, flash or DOC devices as described by an on-board I2C EEPROM. We support SRAM and NOR flash devices only by registering appropriate conventional MTD platform devices as children of the 'pismo' device. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-12-17Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: PCMCIA: fix pxa2xx_lubbock modular build error [ARM] Update mach-types [ARM] pxa: fix no reference of cpu_is_pxa25x() in devices.c [ARM] pxa/cm-x300: add PWM backlight support revert "[ARM] pxa/cm-x300: add PWM backlight support" ARM: use flush_kernel_dcache_area() for dmabounce ARM: add size argument to __cpuc_flush_dcache_page ARM: 5848/1: kill flush_ioremap_region() ARM: cache-l2x0: make better use of background cache handling ARM: cache-l2x0: avoid taking spinlock for every iteration [ARM] Kirkwood: Add LaCie Network Space v2 support ARM: dove: fix the mm mmu flags of the pj4 procinfo
2009-12-16Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (90 commits) jffs2: Fix long-standing bug with symlink garbage collection. mtd: OneNAND: Fix test of unsigned in onenand_otp_walk() mtd: cfi_cmdset_0002, fix lock imbalance Revert "mtd: move mxcnd_remove to .exit.text" mtd: m25p80: add support for Macronix MX25L4005A kmsg_dump: fix build for CONFIG_PRINTK=n mtd: nandsim: add support for 4KiB pages mtd: mtdoops: refactor as a kmsg_dumper mtd: mtdoops: make record size configurable mtd: mtdoops: limit the maximum mtd partition size mtd: mtdoops: keep track of used/unused pages in an array mtd: mtdoops: several minor cleanups core: Add kernel message dumper to call on oopses and panics mtd: add ARM pismo support mtd: pxa3xx_nand: Fix PIO data transfer mtd: nand: fix multi-chip suspend problem mtd: add support for switching old SST chips into QRY mode mtd: fix M29W800D dev_id and uaddr mtd: don't use PF_MEMALLOC mtd: Add bad block table overrides to Davinci NAND driver ... Fixed up conflicts (mostly trivial) in drivers/mtd/devices/m25p80.c drivers/mtd/maps/pcmciamtd.c drivers/mtd/nand/pxa3xx_nand.c kernel/printk.c
2009-12-14ARM: 5848/1: kill flush_ioremap_region()Nicolas Pitre
There is not enough users to warrant its existence, and it is actually an obstacle to progress with the new DMA API which cannot cover this case properly. To keep backward compatibility, let's perform the necessary custom cache maintenance locally in the only driver affected. Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-08Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (149 commits) arm: omap: Add omap3_defconfig AM35xx: Defconfig for AM3517 EVM board AM35xx: Add support for AM3517 EVM board omap: 3630sdp: defconfig creation omap: 3630sdp: introduce 3630 sdp board support omap3: Add defconfig for IGEP v2 board omap3: Add minimal IGEP v2 support omap3: Add CompuLab CM-T35 defconfig omap3: Add CompuLab CM-T35 board support omap3: rx51: Add wl1251 wlan driver support omap3: rx51: Add SDRAM init omap1: Add default kernel configuration for Herald omap1: Add board support and LCD for HTC Herald omap: zoom2: update defconfig for LL_DEBUG_NONE omap: zoom3: defconfig creation omap3: zoom: Introduce zoom3 board support omap3: zoom: Drop i2c-1 speed to 2400 omap3: zoom: rename zoom2 name to generic zoom omap3: zoom: split board file for software reuse omap3evm: MIgrate to smsc911x ethernet driver ... Fix trivial conflict (two unrelated config options added next to each other) in arch/arm/mach-omap2/Makefile
2009-12-07Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: kernel/irq/chip.c
2009-12-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: (50 commits) pcmcia: rework the irq_req_t typedef pcmcia: remove deprecated handle_to_dev() macro pcmcia: pcmcia_request_window() doesn't need a pointer to a pointer pcmcia: remove unused "window_t" typedef pcmcia: move some window-related code to pcmcia_ioctl.c pcmcia: Change window_handle_t logic to unsigned long pcmcia: Pass struct pcmcia_socket to pcmcia_get_mem_page() pcmcia: Pass struct pcmcia_device to pcmcia_map_mem_page() pcmcia: Pass struct pcmcia_device to pcmcia_release_window() drivers/pcmcia: remove unnecessary kzalloc pcmcia: correct handling for Zoomed Video registers in topic.h pcmcia: fix printk formats pcmcia: autoload module pcmcia pcmcia/staging: update comedi drivers PCMCIA: stop duplicating pci_irq in soc_pcmcia_socket PCMCIA: ss: allow PCI IRQs > 255 PCMCIA: soc_common: remove 'dev' member from soc_pcmcia_socket PCMCIA: soc_common: constify soc_pcmcia_socket ops member PCMCIA: sa1111: remove duplicated initializers PCMCIA: sa1111: wrap soc_pcmcia_socket to contain sa1111 specific data ...
