path: root/drivers/mmc
2017-04-04Merge tag 'v4.4.59' into toradex_vf_4.4-nextMarcel Ziswiler
This is the 4.4.59 stable release
2017-03-30mmc: sdhci: Do not disable interrupts while waiting for clockAdrian Hunter
commit e2ebfb2142acefecc2496e71360f50d25726040b upstream. Disabling interrupts for even a millisecond can cause problems for some devices. That can happen when sdhci changes clock frequency because it waits for the clock to become stable under a spin lock. The spin lock is not necessary here. Anything that is racing with changes to the I/O state is already broken. The mmc core already provides synchronization via "claiming" the host. Although the spin lock probably should be removed from the code paths that lead to this point, such a patch would touch too much code to be suitable for stable trees. Consequently, for this patch, just drop the spin lock while waiting. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Tested-by: Ludovic Desroches <ludovic.desroches@microchip.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-30mmc: ushc: fix NULL-deref at probeJohan Hovold
commit 181302dc7239add8ab1449c23ecab193f52ee6ab upstream. Make sure to check the number of endpoints to avoid dereferencing a NULL-pointer should a malicious device lack endpoints. Fixes: 53f3a9e26ed5 ("mmc: USB SD Host Controller (USHC) driver") Cc: David Vrabel <david.vrabel@csr.com> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-23mmc: core: fix multi-bit bus width without high-speed modeAnssi Hannula
commit 3d4ef329757cfd5e0b23cce97cdeca7e2df89c99 upstream. Commit 577fb13199b1 ("mmc: rework selection of bus speed mode") refactored bus width selection code to mmc_select_bus_width(). However, it also altered the behavior to not call the selection code in non-high-speed modes anymore. This causes 1-bit mode to always be used when the high-speed mode is not enabled, even though 4-bit and 8-bit bus are valid bus widths in the backwards-compatibility (legacy) mode as well (see e.g. 5.3.2 Bus Speed Modes in JEDEC 84-B50). This results in a significant regression in transfer speeds. Fix the code to allow 4-bit and 8-bit widths even without high-speed mode, as before. Tested with a Zynq-7000 PicoZed 7020 board. Fixes: 577fb13199b1 ("mmc: rework selection of bus speed mode") Signed-off-by: Anssi Hannula <anssi.hannula@bitwise.fi> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> [anssi.hannula@bitwise.fi: backported for the different err variable check on v4.4 and tested] Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09mmc: sdhci: Ignore unexpected CARD_INT interruptsGabriel Krisman Bertazi
commit 161e6d44a5e2d3f85365cb717d60e363171b39e6 upstream. One of our kernelCI boxes hanged at boot because a faulty eSDHC device was triggering spurious CARD_INT interrupts for SD cards, causing CMD52 reads, which are not allowed for SD devices. This adds a sanity check to the interruption path, preventing that illegal command from getting sent if the CARD_INT interruption should be disabled. This quirk allows that particular machine to resume boot despite the faulty hardware, instead of getting hung dealing with thousands of mishandled interrupts. Suggested-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Gabriel Krisman Bertazi <krisman@collabora.co.uk> Acked-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-26mmc: mxs-mmc: Fix additional cycles after transmission stopStefan Wahren
commit 01167c7b9cbf099c69fe411a228e4e9c7104e123 upstream. According to the code the intention is to append 8 SCK cycles instead of 4 at end of a MMC_STOP_TRANSMISSION command. But this will never happened because it's an AC command not an ADTC command. So fix this by moving the statement into the right function. Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com> Fixes: e4243f13d10e (mmc: mxs-mmc: add mmc host driver for i.MX23/28) Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-12mmc: mmc_test: Uninitialized return valueDan Carpenter
