The pwc driver used to:
1. kmalloc a buffer
2. memcpy data to send over usb there
3. do the usb_control_msg call (which does not work with data on the stack)
4. free the buffer
For every usb command send. This patch changes the code to instead malloc
a buffer for this purpose once and use it everywhere.
[mchehab@redhat.com: Fix a compilation breakage with allyesconfig:
drivers/media/video/pwc/pwc-ctrl.c: In function ‘pwc_get_cmos_sensor’:
drivers/media/video/pwc/pwc-ctrl.c:546:3: warning: passing argument 4 of ‘recv_control_msg’ makes integer from pointer without a cast [en$
drivers/media/video/pwc/pwc-ctrl.c:107:12: note: expected ‘int’ but argument is of type ‘unsigned char *’
drivers/media/video/pwc/pwc-ctrl.c:546:3: error: too many arguments to function ‘recv_control_msg’
drivers/media/video/pwc/pwc-ctrl.c:107:12: note: declared here]
Since we always do a set_video_mode on stream start, there is no need
to actually send the mode info to the device on a s_fmt / s_parm ioctl.
Not doing this saves us doing (slow) usb io.
Before this patch various code in the mode setting patch checked
pdev->pixfmt, but that was not set until the mode setting succeeded, so
it was looking at the old pixfmt! This patch fixes this by making the
pixfmt a parameter to set_video_mode, and setting it from set_video_mode
on success.
Instead of making this a module parameter, automatically fallback to
higher compression settings if there is not enough bandwidth.
The pwc driver claims to support any resolution between 160x120
and 640x480, but emulates this by simply drawing a black border
around the image. Userspace can draw its own black border if it
really wants one.
This stems from the v4l1 era, with v4l2 everything can be done with
standardized v4l2 API calls.
The in kernel version of the pwc driver has never supported snapshot
mode, and now that we no longer support the pixfmt.priv abuse there also
no longer is a way for userspace to request it, rendering all the code in
question dead (never called), so remove it.
While testing gtk-v4l's new ctrl event code, I hit the following deadlock
in the pwc driver:
Thread 1:
-Does a VIDIOC_G_CTRL
-video2_ioctl takes the modlock
-video2_ioctl calls v4l2_g_ctrl
-v4l2_g_ctrl takes the ctrl_handler lock
-v4l2_g_ctrl calls pwc_g_volatile_ctrl
-pwc_g_volatile_ctrl releases the modlock as the usb transfer can take a
significant amount of time and we don't want to block DQBUF / QBUF too long
Thread 2:
-Does a VIDIOC_FOO_CTRL
-video2_ioctl calls v4l2_foo_ctrl
-v4l2_foo_ctrl blocks while trying to take the ctrl_handler lock
Thread 1:
-Blocks while trying to re-take the modlock, as its caller will eventually
unlock that
Now we have thread 1 waiting for the modlock while holding the ctrl_handler
lock and thread 2 waiting for the ctrl_handler lock while holding the
modlock -> deadlock.
Conclusion:
1) We cannot unlock modlock from pwc_s_ctrl / pwc_g_volatile_ctrl,
but this can cause QBUF / DQBUF to block for up to a full second
2) After evaluating various option I came to the conclusion that pwc should
stop using the v4l2 core locking, and instead do its own locking
Thus this patch stops pwc using the v4l2 core locking, and replaces that with
it doing its own locking where necessary.
Currently auto white balance speed and delay are only available through custom
ioctls, which are deprecated and will be going away in 3.3 .
The semantic patch that makes this change is available
in scripts/coccinelle/api/memdup.cocci.
Signed-off-by: Thomas Meyer <thomas@m3y3r.de>
Remove unused pwc-ioctl.h (the copy in include/media is used everywhere)
Remove almost empty pwc-uncompress.h, move single define to pwc.h
This makes the API for this:
1) v4l2 spec compliant
2) match that of the UVC Logitech QuickCam Sphere models
For now this operates in parellel to the sysfs interface for this, but the
intend is to deprecate the sysfs interface and remove it.
Also remove all the converting from native range to 0-65535 and back
that was going on. This is no longer needed now that we no longer support
v4l1.
Doing a bunch of initialization every time /dev/video is opened, and thus
for example when the udev rules probe for capabilities makes no sense,
do it at driver load, resp. stream start instead.