2009-12-04mtd: Fix comment in KconfigKrzysztof Halasa
IXDP425 and Coyote aren't based on IXP2000 but on IXP425. Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-30mtd: add ARM pismo supportRussell King - ARM Linux
2009-11-30mtd: error return -EIO instead of EIORoel Kluin
Return a negative error value instead of a positive Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-11-30mtd: ixp4xx map: use resource_sizeTobias Klauser
Use the resource_size inline function instead of manually calculating the resource size. This reduces the chance of introducing off-by-one errors. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-11-28pcmcia: pcmcia_request_window() doesn't need a pointer to a pointerDominik Brodowski
pcmcia_request_window() only needs a pointer to struct pcmcia_device, not a pointer to a pointer. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-scsi@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> Acked-by: Karsten Keil <keil@b1-systems.de> (for ISDN) Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-11-28pcmcia: Pass struct pcmcia_device to pcmcia_map_mem_page()Magnus Damm
No logic changes, just pass struct pcmcia_device to pcmcia_map_mem_page() [linux@dominikbrodowski.net: update to 2.6.31] CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-scsi@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> Acked-by: Karsten Keil <keil@b1-systems.de> (for ISDN) Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-11-28pcmcia: Pass struct pcmcia_device to pcmcia_release_window()Magnus Damm
No logic changes, just pass struct pcmcia_device to pcmcia_release_window(). [linux@dominikbrodowski.net: update to 2.6.31] CC: netdev@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-11-22Merge 7xx-iosplit-plat-merge with omap-fixesTony Lindgren
Merge branch '7xx-iosplit-plat-merge' into omap-for-linus
2009-11-20mtd: vmu-flash: Use hweight_longAkinobu Mita
Use hweight_long instead of Brian Kernighan's/Peter Wegner's method Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-11-16ARM: Fix warning in sa1100-flash.cRussell King
drivers/mtd/maps/sa1100-flash.c: In function 'sa1100_probe_subdev': drivers/mtd/maps/sa1100-flash.c:214: warning: format '%d' expects type 'int', but argument 3 has type 'uint64_t' Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-11-09mtd/maps: Fix accidental removal in MakefileAtsushi Nemoto
The commit d79c326 ("gpio-addr-flash: new driver for GPIO assisted flash addressing") removed two lines from the Makefile by accident. Though I'm not sure how this accident happened, this patch reverts the removal. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-09Kconfig: Remove useless and sometimes wrong commentsMichael Roth
Additionally, some excessive newlines removed. Signed-off-by: Michael Roth <mroth@nessie.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-09pcmcia: use dynamic debug infrastructure, deprecate CS_CHECK (misc drivers)Dominik Brodowski
Convert PCMCIA drivers to use the dynamic debug infrastructure, instead of requiring manual settings of PCMCIA_DEBUG. Also, remove all usages of the CS_CHECK macro and replace them with proper Linux style calling and return value checking. The extra error reporting may be dropped, as the PCMCIA core already complains about any (non-driver-author) errors. CC: linux-mtd@lists.infradead.org CC: linux-usb@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-11-08pcmcia: convert pcmciamtd driver to use new CIS helpersDominik Brodowski
Convert the (broken) pcmciamtd driver to use the new CIS helpers. CC: David.Woodhouse@intel.com CC: linux-mtd@lists.infradead.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-11-05Merge git://git.infradead.org/users/dwmw2/mtd-2.6.32Linus Torvalds
