All host drivers were #include:ing mmc/protocol.h just to
get access to the OCR bit defines. Move these to host.h instead.
Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
Many controllers have an upper limit on the number of blocks that can be
transferred in one request. Allow the host drivers to specify this and make
sure we avoid hitting this limit.
Also change the max_sectors field to avoid confusion. This makes it map
less directly to the block layer limits, but as they didn't apply directly
on MMC cards anyway, this isn't a great loss.
Most controllers have an upper limit on the block size. Allow the host
drivers to specify this and make sure we avoid hitting this limit.
During development of SDHC support, it was discovered that the definition
for R6 was incorrect. This patch fixes that and patches the drivers that
do switch on the response type.
Signed-off-by: Philip Langdale <philipl@overt.org>
Cc: Alex Dubov <oakad@yahoo.com>
Cc: Pavel Pisa <ppisa@pikron.com>
since commit fcaf71fd51f9cfc504455d3e19ec242e4b2073ed
struct mmc_host does not have a dev field. Retrieve the device with
mmc_dev() instead.
Now that mmc_host_ops can be constified, update the various drivers
to constify those method tables and shrink the writable data segment.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
command and cleanups
Patch from Pavel Pisa
There has been problems that for some paths that clock are not stopped
during new command programming and initiation. Result is issuing
of incorrect command to the card. Some other problems are cleaned too.
Noisy report of known ERRATUM #4 has been suppressed.
Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz>
Rather than having every driver duplicate the set_ios debugging,
provide a single version in mmc.c which can be expanded as we
add additional functionality.
There's no reason for the PXAMCI debug code to print so many lines - it
causes the kernel buffer to overflow when trying to debug this driver.
Remove some debug messages which are duplicated by core code, and
combine other messages, resulting in fewer characters written to the
kernel log.
Always send a stop command at the end of a data transfer. If we avoid
sending the stop command, some cards remain in data transfer mode, and
refuse to accept further read/write commands.
The MMC layer gives us two parts for the timeout calculation - a fixed
timeout in nanoseconds, and a card clock-speed dependent part.
The PXA MMC hardware allows for a timeout based on the fixed host clock
speed only. This resulted in some cards being given a short timeout,
and therefore failing to work.
Rather than each driver test MMC_DEBUG itself, and define DEBUG,
pass it in via the makefile instead.
Fix drivers to use pr_debug() where appropriate, and avoid defining
a DEBUG() macro.
platform_get_irq*() now returns on -ENXIO when the resource cannot be
found. Ensure all users of platform_get_irq*() handle this error
appropriately.
Signed-off-by: David Vrabel <dvrabel@arcom.com>
Some hosts need to know the command type, so pass it via a set of
flags in cmd->flags.
This allows us to eliminate the casts in the drivers, and eventually
remove the use of the device_driver function pointer methods for
platform device drivers.
Manual #include fixups for clashes - there may be some unnecessary
Convert everyone who uses platform_bus_type to include
linux/platform_device.h.
In PM v1, all devices were called at SUSPEND_DISABLE level. Then
all devices were called at SUSPEND_SAVE_STATE level, and finally
SUSPEND_POWER_DOWN level. However, with PM v2, to maintain
compatibility for platform devices, I arranged for the PM v2
suspend/resume callbacks to call the old PM v1 suspend/resume
callbacks three times with each level in order so that existing
drivers continued to work.
Since this is obsolete infrastructure which is no longer necessary,
we can remove it. Here's an (untested) patch to do exactly that.
Allow PXA platforms to pass an appropriate delay value to the
PXA MCI driver for delaying detection changes.
Signed-Off-By: Richard Purdie <rpurdie@rpsys.net>
Change mmc_detect_change() to take a delay argument such that
the detection of card insertions and removals can be delayed
according to the requirements of the host driver or platform.
Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
Add a write protection switch handling code to the PXA MMC driver so
that platform specific code can provide it if available.
This fixes u32 vs. pm_message_t in drivers/mmc, drivers/mtd and
drivers/scsi.
Signed-off-by: Pavel Machek <pavel@suse.cz>
infrastructure for it.
Let it rip!
