When unplug, blank happens, HDMI audio can't play properly. So in
driver, audio pcm would be disconnected when event above happens.
However, pulse audio can't process disconnect event properly and if an
blank or unplug event happens, HDMI sink would lost and can't be back
again.
In this patch, instead of disconnecting audio PCM stream, triggering
stop audio pcm while unplug and blank, triggering start again while plug
and unblank if the audio pcm is triggerd stop in the unplug/blank event.
Signed-off-by: Chen Liangjun <b36089@freescale.com>
In this patch, add support for:
1. Interface for HDMI audio to register PCM into HDMI core driver.
2. Interface for HDMI video driver to stop HDMI audio
3. Interface for HDMI video driver to inform the state of HDMI cable and
state of HDMI blank.
In RIGEL TO1.1, the same HDMI_SDMA fix is introduced as ARIK TO1.2. Add
support for RIGEL TO1.1 for HDMI_SDMA functionality.
In this patch:
1.Add hdmi_SDMA_check() interface to judge whether MX6 chip
support HDMI_SDMA.
2.Replace mx6q_version() check with hdmi_SDMA_check() to support
both ARIK To1.2 and RIGEL TO1.1.
1.remove related old code in pfuze driver
2.add i2c write retry as i2c read retry.
Signed-off-by: Robin Gong <B38343@freescale.com>
It is a warning cause by HDMI driver irq enable count mismatch.
The purpose of maintain HDMI irq count is to disable hdmi_iahb_clk
when HDMI cable plugout.
But hdmi_iahb_clk parent ahb clock is always enabled when system run,
so hdmi_iabh_clk power consumption is very low.
The function clk_get_usecount introduce by irq count maintain
is not safety in SMP.
Remove HDMI irq count in HDMI driver, keep hdmi_iahb_clk always run.
and disable hdmi_iahb_clk and hdmi_isfr_clk when FB Blank.
Signed-off-by: Sandor Yu <R01008@freescale.com>
It is cause by HDMI audio driver can't get right pixel clock
from IPU driver if pixel clock source from HSP clock not from
DI clock.
HDMI driver get pixel clock by call clk_get_rate() function,
but the function return actually clock, in some videomode the
actually pixel clock is not right equal the pixel clock in CEA spec.
Get pixel clock from video mode struct instead of CCM register.
480P HDMI audio can work.
because mx6sl arm2 board didn't use pfuse INT, pfuze driver should judge if no
interrupt.
update pixel clock name in HDMI Audio driver
This patch includes some of the clk enable/disable changes from rev2
Check the version of the HDMI IP to determine whether the fifo
threshold needs to be high. The i.Mx6dl version of the HDMI doesn't
need the workaround. All other parts of the workaround are used
for both parts for code simplicity.
For i.Mxq, set the Threshold of audio fifo as: FIFO depth - 2 (fixed
and independent of the number of channels actually used).
Use unspecified length ahb bursts (using fixed INCRx will make the
audio dma fail).
Additionally and in order to get it working on all conditions it will
be necessary to run the following sw steps at startup of video and audio
(or when video changes or audio changes):
1-Configure AUD_N1 and AUD_CTS1 registers with final value and let the
AUD_N2, AUD_N3, AUD_CTS2 and AUD_CTS3 to 0s.
2-Configure start and end addresses of audio DMA registers.
3-Start DMA operation
4-Configure the AUD_CTS2 and AUD_CTS3 with the final value.
5-Configure the AUD_N2 and AUD_N3 with final value.
Signed-off-by: Alan Tull <r80115@freescale.com>
add wm8958 audio codec support
Signed-off-by: Gary Zhang <b13634@freescale.com>
Don't show hdmi as an audio playback device if hdmi isn't
configured on the command line.
Add functionality to parse Audio Data Blocks from EDID data to
find out what modes of LPCM are suppored by the HDMI sink device.
The parsed settings are saved in the hdmi mfd. The HDMI audio driver
will check the settings when the audio stream is opened and will
then apply appropriate constraints.
If we are unable to read from the EDID, then we default to supporting
Basic Audio as defined by the HDMI specification (stereo, 16 bit,
32KHz, 44.1KHz, 48KHz PCM).
