path: root/drivers/mmc/host/s3cmci.c
2010-10-23mmc: Remove distinction between hw and phys segmentsMartin K. Petersen
We have deprecated the distinction between hardware and physical segments in the block layer. Consolidate the two limits into one in drivers/mmc/. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2010-09-09ARM: SAMSUNG: MMC: fix build error when both DMA and PIO mode selectedJiri Pinkava
[cjb: fix line-wrapped patch] Signed-off-by: Jiri Pinkava <jiri.pinkava@vscht.cz> Signed-off-by: Chris Ball <cjb@laptop.org> Cc: Matt Fleming <matt@console-pimps.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ben Dooks <ben-linux@fluff.org> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27mmc: remove the "state" argument to mmc_suspend_host()Matt Fleming
Even though many mmc host drivers pass a pm_message_t argument to mmc_suspend_host() that argument isn't used the by MMC core. As host drivers are converted to dev_pm_ops they'll have to construct pm_message_t's (as they won't be passed by the PM subsystem any more) just to appease the mmc suspend interface. We might as well just delete the unused paramter. Signed-off-by: Matt Fleming <matt@console-pimps.org> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Acked-by: Michal Miroslaw <mirq-linux@rere.qmqm.pl>ZZ Acked-by: Sascha Sommer <saschasommer@freenet.de> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06s3cmci: s3cmci_card_present: Use no_detect to decide whether there is a card ↵Lars-Peter Clausen
detect pin Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Cc: Ben Dooks <ben-linux@fluff.org> Cc: <linux-mmc@vger.kernel.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06s3cmci: initialize default platform data no_wprotect and no_detect with 1Lars-Peter Clausen
If no platform_data was givin to the device it's going to use it's default platform data struct which has all fields initialized to zero. As a result the driver is going to try to request gpio0 both as write protect and card detect pin. Which of course will fail and makes the driver unusable Previously to the introduction of no_wprotect and no_detect the behavior was to assume that if no platform data was given there is no write protect or card detect pin. This patch restores that behavior. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Cc: Ben Dooks <ben-linux@fluff.org> Cc: <linux-mmc@vger.kernel.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15s3cmci: convert missed s3c2410_gpio calls to gpiolib callsBen Dooks
Convert two missed s3c2410 specific gpio calls to gpiolib calls. Signed-off-by: Ben Dooks <ben@simtec.co.uk> Signed-off-by: Simtec Linux Team <linux@simtec.co.uk> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15drivers/mmc: Move dereference after NULL testJulia Lawall
If the NULL test on mrq is needed, then the derefernce should be after the NULL test. A simplified version of the semantic match that detects this problem is as follows (http://coccinelle.lip6.fr/): // <smpl> @match exists@ expression x, E; identifier fld; @@ * x->fld ... when != \(x = E\|&x\) * x == NULL // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15const: constify remaining dev_pm_opsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-10-01s3cmci: add better support for no card detect or write protect availableBen Dooks
Add better support for omitting either the card detect or the write protect GPIOs if the board does not support it. Add the fields no_wprotect and no_detect to the platform data which when set indicate the absence of the respective GPIOs. Note, this also fixes a minor bug where it tries to free IRQ0 if there is no detect gpio available. Signed-off-by: Ben Dooks <ben@simtec.co.uk> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-01s3cmci: make SDIO IRQ hardware IRQ support build-time configurableBen Dooks
We have found a couple of boards where the SDIO IRQ hardware support has failed to work properly, and thus we should make it configurable whether or not to be included in the driver. Signed-off-by: Ben Dooks <ben@simtec.co.uk> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-01s3cmci: DMA fixesBen Dooks
