path: root/drivers/message/fusion/mptsas.c
2009-09-12[SCSI] mptsas : FW event thread and scsi mid layer deadlock in SYNCHRONIZE ↵Kashyap, Desai
CACHE command Normally In HBA reset path MPT driver will flush existing work in current work queue (mpt/0) . This is just a dummy activity for MPT driver point of view, since HBA reset will turn off Work queue events. It means we will simply returns from work queue without doing anything. But for the case where Work is already done (half the way), we have to have that work to be done. Considering above condition we stuck forever since Deadlock in scsi midlayer and MPT driver. sd_sync_cache() will wait forever since HBA is not in Running state, and it will never come into Running state since sd_sync_cache() is called from HBA reset context. Now new code will not wait for half cooked work to be finished before returning from HBA reset. Once we are out of HBA reset, EH thread will change host state to running from recovery and work waiting for running state of HBA will be finished. New code is turning ON firmware event from another special work called Rescan toplogy. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-09-12[SCSI] mptsas : NULL pointer on big endian systems causing Expander not to ↵Kashyap, Desai
tear off On Big endian system kernel will crash due to address translation is not handle properly. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-09-12[SCSI] mptsas : Sanity check for phyinfo is addedKashyap, Desai
Check for phyinfo->phy before calling sas_port_delete_phy. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-08-22[SCSI] mptsas : set max_id to infinite value.Kashyap, Desai
Do not set max_id value received from FW. Once SAS transport layer is introduced max_id value is missleading to SCSI mid layer. Use max_id to infinite value. logic of can queue of scsi host is changed. Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-08-22[SCSI] mptsas : Change config request timeout value to 30 seconds.Kashyap, Desai
Change config request timeout value to 30 seconds. Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-08-22[SCSI] mptsas : Removed mptscsih_timer_expired.Kashyap, Desai
Removed mptscsih_timer_expired. This timer is no more use. Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-08-22[SCSI] mptsas : Change DEFINED value of can queue for FC and SAS devices.Kashyap, Desai
Change DEFINED value of can queue for FC and SAS devices. Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-06-22fusion: mptsas, fix lock imbalanceJiri Slaby
Fix two typos in mptsas_not_responding_devices. It was mutex_lock instead of unlock. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Acked-by: "Desai, Kashyap" <Kashyap.Desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-12[SCSI] Merge branch 'linus'James Bottomley
Conflicts: drivers/message/fusion/mptsas.c fixed up conflict between req->data_len accessors and mptsas driver updates. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-09[SCSI] mpt fusion: fix up doc book commentsJames Bottomley
Several of the doc book in the previous patches had incorrect multi-line short function descriptors. Fixed it all to be the correct single line descriptor. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-09[SCSI] mpt fusion: Added support for Broadcast primitives Event handlingKashyap, Desai
Firmware is able to handle Broadcast primitives, but upstream driver does not have support for broadcast primitive handling. Now this patch is mainly to support broadcast primitives. Signed-off-by: Kashyap Desai <kadesai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-09[SCSI] mpt fusion: Queue full event handlingKashyap, Desai
FW will report Queue full event to Driver and driver will handle this queue full event to SCSI Mid layer. Signed-off-by: Kashyap Desai <kadesai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-09[SCSI] mpt fusion: RAID device handling and Dual port Raid support is addedKashyap, Desai
1. Handle integrated Raid device(Add/Delete) and error condition and check related to Raid device. is_logical_volume will represent logical volume device. 2. Raid device dual port support is added. Main functions to support this feature are mpt_raid_phys_disk_get_num_paths and mpt_raid_phys_disk_pg1. Signed-off-by: Kashyap Desai <kadesai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-09[SCSI] mpt fusion: Code Cleanup patchKashyap, Desai
Resending patch considering Grants G's code review. Main goal to submit this patch is code cleaup. 1. Better driver debug prints and code indentation. 2. fault_reset_work_lock is not used anywhere. driver is using taskmgmt_lock instead of fault_reset_work_lock. 3. setting pci_set_drvdata properly. 4. Ingore config request when IOC is in reset state.( ioc_reset_in_progress is set). 5. Init/clear managment frame proprely.(INITIALIZE_MGMT_STATUS and CLEAR_MGMT_STATUS) Signed-off-by: Kashyap Desai <kadesai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-09[SCSI] mpt fusion: Rescan SAS topology addedKashyap, Desai
1.) SAS topology Rescan is added. If Firmware is doing Reset and we get Device add interrupt from Firmware, we will not receive it as part of Reset is going ON. After Reset we will do special Rescan of SAS topology. 2.) Driver version changed from 3.04.08 to 3.04.09. Added proper lock/unlock in mptsas_not_responding_devices() as per James' comment. Signed-off-by: Kashyap Desai <kadesai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-09[SCSI] mpt fusion: SAS topology scan changes, expander eventsKashyap, Desai
