path: root/drivers/misc/Kconfig
2009-12-17cs5535: CS5535_MFGPT_DEFAULT_IRQ should depend on CS5535_MFGPTGeert Uytterhoeven
It doesn't make much sense to have CS5535_MFGPT_DEFAULT_IRQ show up in configs that cannot have CS5535_MFGPT. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Andres Salomon <dilinger@collabora.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15Merge branch 'dell-laptop' into releaseLen Brown
2009-12-15cs5535: drop the Geode-specific MFGPT/GPIO codeAndres Salomon
With generic modular drivers handling all of this stuff, the geode-specific code can go away. The cs5535-gpio, cs5535-mfgpt, and cs5535-clockevt drivers now handle this. Signed-off-by: Andres Salomon <dilinger@collabora.co.uk> Cc: Jordan Crouse <jordan@cosmicpenguin.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Chris Ball <cjb@laptop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15cs5535: add a generic MFGPT driverAndres Salomon
This is based on the old code on arch/x86/kernel/mfgpt_32.c, except it's not x86 specific, it's modular, and it makes use of a PCI BAR rather than a random MSR. Currently module unloading is not supported; it's uncertain whether or not it can be made work with the hardware. [akpm@linux-foundation.org: add X86 dependency] Signed-off-by: Andres Salomon <dilinger@collabora.co.uk> Cc: Jordan Crouse <jordan@cosmicpenguin.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Chris Ball <cjb@laptop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15drivers/misc: add driver for Texas Instruments DAC7512Daniel Mack
Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: "H Hartley Sweeten" <hartleys@visionengravers.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15ad525x_dpot: new driver for AD525x digital potentiometersMichael Hennerich
This driver supports the non-volatile digital potentiometers via I2C: AD5258, AD5259, AD5251, AD5252, AD5253, AD5254, and AD5255 It provides a sysfs interface to each device for reading/writing which is documented in Documentation/misc-devices/ad525x_dpot.txt. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Chris Verges <chrisv@cyberswitching.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-10dell-laptop: remove duplicate Kconfig entry under drivers/miscAlan Jenkins
This showed up as an unselectable option when using xconfig and searching for "dell". It must been overlooked when dell-laptop was moved to drivers/platform/x86. Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-08Merge branch 'i2c-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: i2c-stub: Documentation update i2c-stub: Allow user to disable some commands i2c-stub: Implement I2C block support i2c: Refactor for_each callbacks i2c-i801: Retry on lost arbitration i2c: Remove big kernel lock from i2cdev_open ics932s401: Clean up detect function i2c: Simplify i2c_detect_address i2c: Drop probe, ignore and force module parameters i2c: Add missing __devinit markers to old i2c adapter drivers i2c: Bus drivers don't have to support I2C_M_REV_DIR_ADDR i2c: Prevent priority inversion on top of bus lock i2c-voodoo3: Delete i2c-powermac: Drop temporary name buffer i2c-powermac: Include the i2c_adapter in struct pmac_i2c_bus i2c-powermac: Log errors i2c-powermac: Refactor i2c_powermac_smbus_xfer i2c-powermac: Reject unsupported I2C transactions i2c/chips: Move ds1682 to drivers/misc
2009-12-06i2c/chips: Move ds1682 to drivers/miscWolfram Sang
As i2c/chips is deprecated, move ds1682 to a more apropriate location. Build tested. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-10-19iwmc3200top: Add Intel Wireless MultiCom 3200 top driver.Tomas Winkler
This patch adds Intel Wireless MultiCom 3200 top driver. IWMC3200 is 4Wireless Com CHIP (GPS/BT/WiFi/WiMAX). Top driver is responsible for device initialization and firmware download. Firmware handled by top is responsible for top itself and as well as bluetooth and GPS coms. (Wifi and WiMax provide their own firmware) In addition top driver is used to retrieve firmware logs and supports other debugging features Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-30ARM: 5628/1: ep93xx: Introduce Pulse Width Modulator (PWM) driverHartley Sweeten
The EP93xx features two PWMs (one on the EP9307) with the following features: * Configurable dual output * Separate input clocks for each PWM output * 16-bit resolution * Programmable pulse width (duty cycle), interval (frequency), and polarity This adds the necessary core support as well as the driver. A sysfs interface is provided to control the PWM outputs. Signed-off-by: Matthieu Crapet <mcrapet@gmail.com> Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-06-13mmc: Driver for CB710/720 memory card reader (MMC part)Michał Mirosław
The code is divided in two parts. There is a virtual 'bus' driver that handles PCI device and registers three new devices one per card reader type. The other driver handles SD/MMC part of the reader. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: Pierre Ossman <pierre@ossman.eu>
2009-04-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (28 commits) trivial: Update my email address trivial: NULL noise: drivers/mtd/tests/mtd_*test.c trivial: NULL noise: drivers/media/dvb/frontends/drx397xD_fw.h trivial: Fix misspelling of "Celsius". trivial: remove unused variable 'path' in alloc_file() trivial: fix a pdlfush -> pdflush typo in comment trivial: jbd header comment typo fix for JBD_PARANOID_IOFAIL trivial: wusb: Storage class should be before const qualifier trivial: drivers/char/bsr.c: Storage class should be before const qualifier trivial: h8300: Storage class should be before const qualifier trivial: fix where cgroup documentation is not correctly referred to trivial: Give the right path in Documentation example trivial: MTD: remove EOL from MODULE_DESCRIPTION trivial: Fix typo in bio_split()'s documentation trivial: PWM: fix of #endif comment trivial: fix typos/grammar errors in Kconfig texts trivial: Fix misspelling of firmware trivial: cgroups: documentation typo and spelling corrections trivial: Update contact info for Jochen Hein trivial: fix typo "resgister" -> "register" ...
