path: root/drivers/misc
2009-03-01Merge branch 'x86/urgent' into x86/patIngo Molnar
2009-02-27hpilo: new pci deviceDavid Altobelli
Future iLO devices will have an HP vendor id. Signed-off-by: David Altobelli <david.altobelli@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-11SGI IA64 UV: fix ia64 build error in the linux-next treeDean Nelson
Fix the ia64 build error that occurs in the linux-next tree by introducing an ia64 version of uv.h. Additionally, clean up the usage of is_uv_system(). Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-09Merge commit 'v2.6.29-rc4' into core/percpuIngo Molnar
Conflicts: arch/x86/mach-voyager/voyager_smp.c arch/x86/mm/fault.c
2009-02-05sgi-xp: fix writing past the end of kzalloc()'d spaceDean Nelson
A missing type cast results in writing way beyond the end of a kzalloc()'d memory segment resulting in slab corruption. But it seems like the better solution is to define ->recv_msg_slots as a 'void *' rather than a 'struct xpc_notify_mq_msg_uv *' and add the type cast. Signed-off-by: Dean Nelson <dcn@sgi.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-05atmel-ssc: fix misuse of dev_dbg when requested ssc instance is not foundHans-Christian Egtvedt
The ssc pointer is not valid when the id is not found in the list. Convert the message from a debug one into an error message and avoid dereferencing the bad pointer. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Huang Weiyi <weiyi.huang@gmail.com> Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-05misc: dell-laptop should depend on POWER_SUPPLYMatthew Garrett
dell-laptop makes use of the power supply class information to choose which backlight interface to change. Add a depends on it. Signed-off-by: Matthew Garrett <mjg@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Len Brown <lenb@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-05hpilo: open/close fixDavid Altobelli
The device can take a while to respond to an open/close request, so increase the time kernel will wait for response (1 ms to 10ms). Also, properly clean up a channel on a failed open, by calling the channel close routine. Just freeing the memory isn't sufficient, the device needs to be informed that the channel is no longer open, and the device memory cleared of references to freed dma buffer. Signed-off-by: David Altobelli <david.altobelli@hp.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-03sgi-xp: link XPNET's net_device_ops to its net_device structureDean Nelson
A recent patch by Stephen Hemminger to convert XPNET to use net_device_ops and internal net_device_stats failed to link the net_device_ops structure to the net_device structure. See commit e8ac9c55f28482f5b2f497a8e7eb90985db237c2 ("xpnet: convert devices to new API"). Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-30Merge branch 'linus' into core/percpuIngo Molnar
Conflicts: kernel/irq/handle.c
2009-01-29hpilo: increment versionDavid Altobelli
Bump hpilo module version to indicate that the open/close bug is fixed. Signed-off-by: David Altobelli <david.altobelli@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-29sgi-xpc: fix up stale DBUG_ON statementsRobin Holt
Clean up the stale DBUG_ON checks and add a couple new ones. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-29sgi-xpc: Remove NULL pointer dereference.Robin Holt
If the bte copy fails, the attempt to retrieve payloads merely returns a null pointer deref and not NULL as was expected. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Dean Nelson <dcn@sgi.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-29sgi-xpc: ensure flags are updated before bte_copyRobin Holt
The clearing of the msg->flags needs a barrier between it and the notify of the channel threads that the messages are cleaned and ready for use. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Dean Nelson <dcn@sgi.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-27Merge branch 'linus' into core/percpuIngo Molnar
Conflicts: arch/x86/kernel/setup_percpu.c
2009-01-26eeprom: More consistent symbol namesJean Delvare
Now that all EEPROM drivers live in the same place, let's harmonize their symbol names. Also fix eeprom's dependencies, it definitely needs sysfs, and is no longer experimental after many years in the kernel tree. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Cc: David Brownell <dbrownell@users.sourceforge.net>
2009-01-26eeprom: Move 93cx6 eeprom driver to /drivers/misc/eepromWolfram Sang
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-01-26spi: Move at25 (for SPI eeproms) to /drivers/misc/eepromWolfram Sang
