path: root/drivers/misc/cxl/main.c
2015-06-03cxl: Move include file cxl.h -> cxl-base.hMichael Neuling
This moves the current include file from cxl.h -> cxl-base.h. This current include file is used only to pass information between the base driver that needs to be built into the kernel and the cxl module. This is to make way for a new include/misc/cxl.h which will contain just the kernel API for other driver to use Signed-off-by: Michael Neuling <mikey@neuling.org> Acked-by: Ian Munsie <imunsie@au1.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-01-22cxl: Add tracepointsIan Munsie
This patch adds tracepoints throughout the cxl driver, which can provide insight into: - Context lifetimes - Commands sent to the PSL and AFU and their completion status - Segment and page table misses and their resolution - PSL and AFU interrupts - slbia calls from the powerpc copro_fault code These tracepoints are mostly intended to aid in debugging (particularly for new AFU designs), and may be useful standalone or in conjunction with hardware traces collected by the PSL (read out via the trace interface in debugfs) and AFUs. Signed-off-by: Ian Munsie <imunsie@au1.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2014-10-08cxl: Driver code for powernv PCIe based cards for userspace accessIan Munsie
This is the core of the cxl driver. It adds support for using cxl cards in the powernv environment only (ie POWER8 bare metal). It allows access to cxl accelerators by userspace using the /dev/cxl/afuM.N char devices. The kernel driver has no knowledge of the function implemented by the accelerator. It provides services to userspace via the /dev/cxl/afuM.N devices. When a program opens this device and runs the start work IOCTL, the accelerator will have coherent access to that processes memory using the same virtual addresses. That process may mmap the device to access any MMIO space the accelerator provides. Also, reads on the device will allow interrupts to be received. These services are further documented in a later patch in Documentation/powerpc/cxl.txt. Documentation of the cxl hardware architecture and userspace API is provided in subsequent patches. Signed-off-by: Ian Munsie <imunsie@au1.ibm.com> Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