Remove usless code in pfuze100 regulator driver
Signed-off-by: Robin Gong <b38343@freescale.com>
Signed-off-by: Nancy Chen <Nancy.Chen@freescale.com>
fix the building errors when upgrade to v3.0
we use data_size from mfd_cell struct on 2.6.38, but after that
there are some changes for this field of mfd_cell struct, see:
commit 40e03f571b2e63827f2afb90ea9aa459612c29e3
Author: Andres Salomon <dilinger@queued.net>
Date: Thu Feb 17 19:07:24 2011 -0800
mfd: Drop data_size from mfd_cell struct
Now that there are no more users of this, drop it.
Signed-off-by: Andres Salomon <dilinger@queued.net>
and this:
commit eb8956074e7652e802be5f078080c704c2c87104
Author: Samuel Ortiz <sameo@linux.intel.com>
Date: Wed Apr 6 16:52:52 2011 +0200
mfd: Add platform data pointer back
Now that we have a way to pass MFD cells down to the sub drivers,
we can gradually get rid of mfd_data by putting the platform pointer
back in place.
But the above commit also change the name from data_size to pdata_size,
This patch just give one fix for the pfuze driver to use pdata_size field.
Signed-off-by: Jason Liu <r64343@freescale.com>
fix build warnings on pfuze driver:
arch/arm/mach-mx6/mx6q_sabreauto_pmic_pfuze100.c:388:
warning: initialization from incompatible pointer type
drivers/mfd/pfuze-core.c:523:
drivers/mfd/pfuze-core.c:412:
warning: 'pfuze_add_subdevice' defined but not used
add pfuze core driver for mx6
This commit intends to implement the flowchart and details
documented in the HDMI Transmitter Controller User Guide
section entitled "Programming Model".
Some input is also from the Synopsys API code.
The HDMI specification requires HDMI to set itself to VGA DVI mode
before reading the EDID.
So follow this sequence when HDMI is hotplugged:
1. Hdmi connector is plugged in, HDMI video gets an interrupt.
2. Clear out video mode list. Add only VGA DVI mode to list.
3. Request VGA DVI mode (call fb_set_var())
4. HDMI video driver will get FB_EVENT_MODE_CHANGE callback and
call mxc_hdmi_setup() to set up HDMI.
5. Read the edid and add video modes from edid. Select the video
mode that is similar to the command line default.
6. Request VGA DVI mode (call fb_set_var())
7. HDMI video driver will get FB_EVENT_MODE_CHANGE callback and
do mxc_hdmi_setup().
Also included is a workaround for an overflow condition in the HDMI.
The frame composer has an arithmetic unit that gets updated every time
we write to one of the FC registers. But sometimes, depending on the
relation between the tmds and sfr clocks, it may happen that this unit
doesn't get updated, even though the registers are holding correct
values. The workaround for this is, after completing the controller
configuration, to rewrite one of the FC registers (i.e. FC_INVIDCONF)
three or four times with the same value, and then follow it up by a SW
reset to the TMDS clock domain (MC_SWRSTZ).
We clear the overflow condition as described above every time we
change video mode. Also an overflow interupt handler will clear the
overflow condition if it happens again. This overflow condition is
expected (and not a problem) when we are in DVI (non-HDMI) mode, so
we do not worry about it in that case.
Signed-off-by: Alan Tull <alan.tull@freescale.com>
- Added V3P3 regulator to max17135
- Added calls to enable/disable V3P3 regulator from EPDC driver
- Improved Kconfig detail for max17135 MFD and HWMON entries
Signed-off-by: Danny Nold <dannynold@freescale.com>
Audio driver for i.Mx built-in HDMI Transmitter.
* Uses HDMI Transmitter's built-in DMA.
* Adds IEC958-style digital audio header info to the raw audio.
* Gets pixel clock from the IPU driver and calculates clock
regenerator values (cts and N).
* Move ipu_id, and disp_id from the HDMI's platform data to the
HDMI mfd's platform data. Saves them in the hdmi mfd.
* Add mfd functionality to update the clock regenerator values
when the hdmi changes the pixel clock rate or when requested
from the audio driver with a new audio sample rate.
add new mc34708's core driver based on MFD
- Ensure HDMI clocks are disabled when leaving HDMI core probe function.
- Create HDMI core api to allow HDMI sub-drivers to init, enable, and
disable the HDMI IRQ. Required to optimally manage HDMI clocks,
allow IAHB to be disabled, and still have video and audio sub-drivers
able to receive interrupts.
- Update code to adjust for decoupled ISFR and IAHB clocks.
- Disable IAHB clocks whenever HDMI not plugged in.
