path: root/drivers/misc/eeprom/at25.c
2010-05-21sysfs: add struct file* to bin_attr callbacksChris Wright
This allows bin_attr->read,write,mmap callbacks to check file specific data (such as inode owner) as part of any privilege validation. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-14init dynamic bin_attribute structuresWolfram Sang
Commit 6992f5334995af474c2b58d010d08bc597f0f2fe ("sysfs: Use one lockdep class per sysfs attribute.") introduced this requirement. First, at25 was fixed manually. Then, other occurences were found with coccinelle and the following semantic patch. Results were reviewed and fixed up: @ init @ identifier struct_name, bin; @@ struct struct_name { ... struct bin_attribute bin; ... }; @ main extends init @ expression E; statement S; identifier name, err; @@ ( struct struct_name *name; | - struct struct_name *name = NULL; + struct struct_name *name; ) ... ( sysfs_bin_attr_init(&name->bin); | + sysfs_bin_attr_init(&name->bin); if (sysfs_create_bin_file(E, &name->bin)) S | + sysfs_bin_attr_init(&name->bin); err = sysfs_create_bin_file(E, &name->bin); ) Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23spi: prefix modalias with "spi:"Anton Vorontsov
This makes it consistent with other buses (platform, i2c, vio, ...). I'm not sure why we use the prefixes, but there must be a reason. This was easy enough to do it, and I did it. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Jean Delvare <khali@linux-fr.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Samuel Ortiz <sameo@openedhand.com> Cc: "John W. Linville" <linville@tuxdriver.com> Acked-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-29eeprom/at25: bugfix "not ready" timeout after writeSebastian Heutling
Under certain circumstances msleep(1) within the loop, which waits for the EEPROM to be finished, might take longer than the timeout. On the next loop the status register might now return to be ready and therefore the loop finishes. The following check now tests if a timeout occurred and if so returns an error although the device reported it was ready. This fix replaces testing the occurrence of the timeout by testing the "not ready" bit in the status register. Signed-off-by: Sebastian Heutling <heutling@who-ing.de> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13at25: make input buffers of at25_*write() constGeert Uytterhoeven
| drivers/misc/eeprom/at25.c:358: warning: assignment from incompatible pointer type Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02memory_accessor: implement the new memory_accessor interfaces for SPI EEPROMsDavid Brownell
- Define new setup() hook to export the accessor - Implement accessor methods Moves some error checking out of the sysfs interface code into the layer below it, which is now shared by both sysfs and memory access code. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-26spi: Move at25 (for SPI eeproms) to /drivers/misc/eepromWolfram Sang
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
