path: root/drivers/message/fusion/mptctl.c
2010-07-28[SCSI] mptfusion: Extra debug prints added relavent to Device missing delay ↵Kashyap, Desai
error handling Adding function name in original debug prints and few more debug prints are added. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-27[SCSI] mptfusion: print Doorbell register in a case of hard reset and timeoutKei Tokunaga
Printing Doorbell register in a case of hard reset and timeout should be useful for figuring out the state of the system. Signed-off-by: Kei Tokunaga <tokunaga.keiich@jp.fujitsu.com> Acked-by: "Desai, Kashyap" <Kashyap.Desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-27[SCSI] mptfusion: schedule_target_reset from all Reset contextKashyap, Desai
Issue: target reset will be queued to driver's internal queue to get schedule later. When driver add target into internal target_reset queue we will block IOs on those target using scsi midlayer API. Now due to some cause driver is not executing those target_reset list and it is always in block state. Changes: now we are clearing target_reset queue from all other Callback context instead of only DeviceReset context.Now wherever driver is clearing taskmgmt_in_progress flag it is considering target_reset queue cleanup also. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-04-11[SCSI] mptfusion: sanity check for vdevice pointer is addedKashyap, Desai
Added sanity checks before accessing vdevice and added vdevice->deleted setting for mptfc. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-04-11[SCSI] mptfusion: Updated SCSI IO IOCTL error handling.Kashyap, Desai
Behavior changes only for IOCTLs that time out. Current behavior of Bus Reset remains the same for RAID Passthru Timeouts Current behavior of Diagnostic reset for any other type of IOCTL remains the same CHANGE: For IOCTL SCSI IOs that timeout, a Target Reset TM is sent, instead of Bus Reset. All error handing from that point is the same as what the driver currently does, which is to say that if the Device Reset TM fails it escalates do diagnostic reset. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-04-11[SCSI] mptfusion: Added new less expensive RESET (Message Unit Reset)Kashyap, Desai
Message Unit Reset - instructs the IOC to reset the Reply Post and Free FIFO's. All the Message Frames on Reply Free FIFO are discarded. All posted buffers are freed, and event notification is turned off. IOC doesnt reply to any outstanding request. This will transfer IOC to READY state. Message unit ready is less expensive operations than Hard Reset. soft reset will not force Firmware to reload again, it only do clean up of Message units. mpt_Soft_Hard_ResetHandler will first try for Soft Reset,if it fails then go for big hammer reset which is Hard Reset. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-04-11[SCSI] mpt: modify mptctl_exit() to call proper deregister functionsKei Tokunaga
This patch fixes some issues of mptctl_exit(). 1) It doesn't call mpt_deregister() for mptctl_taskmgmt_id => Insmoding/rmmoding mptctl.ko repeadtedly (up to MPT_MAX_PROTOCOL_DRIVERS-1 at most) can eat up all cb_idx, and that would cause a lack of MptCallbacks[], MptDriverClass[], and MptEvHandlers[]. 2) It doesn't call mpt_event_deregister() for mptctl_id => Need to call it. 3) It calls mpt_reset_deregister() for mptctl_taskmgmt_id => This could accidentally deregister an innocent reset handler that you don't want to. This patch also adds a check for mptctl_taskmgmt_id. Signed-off-by: Kei Tokunaga <tokunaga.keiich@jp.fujitsu.com> Acked-by: "Desai, Kashyap" <Kashyap.Desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-01-18[SCSI] mptfusion: corrected if condition check for SCSIIO and PASSTHROUGH ↵Kashyap, Desai
commands Modified the function type check to verify it is not MPI_FUNCTION_RAID_SCSI_IO_PASSTHROUGH or MPI_FUNCTION_SCSI_IO_REQUEST. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-29[SCSI] mptctl : Remove printk which floods unnecessary messages to ↵Kashyap, Desai
var/log/message Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-06-09[SCSI] mpt fusion: Code Cleanup patchKashyap, Desai
Resending patch considering Grants G's code review. Main goal to submit this patch is code cleaup. 1. Better driver debug prints and code indentation. 2. fault_reset_work_lock is not used anywhere. driver is using taskmgmt_lock instead of fault_reset_work_lock. 3. setting pci_set_drvdata properly. 4. Ingore config request when IOC is in reset state.( ioc_reset_in_progress is set). 5. Init/clear managment frame proprely.(INITIALIZE_MGMT_STATUS and CLEAR_MGMT_STATUS) Signed-off-by: Kashyap Desai <kadesai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-09[SCSI] mpt fusion: rewrite of ioctl_cmds internal generated functionKashyap, Desai