This is a mfd for the internal HDMI Transmitter on i.Mx. It handles
resources that are shared by the seperate video and audio drivers.
- Ported MAX17135 MFD core driver to 2.6.38
- Ported MAX17135 HWMON temperature sensor driver to 2.6.38
- Ported MAX17135 regulator driver to 2.6.38
Fix da9053 backlight Kconfig error
porting da9052 regulator driver
Signed-off-by: Zhou Jingyu <Jingyu.Zhou@freescale.com>
Acked-by: Lily Zhang <r58066@freescale.com>
Add DA9053 original source code
commit 3f8349e6e98ba0455437724589072523865eae5e upstream.
TWL6030 family of PMIC use a shadow interrupt status register
while kernel processes the current interrupt event.
However, any write(0 or 1) to register INT_STS_A, INT_STS_B or
INT_STS_C clears all 3 interrupt status registers.
Since clear of the interrupt is done on 32k clk, depending on I2C
bus speed, we could in-adverently clear the status of a interrupt
status pending on shadow register in the current implementation.
This is due to the fact that multi-byte i2c write operation into
three seperate status register could result in multiple load
and clear of status and result in lost interrupts.
Instead, doing a single byte write to INT_STS_A register with 0x0
will clear all three interrupt status registers without the related
risk.
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Signed-off-by: Nishanth Menon <nm@ti.com>
commit 97e43c983c721a47546e6db3b7711dcd912a6481 upstream.
Silence following warnings:
WARNING: drivers/mfd/cs5535-mfd.o(.data+0x20): Section mismatch in
reference from the variable cs5535_mfd_drv to the function
.devinit.text:cs5535_mfd_probe()
The variable cs5535_mfd_drv references
the function __devinit cs5535_mfd_probe()
If the reference is valid then annotate the
variable with __init* or __refdata (see linux/init.h) or name the variable:
*driver, *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console
WARNING: drivers/mfd/cs5535-mfd.o(.data+0x28): Section mismatch in
.devexit.text:cs5535_mfd_remove()
the function __devexit cs5535_mfd_remove()
variable with __exit* (see linux/init.h) or name the variable:
Rename the variable from *_drv to *_driver so
modpost ignore the OK references to __devinit/__devexit
functions.
Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Acked-by: Andres Salomon <dilinger@queued.net>
commit 81b5482c32769abb6dfb979560dab2f952ba86fa upstream.
The code is currently always checking the first resource of every
device only (several times.) This has been broken since the ACPI check
was added in February 2010 in commit
91fedede0338eb6203cdd618d8ece873fdb7c22c.
Fix the check to run on each resource individually, once.
commit 3d6271f92e98094584fd1e609a9969cd33e61122 upstream.
Without turning the MADC clock on, no MADC conversions occur.
$ cat /sys/class/hwmon/hwmon0/device/in8_input
[ 53.428436] twl4030_madc twl4030_madc: conversion timeout!
cat: read error: Resource temporarily unavailable
Signed-off-by: Kyle Manna <kyle@kylemanna.com>
commit d0e84caeb4cd535923884735906e5730329505b4 upstream.
If the twl4030-madc device wasn't registered, and another device, such
as twl4030-madc-hwmon, calls twl4030_madc_conversion() a NULL pointer is
dereferenced.
commit 66cc5b8e50af87b0bbd0f179d76d2826f4549c13 upstream.
Worst case this fixes the following error:
[ 72.086212] (NULL device *): conversion timeout!
Best case it prevents a crash
commit e178ccb33569da17dc897a08a3865441b813bdfb upstream.
A mutex is locked on entry into twl4030_madc_conversion().
Immediate return on some error conditions leaves the
mutex locked.
This patch ensures that mutex is always unlocked before
leaving the function.
Signed-off-by: Sanjeev Premi <premi@ti.com>
Cc: Keerthy <j-keerthy@ti.com>
commit 8653be1afd60d6e8c36139b487e375b70357d9ef upstream.
Check inuse variable before trying to access twl_map to prevent
dereferencing of uninitialized variable.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
This reverts commit 11b8fc6ae54bf18a48c94e181c37ca135b858b42, which was commit f09ee0451a44a4e913a7c3cec3805508f7de6c54 upstream.
Koen Kooi <koen@dominion.thruhere.net> reports that this shouldn't have been applied to the 3.0 kernel as it isn't relevant there, only 3.1.