Fixes for the DMA transfer mode of the driver to try and improve the state of the code: - Ensure that dma_complete is set during the end of the command phase so that transfers do not stall awaiting the completion - Update the DMA debugging to provide a bit more useful information such as how many DMA descriptors where not processed and print the DMA addresses in hexadecimal. - Fix the DMA channel request code to actually request DMA for the S3CMCI block instead of whatever '0' signified. - Add fallback to PIO if we cannot get the DMA channel, as many of the devices with this block only have a limited number of DMA channels. - Only try and claim and free the DMA channel if we are trying to use it. This improves the driver DMA code to the point where it can now identify a card and read the partition table. However the DMA can still stall when trying to move data between the host and memory. Signed-off-by: Ben Dooks <ben@simtec.co.uk> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-01s3cmci: Kconfig selection for PIO/DMA/BothBen Dooks
Add a selection for the data transfer mode of the s3cmci driver, allowing for either a configuration or rumtime selection of the use of the DMA or PIO transfer code. The PIO only mode is 476 bytes smaller than the driver with both methods compiled in. Signed-off-by: Ben Dooks <ben@simtec.co.uk> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-01s3cmci: add SDIO IRQ supportBen Dooks
The controller supports SDIO IRQ detection so add support for hardware assisted SDIO interrupt detection for the SDIO core. This improves the response time for SDIO interrupts and thus the transfer rate from devices such as the Marvel 8686. As a note, it does seem that the controller will miss an IRQ than is held asserted, so there are some manual checks to see if the SDIO interrupt is active after a transfer. Major testing on the S3C2440. Signed-off-by: Ben Dooks <ben@simtec.co.uk> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-01s3cmci: add debugfs support for examining driver and hardware stateBen Dooks
Export driver state and hardware register state via debugfs entries created under a directory formed from dev_name() on the probed device when CONFIG_DEBUG_FS is set. Signed-off-by: Ben Dooks <ben@simtec.co.uk> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-01s3cmci: fix direct write to interrupt maskBen Dooks
The clear_imask() call should be used to clear the interrupt mask register, as it may end up clearing the SDIO interrupt bit if this is enabled. Change all writes of zero to SDIIMSK register to use clear_imask() ready for the SDIO updates. Signed-off-by: Ben Dooks <ben@simtec.co.uk> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-01s3cmci: change to use dev_pm_opsBen Dooks
Move to using dev_pm_ops for suspend and resume. Signed-off-by: Ben Dooks <ben@simtec.co.uk> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-01s3cmci: change GPIO to gpiolib from S3C24XX specific callsBen Dooks
Move to using gpiolib to access the card detect and write protect GPIO lines instead of using the platform speicifc s3c2410_gpio calls. Also ensure that the card lines are claimed the same way to avoid overlap with any other drivers. Signed-off-by: Ben Dooks <ben@simtec.co.uk> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-01s3cmci: update probe to use new platform id listBen Dooks
Use the platform id list to match the three different versions of the hardware block that this driver supports. This will change the prefix of the console messages produced by this driver to be prefixed by s3c-mci instead of the hardware block name, such as s3c2440-mci. Signed-off-by: Ben Dooks <ben@simtec.co.uk> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-01s3cmci: use resource_size() instead of local macroBen Dooks
Replace the local definition RESSIZE() with the standard resource_size() call for getting the size of a struct resource. Signed-off-by: Ben Dooks <ben@simtec.co.uk> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-21s3cmci: fix dma configuration callBen Dooks
This was missed in the DMA changes during the s3c24xx updates in commit 8970ef47d56fd3db28ee798b9d400caf08abd924. Signed-off-by: Ben Dooks <ben@simtec.co.uk> Signed-off-by: Pierre Ossman <pierre@ossman.eu>
2009-05-21[ARM] S3C24XX: Merge devel-gpioBen Dooks
Merge branch 'devel-gpio' into for-rmk-devel
2009-05-18[ARM] S3C24XX: GPIO: Move gpio functions out of <mach/hardware.h>Ben Dooks
Move all the gpio functions out of <mach/hardware.h> as this file is for defining the generic IO base addresses for the kernel IO calls. Make a new header <mach/gpio-fns.h> to take this and include it via the chain from <linux/gpio.h> which is what most of these files should be using (and will be changed as soon as possible). Note, this does make minor changes to some drivers but should not mess up any pending merges. CC: Richard Purdie <rpurdie@rpsys.net> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> CC: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-05-01[ARM] S3C24XX: Remove hardware specific registers from DMABen Dooks
