path: root/drivers/mfd/rts5227.c
2013-09-07Merge tag 'mfd-3.12-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-next Pull MFD (multi-function device) updates from Samuel Ortiz: "For the 3.12 merge window we have one new driver for the DA9063 PMIC from Dialog Semiconductor. Besides that driver we also have: - Device tree support for the s2mps11 driver - More devm_* conversion for the pm8921, max89xx, menelaus, tps65010, wl1273 and pcf50633-adc drivers. - A conversion to threaded IRQ and IRQ domain for the twl6030 driver. - A fairly big update for the rtsx driver: Better power saving support, better vendor settings handling, and a few fixes. - Support for a couple more boards (COMe-bHL6 and COMe-cTH6) for the Kontron driver. - A conversion to the dev_get_platdata() API for all MFD drivers. - A removal of non-DT (legacy) support for the twl6040 driver. - A few fixes and additions (Mic detect level) to the wm5110 register tables. - Regmap support for the davinci_voicecodec driver. - The usual bunch of minor cleanups and janitorial fixes" * tag 'mfd-3.12-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-next: (81 commits) mfd: ucb1x00-core: Rewrite ucb1x00_add_dev() mfd: ab8500-debugfs: Apply a check for -ENOMEM after allocating memory for event name mfd: ab8500-debugfs: Apply a check for -ENOMEM after allocating memory for sysfs mfd: timberdale: Use module_pci_driver mfd: timberdale: Remove redundant break mfd: timberdale: Staticize local variables mfd: ab8500-debugfs: Staticize local variables mfd: db8500-prcmu: Staticize clk_mgt mfd: db8500-prcmu: Use ANSI function declaration mfd: omap-usb-host: Staticize usbhs_driver_name mfd: 88pm805: Fix potential NULL pdata dereference mfd: 88pm800: Fix potential NULL pdata dereference mfd: twl6040: Use regmap for register cache mfd: davinci_voicecodec: Provide a regmap for register I/O mfd: davinci_voicecodec: Remove unused read and write functions mmc: memstick: rtsx: Modify copyright comments mmc: rtsx: Clear SD_CLK toggle enable bit if switching voltage fail mfd: mmc: rtsx: Change default tx phase mfd: pcf50633-adc: Use devm_*() functions mfd: rtsx: Copyright modifications ...
2013-08-30mfd: mmc: rtsx: Change default tx phaseWei WANG
The default phase can meet most cards' requirement, but it is not the optimal one. In some extreme situation, the rx phase point produced by the following tuning process will drift quite a distance. Before tuning UHS card, this patch will set a more proper initial tx phase point, which is calculated from statistic data, and can achieve a much better tx signal quality. Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Acked-by: Lee Jones <lee.jones@linaro.org> Acked-by: Chris Ball <cjb@laptop.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-08-27PCI: Rename PCIe capability definitions to follow conventionBjorn Helgaas
All other PCIe capability register fields include "PCI_EXP" + <reg-name> + <field-name>. This renames PCI_EXP_OBFF_MASK, PCI_EXP_IDO_REQ_EN, PCI_EXP_LTR_EN, and related fields using the same convention. No functional change. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Samuel Ortiz <sameo@linux.intel.com> # for MFD driver
2013-08-20mfd: rtsx: Copyright modificationsWei WANG
Update copyright date, remove author address and add Roger Tseng. Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-08-20mfd: rtsx: Configure to enter a deeper power-saving mode in S3Wei WANG
Set a bit to enable rts5227 and rts5249 to enter a deeper internal power-saving mode in S3, and recover it after resuming. Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-08-20mfd: rtsx: Move some actions from rtsx_pci_init_hw to individual extra_init_hwWei WANG
These actions are individual for each reader model, so should be put in extra_init_hw instead of rtsx_pci_init_hw. Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-08-20mfd: rtsx: Add shutdown callback in rtsx_pci_driverWei WANG
Some actions to clear power state should be handled in .shutdown callback in rtsx_pci_driver. This patch adopts the following measures to catch this goal: 1. Add a function rtsx_pci_power_off to abstract the common ops in .shutdown and .suspend 2. Add pcr->ops->force_power_down to fulfill the individual action for each reader model Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-08-20mfd: rtsx: Read vendor setting from config spaceWei WANG
Normally OEMs will set vendor setting to the config space of Realtek card reader in BIOS stage. This patch reads the setting at the first, and configure the internal registers according to it, to improve card reader's compatibility condition. Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-02-14mfd: rtsx: Support RTS5227Roger Tseng
Support new model RTS5227. Signed-off-by: Roger Tseng <rogerable@realtek.com> Reviewed-by: Wei WANG <wei_wang@realsil.com.cn> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