2009-01-26i2c: Move old eeprom driver to /drivers/misc/eepromWolfram Sang
Update Kconfig text to specify this driver as I2C. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-01-26i2c: Move at24 to drivers/misc/eepromWolfram Sang
As drivers/i2c/chips is going to go away, move the driver to drivers/misc/eeprom. Other eeprom drivers may be moved here later, too. Update Kconfig text to specify this driver as I2C. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-01-21x86: make UV support configurableNick Piggin
Make X86 SGI Ultraviolet support configurable. Saves about 13K of text size on my modest config. text data bss dec hex filename 6770537 1158680 694356 8623573 8395d5 vmlinux 6757492 1157664 694228 8609384 835e68 vmlinux.nouv Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-21x86: uv cleanup, build fix #2Ingo Molnar
Fix more build-failure fallout from the UV cleanup - the UV drivers were not updated to include <asm/uv/uv.h>. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-21Merge branch 'x86/mm' into core/percpuIngo Molnar
Conflicts: arch/x86/mm/fault.c
2009-01-16Merge branch 'misc' into releaseLen Brown
2009-01-16dell-laptop: move to drivers/platform/x86/ from drivers/misc/Len Brown
Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-15sgi-xp: eliminate false detection of no heartbeatDean Nelson
After XPC has been up and running on multiple partitions for any length of time, if XPC on one of the partitions is stopped and restarted (either by a rmmod/insmod or a system restart), it is possible for the XPCs running on the other partitions to falsely detect a lack of heartbeat from the XPC that was just restarted. This false detection will occur if the restarted XPC comes up within the five-seconds preceding one of the other XPC's heartbeat check (which occurs once every twenty seconds). The detection of no heartbeat results in the detecting XPC deactivating from the just restarted XPC. The only remedy is to restart one of the XPCs and hope that one doesn't hit this five-second window on any of the other partitions. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Robin Holt <holt@sgi.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-11cpumask: convert misc driver functionsRusty Russell
Impact: use new cpumask API. Convert misc driver functions to use struct cpumask. To Do: - Convert iucv_buffer_cpumask to cpumask_var_t. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com> Acked-by: Dean Nelson <dcn@sgi.com> Cc: Robert Richter <robert.richter@amd.com> Cc: oprofile-list@lists.sf.net Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Chris Wright <chrisw@sous-sol.org> Cc: virtualization@lists.osdl.org Cc: xen-devel@lists.xensource.com Cc: Ursula Braun <ursula.braun@de.ibm.com> Cc: linux390@de.ibm.com Cc: linux-s390@vger.kernel.org
2009-01-09Merge branch 'drivers-platform' into releaseLen Brown
Conflicts: drivers/misc/Kconfig Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-09Merge branch 'linus' into releaseLen Brown
2009-01-09Merge branch 'fujitsu-laptop' into releaseLen Brown
2009-01-09Merge branch 'asus-eeepc' into releaseLen Brown
2009-01-09fujitsu-laptop: Simplify SBLL/SBL2 backlight handlingTony Vroon
GBLS and GBLL only differ in the clearing of the GHKS flag, so there is no need to have two backlight level readouts. Also, per Peter Gruber, the need for the BLNF check has disappeared. As a result, cleanups can be made in the code. This has been tested on the both the S6410 and the S6420 platforms and causes no functionality regressions, on the console without X or within X. One module parameter to disable the hotkeys is dropped, as we only ever took one codepath anyway. Signed-off-by: Tony Vroon <tony@linx.net> Tested-by: Peter Gruber <nokos@gmx.net> Tested-By: Stephen Gildea <stepheng+linux@gildea.com> Acked-by: Jonathan Woithe <jwoithe@physics.adelaide.edu.au> Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-09fujitsu-laptop: Add BL power, LED control and radio state informationTony Vroon