* git://git.infradead.org/users/dwmw2/mtd-2.6.32: mtd/maps: gpio-addr-flash: depend on GPIO arch support mtd/maps: gpio-addr-flash: pull in linux/ headers rather than asm/ mtd: nand: fix htmldocs warnings
2009-10-21mtd: Fix compile failure and error path in physmap.cH Hartley Sweeten
Commit 4b56ffcacee937a85bf39e14872dd141e23ee85f ("mtd: Fix kernel NULL pointer dereference in physmap.c") introduced a couple of bugs. It neglected to run the loop of map_destroy() calls in physmap_flash_remove(), if !info->cmtd, which would happen if that function was called to clean up errors during probe. It also failed to compile if CONFIG_MTD_PARTITIONS was not defined. Reported-By: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-10-20omap: headers: Move remaining headers from include/mach to include/platTony Lindgren
Move the remaining headers under plat-omap/include/mach to plat-omap/include/plat. Also search and replace the files using these headers to include using the right path. This was done with: #!/bin/bash mach_dir_old="arch/arm/plat-omap/include/mach" plat_dir_new="arch/arm/plat-omap/include/plat" headers=$(cd $mach_dir_old && ls *.h) omap_dirs="arch/arm/*omap*/ \ drivers/video/omap \ sound/soc/omap" other_files="drivers/leds/leds-ams-delta.c \ drivers/mfd/menelaus.c \ drivers/mfd/twl4030-core.c \ drivers/mtd/nand/ams-delta.c" for header in $headers; do old="#include <mach\/$header" new="#include <plat\/$header" for dir in $omap_dirs; do find $dir -type f -name \*.[chS] | \ xargs sed -i "s/$old/$new/" done find drivers/ -type f -name \*omap*.[chS] | \ xargs sed -i "s/$old/$new/" for file in $other_files; do sed -i "s/$old/$new/" $file done done for header in $(ls $mach_dir_old/*.h); do git mv $header $plat_dir_new/ done Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-20mtd: Fix kernel NULL pointer dereference in physmap.cH Hartley Sweeten
During the probe for physmap platform flash devices there are a number error exit conditions that all do a goto err_out which then calls physmap_flash_remove(). In that function one of the cleanup steps is: #ifdef CONFIG_MTD_CONCAT if (info->cmtd != info->mtd[0]) mtd_concat_destroy(info->cmtd); #endif This test will succeed since info->cmtd == NULL and info->mtd[0] is valid. Fix this by exiting the remove function when info->cmtd == NULL. Also, cleanup the #ifdef CONFIG_MTD_PARTITIONS stuff by using mtd_has_partitions(). Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-10-19pcmcia: convert pcmciamtd driver to use new CIS helpersDominik Brodowski
Convert the (broken) pcmciamtd driver to use the new CIS helpers. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-10-17mtd: maps: remove obsolete ipaq-flash driverDmitry Artamonow
This driver seems to be obsolete and broken for a long time. It depends on CONFIG_IPAQ_HANDHELD that simply doesn't exists anywhere in kernel. Also, it seems that none of machines it claims to support have any use of it: SA11xx-based iPAQs (h3100/h3600) use sa1100-flash iPAQ h5000 uses physmap-flash Jornada 720 uses sa1100-flash Jornada 560 and iPAQ h1910 are not in mainline Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-10-17mtd: maps/sa1100: fix section mismatchDmitry Artamonow