commit 16652a936e96f5dae53c3fbd38a570497baadaa8 upstream. We never set "ret" to RESULT_OK. Fixes: 9f9c4180f88d ("mmc: mmc_test: add test for non-blocking transfers") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-11Merge tag 'v4.4.39' into toradex_vf_4.4-nextStefan Agner
This is the 4.4.39 stable release
2017-01-11sdhci-esdhc-imx: fix bus-width for 1-bit operation.Leonardo Graboski Veiga
The 1-bit operation mode, enabled by setting the 'bus-width' property of the device tree 'esdhc' node to <1>, does not work while using SD card. The behavior is only noticed when only the data pin 0 is connected to the hardware. A series of kernel errors are printed to the console, all of them returning the following error message followed by some explanation: mmcblk0: error -84 transferring data If four data lines are connected, it ignores the device-tree property and works in 4-bit mode of operation without errors. The hardware used for testing does not support 8-bit mode. Check the 'bus-width' property and if set to <1>, enable the SDHCI_QUIRK_FORCE_1_BIT_DATA quirk. Signed-off-by: Leonardo Graboski Veiga <leonardo.veiga@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-09mmc: sdhci: Fix recovery from tuning timeoutAdrian Hunter
commit 61e53bd0047d58caee0c7170613045bf96de4458 upstream. Clearing the tuning bits should reset the tuning circuit. However there is more to do. Reset the command and data lines for good measure, and then for eMMC ensure the card is not still trying to process a tuning command by sending a stop command. Note the JEDEC eMMC specification says the stop command (CMD12) can be used to stop a tuning command (CMD21) whereas the SD specification is silent on the subject with respect to the SD tuning command (CMD19). Considering that CMD12 is not a valid SDIO command, the stop command is sent only when the tuning command is CMD21 i.e. for eMMC. That addresses cases seen so far which have been on eMMC. Note that this replaces the commit fe5fb2e3b58f ("mmc: sdhci: Reset cmd and data circuits after tuning failure") which is being reverted for v4.9+. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: Dan O'Donovan <dan@emutex.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-18mmc: mxs: Initialize the spinlock prior to using itFabio Estevam
commit f91346e8b5f46aaf12f1df26e87140584ffd1b3f upstream. An interrupt may occur right after devm_request_irq() is called and prior to the spinlock initialization, leading to a kernel oops, as the interrupt handler uses the spinlock. In order to prevent this problem, move the spinlock initialization prior to requesting the interrupts. Fixes: e4243f13d10e (mmc: mxs-mmc: add mmc host driver for i.MX23/28) Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Marek Vasut <marex@denx.de> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10mmc: dw_mmc-pltfm: fix the potential NULL pointer dereferenceJaehoon Chung
commit 45c7a4908a307a023e237a64a3eadcafc4836493 upstream. platform_get_resource can be returned the NULL pointer. Then regs->start should be referred to NULL Pointer. devm_ioremap_resource() checks whether res is NULL or not. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Shawn Lin <shawn.lin@rock-chips.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28mmc: rtsx_usb_sdmmc: Handle runtime PM while changing the ledUlf Hansson
commit 4f48aa7a11bfed9502a7c85a5b68cd40ea827f73 upstream. Accesses of the rtsx sdmmc's parent device, which is the rtsx usb device, must be done when it's runtime resumed. Currently this isn't case when changing the led, so let's fix this by adding a pm_runtime_get_sync() and a pm_runtime_put() around those operations. Reported-by: Ritesh Raj Sarraf <rrs@researchut.com> Tested-by: Ritesh Raj Sarraf <rrs@researchut.com> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28mmc: rtsx_usb_sdmmc: Avoid keeping the device runtime resumed when unusedUlf Hansson
commit 31cf742f515c275d22843c4c756e048d2b6d716c upstream. The rtsx_usb_sdmmc driver may bail out in its ->set_ios() callback when no SD card is inserted. This is wrong, as it could cause the device to remain runtime resumed when it's unused. Fix this behaviour. Tested-by: Ritesh Raj Sarraf <rrs@researchut.com> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28mmc: core: Annotate cmd_hdr as __le32Jiri Slaby