SAS topology scan is restructured. HBA firmware is generating more events. Expander Events are added, Link status events are also added with respect to SAS topology scan optimization. Signed-off-by: Kashyap Desai <kadesai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-09[SCSI] mpt fusion: Firmware event implementation using seperate WorkQueueKashyap, Desai
Now Firmware events are handled by firmware event queue. Previously it was handled in interrupt context/WorkQueue of Linux. Firmware Event handling is restructured and optimized. Signed-off-by: Kashyap Desai <kadesai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-09[SCSI] mpt fusion: rewrite of ioctl_cmds internal generated functionKashyap, Desai
1) rewrite of ioctl_cmds internal generated function that issue commands to firmware, porting them to be single threaded using the generic MPT_MGMT struct. All wait Queues are replace by completion Queue. 2) added seperate callback handler for ioctl task managment (mptctl_taskmgmt_reply), to handle command that timeout 3) rewrite mptctl_bus_reset Signed-off-by: Kashyap Desai <kadesai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-09[SCSI] mpt fusion: Adding DeviceResetCtx for internal Device reset frameKashyap, Desai
1.) Added taskmgmt_quiesce_io flag in IOC and removed resetPending from _MPT_SCSI_HOST struct. 2.) Reset from Scsi mid layer and internal Reset are seperate context. Adding DeviceResetCtx for internal Device reset frame. mptsas_taskmgmt_complete is optimized as part of implementation. Signed-off-by: Kashyap Desai <kadesai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-09[SCSI] mpt fusion: rewrite of all internal generated functionsKashyap, Desai
Rewrite of all internal generated functions that issue commands to firmware, porting them to be single threaded using the generic MPT_MGMT struct. Implemented using completion Queue. Signed-off-by: Kashyap Desai <kadesai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-09[SCSI] mpt fusion: config path optimized, completion queue is usedKashyap, Desai
1) Previously we had mutliple #defines to use same values. Now those #defines are optimized. MPT_IOCTL_STATUS_* is removed and MPT_MGMT_STATUS_* are new #defines. 2.) config path is optimized. Instead of wait Queue and timer, using completion Q. 3.) mpt_timer_expired is not used. [jejb: elide patch to eliminate mpt_timer_expired] Signed-off-by: Kashyap Desai <kadesai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-09[SCSI] mpt fusion: Added support for MPT discovery completion checkKashyap, Desai
sas_discovery_quiesce_io flag is used to control IO start/resume functionality. IO will be stoped while doing discovery of topology. Once discovery is completed It will resume IO. Resending patch including James review. Signed-off-by: Kashyap Desai <kadesai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-09[SCSI] mpt fusion: Fixing 1078 data corruption issue for 36GB memory regionKashyap, Desai
The reason for this change is there is a data corruption when four different physical memory regions in the 36GB to 37GB region are accessed. This is only affecting 1078. The solution is we need to use different addressing when filling in the scatter gather table for the effected memory regions. So instead of snooping on all four different memory holes, we treat any physical addresses in the 36GB address with the same algorithm. The fix is explained below 1) Ensure that the message frames are NOT located in the trouble region. There is no remapping available for message frames, they must be allocated outside the problem region. 2) Ensure that Sense buffers are NOT in the trouble region. There is no remapping available. 3) Walk through the SGE entries and if any are inside the trouble region then they need to be remapped as discussed below. 1) Set the Local Address bit in the SGE Flags field. MPI_SGE_FLAGS_LOCAL_ADDRESS 2) Ensure we are using 64-bit SGEs 3) Set MSb (Bit 63) of the 64-bit address, this will indicate buffer location is Host Memory. Signed-off-by: Kashyap Desai <kadesai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-05-19block: set rq->resid_len to blk_rq_bytes() on issueTejun Heo
In commit c3a4d78c580de4edc9ef0f7c59812fb02ceb037f, while introducing rq->resid_len, the default value of residue count was changed from full count to zero. The conversion was done under the assumption that when a request fails residue count wasn't defined. However, Boaz and James pointed out that this wasn't true and the residue count should be preserved for failed requests too. This patchset restores the original behavior by setting rq->resid_len to blk_rq_bytes(rq) on request start and restoring explicit clearing in affected drivers. While at it, take advantage of the fact that rq->resid_len is set to full count where applicable. * ide-cd: rq->resid_len cleared on pc success * mptsas: req->resid_len cleared on success * sas_expander: rsp/req->resid_len cleared on success * mpt2sas_transport: req->resid_len cleared on success * ide-cd, ide-tape, mptsas, sas_host_smp, mpt2sas_transport, ub: take advantage of initial full count to simplify code Boaz Harrosh spotted bug in resid_len initialization. Fixed as suggested. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Borislav Petkov <petkovbb@googlemail.com> Cc: Boaz Harrosh <bharrosh@panasas.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: cleanup rq->data_len usagesTejun Heo