The FUNC interface in the Fujitsu-Siemens DSDT was unused until now. It exposes state information that is now reported in additional platform files (whether the radios are killed by the hardware switch or operational, whether the machine is docked and whether the lid is open). Support for the backlight class is now extended with the ability to power the backlight on & off. Optional support for the LED class allows the keyboard headlamps found on the U810 netbook and the Fujitsu logo illumination on the P8010 notebook to be turned on & off. This was fed through checkpatch.pl and tested on the S6420, P8010 & U810 platforms. Signed-off-by: Stephen Gildea <stepheng+linux@gildea.com> Tested-by: Stephen Gildea <stepheng+linux@gildea.com> Tested-by: Julian Brown <jules@panic.cs-bristol.org.uk> Signed-off-by: Tony Vroon <tony@linx.net> Tested-by: Peter Gruber <nokos@gmx.net> Acked-by: Jonathan Woithe <jwoithe@physics.adelaide.edu.au> Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (45 commits) [SCSI] qla2xxx: Update version number to 8.03.00-k1. [SCSI] qla2xxx: Add ISP81XX support. [SCSI] qla2xxx: Use proper request/response queues with MQ instantiations. [SCSI] qla2xxx: Correct MQ-chain information retrieval during a firmware dump. [SCSI] qla2xxx: Collapse EFT/FCE copy procedures during a firmware dump. [SCSI] qla2xxx: Don't pollute kernel logs with ZIO/RIO status messages. [SCSI] qla2xxx: Don't fallback to interrupt-polling during re-initialization with MSI-X enabled. [SCSI] qla2xxx: Remove support for reading/writing HW-event-log. [SCSI] cxgb3i: add missing include [SCSI] scsi_lib: fix DID_RESET status problems [SCSI] fc transport: restore missing dev_loss_tmo callback to LLDD [SCSI] aha152x_cs: Fix regression that keeps driver from using shared interrupts [SCSI] sd: Correctly handle 6-byte commands with DIX [SCSI] sd: DIF: Fix tagging on platforms with signed char [SCSI] sd: DIF: Show app tag on error [SCSI] Fix error handling for DIF/DIX [SCSI] scsi_lib: don't decrement busy counters when inserting commands [SCSI] libsas: fix test for negative unsigned and typos [SCSI] a2091, gvp11: kill warn_unused_result warnings [SCSI] fusion: Move a dereference below a NULL test ... Fixed up trivial conflict due to moving the async part of sd_probe around in the async probes vs using dev_set_name() in naming.
2009-01-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (84 commits) wimax: fix kernel-doc for debufs_dentry member of struct wimax_dev net: convert pegasus driver to net_device_ops bnx2x: Prevent eeprom set when driver is down net: switch kaweth driver to netdevops pcnet32: round off carrier watch timer i2400m/usb: wrap USB power saving in #ifdef CONFIG_PM wimax: testing for rfkill support should also test for CONFIG_RFKILL_MODULE wimax: fix kconfig interactions with rfkill and input layers wimax: fix '#ifndef CONFIG_BUG' layout to avoid warning r6040: bump release number to 0.20 r6040: warn about MAC address being unset r6040: check PHY status when bringing interface up r6040: make printks consistent with DRV_NAME gianfar: Fixup use of BUS_ID_SIZE mlx4_en: Returning real Max in get_ringparam mlx4_en: Consider inline packets on completion netdev: bfin_mac: enable bfin_mac net dev driver for BF51x qeth: convert to net_device_ops vlan: add neigh_setup dm9601: warn on invalid mac address ...
2009-01-08Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
2009-01-08misc: add dell-laptop driverMatthew Garrett
Add a driver for controlling Dell-specific backlight and rfkill interfaces. This driver makes use of the dcdbas interface to the Dell firmware to allow the backlight and rfkill interfaces on Dell systems to be driven through the standardised sysfs interfaces. Signed-off-by: Matthew Garrett <mjg@redhat.com> Cc: Matt Domsch <Matt_Domsch@dell.com> Cc: Ivo van Doorn <ivdoorn@gmail.com> Cc: Len Brown <lenb@kernel.org> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-07xpnet: convert devices to new APIStephen Hemminger
Convert to net_device_ops and internal net_device_stats Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (24 commits) trivial: chack -> check typo fix in main Makefile trivial: Add a space (and a comma) to a printk in 8250 driver trivial: Fix misspelling of "firmware" in docs for ncr53c8xx/sym53c8xx trivial: Fix misspelling of "firmware" in powerpc Makefile trivial: Fix misspelling of "firmware" in usb.c trivial: Fix misspelling of "firmware" in qla1280.c trivial: Fix misspelling of "firmware" in a100u2w.c trivial: Fix misspelling of "firmware" in megaraid.c trivial: Fix misspelling of "firmware" in ql4_mbx.c trivial: Fix misspelling of "firmware" in acpi_memhotplug.c trivial: Fix misspelling of "firmware" in ipw2100.c trivial: Fix misspelling of "firmware" in atmel.c trivial: Fix misspelled firmware in Kconfig trivial: fix an -> a typos in documentation and comments trivial: fix then -> than typos in comments and documentation trivial: update Jesper Juhl CREDITS entry with new email trivial: fix singal -> signal typo trivial: Fix incorrect use of "loose" in event.c trivial: printk: fix indentation of new_text_line declaration trivial: rtc-stk17ta8: fix sparse warning ...