commit 3f2d26643595973e835e8356ea90c7c15cb1b0f1 upstream. Commit f68381a70bb2 (mmc: block: fix packed command header endianness) correctly fixed endianness handling of packed_cmd_hdr in mmc_blk_packed_hdr_wrq_prep. But now, sparse complains about incorrect types: drivers/mmc/card/block.c:1613:27: sparse: incorrect type in assignment (different base types) drivers/mmc/card/block.c:1613:27: expected unsigned int [unsigned] [usertype] <noident> drivers/mmc/card/block.c:1613:27: got restricted __le32 [usertype] <noident> ... So annotate cmd_hdr properly using __le32 to make everyone happy. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Fixes: f68381a70bb2 (mmc: block: fix packed command header endianness) Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28mmc: sdhci: cast unsigned int to unsigned long long to avoid unexpeted errorHaibo Chen
commit 02265cd60335a2c1417abae4192611e1fc05a6e5 upstream. Potentially overflowing expression 1000000 * data->timeout_clks with type unsigned int is evaluated using 32-bit arithmetic, and then used in a context that expects an expression of type unsigned long long. To avoid overflow, cast 1000000U to type unsigned long long. Special thanks to Coverity. Fixes: 7f05538af71c ("mmc: sdhci: fix data timeout (part 2)") Signed-off-by: Haibo Chen <haibo.chen@nxp.com> Acked-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28mmc: block: don't use CMD23 with very old MMC cardsDaniel Glöckner
commit 0ed50abb2d8fc81570b53af25621dad560cd49b3 upstream. CMD23 aka SET_BLOCK_COUNT was introduced with MMC v3.1. Older versions of the specification allowed to terminate multi-block transfers only with CMD12. The patch fixes the following problem: mmc0: new MMC card at address 0001 mmcblk0: mmc0:0001 SDMB-16 15.3 MiB mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 ... blk_update_request: I/O error, dev mmcblk0, sector 0 Buffer I/O error on dev mmcblk0, logical block 0, async page read mmcblk0: unable to read partition table Signed-off-by: Daniel Glöckner <dg@emlix.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-07mmc: pxamci: fix potential oopsRobert Jarzmik
commit b3802db5eb72d2a96f4aa4ff0abb937033df2acf upstream. As reported by Dan in his report in [1], there is a potential NULL pointer derefence if these conditions are met : - there is no platform_data provided, ie. host->pdata = NULL Fix this by only using the platform data ro_invert when a gpio for read-only is provided by the platform data. This doesn't appear yet as every pxa board provides a platform_data, and calls pxa_set_mci_info() with a non NULL pointer. [1] [bug report] mmc: pxamci: fix card detect with slot-gpio API. The commit fd546ee6a7dc ("mmc: pxamci: fix card detect with slot-gpio API") from Sep 26, 2015, leads to the following static checker warning: drivers/mmc/host/pxamci.c:809 pxamci_probe() warn: variable dereferenced before check 'host->pdata' (see line 798) Fixes: fd546ee6a7dc ("mmc: pxamci: fix card detect with slot-gpio API") Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-29Merge tag 'v4.4.21' into toradex_vf_4.4-nextStefan Agner
This is the 4.4.21 stable release
2016-09-24mmc: dw_mmc: use resource_size_t to store physical addressArnd Bergmann
commit 260b31643691e8a58683a4ccc3bdf7abfd86f54a upstream. The dw_mmc driver stores the physical address of the MMIO registers in a pointer, which requires the use of type casts, and is actually broken if anyone ever has this device on a 32-bit SoC in registers above 4GB. Gcc warns about this possibility when the driver is built with ARM LPAE enabled: mmc/host/dw_mmc.c: In function 'dw_mci_edmac_start_dma': mmc/host/dw_mmc.c:702:17: warning: cast from pointer to integer of different size cfg.dst_addr = (dma_addr_t)(host->phy_regs + fifo_offset); ^ mmc/host/dw_mmc-pltfm.c: In function 'dw_mci_pltfm_register': mmc/host/dw_mmc-pltfm.c:63:19: warning: cast to pointer from integer of different size host->phy_regs = (void *)(regs->start); This changes the code to use resource_size_t, which gets rid of the warning, the bug and the useless casts. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-15mmc: sdhci: Do not BUG on invalid vddAdrian Hunter