With recent unification of fields, it's now guaranteed that rq->data_len always equals blk_rq_bytes(). Convert all non-IDE direct users to accessors. IDE will be converted in a separate patch. Boaz: spotted incorrect data_len/resid_len conversion in osd. [ Impact: convert direct rq->data_len usages to blk_rq_bytes() ] Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: Darrick J. Wong <djwong@us.ibm.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: Boaz Harrosh <bharrosh@panasas.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: add rq->resid_lenTejun Heo
rq->data_len served two purposes - the length of data buffer on issue and the residual count on completion. This duality creates some headaches. First of all, block layer and low level drivers can't really determine what rq->data_len contains while a request is executing. It could be the total request length or it coulde be anything else one of the lower layers is using to keep track of residual count. This complicates things because blk_rq_bytes() and thus [__]blk_end_request_all() relies on rq->data_len for PC commands. Drivers which want to report residual count should first cache the total request length, update rq->data_len and then complete the request with the cached data length. Secondly, it makes requests default to reporting full residual count, ie. reporting that no data transfer occurred. The residual count is an exception not the norm; however, the driver should clear rq->data_len to zero to signify the normal cases while leaving it alone means no data transfer occurred at all. This reverse default behavior complicates code unnecessarily and renders block PC on some drivers (ide-tape/floppy) unuseable. This patch adds rq->resid_len which is used only for residual count. While at it, remove now unnecessasry blk_rq_bytes() caching in ide_pc_intr() as rq->data_len is not changed anymore. Boaz : spotted missing conversion in osd Sergei : spotted too early conversion to blk_rq_bytes() in ide-tape [ Impact: cleanup residual count handling, report 0 resid by default ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Mike Miller <mike.miller@hp.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Doug Gilbert <dgilbert@interlog.com> Cc: Mike Miller <mike.miller@hp.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: Darrick J. Wong <djwong@us.ibm.com> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-03[SCSI] mptsas: remove unneeded checkAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Cc: Eric Moore <eric.moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-27[SCSI] replace __FUNCTION__ with __func__Harvey Harrison
[jejb: fixed up a ton of missed conversions. All of you are on notice this has happened, driver trees will now need to be rebased] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: SCSI List <linux-scsi@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-06-05[SCSI] mpt fusion : Updated copyright statment with 2008 includedPrakash, Sathya
Updating copyright statement to include the year 2008 Signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-27[SCSI] fusion mpt: fix target missing after resetting external raidMichael Reed
Following a hard reset of a SAS raid, one of the raid targets is occasionally missing. I tracked this down to a pretty obscure little bug. The LSI fusion drivers for SAS and Fibre Channel both use their respective transport layers. Those transport layers increment the target number assigned to new targets. The routine __scsi_scan_target uses the "this_id" element of the Scsi_Host structure to avoid scanning the scsi host adapter. Both fusion drivers set "this_id" from a value returned in a firmware PortFacts response. For my particular test case (SAS) the firmware id assigned to the initiator was 173. After enough raid resets to cause the raid targets to go and come a sufficient number of times, the id assigned by the transport to a raid target would match the id assigned by the host adapter to the "this_id" field, resulting in that target not being scanned. Fix by not assigning this_id and not checking it in slave_configure. Signed-off-by: Michael Reed <mdr@sgi.com> Acked-by: "Moore, Eric" <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] mptsas: do not use ioc->handle to locate hba portinfo structureMichael Reed
While performing hardware raid reset testing via the raid's client, I noticed that sometimes, following the reset, that there would be more raid targets in the lsscsi output than there actually were raid targets. I tracked this down to the following issue. Fusion cannot always find the mptsas_portinfo structure for the hba because it uses the handle stored in ioc->handle to locate it. The problem is that the firmware can change the handle associated with the hba when h/w raid is reset (via the raid client). When this happens, the driver will allocate another mptsas_portinfo structure and link it into the chain of said structures. This ultimately causes confusion within the driver resulting in targets not being removed when they should be. Eric Moore pointed out that the hba's portinfo structure is always the first structure on the sas_topology list. This patch modifies mptsas.c to access the hba's portinfo structure by taking the first structure on said list. Signed-off-by: Michael Reed <mdr@sgi.com> Acked-by: "Moore, Eric" <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-03-05[SCSI] mpt fusion: don't oops if NumPhys==0Krzysztof Oledzki
Don't oops if NumPhys==0, instead return -ENODEV. This patch fixes http://bugzilla.kernel.org/show_bug.cgi?id=9909 Signed-off-by: Krzysztof Piotr Oledzki <ole@ans.pl> Acked-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] mpt fusion: make mptsas_smp_handler update residFUJITA Tomonori