Reported-by: Koen Kooi <koen@dominion.thruhere.net>
Cc: Thomas Weber <weber@corscience.de>
Cc: Peter Ujfalusi <peter.ujfalusi@ti.com>
Cc: Samuel Ortiz <sameo@linux.intel.com>
Cc: Jarkko Nikula <jarkko.nikula@bitmer.com>
The codec for Devkit8000 (TWL4030) was not detected except
when build with CONFIG_SND_SOC_ALL_CODECS.
twl-core.c still uses the CONFIG_TWL4030_CODEC for
twl_has_codec().
In commit 57fe7251f5bfc4332f24479376de48a1e8ca6211
the CONFIG_TWL4030_CODEC was renamed
into CONFIG_MFD_TWL4030_AUDIO, thatswhy the codec
was not detected.
This patch renames the CONFIG_ TWL4030_CODEC into
CONFIG_MFD_TWL4030_AUDIO in twl-core.c.
Signed-off-by: Thomas Weber <weber@corscience.de>
Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
commit e600cffe618ff0da29ae1f8b8d3824ce0e2409fc upstream.
This code section seems to have been accidentally copy pasted.
It causes incorrect bits to be set up in the TLL_CHANNEL_CONF
register and prevents the TLL mode from working correctly.
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
Cc: Keshava Munegowda <keshava_mgowda@ti.com>
Acked-by: Felipe Balbi <balbi@ti.com>
commit fa948761e685fb03823b3029e5b6bdb52229d6ce upstream.
Fix regression introduced by commit
a2974732ca7614aaf0baf9d6dd3ad893d50ce1c5 (TPS65911: Add new irq
definitions) which caused irq_num to be incorrectly set for tps65910.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
Acked-by: Graeme Gregory <gg@slimlogic.co.uk>
This fixes a regression in 3.0 reported by Paul Parsons regarding the
removal of the msleep(1) in the ds1wm_reset() function:
: The linux-3.0-rc4 DS1WM 1-wire driver is logging "bus error, retrying"
: error messages on an HP iPAQ hx4700 PDA (XScale-PXA270):
: <snip>
: Driver for 1-wire Dallas network protocol.
: DS1WM w1 busmaster driver - (c) 2004 Szabolcs Gyurko
: 1-Wire driver for the DS2760 battery monitor chip - (c) 2004-2005, Szabolcs Gyurko
: ds1wm ds1wm: pass: 1 bus error, retrying
: ds1wm ds1wm: pass: 2 bus error, retrying
: ds1wm ds1wm: pass: 3 bus error, retrying
: ds1wm ds1wm: pass: 4 bus error, retrying
: ds1wm ds1wm: pass: 5 bus error, retrying
: The visible result is that the battery charging LED is erratic; sometimes
: it works, mostly it doesn't.
: The linux-2.6.39 DS1WM 1-wire driver worked OK. I haven't tried 3.0-rc1,
: 3.0-rc2, or 3.0-rc3.
This sleep should not be required on normal circuitry provided the
pull-ups on the bus are correctly adapted to the slaves. Unfortunately,
this is not always the case. The sleep is restored but as a parameter to
the probe function in the pdata.
Reported-by: Paul Parsons <lost.distance@yahoo.com>
Tested-by: Paul Parsons <lost.distance@yahoo.com>
Signed-off-by: Jean-François Dagenais <dagenaisj@sonatest.com>
Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru>
Base on Mark's comment [1], I make the Kconfig entry invisible to users.
[1] https://lkml.org/lkml/2011/5/14/136
Fix below build error:
CC drivers/mfd/tps65911-comparator.o
drivers/mfd/tps65911-comparator.c: In function 'tps65911_comparator_probe':
drivers/mfd/tps65911-comparator.c:131: error: 'struct tps65910_platform_data' has no member named 'vmbch_threshold'
drivers/mfd/tps65911-comparator.c:137: error: 'struct tps65910_platform_data' has no member named 'vmbch2_threshold'
make[2]: *** [drivers/mfd/tps65911-comparator.o] Error 1
make[1]: *** [drivers/mfd] Error 2
make: *** [drivers] Error 2
This reverts commit 7e6502d577106fb5b202bbaac64c5f1b065e6daa.
