Since commit ab78029ecc34 (drivers/pinctrl: grab default handles from device
core), we can rely on device core for setting the default pins.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
The MMC core makes use of the devm_* functions while requesting the
CD/WP GPIOs, let's rely on that.
Cc: Nicolas Pitre <nico@fluxnic.net>
In order to use the mvsdio driver for sdio, it has been necessary to
use a module parameter to disable DMA so to force PIO is used. It is
then possible to use wireless LAN devices like mwifiex found on
topkick and mirabox. However, accessing an MMC SD card does work with
DMA.
Investigation has shown that MMC block device accesses are always
aligned to 64 byte boundaries, where as transfers from mwifiex are
rarely more than word aligned. It has also been determined that card
to host transfers work with DMA for SDIO devices, but host to card
transfers with DMA have problems.
This patch extends the current checks for buffers which are not word
aligned or multiple of words. All host to card transfers which are not
64 byte aligned are now also performed via PIO. This should not affect
the performance of SD cards, but allow sdio devices to work out of the
box, and they are likely to be more efficient since DMA will be used
for card to host transfers.
Tested on mirabox for wifi via mwifiex
Tested on 370 RD for file systems on an SD card.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
gcc correctly points out that hw_state can be used uninitially
in the mvsd_setup_data() function. This rearranges the function
to ensure it always contains a proper value.
Cc: Chris Ball <chris@printf.net>
Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: linux-mmc@vger.kernel.org
Acked-by: Nicolas Pitre <nico@linaro.org>
SDIO controllers found on Marvell Kirkwood SoCs seem to cause a late,
spurious irq although all interrupts have been disabled. This irq
doesn't do any harm, neither to HW nor driver. To avoid some
"unexpected irq" warning later, we workaround above issue by bailing
out of irq handler early, if we didn't expect any.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Jason Cooper <jason@lakedaemon.net>
Signed-off-by: Chris Ball <chris@printf.net>
mvsdio reports method of card detection with dev_notice, while for
removable cards it may be sane, for non-removable cards it is not.
Also, as the user cannot do anything about it, silence the message
by reducing it from dev_notice to dev_dbg.
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc
Pull MMC updates from Chris Ball:
"MMC highlights for 3.13:
Core:
- Improve runtime PM support, remove mmc_{suspend,resume}_host().
- Add MMC_CAP_RUNTIME_RESUME, for delaying MMC resume until we're
outside of the resume sequence (in runtime_resume) to decrease
system resume time.
Drivers:
- dw_mmc: Support HS200 mode.
- sdhci-eshdc-imx: Support SD3.0 SDR clock tuning, DDR on IMX6.
- sdhci-pci: Add support for Intel Clovertrail and Merrifield"
* tag 'mmc-updates-for-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (108 commits)
mmc: wbsd: Silence compiler warning
mmc: core: Silence compiler warning in __mmc_switch
mmc: sh_mmcif: Convert to clk_prepare|unprepare
mmc: sh_mmcif: Convert to PM macros when defining dev_pm_ops
mmc: dw_mmc: exynos: Revert the sdr_timing assignment
mmc: sdhci: Avoid needless loop while handling SDIO interrupts in sdhci_irq
mmc: core: Add MMC_CAP_RUNTIME_RESUME to resume at runtime_resume
mmc: core: Improve runtime PM support during suspend/resume for sd/mmc
mmc: core: Remove redundant mmc_power_up|off at runtime callbacks
mmc: Don't force card to active state when entering suspend/shutdown
MIPS: db1235: Don't use MMC_CLKGATE
mmc: core: Remove deprecated mmc_suspend|resume_host APIs
mmc: mmci: Move away from using deprecated APIs
mmc: via-sdmmc: Move away from using deprecated APIs
mmc: tmio: Move away from using deprecated APIs
mmc: sh_mmcif: Move away from using deprecated APIs
mmc: sdricoh_cs: Move away from using deprecated APIs
mmc: rtsx: Remove redundant suspend and resume callbacks
mmc: wbsd: Move away from using deprecated APIs
mmc: pxamci: Remove redundant suspend and resume callbacks
Suspend and resume of cards are handled by the protocol layer and
consequently the mmc_suspend|resume_host APIs are marked as deprecated.
While moving away from using the deprecated APIs, there are nothing
left to be done for the suspend and resume callbacks, so remove them.
Signed-off-by: Chris Ball <cjb@laptop.org>
Move probe out of __init section and don't use platform_driver_probe
which cannot be used with deferred probing.
Since commit e9354576 ("gpiolib: Defer failed gpio requests by default")
this driver might return -EPROBE_DEFER if the mmc_gpio_request_cd fails.