1) rewrite of ioctl_cmds internal generated function that issue commands to firmware, porting them to be single threaded using the generic MPT_MGMT struct. All wait Queues are replace by completion Queue. 2) added seperate callback handler for ioctl task managment (mptctl_taskmgmt_reply), to handle command that timeout 3) rewrite mptctl_bus_reset Signed-off-by: Kashyap Desai <kadesai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-09[SCSI] mpt fusion: config path optimized, completion queue is usedKashyap, Desai
1) Previously we had mutliple #defines to use same values. Now those #defines are optimized. MPT_IOCTL_STATUS_* is removed and MPT_MGMT_STATUS_* are new #defines. 2.) config path is optimized. Instead of wait Queue and timer, using completion Q. 3.) mpt_timer_expired is not used. [jejb: elide patch to eliminate mpt_timer_expired] Signed-off-by: Kashyap Desai <kadesai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-09[SCSI] mpt fusion: Fixing 1078 data corruption issue for 36GB memory regionKashyap, Desai
The reason for this change is there is a data corruption when four different physical memory regions in the 36GB to 37GB region are accessed. This is only affecting 1078. The solution is we need to use different addressing when filling in the scatter gather table for the effected memory regions. So instead of snooping on all four different memory holes, we treat any physical addresses in the 36GB address with the same algorithm. The fix is explained below 1) Ensure that the message frames are NOT located in the trouble region. There is no remapping available for message frames, they must be allocated outside the problem region. 2) Ensure that Sense buffers are NOT in the trouble region. There is no remapping available. 3) Walk through the SGE entries and if any are inside the trouble region then they need to be remapped as discussed below. 1) Set the Local Address bit in the SGE Flags field. MPI_SGE_FLAGS_LOCAL_ADDRESS 2) Ensure we are using 64-bit SGEs 3) Set MSb (Bit 63) of the 64-bit address, this will indicate buffer location is Host Memory. Signed-off-by: Kashyap Desai <kadesai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-02[SCSI] fusion: Move a dereference below a NULL testJulia Lawall
If the NULL test is necessary, then the dereference should be moved below the NULL test. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/). // <smpl> @disable is_null@ identifier f; expression E; identifier fld; statement S; @@ + if (E == NULL) S f(...,E->fld,...); - if (E == NULL) S @@ identifier f; expression E; identifier fld; statement S; @@ + if (!E) S f(...,E->fld,...); - if (!E) S // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: "Prakash, Sathya" <Sathya.Prakash@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-11-01saner FASYNC handling on file closeAl Viro
As it is, all instances of ->release() for files that have ->fasync() need to remember to evict file from fasync lists; forgetting that creates a hole and we actually have a bunch that *does* forget. So let's keep our lives simple - let __fput() check FASYNC in file->f_flags and call ->fasync() there if it's been set. And lose that crap in ->release() instances - leaving it there is still valid, but we don't have to bother anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-27[SCSI] replace __FUNCTION__ with __func__Harvey Harrison
[jejb: fixed up a ton of missed conversions. All of you are on notice this has happened, driver trees will now need to be rebased] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: SCSI List <linux-scsi@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (102 commits) [SCSI] scsi_dh: fix kconfig related build errors [SCSI] sym53c8xx: Fix bogus sym_que_entry re-implementation of container_of [SCSI] scsi_cmnd.h: remove double inclusion of linux/blkdev.h [SCSI] make struct scsi_{host,target}_type static [SCSI] fix locking in host use of blk_plug_device() [SCSI] zfcp: Cleanup external header file [SCSI] zfcp: Cleanup code in zfcp_erp.c [SCSI] zfcp: zfcp_fsf cleanup. [SCSI] zfcp: consolidate sysfs things into one file. [SCSI] zfcp: Cleanup of code in zfcp_aux.c [SCSI] zfcp: Cleanup of code in zfcp_scsi.c [SCSI] zfcp: Move status accessors from zfcp to SCSI include file. [SCSI] zfcp: Small QDIO cleanups [SCSI] zfcp: Adapter reopen for large number of unsolicited status [SCSI] zfcp: Fix error checking for ELS ADISC requests [SCSI] zfcp: wait until adapter is finished with ERP during auto-port [SCSI] ibmvfc: IBM Power Virtual Fibre Channel Adapter Client Driver [SCSI] sg: Add target reset support [SCSI] lib: Add support for the T10 (SCSI) Data Integrity Field CRC [SCSI] sd: Move scsi_disk() accessor function to sd.h ...