2009-04-02sgi-gru: remove SGI_GRU as a valid config option for ia64 configs with SGI_UVRobin Holt
Some current configs turn on GRU for ia64. The GRU code does not correctly load on boot on ia64 (GRU does continue to work for x86-64), so changing the IA64 Kconfig to not select GRU on ia64 configs for now until we have time to fix. Signed-off-by: Robin Holt <holt@sgi.com> Acked-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01drivers/misc/isl29003.c: driver for the ISL29003 ambient light sensorDaniel Mack
Add a driver for Intersil's ISL29003 ambient light sensor device plus some documentation. Inspired by tsl2550.c, a driver for a similar device. It is put in drivers/misc for now until the industrial I/O framework gets merged. Signed-off-by: Daniel Mack <daniel@caiaq.de> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30trivial: fix typos/grammar errors in Kconfig textsMatt LaPlante
Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-02-09Merge commit 'v2.6.29-rc4' into core/percpuIngo Molnar
Conflicts: arch/x86/mach-voyager/voyager_smp.c arch/x86/mm/fault.c
2009-02-05misc: dell-laptop should depend on POWER_SUPPLYMatthew Garrett
dell-laptop makes use of the power supply class information to choose which backlight interface to change. Add a depends on it. Signed-off-by: Matthew Garrett <mjg@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Len Brown <lenb@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-27Merge branch 'linus' into core/percpuIngo Molnar
Conflicts: arch/x86/kernel/setup_percpu.c
2009-01-26eeprom: Move 93cx6 eeprom driver to /drivers/misc/eepromWolfram Sang
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-01-26i2c: Move at24 to drivers/misc/eepromWolfram Sang
As drivers/i2c/chips is going to go away, move the driver to drivers/misc/eeprom. Other eeprom drivers may be moved here later, too. Update Kconfig text to specify this driver as I2C. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-01-21x86: make UV support configurableNick Piggin
Make X86 SGI Ultraviolet support configurable. Saves about 13K of text size on my modest config. text data bss dec hex filename 6770537 1158680 694356 8623573 8395d5 vmlinux 6757492 1157664 694228 8609384 835e68 vmlinux.nouv Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-09Merge branch 'drivers-platform' into releaseLen Brown
Conflicts: drivers/misc/Kconfig Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-09Merge branch 'linus' into releaseLen Brown
2009-01-08misc: add dell-laptop driverMatthew Garrett
Add a driver for controlling Dell-specific backlight and rfkill interfaces. This driver makes use of the dcdbas interface to the Dell firmware to allow the backlight and rfkill interfaces on Dell systems to be driven through the standardised sysfs interfaces. Signed-off-by: Matthew Garrett <mjg@redhat.com> Cc: Matt Domsch <Matt_Domsch@dell.com> Cc: Ivo van Doorn <ivdoorn@gmail.com> Cc: Len Brown <lenb@kernel.org> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-23eeepc-laptop: use select and not depends onCorentin Chary
As len said: "Kconfig should offer users features, and not make users devine their dependencies. Signed-off-by: Corentin Chary <corentincj@iksaif.net> Signed-off-by: Len Brown <len.brown@intel.com>
2008-12-19create drivers/platform/x86/ from drivers/misc/Len Brown
Move x86 platform specific drivers from drivers/misc/ to a new home under drivers/platform/x86/. The community has been maintaining x86 vendor-specific platform specific drivers under /drivers/misc/ for a few years. The oldest ones started life under drivers/acpi. They moved out of drivers/acpi/ because they don't actually implement the ACPI specification, but either simply use ACPI, or implement vendor-specific ACPI extensions. In the future we anticipate... drivers/misc/ will go away. other architectures will create drivers/platform/<arch> Signed-off-by: Len Brown <len.brown@intel.com>
2008-12-19drivers/misc/Makefile, Kconfig: cleanupLen Brown
tabs->space and delete unnecessary dummy build-in.o rule. Suggested-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-11-12Add c2 port supportRodolfo Giometti
C2port implements a two wire serial communication protocol (bit banging) designed to enable in-system programming, debugging, and boundary-scan testing on low pin-count Silicon Labs devices. Currently this code supports only flash programming through sysfs interface but extensions shoud be easy to add. Signed-off-by: Rodolfo Giometti <giometti@linux.it> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12ics932s401: new clock generator chip driverDarrick J. Wong
