path: root/drivers/mmc/mmc.c
2005-12-14[MMC] Explain the internals of mmc_power_up()Russell King
It seems that people get confused about what is happening in mmc_power_up(). Add a comment to make it clear why we have a two stage process. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-12-05[MMC] Proper check of SCR error codePierre Ossman
The routine reading the SCR wasn't paying proper attention to the error codes returned from the driver. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-28[MMC] Fix protocol errorsPierre Ossman
A review against MMC/SD specifications found some errors in the current implementation. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-07[ARM] 3120/1: Fix MMC/SD card driver resume deadlockUli Luckas
Patch from Uli Luckas This is a simplification of patch 3116/1 as sugested by Russell King. Signed-off-by: Uli Luckas <u.luckas@road-gmbh.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-08[MMC] Allow detection/removal to be delayedRichard Purdie
Change mmc_detect_change() to take a delay argument such that the detection of card insertions and removals can be delayed according to the requirements of the host driver or platform. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-07[PATCH] sd: SD copyright noticePierre Ossman
Credit where credit is due. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] sd: SD 4-bit busPierre Ossman
Infrastructure for 4-bit bus transfers with SD cards. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] sd: SCR registerPierre Ossman
Read the SD specific SCR register from the card. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] sd: read-only switchPierre Ossman
Support for the read-only switch on SD cards which must be enforced by the host. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] sd: initialize SD cardsPierre Ossman
Support for the Secure Digital protocol in the MMC layer. A summary of the legal issues surrounding SD cards, as understood by yours truly: Members of the Secure Digital Association, hereafter SDA, are required to sign a NDA[1] before given access to any specifications. It has been speculated that including an SD implementation would forbid these members to redistribute Linux. This is the basic problem with SD support so it is unclear if it even is a problem since it has no effect on those of us that aren't members. The SDA doesn't seem to enforce these rules though since the patches included here are based on documentation made public by some of the members. The most complete specs[2] are actually released by Sandisk, one of the founding companies of the SDA. Because of this the NDA is considered a non-issue by most involved in the discussions concerning these patches. It might be that the SDA is only interested in protecting the so called "secure" bits of SD, which so far hasn't been found in any public spec. (The card is split into two sections, one "normal" and one "secure" which has an access scheme similar to TPM:s). (As a side note, Microsoft is working to make things easier for us since they want to be able to include the source code for a SD driver in one of their development kits. HP is making sure that the new NDA will allow a Linux implementation. So far only the SDIO specs have been opened up[3]. More will hopefully follow.) [1] http://www.sdcard.org/membership/images/ippolicy.pdf [2] http://www.sandisk.com/pdf/oem/ProdManualSDCardv1.9.pdf [3] http://www.sdcard.org/sdio/Simplified%20SDIO%20Card%20Specification.pdf This patch contains the central parts of the SD support. If no MMC cards are found on a bus then the MMC layer proceeds looking for SD cards. Helper functions are extended to handle the special needs of SD cards. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-03[MMC] ios for mmc chip selectPierre Ossman
Adds a new ios for setting the chip select pin on MMC cards. Needed on SD controllers which use this pin for other things and therefore cannot have it pulled high at all times. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-08-19[MMC] Add MMC class devicesRussell King
Create a mmc_host class to allow enumeration of MMC host controllers even though they have no card(s) inserted. Patch based on work by Pierre Ossman. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-08-19[MMC] Add mmc_hostname() macroRussell King
mmc_hostname() returns a pointer to the hostname for the mmc_host. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-04-16[PATCH] fix u32 vs. pm_message_t in drivers/mmc,mtd,scsiPavel Machek
This fixes u32 vs. pm_message_t in drivers/mmc, drivers/mtd and drivers/scsi. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