calls The S3C24XX DMA API channel configuration registers are being passed values comprised of register values which makes it hard to move the API to cover both the S3C24XX and S3C64XX. These values can be calculated from knowing which device the channel is connected to, so remove them from the two calls s3c2410_dma_config and s3c2410_dma_devconfig. Signed-off-by: Ben Dooks <ben@simtec.co.uk> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-03-12mmc: s3cmci: fix s3c2410_dma_config() arguments.Ben Dooks
The s3cmci driver is calling s3c2410_dma_config with incorrect data for the DCON register. The S3C2410_DCON_HWTRIG is implicit in the channel configuration and the device selection of S3C2410_DCON_CH0_SDI is incorrect as the DMA system may not select channel 0. Signed-off-by: Ben Dooks <ben@simtec.co.uk> Acked-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-18s3cmci: Fix hangup in do_pio_write()Yauhen Kharuzhy
This commit fixes the regression what was added by commit 088a78af978d0c8e339071a9b2bca1f4cb368f30 "s3cmci: Support transfers which are not multiple of 32 bits." fifo_free() now returns amount of available space in FIFO buffer in bytes. But do_pio_write() writes to FIFO 32-bit words. Condition for return from cycle is (fifo_free() == 0), but when fifo has 1..3 bytes of free space then this condition will never be true and system hangs. This patch changes condition in the while() to (fifo_free() > 3). Signed-off-by: Yauhen Kharuzhy <jekhor@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2009-01-24[ARM] 5365/1: s3cmci: Use new include path of dma.hRamax Lo
Since dma.h has been moved to arch/arm/mach-s3c2410/include/mach, use the new include path. Signed-off-by: Ramax Lo <ramaxlo@gmail.com> Acked-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-30[ARM] S3C24XX: Move mci.h to arch/arm/plat-s3c24xx/include/platBen Dooks
Move mci.h to new position in arch/arm/plat-s3c24xx/include/plat ready to clean out old include directories. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-10-15s3cmci: Add Ben Dooks/Simtec Electronics to header & copyrightben@fluff.org.uk
Since the original authour (Thomas Kleffel) has been too busy to merge the s3cmci driver and keep it up to date, I (mostly as part of my role with Simtec Electronics) got the driver to a mergable state and have been maintaining it since I think that I should be added to the header. Also add a copyright statement for the new work. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-10-15s3cmci: fix continual accesses to host->pio_ptrben@fluff.org.uk
The s3cmci driver uses the host->pio_ptr field to point to the current position into the buffer for data transfer. During the transfers it does the following: while (fifo_words--) *(host->pio_ptr++) = readl(from_ptr); This is inefficent, as host->pio_ptr is not used in any other part of the transfer but the compiler emits code which does the following: while (fifo_words--) { u32 *ptr = host->pio_ptr; *ptr = readl(from_ptr); ptr++; host->pio_ptr = ptr; } This is obviously a waste of a load and store each time around the loop, which could be up to 16 times depending on how much needs to be transfered. Move the ptr accesses to outside the while loop so that we do not end up reloading/re-writing the pointer. Note, this seems to make the code 16 bytes larger. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-10-15s3cmci: Support transfers which are not multiple of 32 bits.Christer Weinigel
To be able to do SDIO the s3cmci driver has to support non-word-sized transfers. Change pio_words into pio_bytes and fix up all the places where it is used. This variant of the patch will not overrun the buffer when reading an odd number of bytes. When writing, this variant will still read past the end of the buffer, but since the driver can't support non-word- aligned transfers anyway, this should not be a problem, since a word-aligned transfer will never cross a page boundary. This has been tested with a CSR SDIO Bluetooth Type A device on a Samsung S3C24A0 processor. Signed-off-by: Christer Weinigel <christer@weinigel.se> Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-10-15s3cmci: cpufreq supportben@fluff.org.uk