Commit f0b1e589 changed sa1100_mtd_probe from __init to __devinit, but missed to correct sa1100_setup_mtd definition accordingly, which causes following warning: WARNING: vmlinux.o(.devinit.text+0xf4): Section mismatch in reference from the function sa1100_mtd_probe() to the function .init.text:sa1100_setup_mtd() The function __devinit sa1100_mtd_probe() references a function __init sa1100_setup_mtd(). If sa1100_setup_mtd is only used by sa1100_mtd_probe then annotate sa1100_setup_mtd with a matching annotation. Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-27mtd: Fix warning in sa1100-flash.cRussell King
drivers/mtd/maps/sa1100-flash.c: In function 'sa1100_probe_subdev': drivers/mtd/maps/sa1100-flash.c:214: warning: format '%d' expects type 'int', but argument 3 has type 'uint64_t' Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-24mtd/maps: gpio-addr-flash: depend on GPIO arch supportMike Frysinger
The driver requires gpio functionality, so make sure we depend on that in the Kconfig menu. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-24mtd/maps: gpio-addr-flash: pull in linux/ headers rather than asm/Mike Frysinger
Now that there are linux/ versions of gpio.h and io.h, include those rather than hitting the asm/ versions. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-24Merge branch 'for-linus' of git://git.monstr.eu/linux-2.6-microblazeLinus Torvalds
* 'for-linus' of git://git.monstr.eu/linux-2.6-microblaze: (24 commits) microblaze: Disable heartbeat/enable emaclite in defconfigs microblaze: Support simpleImage.dts make target microblaze: Fix _start symbol to physical address microblaze: Use LOAD_OFFSET macro to get correct LMA for all sections microblaze: Create the LOAD_OFFSET macro used to compute VMA vs LMA offsets microblaze: Copy ppc asm-compat.h for clean handling of constants in asm and C microblaze: Actually show KiB rather than pages in "Freeing initrd memory:" microblaze: Support ptrace syscall tracing. microblaze: Updated CPU version and FPGA family codes in PVR microblaze: Generate correct signal and siginfo for integer div-by-zero microblaze: Don't be noisy when userspace causes hardware exceptions microblaze: Remove ipc.h file which points to non-existing asm-generic file microblaze: Clear sticky FSR register after generating exception signals microblaze: Ensure CPU usermode is set on new userspace processes microblaze: Use correct kbuild variable KBUILD_CFLAGS microblaze: Save and restore msr in hw exception microblaze: Add architectural support for USB EHCI host controllers microblaze: Implement include/asm/syscall.h. microblaze: Improve checking mechanism for MSR instruction microblaze: Add checking mechanism for MSR instruction ...
2009-09-23Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (58 commits) mtd: jedec_probe: add PSD4256G6V id mtd: OneNand support for Nomadik 8815 SoC (on NHK8815 board) mtd: nand: driver for Nomadik 8815 SoC (on NHK8815 board) m25p80: Add Spansion S25FL129P serial flashes jffs2: Use SLAB_HWCACHE_ALIGN for jffs2_raw_{dirent,inode} slabs mtd: sh_flctl: register sh_flctl using platform_driver_probe() mtd: nand: txx9ndfmc: transfer 512 byte at a time if possible mtd: nand: fix tmio_nand ecc correction mtd: nand: add __nand_correct_data helper function mtd: cfi_cmdset_0002: add 0xFF intolerance for M29W128G mtd: inftl: fix fold chain block number mtd: jedec: fix compilation problem with I28F640C3B definition mtd: nand: fix ECC Correction bug for SMC ordering for NDFC driver mtd: ofpart: Check availability of reg property instead of name property driver/Makefile: Initialize "mtd" and "spi" before "net" mtd: omap: adding DMA mode support in nand prefetch/post-write mtd: omap: add support for nand prefetch-read and post-write mtd: add nand support for w90p910 (v2) mtd: maps: add mtd-ram support to physmap_of mtd: pxa3xx_nand: add single-bit error corrections reporting ...