Oops are produced during initialization of ehci and ohci
drivers. This is because the run time pm apis are used by
the driver but the corresponding hwmod structures and
initialization is not merged. hence revering back the
commit id 7e6502d577106fb5b202bbaac64c5f1b065e6daa
Signed-off-by: Keshava Munegowda <keshava_mgowda@ti.com>
Reported-by: Luciano Coelho <coelho@ti.com>
Signed-off-by: Liam Girdwood <lrg@ti.com>
With the addition of a device platform mfd_cell pointer, MFD drivers
can go back to passing platform data back to their sub drivers.
This allows for an mfd_cell->mfd_data removal and thus keep the
sub drivers MFD agnostic. This is mostly needed for non MFD aware
sub drivers.
Signed-off-by: Mattias Wallin <mattias.wallin@stericsson.com>
This driver adds functionality to the tps65911 chip driver.
Two of the comparators are configurable by software and measures
VCCS voltage to detect high or low voltage scenarios.
Signed-off-by: Jorge Eduardo Candelaria <jedu@slimlogic.co.uk>
Acked-by: Samuel Ortiz <sameo@linux.intel.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
The GPIO driver should reside in drivers/gpio/ for better
organization.
TPS65911 adds new interrupt sources, as well as two new registers
to handle them, one for interrupt status and one for interrupt
masking. The added irqs are:
-VMBCH2 - Low and High threshold
-GPIO1-8 - Rising and falling edge detection
-WTCHDG - Watchdog interrupt
-PWRDN - PWRDN reset interrupt
The code should handle these new registers only when the chip
version is TPS65911.
The TPS65911 is the next generation of the TPS65910 family of
PMIC chips. It adds a few features:
- Watchdog Timer
- PWM & LED generators
- Comparators for system control status
It also adds a set of Interrupts and GPIOs, among other things.
The driver exports a function to identify between different
versions of the tps65910 family, allowing other modules to
identify the capabilities of the current chip.
If bytes == (TPS65910_MAX_REGISTER + 1), we have a buffer overflow when
doing memcpy(&msg[1], src, bytes).
On May 10, 2011, at 9:27 PM, Stephen Rothwell wrote:
> Hi Jorge,
> On Tue, 10 May 2011 12:30:36 -0500 Jorge Eduardo Candelaria <jedu@slimlogic.co.uk> wrote:
>> On May 10, 2011, at 3:38 AM, Liam Girdwood wrote:
>>> On Tue, 2011-05-10 at 12:44 +1000, Stephen Rothwell wrote:
>>>> Hi Liam,
>>>> After merging the voltage tree, today's linux-next build (x86_64
>>>> allmodconfig) failed like this:
>>>> ERROR: "tps65910_gpio_init" [drivers/mfd/tps65910.ko] undefined!
>>>> ERROR: "tps65910_irq_init" [drivers/mfd/tps65910.ko] undefined!
>>>> ERROR: "irq_modify_status" [drivers/mfd/tps65910-irq.ko] undefined!
>>>> ERROR: "irq_set_chip_and_handler_name" [drivers/mfd/tps65910-irq.ko] undefined!
>>>> ERROR: "handle_edge_irq" [drivers/mfd/tps65910-irq.ko] undefined!
>>>> I have used the voltage tree from next-20110509 for today.
>>> Jorge, could you send a fix for this today.
>> The following patch should solve this:
>> From: Jorge Eduardo Candelaria <jedu@slimlogic.co.uk>
>> MFD: Fix TPS65910 build
>> Support for tps65910 as a module is not available. The driver can
>> only be compiled as built-in. OTOH, the regulator driver can still
>> be built as module without breaking the compilation.
> Today (even with the above patch included) I got these errors from the
> x86_64 allmodconfig build:
> tps65910.c:(.text+0xf4140): undefined reference to `i2c_master_send'
> drivers/built-in.o: In function `tps65910_i2c_read':
> tps65910.c:(.text+0xf41d2): undefined reference to `i2c_transfer'
> drivers/built-in.o: In function `tps65910_i2c_init':
> tps65910.c:(.init.text+0xcb83): undefined reference to `i2c_register_driver'
> drivers/built-in.o: In function `tps65910_i2c_exit':
> tps65910.c:(.exit.text+0x6e0): undefined reference to `i2c_del_driver'
> I have used the voltage tree from next-20110509 again today.
Following patch should fix the dependency problems. Please review:
[PATCH] MFD: TPS65910: Fix I2C dependency
TPS65910 driver can only be compiled built-in, so the I2C driver
should be as well.
>> Hi Liam,
> Thanks
> Liam