This is a preparation patch for allowing multiple opens of the /dev/video
node.
as vcinterface must be set before calling pwc_camera_power()
Looking at the pwc buffer management code has made it clear to me it needed
some serious fixing. Not only was there a ton of code duplication even
internally to pwc (read and mmap wait for frame code was duplicated), the
code also was outright buggy. With the worst offender being dqbuf, which
just round robin returned all the mmap buffers, without paying any attention
to them being queued by the app with qbuf or not. And qbuf itself was a noop.
So I set out to fix this and already had some cleanups in place when
I read Jonathan Corbet's lwn article on videobuf2, this inspired me to just
rip out the buffer management code and replace it with videobuf2, greatly
reducing the amount of code, and fixing all bugs in one go:
Many thanks to Jonathan for the timely article on this !
Unplugging a pwc cam while an app has the /dev/video# node open leads
to an oops in pwc_video_close when the app closes the node, because
the disconnect handler has free-ed the pdev struct pwc_video_close
tries to use. Instead of adding some sort of bandaid for this.
fix it properly using the v4l2 core's new(ish) behavior of keeping the
v4l2_dev structure around until both unregister has been called, and
all file handles referring to it have been closed:
Embed the v4l2_dev structure in the pdev structure and define a v4l2 dev
release callback releasing the pdev structure (and thus also the embedded
v4l2 dev structure.
Cc: stable@kernel.org
pwc was starting streaming on /dev/video# open rather then on STREAM_ON. Now
that the v4l1 compat code is removed from the pwc driver there is no reason
left to do this. So this patch changes the pwc driver to delay starting
the isoc stream (and thus using valuable usb bandwidth) until the application
does a STREAM_ON
Remove the V4L1 API from this driver, making it fully V4L2.
Also fix a bug where the /dev/videoX device was created too early, which led
to initialization problems of the camera, making it unable to capture video.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
constant => sizeof conversion.
Regression was caused by my commit 6b35ca0d3d586b8ecb8396821af21186e20afaf0
which determined message size using sizeof rather than hardcoded constants.
Unfortunately pwc_set_shutter_speed reuses a 2 byte buffer for a one byte
message too so the sizeof was bogus in this case.
All other uses of sizeof checked and are ok.
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Martin Fuzzey <mfuzzey@gmail.com>
This is causes problems on platforms that have alignment requirements
for DMA transfers.
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Since internal to v4l2 the ioctl prototype is the same regardless of it
being called through .ioctl or .unlocked_ioctl, we need to convert it all
to the long return type of unlocked_ioctl.
Thanks to Jean-Francois Moine for posting an initial patch for this and
thus bringing it to our attention.
Cc: Jean-Francois Moine <moinejf@free.fr>
The file(s) below do not use LINUX_VERSION_CODE nor KERNEL_VERSION.
This patch removes the said #include <version.h>.
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
Fixed a lot of sparse warnings: mostly warnings about shadowed variables
and signed/unsigned mismatches.
Also remove some blank lines that were used to split compat code at -devel
tree.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
There were many instances of 7-space indents spread throughout
the v4l-dvb tree.
This patch replaces the 7-space indents with tabs. The whitespace cleaner
script doesn't catch these, because it assumes that all indents are 8-space.
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
This patch add support for the VIDIOC_ENUM_FRAMESIZES and
VIDIOC_ENUM_FRAMEINTERVALS ioctl.
* check if the maximum native framesize for raw mode is correct
* raw mode framerates for all three chipset types
Signed-off-by: Gregor Jasny <gjasny@web.de>
Signed-off-by: Luc Saillard <luc@saillard.org>
This patch makes the following needlessly global code static:
- pwc-ctrl.c: pwc_get_leds()
- pwc_preferred_compression
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
Add v4l2 compatibility
Include the decompressor (legal problem has been resolv by Alan Cox)
Faster decoder and easier to maintain, optimize, ...
Can export to userland compressed stream
Support more cameras, lot of bugs are fixed.
Because of historic reasons, there are two separate directories with
V4L stuff. Most drivers are located at driver/media/video. However, some
code for USB Webcams were inserted under drivers/usb/media.
This makes difficult for module authors to know were things should be.
Also, makes Kconfig menu confusing for normal users.
This patch moves all V4L content under drivers/usb/media to
drivers/media/video, and fixes Kconfig/Makefile entries.