Support for cpu frequency changing. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-10-15s3cmci: Make general protocol errors less noisyben@fluff.org.uk
General errors, such as timeouts during probe do not need to be sent to the console, so move them down to be included if the debug is enabled. Such errors include: s3c2440-sdi s3c2440-sdi: s3cmci_request: no medium present Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-08-17s3cmci: attach get_cd host opsBen Dooks
Attach the routine to get_cd to allow the MMC core to find out whether there is a card present or not without the tedious process of trying to send commands to the card or not. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-08-17s3cmci: fix sparse errors from non-exported functionsBen Dooks
Fix the following sparse errors by making the functions static and fixing the check for host->base. 598:6: warning: symbol 's3cmci_dma_done_callback' was not declared. Should it be static? 744:6: warning: symbol 's3cmci_dma_setup' was not declared. Should it be static? 1209:20: warning: Using plain integer as NULL pointer Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-23s3cmci: ensure host stopped on machine shutdownBen Dooks
Ensure that the s3cmci host controller is turned off when the machine is shutdown, otherwise we end up leaving the card powered and processing insertion and removal events after the system prints "System halted." Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-07-23s3cmci: fixes for section mismatch warningsBen Dooks
Fix the naming of various functions in the s3cmc driver to stop triggering section mismatch warnings. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-07-15MMC: S3C24XX: Refuse incorrectly aligned transfersBen Dooks
The hardware does not support any multi-block transfers with an block-size that is not 32bit aligned. Also the driver itself does not support single block non-32bit transfers either. Ensure that the s3cmci_setup_data() returns the appropriate error if we encounter this. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-07-15MMC: S3C24XX: Update error debugging.Ben Dooks
Add better debugging to show where errors are being generated, as some error codes can come from several different code paths. Also fix the error return path from s3cmci_setup_data() to return the error it returned to the request. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-07-15MMC: S3C24XX: Add media presence test to request handling.Ben Dooks
Ensure that we have physical media present before attempting to send a request to a card. This ensures that we do not get flooded by errors from commands that can never be completed timing out. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-07-15MMC: S3C24XX: Fix use of msecs where jiffies are neededBen Dooks
mmc_detect_change() takes jiffies, not msecs. Convert the previous value of msecs into jiffies before calling. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-07-15MMC: S3C24XX: Add MODULE_ALIAS() entries for the platform devicesBen Dooks
Add MODULE_ALIAS() declerations for all the supported platform devices for this driver. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-07-15MMC: S3C24XX: Fix s3c2410_dma_request() return code check.Ben Dooks
The driver should be checking for a negative error code from s3c2410_dma_request(), not non-zero. Newer kernels now return the DMA channel number that was allocated by the request. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-07-15MMC: S3C24XX: Allow card-detect on non-IRQ capable pinBen Dooks
Add support to the S3C24XX MMC driver to have the card detect be on a pin that is not IRQ capable. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-07-15MMC: S3C24XX: Ensure host->mrq->data is validBen Dooks
Fix a crash if host->mrq->data is NULL on ending a transfer. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-07-15MMC: S3C24XX: Add support to invert write protect lineBen Dooks
Support for inverting the sense of the MMC driver's write protect detection line. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-07-15MMC: S3C24XX: Add platform data for MMC/SD driverBen Dooks
This patch adds platform data support to the s3mci driver. This allows flexible board-specific configuration of set_power, card detect and read only pins. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-07-15MMC: Fix S3C24XX IRQ enable during PIO transfersRoman Moracik
Fix Bug #677 - I/O errors on heavy microSD writes for 2.6.22.x. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