The ics932s401 is a clock generator chip. This driver allows users to read the current clock outputs. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06ACPI: remove CONFIG_ACPI_ECBjorn Helgaas
Remove CONFIG_ACPI_EC. It was always set the same as CONFIG_ACPI, and it had no menu label, so there was no way to set it to anything other than "y". Per section 6.5.4 of the ACPI 3.0b specification, OSPM must make Embedded Controller operation regions, accessed via the Embedded Controllers described in ECDT, available before executing any control method. The ECDT table is optional, but if it is present, the above text means that the EC it describes is a required part of the ACPI subsystem, so CONFIG_ACPI_EC=n wouldn't make sense. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-23Merge branch 'linus' into testLen Brown
Conflicts: MAINTAINERS arch/x86/kernel/acpi/boot.c arch/x86/kernel/acpi/sleep.c drivers/acpi/Kconfig drivers/pnp/Makefile drivers/pnp/quirks.c Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-22Merge branch 'panasonic' into testLen Brown
2008-10-22panasonic-laptop: depends on ACPIRandy Dunlap
panasonic-laptop uses many acpi_*() functions so it should depend on ACPI; otherwise there are approximately 70 warnings/errors generated. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Harald Welte <laforge@gnumonks.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-16AT91: atmel_pwm only available for certain AT91 processorsAndrew Victor
Only three of Atmel's AT91 processors (SAM9263, SAM9RL and CAP9) include a PWM controller. It should therefore only be possible to enable the misc/atmel_pwm.c driver on those processors (and not all AT91 processors). Signed-off-by: Andrew Victor <linux@maxim.org.za> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16eeepc: depends on RFKILLRandy Dunlap
EEEPC_LAPTOP uses RFKILL, so the former should depend on RFKILL. Build errors happen when EEEPC_LAPTOP=y and RFKILL=m. eeepc-laptop.c:(.text+0xd5a7b): undefined reference to `rfkill_allocate' eeepc-laptop.c:(.text+0xd5b04): undefined reference to `rfkill_register' eeepc-laptop.c:(.text+0xd5b48): undefined reference to `rfkill_allocate' eeepc-laptop.c:(.text+0xd5bd4): undefined reference to `rfkill_register' eeepc-laptop.c:(.text+0xd5ece): undefined reference to `rfkill_unregister' eeepc-laptop.c:(.text+0xd5ef6): undefined reference to `rfkill_unregister' make[1]: *** [.tmp_vmlinux1] Error 1 Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Corentin Chary <corentincj@iksaif.net> Cc: Matthew Garrett <mjg@redhat.com> Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: Karol Kozimor <sziwan@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-08acer-wmi: Add rfkill support for wireless and bluetoothCarlos Corbacho
This patch implements rfkill support for the wireless and bluetooth devices commonly found on Acer laptops. For now, we will always poll these devices once a second to guarantee we can catch state changes. On newer Acer laptops, it may be possible to rely on WMI events to do this instead, and experimental support for this will be added in a later patch. 3G has been deliberately left off for now, as we still have no way to detect it, (nor, AFAIK, has any Linux user tried the code) and on laptops that don't support 3G, trying to poll for the status will leave the logs full of ACPI tracebacks. The old sysfs interface for wireless and bluetooth will be removed in a later patch. (Thanks to Henrique de Moraes Holschuh and Dmitry Torokhov for reviewing this patch). Signed-off-by: Carlos Corbacho <carlos@strangeworlds.co.uk> Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Len Brown <len.brown@intel.com>
2008-09-24panasonic-laptop: add Panasonic Let's Note laptop extras driver v0.94Harald Welte
This is a driver for ACPI extras such as hotkeys and backlight brightness control on various Panasonic "Let's Note" series laptop computers. It exports the backlight via the backlight class device API, and the hotkeys as input event device. Some more esoteric items like number of installed batteries are exported via sysfs device attributes. Hotkey events also generate old-style ACPI enents through /proc/acpi/event to interoperate with current versions of acpid. Signed-off-by: Harald Welte <laforge@gnumonks.org> Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Acked-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-08-04[IA64] Fix uniprocessor build w.r.t. SGI_XP and SGI_GRUTony Luck