[ Upstream commit 9d5de93f6d543b356e39e225988ef443a7bce34c ] The driver may not be able to set the power correctly but that is not a reason to BUG(). Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Reviewed-by: Venu Byravarasu <vbyravarasu@nvidia.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-15mmc: sdhci: 64-bit DMA actually has 4-byte alignmentAdrian Hunter
[ Upstream commit 04a5ae6fdd018af29675eb8b6c2550c87f471570 ] The version 3.00 SDHCI spec. was a bit unclear about the required data alignment for 64-bit DMA, whereas the version 4.10 spec. uses different language and indicates that only 4-byte alignment is required rather than the 8-byte alignment currently implemented. That make no difference to SD and EMMC which invariably transfer data in sector-aligned blocks. However with SDIO, it results in using more DMA descriptors than necessary. Theoretically that slows DMA slightly although DMA is not the limiting factor for throughput, so there is no discernable impact on performance. Nevertheless, the driver should follw the spec unless there is good reason not to, so this patch corrects the alignment criterion. There is a more complicated criterion for the DMA descriptor table itself. However the table is allocated by dma_alloc_coherent() which allocates pages (i.e. aligned to a page boundary). For simplicity just check it is 8-byte aligned, but add a comment that some Intel controllers actually require 8-byte alignment even when using 32-bit DMA. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-07mmc: sdhci-acpi: Reduce Baytrail eMMC/SD/SDIO hangsAdrian Hunter
commit 6e1c7d6103fe7031035cec321307c6356809adf4 upstream. Baytrail eMMC/SD/SDIO host controllers have been known to hang. A change to a hardware setting has been found to reduce the occurrence of such hangs. This patch ensures the correct setting. This patch applies cleanly to v4.4+. It could go to earlier kernels also, so I will send backports to the stable list in due course. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: stable@vger.kernel.org # v4.4+ Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-10mmc: block: fix packed command header endiannessTaras Kondratiuk
commit f68381a70bb2b26c31b13fdaf67c778f92fd32b4 upstream. The code that fills packed command header assumes that CPU runs in little-endian mode. Hence the header is malformed in big-endian mode and causes MMC data transfer errors: [ 563.200828] mmcblk0: error -110 transferring data, sector 2048, nr 8, cmd response 0x900, card status 0xc40 [ 563.219647] mmcblk0: packed cmd failed, nr 2, sectors 16, failure index: -1 Convert header data to LE. Signed-off-by: Taras Kondratiuk <takondra@cisco.com> Fixes: ce39f9d17c14 ("mmc: support packed write command for eMMC4.5 devices") Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-06-02Merge tag 'v4.4.12' into toradex_vf_4.4-nextStefan Agner
This is the 4.4.12 stable release
2016-06-01mmc: sdhci-pci: Remove MMC_CAP_BUS_WIDTH_TEST for Intel controllersAdrian Hunter
commit 822969369482166050c5b2f7013501505e025c39 upstream. The CMD19/CMD14 bus width test has been found to be unreliable in some cases. It is not essential, so simply remove it. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-06-01mmc: longer timeout for long read time quirkMatt Gumbel
commit 32ecd320db39bcb007679ed42f283740641b81ea upstream. 008GE0 Toshiba mmc in some Intel Baytrail tablets responds to MMC_SEND_EXT_CSD in 450-600ms. This patch will... () Increase the long read time quirk timeout from 300ms to 600ms. Original author of that quirk says 300ms was only a guess and that the number may need to be raised in the future. () Add this specific MMC to the quirk Signed-off-by: Matt Gumbel <matthew.k.gumbel@intel.com> Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-06-01mmc: sdhci-acpi: Remove MMC_CAP_BUS_WIDTH_TEST for Intel controllersAdrian Hunter