Cc: Chris Ball <cjb@laptop.org>
Signed-off-by: Johan Hovold <jhovold@gmail.com>
devm_request_and_ioremap() is deprecated. Use devm_ioremap_resource()
instead.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Add a debounce parameter to the mmc_gpio_request_cd() function that
enables GPIO debouncing when set to a non-zero value. This can be used
by MMC host drivers to enable debouncing on the card detect signal.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Instead of parsing the DT binding on our own, use the standard parser
mmc_of_parse(), introduced by commit 6c56e7a.
Signed-off-by: Simon Baatz <gmbnomis@gmail.com>
Tested-by: Andrew Lunn <andrew@lunn.ch>
The driver core clears the driver data to NULL after device_release
or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d
(device-core: Ensure drvdata = NULL when no driver is bound).
Thus, it is not needed to manually clear the device driver data to NULL.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Acked-by: Sonic Zhang <sonic.zhang@analog.com>
Acked-by: Seungwon Jeon <tgih.jun@samsung.com>
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Acked-by: Adrian Hunter <adrian.hunter@intel.com>
Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com>
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Tony Prisk <linux@prisktech.co.nz>
The mvsdio driver was already using some dev_*() functions to print
some messages, but still using pr_*() functions for some others. This
patch converts all messages to use dev_*() functions.
Many of the pr_*() function calls were printing the output of
mmc_hostname() to preprend the message with an identifier for the
device. Since the dev_*() functions do that automatically, this patch
also gets rid of those string prefixes.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Ralph Droms <rdroms@gmail.com> reported that 3.9-rc was breaking the
SDIO interface on his Sheevaplug platform, and that the recent changes
to the mvsdio driver are responsible for this breakage. Precisely, the
regression has been introduced by 07728b77c03d (mmc: mvsdio: use
slot-gpio for card detect gpio).
After investigation, is turns out that the Sheevaplug does not have
any "card detect" GPIO, and the Sheevaplug has not been converted to
the Device Tree. Therefore, the Sheevaplug board code does not define
a value for the .gpio_card_detect field of the mvsdio_platform_data
structure, which means that its value is 0. Unfortunately,
gpio_is_valid() considers 0 as a valid GPIO, and therefore calls
mmc_gpio_request_cd(), which fails and makes the entire probing of the
driver fail.
In fact, in the previous mvsdio code, before the Device Tree binding
was introduced, 0 was not considered as a valid GPIO. Therefore, this
fix revert back to this behavior in the non-DT case, by setting the
gpio_card_detect and gpio_write_protect local variables to -EINVAL
when the corresponding fields of the mvsdio_platform_data structure
are set to zero (i.e, left undefined). Of course, it prevents to use
GPIO 0 as a card detect or write protect GPIO, but it was a defiency
of the previous non-DT code, and the fix moving forward is to convert
platforms to the Device Tree.
The problem has been reproduced successfully on the Kirkwood-based
Marvell DB-88F6281-BP Development Board (that doesn't use the Device
Tree) and the fix has proven to work properly, after of course
removing the gpio_card_detect field of the mvsdio_platform_data
instance for this board.
Reported-by: Ralph Droms <rdroms@gmail.com>
Tested-by: Ralph Droms <rdroms@gmail.com>
This patch uses module_platform_driver_probe() macro which makes
the code smaller and simpler.
On many Marvell SoCs, the pins used for the SDIO interface are part of
the MPP pins, that are muxable pins. In order to get the muxing of
those pins correct, this commit integrates the mvsdio driver with the
pinctrl infrastructure by calling devm_pinctrl_get_select_default()
during ->probe().
Note that we permit this function to fail because not all Marvell
platforms have yet been fully converted to using the pinctrl
infrastructure.
Tested-by: Stefan Peter <s.peter@mpl.ch>
Tested-by: Florian Fainelli <florian@openwrt.org>
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
This patch adds a simple Device Tree binding for the mvsdio driver, as
well as the necessary documentation for it. Compatibility with non-DT
platforms is preserved, by keeping the platform_data based
initialization.
We introduce a small difference between non-DT and DT platforms: DT
platforms are required to provide a clocks = <...> property, which the
driver uses to get the frequency of the clock that goes to the SDIO
IP. The behaviour on non-DT platforms is kept unchanged: a clock
reference is not mandatory, but the clock frequency must be passed in
the "clock" field of the mvsdio_platform_data structure.
