CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
Cc: Daniel Walker <dwalker@fifo99.com>
Cc: Bryan Huntsman <bryanh@codeaurora.org>
Acked-by: David Brown <davidb@codeaurora.org>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
Signed-off-by: Kevin Liu <kliu5@marvell.com>
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
I2C drivers can use the clientdata-pointer to point to private data. As I2C
devices are not really unregistered, but merely detached from their driver, it
used to be the drivers obligation to clear this pointer during remove() or a
failed probe(). As a couple of drivers forgot to do this, it was agreed that it
was cleaner if the i2c-core does this clearance when appropriate, as there is
no guarantee for the lifetime of the clientdata-pointer after remove() anyhow.
This feature was added to the core with commit
e4a7b9b04de15f6b63da5ccdd373ffa3057a3681 to fix the faulty drivers.
As there is no need anymore to clear the clientdata-pointer, remove all current
occurrences in the drivers to simplify the code and prevent confusion.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Acked-by: Richard Purdie <rpurdie@linux.intel.com>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
Unlike real i2c-devices which get detached from the driver, dummy-devices
get truly unregistered. So, there has never been a need to clear the
clientdata because the device will go away anyhow. For the occasions fixed
here, clearing clientdata was even dangerous as the structure was freed
already.
Acked-by: Jean Delvare <khali@linux-fr.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Update I2C driver in order to fit all of three I2C components in max8925.
Basic Max8925 support, which is a power management IC from Maxim
Semiconductor.