The SGI XP and GRU drivers only work on SMP systems ... the Kconfig file only disallowed them for non-SMP X86. Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-08-01add reverse dependency of CONFIG_SGI_XP upon CONFIG_SGI_GRUDean Nelson
Add a reverse dependency of CONFIG_SGI_XP upon CONFIG_SGI_GRU to Kconfig. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-01add dependency of CONFIG_SGI_XP upon CONFIG_NETDean Nelson
Add a dependency of CONFIG_SGI_XP upon CONFIG_NET to Kconfig. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: enable building of XPC/XPNET on x86_64Dean Nelson
Get XPC/XPNET to build on x86_64. Trying to modprobe them up on a non-UV or sn2 system will result in a -ENODEV. Signed-off-by: Dean Nelson <dcn@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30GRU Driver: driver/misc Makefile & Kconfig changesJack Steiner
Driver/misc changes for the GRU driver Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25kconfig: fix typos: "Suport" -> "Support"Heikki Orsila
Signed-off-by: Heikki Orsila <heikki.orsila@iki.fi> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-25drivers/misc/phantom: note PCIJiri Slaby
Tell users that the driver is only for PCI devices to stop asking for support of firewire and parallel devices. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25drivers/misc/hpilo.c needs CONFIG_PCIAndrew Morton
m68k allmodconfig: drivers/misc/hpilo.c: In function 'ilo_ccb_close': drivers/misc/hpilo.c:225: error: implicit declaration of function 'pci_free_consistent' drivers/misc/hpilo.c: In function 'ilo_ccb_open': drivers/misc/hpilo.c:244: error: implicit declaration of function 'pci_alloc_consistent' drivers/misc/hpilo.c:245: warning: assignment makes pointer from integer without a cast Cc: David Altobelli <david.altobelli@hp.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25misc: add HP WMI laptop extras driverMatthew Garrett
This driver adds support for reading and configuring certain information on modern HP laptops with WMI BIOS interfaces. It supports enabling and disabling the ambient light sensor, querying attached displays and hard drive temperature, sending events on docking and querying the state of the dock and toggling the state of the wifi, bluetooth and wwan hardware via rfkill. It also makes the little "(i)" button work on machines that send that via WMI rather than via the keyboard controller. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24Merge branch 'release-2.6.27' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-acpi-2.6 * 'release-2.6.27' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-acpi-2.6: acpi: fix crash in core ACPI code, triggered by CONFIG_ACPI_PCI_SLOT=y ACPI: thinkpad-acpi: don't misdetect in get_thinkpad_model_data() on -ENOMEM ACPI: thinkpad-acpi: bump up version to 0.21 ACPI: thinkpad-acpi: add bluetooth and WWAN rfkill support ACPI: thinkpad-acpi: WLSW overrides other rfkill switches ACPI: thinkpad-acpi: prepare for bluetooth and wwan rfkill support ACPI: thinkpad-acpi: consolidate wlsw notification function ACPI: thinkpad-acpi: minor refactor on radio switch init Revert "ACPI: don't walk tables if ACPI was disabled" Revert "dock: bay: Don't call acpi_walk_namespace() when ACPI is disabled." Revert "Fix FADT parsing" ACPI : Set FAN device to correct state in boot phase ACPI: Ignore _BQC object when registering backlight device ACPI: stop complaints about interrupt link End Tags and blank IRQ descriptors
2008-07-21HP iLO driverDavid Altobelli
A driver for the HP iLO/iLO2 management processor, which allows userspace programs to query the management processor. Programs can open a channel to the device (/dev/hpilo/dXccbN), and use this to send/receive queries. The O_EXCL open flag is used to indicate that a particular channel cannot be shared between processes. This driver will replace various packages HP has shipped, including hprsm and hp-ilo. Signed-off-by: David Altobelli <david.altobelli@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21ACPI: thinkpad-acpi: add bluetooth and WWAN rfkill supportHenrique de Moraes Holschuh
Add a read/write rfkill interface to the bluetooth radio switch on the bluetooth submodule, and one for the wireless wan radio switch to the wan submodule. Since rfkill does care for when a switch changes state, use WLSW notifications to also check if the WWAN or Bluetooth switches did not change state (due to them being slaves of WLSW in firmware/hardware, but that reality not being always properly exported by the thinkpad firmware). Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: Ivo van Doorn <IvDoorn@gmail.com> Cc: John W. Linville <linville@tuxdriver.com>