commit 265984b36ce82fec67957d452dd2b22e010611e4 upstream. The CMD19/CMD14 bus width test has been found to be unreliable in some cases. It is not essential, so simply remove it. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-06-01mmc: mmc: Fix partition switch timeout for some eMMCsAdrian Hunter
commit 1c447116d017a98c90f8f71c8c5a611e0aa42178 upstream. Some eMMCs set the partition switch timeout too low. Now typically eMMCs are considered a critical component (e.g. because they store the root file system) and consequently are expected to be reliable. Thus we can neglect the use case where eMMCs can't switch reliably and we might want a lower timeout to facilitate speedy recovery. Although we could employ a quirk for the cards that are affected (if we could identify them all), as described above, there is little benefit to having a low timeout, so instead simply set a minimum timeout. The minimum is set to 300ms somewhat arbitrarily - the examples that have been seen had a timeout of 10ms but were sometimes taking 60-70ms. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-20mmc: sdhci-pci: Add support and PCI IDs for more Broxton host controllersAdrian Hunter
commit 01d6b2a40a0fa73c90e05b1033f181a51fec9292 upstream. Add support and PCI IDs for more Broxton host controllers Other BXT IDs were added in v4.4 so cc'ing stable. This patch is dependent on commit 163cbe31e516 ("mmc: sdhci-pci: Fix card detect race for Intel BXT/APL") but that is already in stable since v4.4.4. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-12mmc: sdhci: Fix override of timeout clk wrt max_busy_timeoutAdrian Hunter
commit 995136247915c5cee633d55ba23f6eebf67aa567 upstream. Normally the timeout clock frequency is read from the capabilities register. It is also possible to set the value prior to calling sdhci_add_host() in which case that value will override the capabilities register value. However that was being done after calculating max_busy_timeout so that max_busy_timeout was being calculated using the wrong value of timeout_clk. Fix that by moving the override before max_busy_timeout is calculated. The result is that the max_busy_timeout and max_discard increase for BSW devices so that, for example, the time for mkfs.ext4 on a 64GB eMMC drops from about 1 minute 40 seconds to about 20 seconds. Note, in the future, the capabilities setting will be tidied up and this override won't be used anymore. However this fix is needed for stable. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-12mmc: sdhci: fix data timeout (part 2)Russell King
commit 7f05538af71c7d30b5fc821cbe9f318edc645961 upstream. The calculation for the timeout based on the number of card clocks is incorrect. The calculation assumed: timeout in microseconds = clock cycles / clock in Hz which is clearly a several orders of magnitude wrong. Fix this by multiplying the clock cycles by 1000000 prior to dividing by the Hz based clock. Also, as per part 1, ensure that the division rounds up. As this needs 64-bit math via do_div(), avoid it if the clock cycles is zero. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-12mmc: sdhci: fix data timeout (part 1)Russell King
commit fafcfda9e78cae8796d1799f14e6457790797555 upstream. The data timeout gives the minimum amount of time that should be waited before timing out if no data is received from the card. Simply dividing the nanosecond part by 1000 does not give this required guarantee, since such a division rounds down. Use DIV_ROUND_UP() to give the desired timeout. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-12mmc: mmc_spi: Add Card Detect comments and fix CD GPIO caseMagnus Damm