2009-09-21trivial: fix typo "to to" in multiple filesAnand Gadiyar
Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-21mtd: Enable Open Firmware initialisation of MTD devices and maps for MicroBlazeJohn Williams
2009-09-20Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/mtd/mtdcore.c Merged in order that I can apply the Nomadik nand/onenand support patches.
2009-09-19mtd: maps: add mtd-ram support to physmap_ofWolfram Sang
Use physmap_of to access RAMs as mtd and add documenation for it. This approach is a lot less intrusive as adding an of-wrapper around plat-ram.c. As most extensions of plat-ram.c (e.g. custom map-functions) can't be mapped to the device tree anyhow, extending physmap_of seems to be the cleanest approach. Tested with a phyCORE-MPC5121e. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Vitaly Wool <vwool@ru.mvista.com> Cc: Artem Bityutskiy <dedekind@infradead.org> Cc: Ken MacLeod <ken@bitsko.slc.ut.us> Cc: Albrecht Dreß <albrecht.dress@arcor.de> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-19mtd/maps: gpio-addr-flash: new driver for GPIO assisted flash addressingMike Frysinger
This driver lets people use GPIO's for additional address lines in case their processor does not have enough address lines already. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-19mtd/maps: uclinux: depend on MTD_RAM being built into the kernelMike Frysinger
If MTD_RAM is built as a module, the uClinux map does not work since it can only be built in to the kernel. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-19mtd/maps: uclinux: fix building when partition support is disabledTimofei Bondarenko
The uClinux map driver doesn't even use partitions, so we shouldn't require it in order to work properly. Signed-off-by: Timofei Bondarenko <tim@ipi.ac.ru> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> CC: Greg Ungerer <gerg@uclinux.org> CC: uclinux-dev@uclinux.org CC: linux-mtd@lists.infradead.org Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-15Nicolas Pitre has a new email addressNicolas Pitre
Due to problems at cam.org, my nico@cam.org email address is no longer valid. FRom now on, nico@fluxnic.net should be used instead. Signed-off-by: Nicolas Pitre <nico@fluxnic.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-04mtd: pmcmsp-flash: fix error paths in init_msp_flashRoel Kluin
Cleanin up after errors in init_msp_flash(). Also cleanup_msp_flash() attempts to determine the size of msp_flash with `sizeof(msp_flash) / sizeof(struct mtd_info **)' This will not work since msp_flash is not an array. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-04mtd: physmap_of: fix incorrect checkvimal singh
This patch fixes a spelling error that has resulted from copy and pasting. The location of the error was found using a semantic patch but the semantic patch was not trying to find these errors. After looking things over it seemed logical that this change was needed. The patch also makes sure mtd_list is not being freed if it has not been allocated Signed-off-by: Stoyan Gaydarov <sgayda2@uiuc.edu> Signed-off-by: Vimal Singh <vimalsingh@ti.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-04mtd: plat-ram: use resource_sizeWolfram Sang
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-04mtd: physmap_of: use resource_sizeWolfram Sang
2009-08-12Remove zero-length file drivers/mtd/maps/sbc8240.cJeff Garzik
It was "deleted" in commit 2bf961b7ccd69e108ac435c67e2b0522b403c578 Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-08-03mtd: remove 'SBC8240 Wind River' Device Driver CodeSubrata Modak
This driver is causing build errors and is no longer needed -- it is obsoleted by physmap_of. Signed-off-by: Subrata Modak <subrata@linux.vnet.ibm.com> Tested-on-PPC64-by: Subrata Modak <subrata@linux.vnet.ibm.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