2008-07-02mpt: fasync BKL pushdownJonathan Corbet
It looks like this driver really needs the BKL here. Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-06-05[SCSI] mpt fusion : Updated copyright statment with 2008 includedPrakash, Sathya
Updating copyright statement to include the year 2008 Signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-03drivers/message/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-12[SCSI] mptctl : shutup uninitialized variable warningsEric Moore
drivers/message/fusion/mptctl.c: In function ‘mptctl_mpt_command’: drivers/message/fusion/mptctl.c:1764: warning: ‘bufIn.len’ may be used uninitialized in this function drivers/message/fusion/mptctl.c:1765: warning: ‘bufOut.len’ may be used uninitialized in this function come because gcc gets confused by some "goto" statements in above function. The warnings have been verified to be bogus, however, the function does initialize these later (after the offending goto's) in the function anyway. So let's move those initializations to top of function, thereby also shutting up these warnings. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: Satyam Sharma <satyam@infradead.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: add use of shost_priv and remove all the typecastingEric Moore
The driver is currently typecasting to obtain the shost hostdata. The driver is updated to use the shost_priv macro. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: rename vdev to vdeviceEric Moore
common naming of vdevice through out driver Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: standardize printks and debug infoEric Moore
Standardize all prints using common MYIOC_s_XXX_FMT macro defined in mptbase.h. Currently the driver uses several different methods to display info, where in some cases the "controller name" generating the printk is not provided. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: mostly kmalloc + memset conversion to kzallocMariusz Kozlowski
This patch does kmalloc + memset conversion to kzalloc anSigned-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> d simplifies mptctl_probe(). drivers/message/fusion/mptctl.c | 82092 -> 81884 (-208 bytes) drivers/message/fusion/mptctl.o | 201784 -> 200648 (-1136 bytes) Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Acked-by: "Moore, Eric Dean" <Eric.Moore@lsil.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: Change company name from LSI Logic to LSIPrakash, Sathya
Recently LSI Logic Corp was renamed as LSI Corp, so whereever there is a reference of LSI Logic, it is changed to LSI in mpt fusion driver code. signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Acked-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: Change call back indices to u8 from intPrakash, Sathya
The call back index requires only u8 but in lot of places it is referred as int, now everywhere the call back index variables are declared as u8 with uniform name cb_idx signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Acked-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: Usage of high priority request FIFO to send task ↵Prakash, Sathya
management commands Added support for sending the task management requests through High priority request FIFO instead of Doorbell writes when firmware support High priority FIFO. signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Acked-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-28[SCSI] mpt fusion: Changes in mptctl.c for logging supportPrakash, Sathya
This patch contains changes in mptctl.c to support logging in MPT fusion drivers The changes are majorly in debug printks, the existing debugprintk are modified accroding to new debug macros defined in the file mptbdebug.h signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-17[SCSI] mpt fusion: update MAINTAINERS (fusion part)Eric Moore