commit bcdc9f260bdce09913db1464be9817170d51044a upstream. This patch fixes the MMC SPI driver from doing polling card detect when a CD GPIO that supports interrupts is specified using the gpios DT property. Without this patch the DT node below results in the following output: spi_gpio: spi-gpio { /* SD2 @ CN12 */ compatible = "spi-gpio"; #address-cells = <1>; #size-cells = <0>; gpio-sck = <&gpio6 16 GPIO_ACTIVE_HIGH>; gpio-mosi = <&gpio6 17 GPIO_ACTIVE_HIGH>; gpio-miso = <&gpio6 18 GPIO_ACTIVE_HIGH>; num-chipselects = <1>; cs-gpios = <&gpio6 21 GPIO_ACTIVE_LOW>; status = "okay"; spi@0 { compatible = "mmc-spi-slot"; reg = <0>; voltage-ranges = <3200 3400>; spi-max-frequency = <25000000>; gpios = <&gpio6 22 GPIO_ACTIVE_LOW>; /* CD */ }; }; # dmesg | grep mmc mmc_spi spi32766.0: SD/MMC host mmc0, no WP, no poweroff, cd polling mmc0: host does not support reading read-only switch, assuming write-enable mmc0: new SDHC card on SPI mmcblk0: mmc0:0000 SU04G 3.69 GiB mmcblk0: p1 With this patch applied the "cd polling" portion above disappears. Signed-off-by: Magnus Damm <damm+renesas@opensource.se> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-12mmc: block: fix ABI regression of mmc_blk_ioctlShawn Lin
commit 83c742c344c08c2bbe338d45c6ec63110e9d5e3d upstream. If mmc_blk_ioctl returns -EINVAL, blkdev_ioctl continues to work without returning err to user-space. But now we check CAP_SYS_RAWIO firstly, so we return -EPERM to blkdev_ioctl, which make blkdev_ioctl return -EPERM to user-space directly. So this will break all the ioctl with BLKROSET. Now we find Android-adb suffer it for the following log: remount of /system failed; couldn't make block device writable: Operation not permitted openat(AT_FDCWD, "/dev/block/platform/ff420000.dwmmc/by-name/system", O_RDONLY) = 3 ioctl(3, BLKROSET, 0) = -1 EPERM (Operation not permitted) Fixes: a5f5774c55a2 ("mmc: block: Add new ioctl to send multi commands") Signed-off-by: Shawn Lin <shawn.lin@rock-chips.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-12mmc: sh_mmcif: Correct TX DMA channel allocationChris Paterson
commit a32ef81c9889c9554a3c4b465c4ee7b2d26c6b10 upstream. Commit 27cbd7e815a8 ("mmc: sh_mmcif: rework dma channel handling") introduced a typo causing the TX DMA channel allocation to be overwritten by the requested RX DMA channel. Fixes: 27cbd7e815a8 ("mmc: sh_mmcif: rework dma channel handling") Signed-off-by: Chris Paterson <chris.paterson2@renesas.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-12mmc: sh_mmcif: rework dma channel handlingArnd Bergmann
commit 27cbd7e815a8e223ff7c4fe56daca724101288ac upstream. When compiling the sh_mmcif driver for ARM64, we currently get a harmless build warning: ../drivers/mmc/host/sh_mmcif.c: In function 'sh_mmcif_request_dma_one': ../drivers/mmc/host/sh_mmcif.c:417:4: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] (void *)pdata->slave_id_tx : ^ ../drivers/mmc/host/sh_mmcif.c:418:4: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] (void *)pdata->slave_id_rx; This could be worked around by adding another cast to uintptr_t, but I decided to simplify the code a little more to avoid that. This splits out the platform data using code into a separate function and builds that only for CONFIG_SUPERH. This part still has a typecast but does not need a second one. The SH platform code could be further modified to pass a pointer directly as we do on other architectures when we have a filter function. The normal case is simplified further and now just calls dma_request_slave_channel() directly without going through the compat handling. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-29Merge tag 'v4.4.5' into toradex_vf_4.4-nextStefan Agner
This is the 4.4.5 stable release
2016-03-03mmc: sdhci: Allow override of get_cd() called from sdhci_request()Adrian Hunter
commit 8d28b7a72fe18bcdcdb047243ba8fec36b149955 upstream. Drivers may need to provide their own get_cd() mmc host op, but currently the internals of the current op (sdhci_get_cd()) are provided by sdhci_do_get_cd() which is also called from sdhci_request(). To allow override of the get_cd functionality, change sdhci_request() to call ->get_cd() instead of sdhci_do_get_cd(). Note, in the future the call to ->get_cd() will likely be removed from sdhci_request() since most drivers don't need actually it. However this change is being done now to facilitate a subsequent bug fix. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-03mmc: sdhci: Allow override of mmc host operationsAdrian Hunter