The MMC core subsystem provides in drivers/mmc/core/slot-gpio.c a nice
set of helper functions to simplify the management of the card detect
GPIO in MMC host drivers. This patch migrates the mvsdio driver to
using those helpers, which will make the ->probe() code simpler, and
therefore ease the process of adding a Device Tree binding for this
driver.
set of helper functions to simplify the management of the write
protect GPIO in MMC host drivers. This patch migrates the mvsdio
driver to using those helpers, which will make the ->probe() code
simpler, and therefore ease the process of adding a Device Tree
binding for this driver.
There are a number of bugs in the error paths of this driver. Make
use of devm_ functions to simplify the cleanup on error.
Based on a patch by Russell King.
Platform data for device drivers should be defined in
include/linux/platform_data/*.h, not in the architecture
and platform specific directories.
This moves such data out of the orion include directories
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Cc: Vinod Koul <vinod.koul@intel.com>
Cc: Dan Williams <djbw@fb.com>
Cc: Bryan Wu <bryan.wu@canonical.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Liam Girdwood <lrg@ti.com>
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Takashi Iwai <tiwai@suse.de>
The clk patches added code to get and enable clocks in the
respective driver probe functions. If the probe function failed
for some reason after enabling the clock, the clock was not
disabled again in many cases.
Signed-off-by: Andrew Lumm <andrew@lunn.ch>
Some orion devices can gate the SDIO clock. If the clock exists,
enable/disable it as appropriate.
Tested-by: Jamie Lentin <jm@lentin.co.uk>
Signed-off-by: Mike Turquette <mturquette@linaro.org>
Use an getter function in plat-orion/addr-map.c to get the address map
structure, rather than pass it to drivers in the platform_data
structures. When the drivers are built for none orion platforms, a
dummy function is provided instead which returns NULL.
Tested-by: Michael Walle <michael@walle.cc>
Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
All the files using printk function for displaying kernel messages
in the mmc driver have been replaced with corresponding macro.
Signed-off-by: Girish K S <girish.shivananjappa@linaro.org>
We have deprecated the distinction between hardware and physical
segments in the block layer. Consolidate the two limits into one in
drivers/mmc/.
Even though many mmc host drivers pass a pm_message_t argument to
mmc_suspend_host() that argument isn't used the by MMC core. As host
drivers are converted to dev_pm_ops they'll have to construct
pm_message_t's (as they won't be passed by the PM subsystem any more) just
to appease the mmc suspend interface.
We might as well just delete the unused paramter.
Signed-off-by: Matt Fleming <matt@console-pimps.org>
Acked-by: Anton Vorontsov <cbouatmailru@gmail.com>
Acked-by: Michal Miroslaw <mirq-linux@rere.qmqm.pl>ZZ
Acked-by: Sascha Sommer <saschasommer@freenet.de>
Cc: <linux-mmc@vger.kernel.org>
Standard data flow for MMC/SD/SDIO cards requires that the mvsdio
controller be set for big endian operation. This is causing problems
with buffers which length is not a multiple of 4 bytes as the last
partial word doesn't get shifted all the way and stored properly in
memory. Let's compensate for this.
Signed-off-by: Nicolas Pitre <nico@marvell.com>
CC: stable@kernel.org
Especially with Sandisk SDHC cards, the second SWITCH command was failing
with a timeout and the card was not recognized at all. However if the
system was busy, or debugging was enabled, or a udelay(100) was inserted
before the second SWITCH command in the core code, then the timing was
so that the card started to work.
With some unusual block sizes, the data FIFO status doesn't indicate a
"empty" state right away when the data transfer is done. Queuing
another data transfer in that condition results in a transfer timeout.
The empty FIFO bit eventually get set by itself in less than 50 usecs
when it is not set right away. So let's just poll for that bit before
configuring the controller with a new data transfer.
Signed-off-by: Pierre Ossman <pierre@ossman.eu>
Empirical evidences show that this is causing far more problems than it
solves when this mode is enabled in the host hardware. Amongst those
cards that are known to be non functional when this bit is set are:
A-Data "Speedy" 2GB SD card
Kodak 512MB SD card
Ativa 1GB MicroSD card
Marvell 8688 (WIFI/Bluetooth) SDIO card
Since those cards do work on other host controllers which do honnor the
hs timing, the issue must be with this particular host hardware.
Tested-by: Martin Michlmayr <tbm@cyrius.com>
Fix usage of obsolete parameters and functions in the driver's PM
callbacks.
Signed-off-by: Rabin Vincent <rabin@rab.in>
Acked-by: Nicolas Pitre <nico@marvell.com>
This supports MMC/SD/SDIO currently found on the Kirkwood 88F6281 and
88F6192 SoC controllers.
Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