This patch fixes mptsas_smp_handler to update both din_resid or dout_resid on success. bsg can report back the residual. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-12[SCSI] mpt fusion: fix up fusion prints using the sdev_printk, dev_printk, ↵Eric Moore
and shost_printk API Cleaning up prints that use the xxx_printk API, in that the fusion preamble "mptbase: iocX" follows the info provided by the print API. The way its currently coded, the [H:C:T] print in sdev_printk will be inbetween "mptbase" and "iocX", instead of before. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: lock down ScsiLookupEric Moore
ScsiLookup is an array of pending scmd pointers that the scsi lld maintains. This array is touched from queuecommand, eh threads, and interrupt context. This array should put under locks, hence this patch to synchronize its access. I've added some nice little function wrappers for this, and moved the ScsiLookup array over to MPT_ADAPTER struct. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: Fix sparse warningsEric Moore
List below is output from C=2 sparse compilation, which are fixed with this patch. 1) mptspi: pg0 is defined in x86 version of include/asm/pgtable.h 2) mptsas: context imbalance in 'mptsas_probe' different lock contexts for basic block 3) mptbase: from mpt_attach - cast adds address space to expression 4) mptbase: from mpt_do_upload - request[] is bad constant expression Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: add use of shost_priv and remove all the typecastingEric Moore
The driver is currently typecasting to obtain the shost hostdata. The driver is updated to use the shost_priv macro. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: removing Dell copyrightEric Moore
Some other vender has concerns over this copyright, and Dell has approved removing it. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: removing references to hd->iocEric Moore
Cleaning up code by accesing the ioc pointer directly instead of via hd->ioc. In the future, most data members of struct MPT_SCSI_HOST will be either deleted or moved to struct MPT_ADAPTER. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: rename vdev to vdeviceEric Moore
common naming of vdevice through out driver Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: standardize printks and debug infoEric Moore
Standardize all prints using common MYIOC_s_XXX_FMT macro defined in mptbase.h. Currently the driver uses several different methods to display info, where in some cases the "controller name" generating the printk is not provided. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: Change company name from LSI Logic to LSIPrakash, Sathya
Recently LSI Logic Corp was renamed as LSI Corp, so whereever there is a reference of LSI Logic, it is changed to LSI in mpt fusion driver code. signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Acked-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: Creation of mptsas.h header filePrakash, Sathya
The data structure definitions from mptsas.c are moved to a new header file mptsas.h signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Acked-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: Change call back indices to u8 from intPrakash, Sathya
The call back index requires only u8 but in lot of places it is referred as int, now everywhere the call back index variables are declared as u8 with uniform name cb_idx signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Acked-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: Usage of high priority request FIFO to send task ↵Prakash, Sathya
management commands Added support for sending the task management requests through High priority request FIFO instead of Doorbell writes when firmware support High priority FIFO. signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Acked-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-31[SCSI] mptsas: add SMP passthrough support via bsgFUJITA Tomonori
This patch adds support for SAS Management Protocol (SMP) passthrough support via bsg. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Eric Moore <eric.moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-28[SCSI] mpt fusion: Changes in mptfc.c mptlan.c mptsas.c and mptspi.c for ↵Prakash, Sathya
logging support This patch contains changes in mptfc.c, mptlan.c, mptsas.c and mptspi.c to support logging in MPT fusion drivers. The changes are majorly in debug printks, the existing debugprintk are modified accroding to new debug macros defined in the file mptbdebug.h signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-18[SCSI] mpt fusion: deregister from transport layer if PCI registration failedPrakash, Sathya
The mptspi and mptsas drivers are modified to deregister from transport layer if registration with PCI driver failed Signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-18[SCSI] mpt fusion: add sysfs attributes to display IOC parametersPrakash, Sathya
New sysfs scsi_host attributes are added to provide information about Firmware version, BIOS version, MPI version and other product related information signed-off-by: Sathya Praksh <sathya.prakash@lsi.com> Acked-by: "Moore, Eric" <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-17[SCSI] mpt fusion: update MAINTAINERS (fusion part)Eric Moore
Update assocated fusion sources with new support email address. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