commit bf60e592a1af4d6f65dd54593250183f14360eed upstream. In the past, fixes for specific hardware devices were implemented in sdhci using quirks. That approach is no longer accepted because the growing number of quirks was starting to make the code difficult to understand and maintain. One alternative to quirks, is to allow drivers to override the default mmc host operations. This patch makes it easy to do that, and it is needed for a subsequent bug fix, for which separate patches are provided. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-03mmc: sdhci-pci: Fix card detect race for Intel BXT/APLAdrian Hunter
commit 163cbe31e5163459908a41a2b4e0d33a28fd557a upstream. Intel BXT/APL use a card detect GPIO however the host controller will not enable bus power unless it's card detect also reflects the presence of a card. Unfortunately those 2 things race which can result in commands not starting, after which the controller does nothing and there is a 10 second wait for the driver's 10-second timer to timeout. That is fixed by having the driver look also at the present state register to determine if the card is present. Consequently, provide a 'get_cd' mmc host operation for BXT/APL that does that. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-03mmc: pxamci: fix again read-only gpio detection polarityRobert Jarzmik
commit 41c89159a6ae5472d39ed8bded5b3b4e07a37944 upstream. The commit fixing the conversion of pxamci to slot-gpio API fixed the inverted the logic of the read-only gpio. Unfortunately, the commit was tested on a non-inverted gpio, and not on the inverted one. And the fix did work partially, by luck. This is the remaining missing part of the fix, trivial but still necessary. Fixes: Fixes: 26d49fe71953 ("mmc: pxamci: fix read-only gpio detection polarity") Reported-by: Andrea Adami <andrea.adami@gmail.com> Tested-by: Andrea Adami <andrea.adami@gmail.com> Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-03mmc: sdhci-acpi: Fix card detect race for Intel BXT/APLAdrian Hunter
commit 6a645dd87a5a506779810d7d9935c25fc2ef4687 upstream. Intel BXT/APL use a card detect GPIO however the host controller will not enable bus power unless it's card detect also reflects the presence of a card. Unfortunately those 2 things race which can result in commands not starting, after which the controller does nothing and there is a 10 second wait for the driver's 10-second timer to timeout. That is fixed by having the driver look also at the present state register to determine if the card is present. Consequently, provide a 'get_cd' mmc host operation for BXT/APL that does that. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-03mmc: mmci: fix an ages old detection errorLinus Walleij
commit 0bcb7efdff63564e80fe84dd36a9fbdfbf6697a4 upstream. commit 4956e10903fd ("ARM: 6244/1: mmci: add variant data and default MCICLOCK support") added variant data for ARM, U300 and Ux500 variants. The Nomadik NHK8815/8820 variant was erroneously labeled as a U300 variant, and when the proper Nomadik variant was later introduced in commit 34fd421349ff ("ARM: 7378/1: mmci: add support for the Nomadik MMCI variant") this was not fixes. Let's say this fixes the latter commit as there was no proper Nomadik support until then. Fixes: 34fd421349ff ("ARM: 7378/1: mmci: add support for the Nomadik...") Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-03mmc: core: Enable tuning according to the actual timingCarlo Caione
commit e10c321977091f163eceedec0650e0ef4b3cf4bb upstream. While in sdhci_execute_tuning() the choice whether or not to enable the tuning is done on the actual timing, in the mmc_sdio_init_uhs_card() the check is done on the capability of the card. This difference is causing some issues with some SDIO cards in DDR50 mode where the CDM19 is wrongly issued. With this patch we modify the check in both mmc_(sd|sdio)_init_uhs_card() functions to take the proper decision only according to the actual timing specification. Signed-off-by: Carlo Caione <carlo@endlessm.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-03mmc: sdhci: Fix sdhci_runtime_pm_bus_on/off()Adrian Hunter