2009-01-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (60 commits) uio: make uio_info's name and version const UIO: Documentation for UIO ioport info handling UIO: Pass information about ioports to userspace (V2) UIO: uio_pdrv_genirq: allow custom irq_flags UIO: use pci_ioremap_bar() in drivers/uio arm: struct device - replace bus_id with dev_name(), dev_set_name() libata: struct device - replace bus_id with dev_name(), dev_set_name() avr: struct device - replace bus_id with dev_name(), dev_set_name() block: struct device - replace bus_id with dev_name(), dev_set_name() chris: struct device - replace bus_id with dev_name(), dev_set_name() dmi: struct device - replace bus_id with dev_name(), dev_set_name() gadget: struct device - replace bus_id with dev_name(), dev_set_name() gpio: struct device - replace bus_id with dev_name(), dev_set_name() gpu: struct device - replace bus_id with dev_name(), dev_set_name() hwmon: struct device - replace bus_id with dev_name(), dev_set_name() i2o: struct device - replace bus_id with dev_name(), dev_set_name() IA64: struct device - replace bus_id with dev_name(), dev_set_name() i7300_idle: struct device - replace bus_id with dev_name(), dev_set_name() infiniband: struct device - replace bus_id with dev_name(), dev_set_name() ISDN: struct device - replace bus_id with dev_name(), dev_set_name() ...
2009-01-06ioc4: automatically load sgiioc4 subordinate moduleBrent Casavant
Modify ioc4 to always load the sgiioc4 IDE module if the board carrying the IOC4 hardware actually implements the IDE interface (not all boards bring this functionality off the IOC4 chip). A drive hosted on the IDE interface may contain the root filesystem, and sgiioc4 doesn't load automatically as ioc4 owns the PCI device ID, not sgiioc4. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Michael Reed <mdr@sgi.com> Signed-off-by: Brent Casavant <bcasavan@sgi.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06pci: use pci_ioremap_bar() in drivers/miscArjan van de Ven
Use the newly introduced pci_ioremap_bar() function in drivers/misc. pci_ioremap_bar() just takes a pci device and a bar number, with the goal of making it really hard to get wrong, while also having a central place to stick sanity checks. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06SGI: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
CC: Jack Steiner <steiner@sgi.com> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-06tifm: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
2009-01-06trivial: fix an -> a typos in documentation and commentsFrederik Schwarzer
It is always "an" if there is a vowel _spoken_ (not written). So it is: "an hour" (spoken vowel) but "a uniform" (spoken 'j') Signed-off-by: Frederik Schwarzer <schwarzerf@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-06trivial: Fix incorrect use of "loose" in event.cNick Andrew
Fix incorrect use of loose in event.c It should be 'lose', not 'loose'. Signed-off-by: Nick Andrew <nick@nick-andrew.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-05zero i_uid/i_gid on inode allocationAl Viro
... and don't bother in callers. Don't bother with zeroing i_blocks, while we are at it - it's already been zeroed. i_mode is not worth the effort; it has no common default value. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-02[SCSI] struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
[jejb: limit ioctl to returning 20 characters to avoid overrun on long device names and add a few more conversions] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-31ACPI: remove private acpica headers from driver filesLin Ming
External driver files should not include any private acpica headers. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-12-31ACPI: panasonic-laptop.c: remove ACPI_FUNCTION_TRACELin Ming
ACPI_FUNCTION_TRACE is an internal acpica function. remove ACPI_FUNCTION_TRACE from driver file Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
