path: root/drivers/misc/enclosure.c
2009-09-15driver model: constify attribute groupsDavid Brownell
Let attribute group vectors be declared "const". We'd like to let most attribute metadata live in read-only sections... this is a start. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-08-22[SCSI] ses: update enclosure data on hot addJames Bottomley
Now that hot add works correctly, if a new device is added, we're still operating on stale enclosure data, so fix that by updating the enclosure diagnostic pages when we get notified of a device hot add Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-08-22[SCSI] ses: add support for enclosure component hot removalJames Bottomley
Right at the moment, hot removal of a device within an enclosure does nothing (because the intf_remove only copes with enclosure removal not with component removal). Fix this by adding a function to remove the component. Also needed to fix the prototype of enclosure_remove_device, since we know the device we've removed but not the internal component number Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-08-22[SCSI] ses: fix hotplug with multiple devices and expandersJames Bottomley
In a situation either with expanders or with multiple enclosure devices, hot add doesn't always work. This is because we try to find a single enclosure device attached to the host. Fix this by looping over all enclosure devices attached to the host and also by making the find loop recognise that the enclosure devices may be expander remote (i.e. not parented by the host). Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-05-15[SCSI] ses: fix problems caused by empty SES provided nameYinghai Lu
We use the name provided by SES to name objects. An empty name is legal in SES but causes problems in our generic device hierarchy. Fix this by falling back to a number if the name is either NULL or empty. Also fix a secondary bug spotted in that dev_set_name(dev, name) uses a string format and so would go wrong if name contained a '%'. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-02[SCSI] struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
[jejb: limit ioctl to returning 20 characters to avoid overrun on long device names and add a few more conversions] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-22[SCSI] ses: fix up functionality after class_device->device conversionJames Bottomley
ses uses an unusual two level class hierarchy which broke in this conversion. Fix it up still with a two level hierarchy, but this time let the ses device manage the links to and from the real device in the enclosure. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-19SCSI: convert struct class_device to struct deviceTony Jones
It's big, but there doesn't seem to be a way to split it up smaller... Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Roland Dreier <rolandd@cisco.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Hal Rosenstock <hal.rosenstock@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-07[SCSI] enclosure: add support for enclosure servicesJames Bottomley
The enclosure misc device is really just a library providing sysfs support for physical enclosure devices and their components. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