commit 5c671c410c8704800f4f1673b6f572137e7e6ddd upstream. sdhci has a legacy facility to prevent runtime suspend if the bus power is on. This is needed in cases where the power to the card is dependent on the bus power. It is controlled by a pair of functions: sdhci_runtime_pm_bus_on() and sdhci_runtime_pm_bus_off(). These functions use a boolean variable 'bus_on' to ensure changes are always paired. There is an additional check for 'runtime_suspended' which is the problem. In fact, its use is ill-conceived as the only requirement for the logic is that 'on' and 'off' are paired, which is actually broken by the check, for example if the bus power is turned on during runtime resume. So remove the check. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-03mmc: mmc: Fix incorrect use of driver strength switching HS200 and HS400Wenkai Du
commit adb24d42a516bca8b9741ed21206509daaab5b13 upstream. Commit cc4f414c885c ("mmc: mmc: Add driver strength selection") added driver strength selection for eMMC HS200 and HS400 modes. That patch also set the driver stength when transitioning through High Speed mode to HS200/HS400, but driver strength is not defined for High Speed mode. While the JEDEC specification is not clear on this point it has been observed to cause problems for some eMMC, and removing the driver strength setting in this case makes it consistent with the normal use of High Speed mode. Signed-off-by: Wenkai Du <wenkai.du@intel.com> Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-03mmc: sdio: Fix invalid vdd in voltage switch power cycleAdrian Hunter
commit d9bfbb95ed598a09cf336adb0f190ee0ff802f0d upstream. The 'ocr' parameter passed to mmc_set_signal_voltage() defines the power-on voltage used when power cycling after a failure to set the voltage. However, in the case of mmc_sdio_init_card(), the value passed has the R4_18V_PRESENT flag set which is not valid for power-on and results in an invalid vdd. Fix by passing the card's ocr value which does not have the flag. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-03mmc: sdhci: Fix DMA descriptor with zero data lengthAdrian Hunter
commit 347ea32dc118326c4f2636928239a29d192cc9b8 upstream. SDHCI has built-in DMA called ADMA2. ADMA2 uses a descriptor table to define DMA scatter-gather. Each desciptor can specify a data length up to 65536 bytes, however the length field is only 16-bits so zero means 65536. Consequently, putting zero when the size is zero must not be allowed. This patch fixes one case where zero data length could be set inadvertently. The problem happens because unaligned data gets split and the code did not consider that the remaining aligned portion might be zero length. That case really only happens for SDIO because SD and eMMC cards transfer blocks that are invariably sector- aligned. For SDIO, access to function registers is done by data transfer (CMD53) when the register is bigger than 1 byte. Generally registers are 4 bytes but 2-byte registers are possible. So DMA of 4 bytes or less can happen. When 32-bit DMA is used, the data alignment must be 4, so 4-byte transfers won't casue a problem, but a 2-byte transfer could. However with the introduction of 64-bit DMA, the data alignment for 64-bit DMA was made 8 bytes, so all 4-byte transfers not on 8-byte boundaries get "split" into a 4-byte chunk and a 0-byte chunk, thereby hitting the bug. In fact, a closer look at the SDHCI specs indicates that only the descriptor table requires 8-byte alignment for 64-bit DMA. That will be dealt with in a separate patch, but the potential for a 2-byte access remains, so this fix is needed anyway. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-03mmc: sdhci-pci: Do not default to 33 Ohm driver strength for Intel SPTAdrian Hunter
commit 1ca896856281d3f1ad4f6f7d4e32e2943452de23 upstream. In some cases, the stronger 33 Ohm driver strength must not be used so it is not a suitable default. Change it to the standard default 50 Ohm value. The patch applies to v4.2+ except the file name changed. It is drivers/mmc/host/sdhci-pci.c prior to v.4.4. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