Update assocated fusion sources with new support email address. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-02-12[PATCH] mark struct file_operations const 4Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. [akpm@sdl.org: dvb fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-02[SCSI] fusion - bump version - 3.04.04Eric Moore
bump version, and fix email addr for lsi support Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-02-02[SCSI] fusion - error handling bug fix'sEric Moore
misc error handling bug fix's - properly interpret iocstatus returned after task management request - clear tmState after a failed doorbell - cleanup mptscsih_taskmgmt_complete Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-02-02[SCSI] fusion - Greater than 255 target and lun supportEric Moore
Add support for greater than 255 target and luns. Kill the hd->Target[] field, and change all references of bus_id/target_id, to channel/id. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-01-06[SCSI] fusion: MODULE_VERSION supportEric Moore
* Add modinfo driver version support. * Change copyright year to 2007. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-13[SCSI] mptfusion: misc fix'sEric Moore
* removing obsolete 1066, 1066E from Kconfig * initializing aen_event_read_flag after host reset * remove oem references * remove obsolete mpt_pq_filter command line option Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-14[SCSI] fusion - static fix'sMoore, Eric
Patch previously provided from Adrian Bunk <bunk@stusta.de>, moving some functions to static. This is already in the -mm tree. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-14[SCSI] fusion - move some debug firmware event debug msgs to verbose levelMoore, Eric
Created a debug level MPT_DEBUG_VERBOSE_EVENTS. Moving some of the more vebose debug messages for firwmare events into new debug level. Also added some more firmware events descriptions. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-04[SCSI] fusion - mptctl -adding asyn event notification supportMoore, Eric
Adding aen support. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-04[SCSI] fusion - mptctl -firmware download fixMoore, Eric
Fix's firmware download ioctl to work with SAS. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-04[SCSI] fusion - mptctl - backplane istwi fixMoore, Eric
Moving the toolbox call from mptbase.c, over to mptctl.c, and using the mptctl infastructure to issue the call. The existing code is hanging on certain HP platforms when this ioctl is issued, and this patch fix's that. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-04[SCSI] fusion - mptctl -sense width fixMoore, Eric
Bug fix for correctly setting sense width for the MPTCOMMAND ioctl. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-04[SCSI] fusion - mptctl - Event Log FixMoore, Eric
Use the hard coded value MPTCTL_EVENT_LOG_SIZE to fix bug where in certain cases, the ioc->eventLogSize was initialized. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-04[SCSI] fusion - mtctl - change to wait_event_timeoutMoore, Eric
Change from using wait_event_interruptible_timeout to wait_event_timeout. Also delete white space and duplicate line of code. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-04[SCSI] fusion - mptctl - adding support for bus_type=SASMoore, Eric
Add bus_type recognization in ioctl path for SAS. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-04[SCSI] fusion - mptctl - MPTCOMMAND - adding function types.Moore, Eric
This adds support for new function types in the existing MPTCOMMAND ioctl. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[SCSI] fusion: convert semaphores to mutexesChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-10[PATCH] don't include ioctl32.h in driversChristoph Hellwig
These days ioctl32.h is only used for communication of fs/compat.c and fs/compat_ioctl.c and doesn't contain anything of interest to drivers. Remove inclusion in various drivers. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-13[SCSI] mptfusion - mapping fixs required support for transport layers.Moore, Eric Dean
This utilizes the hostdata area that is hung off of scsi_target and scsi_device for saving unique firmware mapping. This will be required for supporting new Fibre and SPI transport support. This also fixs problems in error handling error code for SAS controllers, in which the incorrect mapping was passed to the firmware. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
